Re: "Toggle Watchpoint" always greyed out [message #490847 is a reply to message #490793] |
Sun, 11 October 2009 19:40 |
Originally posted by: dkel50.hotremovemail.com
You can't. Watchpoints are not supported. If you want you can raise an
enhancement on bugzilla ( https://bugs.eclipse.org/bugs ).
Dave
On 10/10/09 21:51, continuum.kevin@gmail.com wrote:
> I'm using PDT with xDebug, and I'd like to be able to set a watchpoint.
> I think I'm supposed to be able to do this: if I select a variable in
> the Variables view during debugging, I should be able to then select
> "Toggle watchpoint" from the "Run" menu, to create a watchpoint that
> will break execution whenever the variable changes value. But the
> "Toggle Watchpoint" menu item is always greyed out. How do I enable
> watchpoints?
FUDForum. Page generated in 0.03814 seconds
