Home » Eclipse Projects » Eclipse Platform » How to make a plugin upgrade without confirming with the user?
How to make a plugin upgrade without confirming with the user? [message #49993] Tue, 27 May 2003 11:50
Originally posted by: heather.hotmail.com
If a plugin is provided as a feature to Eclipse with a version number
which changes from build to build, every time when an old build of
Eclipse(customized) with the plugin is uninstalled and a new build is
installed, when the application is launched for the first time, there will
be a pop-up dialog titled \"Configuration Changes\". The message reads
\"Pending Configuration Changes Check the changes you wish to process
now. Remove changes that should never be processed\". The detected changes
will be reported (by default all changes are selected with check marks)
which include the plugin with the new version number. Clicking \"Finish\"
on the dialog will load the plugin and clicking \"Cancel\" will NOT load
the plugin.
Is there a way to prevent this dialog from appearing and the new version
plugin gets loaded automatically? Since clicking \"Cancel\" is never a
desired option and if it\'s already done by mistake only a tricky
workaround can make the plugin available again to the platform, which is
not nice.
Anyone has an idea?
Thanks very much!
Heather
Previous Topic:ECLIPSE_HOME programmatically...
Next Topic:ANT setting properties programmatically
Current Time: Tue Jul 22 12:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.03315 seconds
