Home » Language IDEs » ServerTools (WTP) » InvocationTargetException when creating a new Dyanmic Web Project
InvocationTargetException when creating a new Dyanmic Web Project [message #49982] Wed, 20 October 2004 13:47
Originally posted by: john.zene-NOSPAM-sis.com
I've installed the IBM kit exactly as in the IBM Getting Started (including
exact version numbers of the dependencies and Eclipse), and in the final
part of creating a Dynamic Web Project I get a dialog box saying "An error
has occurred when New Dynamic Web Project finished" and with the following
stack trace in the details:
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:315)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 756)
at com.ibm.wtp.common.ui.wizard.WTPWizard.performFinish(WTPWiza rd.java:55)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:606)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:319)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:413)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:769)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2578)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2256)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:670 )
at org.eclipse.jface.window.Window.open(Window.java:650)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:163)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:550)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:502)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:435)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1562)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1536)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:257)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Caused by: java.lang.NoSuchMethodError:
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.se tURIResourceMap(Ljava/util/Map;)V
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.<init >(ProjectResourceSetImpl.java:28)
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.<init >(ProjectResourceSetImpl.java:31)
com.ibm.wtp.emf.workbench.edit.ProjectResourceSetEditImpl.<init >(ProjectResourceSetEditImpl.java:29)
com.ibm.wtp.emf.workbench.EMFWorkbenchContext.createResource Set(EMFWorkbenchContext.java:306)
com.ibm.wtp.emf.workbench.EMFWorkbenchContextBase.getResourc eSet(EMFWorkbenchContextBase.java:48)
com.ibm.etools.j2ee.j2eeproject.J2EENature.primaryContribute ToContext(J2EENature.java:161)
com.ibm.itp.wt.nature.J2EEWebNatureRuntime.primaryContribute ToContext(J2EEWebNatureRuntime.java:699)
com.ibm.wtp.internal.emf.workbench.EMFWorkbenchContextFactor y.createEMFContext(EMFWorkbenchContextFactory.java:104)
com.ibm.wtp.emf.workbench.WorkbenchResourceHelperBase.create EMFContext(WorkbenchResourceHelperBase.java:174)
com.ibm.wtp.emf.workbench.nature.EMFNature.createEmfContext( EMFNature.java:66)
com.ibm.wtp.emf.workbench.nature.EMFNature.getEmfContextBase (EMFNature.java:151)
com.ibm.wtp.emf.workbench.nature.EMFNature.getResourceSet(EM FNature.java:124)
com.ibm.iwt.webproject.operations.WebProjectCreationOperatio n.createProject(WebProjectCreationOperation.java:41)
com.ibm.etools.application.operations.J2EEModuleCreationOper ation.execute(J2EEModuleCreationOperation.java:46)
com.ibm.iwt.webproject.operations.WebProjectCreationOperatio n.execute(WebProjectCreationOperation.java:71)
at com.ibm.wtp.common.operation.WTPOperation.doRun(WTPOperation .java:212)
at com.ibm.wtp.common.operation.WTPOperation$1.run(WTPOperation .java:157)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1559)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1578)
at com.ibm.wtp.common.operation.WTPOperation.run(WTPOperation.j ava:173)
com.ibm.wtp.common.ui.RunnableWithProgressWrapper.run(Runnab leWithProgressWrapper.java:62)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
... 37 more
Any ideas?
John
Previous Topic:JSP editor in M1
Next Topic:Several questions about M1?
Current Time: Fri Jul 18 19:01:23 EDT 2025
Powered by FUDForum. Page generated in 0.24121 seconds
