Home » Eclipse Projects » GEF » figure in eclipse view
figure in eclipse view [message #49712] Sun, 15 December 2002 19:59 Go to next message
Originally posted by: sg.media.-style.com
a stupid newbie question. How to show a figure/grafik in a eclipse view.
All samples i had see was in a own window.
Stefan
Re: figure in eclipse view [message #49805 is a reply to message #49712] Mon, 16 December 2002 09:30 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Subclass ViewPart and define a View in plugin.xml. In
createControl(Composite), create a FigureCanvas and put a figure in it.
There are wizards and documentation on creating views. These are Eclipse
platform issues, so you might continue on the other newsgroup until the
point where you have a View visible in the WorkbenchWindow.
"Stefan Groschupf" <sg@media.-style.com> wrote in message
news:atj860$oi1$1@rogue.oti.com...
> Thanks
> Stefan
Re: figure in eclipse view [message #60885 is a reply to message #49712] Fri, 31 January 2003 08:41 Go to previous messageGo to next message
I am getting the following exception while running my project
in Linux RH 8.0
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-pi-gtk-2052 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1344)
at java.lang.Runtime.loadLibrary0(Runtime.java:744)
at java.lang.System.loadLibrary(System.java:815)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 4)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:3 97)
at org.eclipse.swt.widgets.Display.create(Display.java:391)
at org.eclipse.swt.graphics.Device.<init>(Device.java:103)
at org.eclipse.swt.widgets.Display.<init>(Display.java:277)
at org.eclipse.swt.widgets.Display.<init>(Display.java:273)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:703)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:227)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:222)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:176)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:115)
at com.yasutech.util.DialogTest.main(DialogTest.java:9)
Where I am going wrong ?
I am creating a new Shell() in the line where this exception is coming from.
Thanks in advance,
Chandresh
Re: figure in eclipse view [message #60908 is a reply to message #60885] Fri, 31 January 2003 10:02 Go to previous message
In windows, the equivalent problem is not having the SWT.DLL on the
classpath.
You need to make the mentioned library available to your JRE for running
standalone SWT applications. When you run Eclipse, the plugin class loader
augments the classpath for each plugin, which is why this library get found
then.
"Chandresh Prakash" <chandreshprakash@hotpop.com> wrote in message
news:3E3A7D08.6010402@hotpop.com...
> Hello,
> in Linux RH 8.0
from.
> Thanks in advance,
> Chandresh
Previous Topic:Scrolling problem while using cell editor
Next Topic:Please tell me if this is doable
Current Time: Tue Jul 22 01:47:17 EDT 2025
Powered by FUDForum. Page generated in 0.24962 seconds
