Home » Eclipse Projects » Eclipse Platform » ANT setting properties programmatically
ANT setting properties programmatically [message #50231] Tue, 27 May 2003 13:53
I have some code that generates a build.xml file in the workspace.This
generated file requires some properties to be set before running, however I
cannot set those values into my script.
So I'd like to know if the code that generates the script could somehow set
the values for some properties as if they were set by the user in the ant
launcher.
Thank you
PaScaL
Previous Topic:How to make a plugin upgrade without confirming with the user?
Next Topic:How to detect if view is closed
Current Time: Sat Jul 26 04:25:08 EDT 2025
Powered by FUDForum. Page generated in 0.04890 seconds
