Home » Eclipse Projects » Nebula » ToolTip widget is not getting disposed properly on Grid Table
ToolTip widget is not getting disposed properly on Grid Table [message #49932] Wed, 27 February 2008 04:53 Go to next message
Originally posted by: vijaya.rao.in.bosch.com
i am creating a grid table in Editor.
Tooltip will be displayed for long column headers.some times even though
editor getting closed tooltip contol is not getting disposed.
The above condition leading for widget disposed exception.
Can anyone tell why this is happening.
Thanks in advance..
Raghava
Re: ToolTip widget is not getting disposed properly on Grid Table [message #50024 is a reply to message #49932] Wed, 27 February 2008 10:31 Go to previous messageGo to next message
Hi Raghava,
Can you attach a stack trace and give me any more details on how/when
this is occuring.
regards,
-Chris
Raghava wrote:
> Hello,
> Thanks in advance..
> Raghava
Re: ToolTip widget is not getting disposed properly on Grid Table [message #50245 is a reply to message #50024] Mon, 03 March 2008 04:49 Go to previous message
Hi Chris,
here i am attaching stack trace for widget disposed exception.
It seems tooltip widget is not getting disposed properly.This exception is
coming in different times.
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:3547)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.SWT.error(SWT.java:3452)
at org.eclipse.swt.widgets.Display.error(Display.java:1137)
at org.eclipse.swt.widgets.Display.map(Display.java:2619)
at org.eclipse.swt.widgets.Display.map(Display.java:2577)
org.eclipse.nebula.widgets.grid.internal.GridToolTip$3.handl eEvent(GridToolTip.java:80)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
com.bosch.autosartool.bsw.ui.configurator.presentation.Confi guratorEditorAdvisor$Application.run(ConfiguratorEditorAdvis or.java:147)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:533)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:155)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Thanks for your quik response.
Raghava
Re: ToolTip widget is not getting disposed properly on Grid Table [message #588795 is a reply to message #49932] Wed, 27 February 2008 10:31 Go to previous message
Hi Raghava,
this is occuring.
regards,
-Chris
Raghava wrote:
> Hello,
> Thanks in advance..
> Raghava
Re: ToolTip widget is not getting disposed properly on Grid Table [message #588870 is a reply to message #50024] Mon, 03 March 2008 04:49 Go to previous message
Hi Chris,
Raghava
Previous Topic:Exceptions from Grid
Next Topic:creating custom row numbers in row headers grid table?
Current Time: Sun Aug 31 03:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.05069 seconds
