Home » General (non-technical) » Eclipse Foundation » Eclipse 3.3 - How to configure multiple filters in the problem pane?
Eclipse 3.3 - How to configure multiple filters in the problem pane? [message #50018] Fri, 26 October 2007 04:31 Go to next message
Originally posted by: adam.lipscombe.qucs.co.uk
Folks
I have lots of compile warnings, many of them about two unused static variables that are present in
all my classes.
They are:
private static final String MODULE_ID = "$Header: $";
private static final String COPYRIGHT = "Copyright blah blah";
I want to filter out any warnings to do with both of these. I can easily setup a filter to remove
messages to do with one, but when I add another filter and tick it, I see error messages for both.
I want to filter out warnings about MODULE_ID and COPYRIGHT
Is this possible? If so how?
Thanks - Adam
Re: Eclipse 3.3 - How to configure multiple filters in the problem pane? [message #50049 is a reply to message #50018] Fri, 26 October 2007 08:11 Go to previous message
Adam,
This newsgroup isn't for technical questions. Please use either
news://news.eclipse.org/eclipse.platform or
news://news.eclipse.org/eclipse.newcomer for questions like this.
You could change
"Window->Preference->Java->Compiler->Errors/Warrnings->Unecessary
code->Unused local or private member" to ignore all such problems, or if
you are using Java 5.0 or greater, you could add
@SuppressWarnings("unused") the declaration.
Adam Lispcombe wrote:
> Folks
> variables that are present in all my classes.
> They are:
> easily setup a filter to remove messages to do with one, but when I
> Thanks - Adam
Previous Topic:TPTP Webinar
Next Topic:Eclipse Group Started on LinkedIn....
Current Time: Fri Jul 18 04:11:49 EDT 2025
Powered by FUDForum. Page generated in 0.07389 seconds
