Home » Eclipse Projects » Subversive » How to reconnect working copy
How to reconnect working copy [message #49985] Thu, 23 July 2009 13:34 Go to next message
Hi all,
I have disconnected my project and I want to know, what is the best way to reconnect the
project to the same repo
In team menu is only Share project and I don't test it beacause of lose or destroy my
project's svn data
Thank you for any advices and suggestions
Re: How to reconnect working copy [message #50105 is a reply to message #49985] Fri, 24 July 2009 03:50 Go to previous messageGo to next message
Hello sNop,
If you didn't delete svn metadata when you disconnected the project, then
the best way to reconnect is to use Team/Share Project menu, then on
'Connect to SVN using project settings' page select 'Use project settings'
option and that's it.
> Hi all,
> reconnect the
> destroy my
> project's svn data
Re: How to reconnect working copy [message #50135 is a reply to message #50105] Fri, 24 July 2009 04:20 Go to previous message
Igor Burilo napsal(a):
> Hello sNop,
Hi Igor,
thank you. It was fast and simple ;)
I didn't want to risk anything.
Previous Topic:Share Project Wizard - Simple vrs. Advanced Mode
Next Topic:Error installing Connectors (2.0.4)
Current Time: Mon Jul 21 21:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.06817 seconds
