Home » Modeling » TMF (Xtext) » xtext generator fails when calling from maven
xtext generator fails when calling from maven [message #50085] Thu, 11 June 2009 08:44 Go to next message
I’m trying to mavenize my xtext project with the fornax plugin. I run in
difficulties with a hierarchical module and directory layout. I have a
parent module and in the parent module are submodules which represent the
xtext and the xtext.ui project. When I build only the xtext project
everything works fine. But when starting from the parent project it fails
when reading the grammar files. But the grammar file is correctly
generated!?!
2219 [main] INFO ipse.xtext.generator.LanguageConfig – generating
infrastructure for com.XXX.XXX.metamodel.type.Type with fragments :
ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment,
EcoreGeneratorFragment, ParseTreeConstructorFragment,
ResourceFactoryFragment, DelegatingGeneratorFragment,
JavaValidatorFragment, JavaScopingFragment, FormatterFragment,
LabelProviderFragment, TransformerFragment,
OutlineNodeAdapterFactoryFragment, JavaBasedContentAssistFragment,
error(7): cannot find or open file:
../metamodel.type/src-gen/com/XXX/XXX/metamodel/type/parser/ antlr/internal/InternalType.g
I have no clue what the exact meaning of the "pathRtProject" parameter is.
Is this a relative path? How to put an absolute path there? At which point
of the code is the path to the grammar file specified? Any ideas how to
solve this?
Christoph
Re: xtext generator fails when calling from maven [message #511877 is a reply to message #50085] Wed, 03 February 2010 05:23 Go to previous message
Hi Christoph,
we run into the same issue using XText 0.7.2 as commented on Karsten's blog article. Have you found a solution yet?
Michel
Previous Topic:Eclipse Community Awards - Vote for Xtext
Next Topic:Content Assist with Xtext
Current Time: Sat Jul 26 05:50:14 EDT 2025
Powered by FUDForum. Page generated in 0.05973 seconds
