Home » Eclipse Projects » Mylyn » Mylyn 3.0 RC3 is available
Mylyn 3.0 RC3 is available [message #49839] Sat, 07 June 2008 00:49 Go to next message
Mylyn 3.0 RC3 is available for download:
http://www.eclipse.org/mylyn/downloads/
We do not recommend updating to 3.0 if you use any connectors other than
those available from one of the Mylyn update sites, as they will not
work until the are ported. We will keep the newsgroup and mailing lists
updated on the status of other connectors that we are aware of.
Please note that we have updated the structure of the update sites. The
main tradeoff with the new structure is that some features have moved to
the new Incubator site (the Web Templates, XPlanner and UI Usage
reporting). Two features previously on the Experimental site that were
not suitable for the Incubator sites are no longer available, and if
anyone installed them they should be uninstalled and used from CVS
instead (Trac Wiki integration and Sandbox Dev). The new separation is
described here:
http://wiki.eclipse.org/Mylyn/User_Guide#Project_Structure
The corresponding bug is:
235470: update Mylyn packaging and update site structure
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235470
RC4 will be available next Wednesday.
Mik
Mik Kersten
President & CTO, http://tasktop.com
Project Lead, http://eclipse.org/mylyn
Re: Mylyn 3.0 RC3 is available [message #49869 is a reply to message #49839] Sat, 07 June 2008 09:02 Go to previous message
Mik Kersten wrote:
> The main tradeoff with the new structure is that some features have
> moved to the new Incubator site (the Web Templates, XPlanner and UI
> Usage reporting). Two features previously on the Experimental site
> that were not suitable for the Incubator sites are no longer
> available, and if anyone installed them they should be uninstalled and
> used from CVS instead (Trac Wiki integration and Sandbox Dev).
What happens with UI experiments feature, or more specifically, the
tasks trim widget? And what was the reason of removing Trac Wiki feature
from the incubator?
Also, what was the criteria for moving Web Templates feature (also
known as the web connector) to the incubator? I guess, I don't
understand feature "maturity" criteria referred on the wiki.
regards,
Eugene
Re: Mylyn 3.0 RC3 is available [message #590019 is a reply to message #49839] Sat, 07 June 2008 09:02 Go to previous message
from the incubator?
regards,
Eugene
Previous Topic:How to integrate mylyn to my rcp project
Next Topic:Mylyn monitor doesn't capture selection and edit event?
Current Time: Fri Jul 18 02:01:07 EDT 2025
Powered by FUDForum. Page generated in 0.04141 seconds
