Re: Troubleshoot pdf export [message #493654 is a reply to message #493630] |
Tue, 27 October 2009 13:19 |
Peter,
Can you post how the report is being executed? Can you post the code?
Jason
peter_bauer_71@hotmail.com wrote:
> Hello
> I'm using Tivoli Common Reporting with the BIRT engine 2.2.1.
> Now I have the following problem. I run a script which produces a few
> reports in pdf format. The greater part works fine, but some of them
> have only header, a grid with the selected report parameters and a
> footer. The chart is missing. I have verified the command which the
> script execute and this is working. Now I will go into depper and would
> like to trace the birt engine pdf creation process. Do you know which,
> from the following components are useful to trace ?
> org.eclipse.birt.chart...
> org.eclipse.birt.core...
> org.eclipse.birt.data... org.eclipse.birt.report...
> Thanks Peter
Re: Troubleshoot pdf export [message #493683 is a reply to message #493654] |
Tue, 27 October 2009 14:45 |
No real name Messages: 3 Registered: October 2009 |
Junior Member |
It's a perl script, where I read a file with a few machines and there osnames. $execute is the command string which I call with the system command.
If I run only linux machines, it works
If I run linux and Unix machine, some of the unix machines fail.
If I run only unix machine, it works
Strange or not !?
$execute = '/TCR/products/tcr/bin/trcmd.sh -distribute -report /ITM621_V1.2/ITM-621/ITM_Resource_Utilization_Details -PDF -location /tmp/tmp/' . $directory . '/' . $servername . '_overview.pdf -notifyFile /tmp/tmp/' . $servername . '_notify.txt -parameters OSType=' . $p_ostype . ' "Server Name=' . $p_servername . '" ShowTable=no -user tipadmin -password xxx';
or do you mean the xml code of the reportdesign file ?
[Updated on: Tue, 27 October 2009 14:57] Report message to a moderator
Re: Troubleshoot pdf export [message #493712 is a reply to message #493683] |
Tue, 27 October 2009 16:22 |
Check permissions on the birt runtime install location. You may also
need to look at font location and permissions.
> command.
> Strange or not !?
> -password xxx';
FUDForum. Page generated in 0.03263 seconds
