Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #49857] |
Mon, 18 September 2006 09:32  |
Originally posted by: denis.rampnoux+eclipse.m4x.org
Hi all,
I was trying to use the diagram editor on Linux with Sun jdk 5.0-08 : I
could not see the items in the editor, I saw them in the outline.
Today I tried with jdk 1.4.2 and it is working correctly.
Did someone got this issue ?
Is the problem kown and/or "workaroundable" ?
Thanks by advance for your help,
Denis.
Re: Can not view .ecore_diagram in editor : problem is jdk 5.0 / Linux [message #58557 is a reply to message #49857] |
Tue, 03 October 2006 03:41   |
Originally posted by: vibhav.drishti-soft.com
Denis wrote:
> Hi all,
> Denis.
Hi all,
I have the exact same problem. The model can be seen in the outline but
not in the editor. The editor only shows the image of the first node put
in and nothing else. If I delete that node, then the editor shows the
next node put in. Then also only the Node Figure itself is shown. It's
label etc. are not rendered.
I'm using eclipse 3.2.0
sun jdk 1.5.0_08
gmf 1.0.0.v20060627-1200
gef SDK 3.2.0.v20060626
The error log does not show any error on opening the diagram file but a
warning on launching eclipse is produced.
Warnings while parsing the commands from the 'org.eclipse.ui.commands'
and 'org.eclipse.ui.actionDefinitions' extension points.
Commands should really have a category:
plug-in='org.openarchitectureware.xpand2.editor',
id='org.openarchitectureware.xpand2.editor.insertRT',
categoryId='org.openarchitectureware.editor'
id='org.openarchitectureware.xpand2.editor.insertLT',
Reverting back to jdk 1.4.2 is not an option. If anybody has any idea
why this should be happening, could you please point it out to me.
Thanks in advance :D.
Vibhav.
FUDForum. Page generated in 0.30816 seconds
