Home » Language IDEs » C / C++ IDE (CDT) » Eclipse crashing trying to open large files.
Eclipse crashing trying to open large files. [message #50160] Thu, 14 November 2002 09:00 Go to next message
Originally posted by: ihutchinson.providencesoftware.com
When I try to open a large c++ source file, 565 lines, eclipse crashes.
Is this a known bug? Do I need to give the jvm more memory? It
currently has a maximum of 384M being allocated to it thru -vmargs
-Xmx384M. The source file is from the mozilla project, so it is large.
Re: Eclipse crashing trying to open large files. [message #50534 is a reply to message #50160] Mon, 18 November 2002 15:49 Go to previous messageGo to next message
"Iran Q. Hutchinson" <ihutchinson@providencesoftware.com> wrote in message
news:ar089b$qvp$1@rogue.oti.com...
There are known "issues" with the C-Tags parser, which we use to populate
the indexer.
Turn off automatic compile on resource change, from the Eclipse properties
page.
You are using good vmargs ... so
Try compiling only on demand and let me know if you still have the same
problem.
-Judy
Re: Eclipse crashing trying to open large files. [message #50840 is a reply to message #50534] Wed, 20 November 2002 01:58 Go to previous message
sorry I did not reply sooner, in the middle of a project :). I still
have the same problem and I generally have automatic compile turned off.
I have be getting around the problem by opening up the larger files with
the text editor. But of course that takes away a lot of features.
I have have tried all the eclipse and cdt releases for linux, motif and
gtk. I see the same problem running Mandrake 9.0 or Gentoo 1.4rc1.
I also tried changing JDK versions, no luck; 1.4.x from Sun and the IBM
1.3.1 SDK. Let me know if you need anymore info or what I can do to help.
Iran.
> the indexer.
> page.
> problem.
> -Judy
Previous Topic:Creating a project via plugin
Next Topic:Auto-Complete: #include parsing not implemented?
Current Time: Mon Sep 01 01:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.03345 seconds
