JSpinner [message #50038] |
Wed, 14 July 2004 03:41  |
I propose to include the JSpinner control in the "Swing components"
palette.
I think it is a component generic and useful enough to deserve inclusion.
Re: JSpinner [message #50268 is a reply to message #50152] |
Wed, 14 July 2004 10:02   |
Hola David,
Yes I'm from Barcelona! (froses@menta.net)
Yes, 1.4 is very used nowdays... Have the VE team plans
to include 1.4?
Francesc
David Pérez wrote:
> Francesc,
> Maybe you are also from Barcelona!!
> I also use this trick for the same reason, and can add a JSpinner in this
> way, without problems.
> But JDK 1.4 is very used nowadays.
> Francesc Rosés wrote:
> > Hola David,
> > It seems VE is based in JDK 1.3, so the JSpinner (nor
> > JFormattedTextField) is
> > not in the pallete. I don't know if the VE team have plans to switch to
> > JDK 1.4 (on even JDK 5.0...), but I think may be suitable.
> > I don't use the palette except to include a "JTable on JScrollPane"
> > because
> > I must assign a bean name after the drop (even with the new feature
> > "fieldName") and is slow. So I use the "Choose bean button".
> > Saludos,
> > Francesc
> > > palette.
Re: JSpinner [message #595173 is a reply to message #50038] |
Wed, 14 July 2004 04:43  |
Hola David,
because
Saludos,
Francesc
> palette.
Re: JSpinner [message #595193 is a reply to message #50097] |
Wed, 14 July 2004 07:14  |
Francesc,
> Hola David,
> because
> Saludos,
> Francesc
> > palette.
Re: JSpinner [message #595238 is a reply to message #50152] |
Hola David,
to include 1.4?
Francesc
David Pérez wrote:
> Francesc,
> > Hola David,
> > because
> > Saludos,
> > Francesc
> > > palette.
FUDForum. Page generated in 0.12268 seconds
