Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » How do I configure the Ruby Runtime for TestCases
How do I configure the Ruby Runtime for TestCases [message #4368] Thu, 17 May 2007 22:44 Go to next message
How can I configure a Ruby Interpreter when running unit tests. I'm extending AbstractModelTests and
creating a new runtime workspace, copying a project from my test/workspace into the runtime
workspace. All that works fine, any paths set up in the project are fine, but the interpreters are
defined in the workspace so they don't show up for the unit test. So I need to setup the ruby
runtime programatically.
Any help would be greatly appreciated.
Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4576 is a reply to message #4368] Mon, 21 May 2007 02:01 Go to previous messageGo to next message
Originally posted by: mikhail.kalugin.xored.com
Hi, Mark.
As I remember, you had already asked this question some time ago. I had
answered at that
time(http://dev.eclipse.org/mhonarc/lists/dltk-dev/msg00007.html). So,
was my thoughts there useful? If not, please say and I'll be grad to
help with a solution.
> extending AbstractModelTests and creating a new runtime workspace,
> copying a project from my test/workspace into the runtime workspace. All
> interpreters are defined in the workspace so they don't show up for the
> unit test. So I need to setup the ruby runtime programatically.
> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4715 is a reply to message #4576] Tue, 22 May 2007 22:05 Go to previous messageGo to next message
Hi Mikhail, sorry I didn't see your previous post for some reason (guess I was looking at the old
newsgroup). Thanks for the info, will give this a go and see if I need any more help
Mark
Mikhail Kalugin wrote:
> Hi, Mark.
> answered at that
>> the unit test. So I need to setup the ruby runtime programatically.
>> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4853 is a reply to message #4576] Thu, 24 May 2007 15:09 Go to previous messageGo to next message
Hi Mikhail, another test related question.
If I get SourceMethod in a test case and then ask for a SourceReflementInfo, it's always null
(whereas asking a SourceModule works fine). I must not be intializing the test project correctly,
any idea what that might be (sorry how little context there is for the question :>).
Mark
> Hi, Mark.
> answered at that
>> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4991 is a reply to message #4853] Tue, 29 May 2007 17:29 Go to previous messageGo to next message
I figured out what I was doing wrong, thanks
> SourceReflementInfo, it's always null (whereas asking a SourceModule
> works fine). I must not be intializing the test project correctly, any
> question :>).
> Thanks
> Mark
>> Hi, Mark.
>> had answered at that
>>> the interpreters are defined in the workspace so they don't show up
>>> for the unit test. So I need to setup the ruby runtime programatically.
>>> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #8173 is a reply to message #4576] Thu, 28 June 2007 15:08 Go to previous message
BTW I did get this to work. I ended grabbing the search code you use when setting up the
interpreter, it's fast and works well.
Mark
> Hi, Mark.
> answered at that
>> Thanks Mark
Previous Topic:dltk source coding format template
Next Topic:IEvaluatedType representing an Array of a certain type
Current Time: Sat Jul 26 10:02:59 EDT 2025
Powered by FUDForum. Page generated in 0.05908 seconds
