Home » Modeling » GMF (Graphical Modeling Framework) » Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux
Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #49857] Mon, 18 September 2006 09:32 Go to next message
Originally posted by: denis.rampnoux+eclipse.m4x.org
Hi all,
I was trying to use the diagram editor on Linux with Sun jdk 5.0-08 : I
could not see the items in the editor, I saw them in the outline.
Today I tried with jdk 1.4.2 and it is working correctly.
Did someone got this issue ?
Is the problem kown and/or "workaroundable" ?
Thanks by advance for your help,
Denis.
Re: Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #58557 is a reply to message #49857] Tue, 03 October 2006 03:41 Go to previous messageGo to next message
Originally posted by: vibhav.drishti-soft.com
Denis wrote:
> Hi all,
> Denis.
Hi all,
I have the exact same problem. The model can be seen in the outline but
not in the editor. The editor only shows the image of the first node put
in and nothing else. If I delete that node, then the editor shows the
next node put in. Then also only the Node Figure itself is shown. It's
label etc. are not rendered.
I'm using eclipse 3.2.0
sun jdk 1.5.0_08
gmf 1.0.0.v20060627-1200
gef SDK 3.2.0.v20060626
The error log does not show any error on opening the diagram file but a
warning on launching eclipse is produced.
Warnings while parsing the commands from the 'org.eclipse.ui.commands'
and 'org.eclipse.ui.actionDefinitions' extension points.
Commands should really have a category:
plug-in='org.openarchitectureware.xpand2.editor',
id='org.openarchitectureware.xpand2.editor.insertRT',
categoryId='org.openarchitectureware.editor'
id='org.openarchitectureware.xpand2.editor.insertLT',
Reverting back to jdk 1.4.2 is not an option. If anybody has any idea
why this should be happening, could you please point it out to me.
Thanks in advance :D.
Vibhav.
Re: Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #67950 is a reply to message #58557] Mon, 23 October 2006 11:15 Go to previous messageGo to next message
everybody I know of who uses Linux encounters this bug, so I'm wondering if
anybody knows what's going on here or has a solution.
Carsten
Re: Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #76684 is a reply to message #67950] Fri, 10 November 2006 10:27 Go to previous messageGo to next message
Originally posted by: roland.gmx.it
AFAIU it's due to the libcairo (or x11-libs/cairo, or similar) version
being 1.2*...
With the libcairo version 1.0.4 the diagram is visible.
Roland
> Carsten
Re: Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #77988 is a reply to message #67950] Wed, 15 November 2006 13:23 Go to previous messageGo to next message
you can have a look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=164623.
Fedor.
> Carsten
Re: Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #78434 is a reply to message #77988] Fri, 17 November 2006 06:45 Go to previous message
Thanks, I just subscribed to it!
Carsten
Previous Topic:Displaying and Editing Properties
Next Topic:Connecting conections to connections
Current Time: Sun Aug 31 14:17:18 EDT 2025
Powered by FUDForum. Page generated in 0.05040 seconds
