Home » Eclipse Projects » Plugin Development Environment (PDE) » PropertyPages on Popup for Java Projects in Package Explorer
PropertyPages on Popup for Java Projects in Package Explorer [message #4351] Wed, 28 May 2008 06:53 Go to next message
using Eclipse 3.3 eclipse.buildId=M20080221-1800
I defined a property page in my plugin.xml like this:
<page
class="com.example.ui.WorkbenchPropertyPage"
id="com.example.page1"
name="Test">
<enabledWhen>
<instanceof
value="org.eclipse.core.resources.IProject">
</instanceof>
</enabledWhen>
</page>
This works fine from the Navigator view.
In the Package Explorer view however, whenever I choose a Java Project and
right-click and select Properties, my page will not appear. It appears if
I choose Project > Properties from the menu bar, also if I right-click
such projects in the Navigator view, but not in the Package Explorer. The
page also appears for non-Java projects even when right-clicking in the
Package Explorer view.
Is this a bug or not? It appears like on e to me.
How else can I make contributions to the Property Pages of Java Projects
that show up on right-clicks in the Package Explorer?
Re: PropertyPages on Popup for Java Projects in Package Explorer [message #4419 is a reply to message #4351] Wed, 28 May 2008 10:33 Go to previous message
found out that in the Package Explorer View, Java projects are of type
IJavaProject, not of type IProject (both extend IAdaptable directly), and
that the adaptable flag in the plugin.xml may be used to get the extention
to show for Java Projects in the Package Explorer.
Re: PropertyPages on Popup for Java Projects in Package Explorer [message #567400 is a reply to message #4351] Wed, 28 May 2008 10:33 Go to previous message
Previous Topic:PropertyPages on Popup for Java Projects in Package Explorer
Next Topic:Ensuring plugin activation at startup
Current Time: Tue Jul 15 07:13:27 EDT 2025
Powered by FUDForum. Page generated in 0.03887 seconds
