Home » Archived » XML Schema Definition (XSD) » How to create schema with any number of elements(0-n) and in any order?
How to create schema with any number of elements(0-n) and in any order? [message #50025] Wed, 11 August 2004 13:12 Go to next message
Originally posted by: susil.bravobrava.com
Hello All,
I am working in an existing xml that has the following syntax:
1. element "actions" can have following elements more than once or not
at all:
: Sub elements "record", "say", "listen", "play","explain" as in xml
sample below
2. These sub elements could be in any order
Initially I thought of using all but it does not allow more than one
itration.
What could be the xml schema definition for these?
Any help will be highly appreciated.
Su
--------- Sample XML ------------------------------
Sample Xml:
<?xml version="1.0" encoding="utf-8"?>
<historySubmit sessionId="17A5C33539093BEB3B74E0FEEE476240" Version="1.0">
<sessions storyId="B5BB0DCB31F10C31E4DCC88ECF30F4EB" version="1.0">
<session start="2004-08-09 16:22:01" duration="00:03:21.122">
<properties>
<type>PRACTICE</type>
<software>SpeaK!</software>
</properties>
<actions>
<record start="00:00:10.083" wordId="0"
filename="20040809_162211.spx">
<w id="0" start="0" duration="540" result="MEDIUM" />
<w id="1" start="540" duration="440" result="FORCED" />
</record>
<record start="00:00:12.281" wordId="2"
filename="20040809_162213.spx" auto="True">
<w id="2" start="0" duration="580" result="BAD" />
<w id="3" start="580" duration="480" result="BAD" />
<w id="4" start="1230" duration="910" result="MEDIUM" />
<w id="5" start="2470" duration="210" result="FORCED" />
<w id="6" start="2680" duration="500" result="MEDIUM" />
<w id="7" start="3850" duration="370" result="MEDIUM" />
<w id="8" start="4340" duration="520" result="GOOD" />
<w id="9" start="4890" duration="370" result="BAD" />
<w id="10" start="5260" duration="210" result="FORCED" />
<w id="11" start="5470" duration="260" result="MEDIUM" />
<w id="11" start="5980" duration="330" result="MEDIUM" />
<w id="12" start="7340" duration="600" result="BAD" />
<w id="13" start="8530" duration="450" result="FORCED" />
</record>
<record start="00:00:22.130" wordId="14"
filename="20040809_162223.spx" auto="True">
<w id="14" start="0" duration="500" result="FORCED" />
</record>
<record start="00:00:24.141" wordId="15"
filename="20040809_162225.spx" auto="True">
<w id="15" start="0" duration="1020" result="MEDIUM" />
<w id="16" start="1020" duration="610" result="MEDIUM" />
<w id="17" start="1670" duration="450" result="MEDIUM" />
<w id="18" start="2480" duration="360" result="MEDIUM" />
<w id="19" start="2840" duration="410" result="MEDIUM" />
<w id="20" start="3250" duration="160" result="GOOD" />
<w id="21" start="3510" duration="190" result="FORCED" />
<w id="22" start="3700" duration="280" result="GOOD" />
<w id="23" start="4010" duration="480" result="MEDIUM" />
</record>
<play start="00:00:31.154" startId="24" stopId="26" />
<say start="00:00:33.601" wordId="36" />
<say start="00:00:34.629" wordId="37" />
<explain start="00:00:35.596" wordId="37" />
<play start="00:00:36.671" startId="37" stopId="40" />
<record start="00:00:40.069" wordId="40"
filename="20040809_162241.spx">
<w id="40" start="0" duration="970" result="MEDIUM" />
</record>
</actions>
</session>
<session start="2004-08-09 16:31:12" duration="00:00:19.872">
<properties>
</properties>
</session>
<session start="2004-08-09 16:41:52" duration="00:00:27.915">
<properties>
</properties>
<actions>
<record start="00:00:23.364" wordId="37"
filename="20040809_164216.spx" />
<say start="00:00:25.702" wordId="37" />
</actions>
</session>
</sessions>
</historySubmit>
Re: How to create schema with any number of elements(0-n) and in any order? [message #50087 is a reply to message #50025] Wed, 11 August 2004 13:36 Go to previous message
Su,
A <choice> with minOccurs="0" and maxOccurs="unbounded" of the
subelements will validate any combination of zero or more subelements.
exquisitus wrote:
> Hello All,
> at all:
> sample below
> itration.
> Thanks
> Su
> Sample Xml:
> Version="1.0">
> <properties>
> </properties>
> <actions>
> </record>
> </record>
> </record>
> </record>
> </record>
> </actions>
> </session>
> <properties>
> </properties>
> </session>
> <properties>
> </properties>
> <actions>
> </actions>
> </session>
> </sessions>
> </historySubmit>
Re: How to create schema with any number of elements(0-n) and in any order? [message #590102 is a reply to message #50025] Wed, 11 August 2004 13:36 Go to previous message
Su,
exquisitus wrote:
> Hello All,
> at all:
> sample below
> itration.
> Thanks
> Su
> Sample Xml:
> Version="1.0">
> <properties>
> </properties>
> <actions>
> </record>
> </record>
> </record>
> </record>
> </record>
> </actions>
> </session>
> <properties>
> </properties>
> </session>
> <properties>
> </properties>
> <actions>
> </actions>
> </session>
> </sessions>
> </historySubmit>
Previous Topic:How to Create xml schema with any number of subelement(0-n) and in any order
Next Topic:Correct insertion point for child elements according to schema
Current Time: Wed Jul 16 21:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.07574 seconds
