Re: Ecore model instances to GXT(GWT with extjs) beans [message #489535 is a reply to message #489529] |
Sun, 04 October 2009 15:25  |
Ed Merks Messages: 32390 Registered: July 2009 |
Mdu,
Please avoid cross posting the same question to multiple newsgroups.
Mdu wrote:
> Hi All,
> Here's my Use Case:
> Intro:
> We are using GXT (extjs with GWT) as a front-end. GXT UI widgets
> (grids,trees) naturally bind to any POJO that implements DataModel
> ( http://www.extjs.com/deploy/gxtdocs/com/extjs/gxt/ui/client/ data/BaseModelData.html).
> We also have invested in using EMFT stack (Ecore models, Teneo, etc.)
> to build our models.
> We would like to (at runtime) marshal/unmarshal OR
> serialize/deserialize between Ecore model instances and DataModel
> POJOs as described above.
> Q1) Which tooling (approach) would support this use case?
> Q2) We thought of creating a custom Resource that can mapping between
> these two models - is this the right approach?
> Q3) We also thought of using Ecore -> XML -> XML/java binding to
> POJOS. Is this a wrong approach?
> Q4) What about leveraging built in Ecore -> XML feature and making all
> data available via web services (idea similar to Servus - is this
> alive yet). And then have a front-end like GXT talk via web service
> interface.
> I hope my questions make sense.
> -Mdu
Ed Merks
FUDForum. Page generated in 0.02128 seconds
