Home » Modeling » TMF (Xtext) » Crosslinks to rule that further crossreferences to an external metamodel class
Crosslinks to rule that further crossreferences to an external metamodel class [message #50172] |
Thu, 11 June 2009 09:00  |
Hello Everyone
I'm trying to implement a grammar that should allow to create concrete
models of a graph structure rather than a tree structure.
My requirement is -
For Ex:
(1)
Pr_dtype id:"pr1"{
doc:"safwaef";
type:0 ;
MessageType id:"mssg_01"{
doc:"sadfasf";
parameters:Parameter type: "pr_dtype_a" ;
which is backed by a grammar of the following pattern:
import "http://q-impress.eu/samm/core" as refn_core
import "http://q-impress.eu/samm/datatype" as refn_datatypes
import "http://q-impress.eu/samm/staticstructure" as refn_staticstructure
import "http://q-impress.eu/identifier" as ident
MessageType returns refn_staticstructure::MessageType:
'MessageType' 'id:' id=STRING '{'
//parent attrib(s)
'name:' name=STRING';'
'doc:' documentation=STRING';'
//class specific attributes
'parameters:' (parameters+=Parameter)+ ';'
Parameter returns refn_staticstructure::Parameter:
'Parameter' 'type:' type=[refn_datatypes::Type] ';'
Type returns refn_datatypes::Type:
CollectionDataType | ComplexDataType | PrimitiveDataType
PrimitiveDataType returns refn_datatypes::PrimitiveDataType:
'Pr_dtype' 'id:' id=STRING '{'
'name:' name=STRING ';'
'doc:' documentation=STRING ';'
'type:'type=XSDPrimitiveDatatypes ';'
enum XSDPrimitiveDatatypes returns refn_datatypes::XSDPrimitiveDataTypes:
string='0' | int='1' | float='2' | date='3' | time='4' | boolean='5'
So, the problem that I'm facing is that in using the above grammar, the
editor shows the error that:
< mismatched input 'MessageType' expecting EOF > for the model declaration
(1).
and if I alter the sequence of declaration as follows:
(2)
doc:"sadfasf";
Pr_dtype id:"pr1"{
doc:"safwaef";
type:0 ;
errors are :
< Multiple markers at this line
- The feature 'type' of
'eu.qimpress.samm.staticstructure.impl.ParameterImpl@15ee9d9{platform:/resource/Test/test.edifice#//@parameters.0}'
contains an unresolved proxy
' eu.qimpress.samm.datatypes.impl.CollectionDataTypeImpl@1a102 ef{platform:/resource/Test/test.edifice#xtextLink_:://@param eters.0::http://q-impress.eu/samm/staticstructure#//Paramete r/type::/4}'
- Couldn't resolve reference to Type >
< mismatched input 'Pr_dtype' expecting EOF >
And yes I'm using TMF XText
Eclipse SDK
Version: 3.5.0
Build id: I20090522-1710
cud anyone suggest a solution.
Durga
Re: Crosslinks to rule that further crossreferences to an external metamodel class [message #50376 is a reply to message #50234] |
Thu, 11 June 2009 11:39   |
Sebastian Zarnekow wrote:
> Hi Durga,
> how did you install Xtext? Did you get any warnings when generating your
> language?
> Sebastian
> Am 11.06.2009 15:00 Uhr, schrieb Durga Prasana Sahoo:
>> Hello Everyone
>> My requirement is -
>> For Ex:
>> (1)
>> Pr_dtype id:"pr1"{
>> doc:"safwaef";
>> type:0 ;
>> doc:"sadfasf";
>> //parent attrib(s)
>> declaration (1).
>> (2)
>> doc:"sadfasf";
>> Pr_dtype id:"pr1"{
>> doc:"safwaef";
>> type:0 ;
>> errors are :
>> Eclipse SDK
>> Version: 3.5.0
>> Durga
Hello Sebastian
I just extracted the entire folder of TMF
XText[eclipse-SDK-3.5RC2-xtext-0.7RC2-win32] using winrar. And run the
eclipse.exe.
That's it.
Did I go wrong?
Didn't get any error messages.Ya..but I just set the parent folder name as
TMF_XText while extracting rather than the default
[eclipse-SDK-3.5RC2-xtext-0.7RC2-win32] before extracting.
Ya..2 warnings while running workflow:
error(10): internal error:
org.antlr.tool.Grammar.getCharValueFromGrammarCharLiteral(Gr ammar.java:1514):
invalid char literal: ''
Following is my console message:
659 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.datatypes.DatatypesPackage'
664 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated
EPackage 'eu.qimpress.samm.annotation.AnnotationPackage'
EPackage 'eu.qimpress.samm.usagemodel.UsagemodelPackage'
2981 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory '../org.xtext.samm_dsl.Edifice/src-gen'
2981 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
C:\Users\Durga\workspace_TMF\org.xtext.samm_dsl.Edifice\..\o rg.xtext.samm_dsl.Edifice\src-gen
2991 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory '../org.xtext.samm_dsl.Edifice.ui/src-gen'
2992 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
C:\Users\Durga\workspace_TMF\org.xtext.samm_dsl.Edifice\..\o rg.xtext.samm_dsl.Edifice.ui\src-gen
2995 [main] INFO e.core.container.CompositeComponent - Generator
3062 [main] INFO ipse.xtext.generator.LanguageConfig - generating
infrastructure for org.xtext.samm_dsl.Edifice with fragments :
ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment,
EcoreGeneratorFragment, ParseTreeConstructorFragment,
ResourceFactoryFragment, DelegatingGeneratorFragment,
JavaValidatorFragment, JavaScopingFragment, FormatterFragment,
LabelProviderFragment, TransformerFragment, JavaBasedContentAssistFragment
16124 [main] INFO or.validation.JavaValidatorFragment - executing
generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
16335 [main] DEBUG enerator.CompositeGeneratorFragment - replacing
binding :
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.ITok enColorer ->
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.ITok enColorer.NullTokenColorer
(contributed by org.eclipse.xtext.ui.generator.ImplicitUiFragment)
16336 [main] DEBUG enerator.CompositeGeneratorFragment - with new
binding :
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.Comm onAntlrTokenColorer
(contributed by de.itemis.xtext.antlr.XtextAntlrGeneratorFragment)
16336 [main] DEBUG enerator.CompositeGeneratorFragment - replacing
binding : org.eclipse.jface.text.rules.ITokenScanner ->
org.eclipse.xtext.ui.common.editor.syntaxcoloring.DefaultTok enScanner
org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.Antl rTokenScanner
binding : org.eclipse.xtext.ui.core.editor.IDamagerRepairer ->
org.eclipse.xtext.ui.core.editor.FastLineBasedDamagerRepaire r (contributed
16337 [main] DEBUG enerator.CompositeGeneratorFragment - with new
org.eclipse.xtext.ui.core.editor.XtextDamagerRepairer (contributed by
16337 [main] DEBUG enerator.CompositeGeneratorFragment - replacing
binding : org.eclipse.jface.viewers.ILabelProvider ->
org.eclipse.xtext.ui.core.DefaultLabelProvider (contributed by
org.xtext.samm_dsl.labeling.EdificeLabelProvider (contributed by
org.eclipse.xtext.ui.generator.labeling.LabelProviderFragmen t)
16338 [main] DEBUG enerator.CompositeGeneratorFragment - replacing
binding :
org.eclipse.xtext.ui.common.editor.outline.ISemanticModelTra nsformer ->
org.eclipse.xtext.ui.common.editor.outline.impl.DefaultSeman ticModelTransformer
16338 [main] DEBUG enerator.CompositeGeneratorFragment - with new
binding :
org.xtext.samm_dsl.outline.EdificeTransformer (contributed by
org.eclipse.xtext.ui.generator.outline.TransformerFragment)
binding :
org.eclipse.xtext.ui.core.editor.contentassist.IContentPropo salProvider ->
org.eclipse.xtext.common.contentassist.TerminalsProposalProv ider
binding :
org.xtext.samm_dsl.contentassist.EdificeProposalProvider (contributed by
org.eclipse.xtext.ui.generator.contentAssist.JavaBasedConten tAssistFragment)
16459 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - workflow
completed in 13479ms!
Thanks.
Durga
Re: Crosslinks to rule that further crossreferences to an external metamodel class [message #50404 is a reply to message #50234] |
Thu, 11 June 2009 11:43   |
Hello Sebastian
eclipse.exe.
That's it.
Did I go wrong?
Ya..but I just set the parent folder name as TMF_XText while extracting
rather than the default [eclipse-SDK-3.5RC2-xtext-0.7RC2-win32] before
extracting.
--> Ya..2 warnings while running workflow:
binding :
binding :
binding :
binding :
binding :
binding :
Thanks.
Durga
> Hi Durga,
> language?
> Sebastian
>> Hello Everyone
>> My requirement is -
>> For Ex:
>> (1)
>> Pr_dtype id:"pr1"{
>> doc:"safwaef";
>> type:0 ;
>> doc:"sadfasf";
>> //parent attrib(s)
>> declaration (1).
>> (2)
>> doc:"sadfasf";
>> Pr_dtype id:"pr1"{
>> doc:"safwaef";
>> type:0 ;
>> errors are :
>> Eclipse SDK
>> Version: 3.5.0
>> Durga
Re: Crosslinks to rule that further crossreferences to an external metamodel class [message #50432 is a reply to message #50404] |
Thu, 11 June 2009 11:53   |
Hi Durga,
actually this is not a warning but an error. I guess, the Antlr Parser
has not been generated successfully.
The message indicates some wrong character literal in a terminal rule.
Did you define an empty character somewhere ('') or used two single
quotes inside a character literal?
If you don't mind, please send me your grammar and I'll have a look at it.
Sebastian
Am 11.06.2009 17:43 Uhr, schrieb Durga Prasana Sahoo:
> Hello Sebastian
> eclipse.exe.
> That's it.
> Did I go wrong?
> extracting.
> binding :
> binding :
> org.eclipse.xtext.ui.common.editor.syntaxcoloring.antlr.Antl rTokenScanner (contributed
> binding :
> binding :
> binding :
> -> org.eclipse.xtext.common.contentassist.TerminalsProposalProv ider
> binding :
> -> org.xtext.samm_dsl.contentassist.EdificeProposalProvider (contributed
> by
> Thanks.
> Durga
>> Hi Durga,
>> your language?
>> Regards,
>> Sebastian
>>> Hello Everyone
>>> My requirement is -
>>> For Ex:
>>> (1)
>>> Pr_dtype id:"pr1"{
>>> doc:"safwaef";
>>> type:0 ;
>>> doc:"sadfasf";
>>> //parent attrib(s)
>>> declaration (1).
>>> (2)
>>> doc:"sadfasf";
>>> Pr_dtype id:"pr1"{
>>> doc:"safwaef";
>>> type:0 ;
>>> errors are :
>>> Eclipse SDK
>>> Version: 3.5.0
>>> Durga
Re: Crosslinks to rule that further crossreferences to an external metamodel class [message #50655 is a reply to message #50432] |
Fri, 12 June 2009 09:16  |
Hello Sebastian
You were perfectly correct. Indeed I had left out just '' in one place to
define
an abstract rule with no child inheritances or no assignments.
However, I removed the error.
Infact, I shall send you my grammar along with the intended purpose that I
wish to get out of TMF XText. But Since I have to elaborate what I exactly
need of the grammar, So I'm hoping to send you a detailed mail including
the grammar and the ecore metamodel it has to import as dependency.
I shall try sending it within a day or two.
Thanks a lot.
Durga
Current Time: Wed Jul 30 10:14:29 EDT 2025
Powered by FUDForum. Page generated in 0.05901 seconds
