Home » Eclipse Projects » Subversive » How to relocate the location of my projects
How to relocate the location of my projects [message #50164] Fri, 24 July 2009 06:12 Go to next message
Originally posted by: formatzeh.gmx.de
On my svn server the structure of the projects has changed (they all
were moved into one parent folder). Now how can I relocate the
locations of my local copies? I really don't want to checkout all by new
because there are a lot of projects.
regards
Gilbert
Re: How to relocate the location of my projects [message #50193 is a reply to message #50164] Fri, 24 July 2009 06:20 Go to previous messageGo to next message
Gilbert Mirenque napsal(a):
> regards
> Gilbert
Hi Gil,
this wrote Igor above in newsgroup:
Hello Jeff,
1. You can relocate the project in the following way: in SVN Repositories
view find the project location which corresponds to the project and change
its url to needed one. I just tried it and found several problems (and a
workaround) related to relocation, for more details, please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259626
Re: How to relocate the location of my projects [message #50223 is a reply to message #50193] Fri, 24 July 2009 06:22 Go to previous messageGo to next message
sNop napsal(a):
>> regards
>> Gilbert
> Hi Gil,
> Hello Jeff,
sry, this isn't workaround
Hi Igor,
Important problem, support Subversive Relocate at this time ?
To Gil:
if not, then you can use TortoiseSvn, it support relocate feature
Re: How to relocate the location of my projects [message #50252 is a reply to message #50223] Fri, 24 July 2009 07:04 Go to previous messageGo to next message
The switch-operation did it.
Re: How to relocate the location of my projects [message #480995 is a reply to message #50252] Wed, 19 August 2009 06:10 Go to previous message
If you changed project location inside repository, you can use Switch
action, as you did it.
Previous Topic:Using subversive with an existing eclipse project
Next Topic:Native JavaHL: Can't find dependent libraries
Current Time: Mon Jul 14 21:26:58 EDT 2025
Powered by FUDForum. Page generated in 0.04667 seconds
