Home » Modeling » M2T (model-to-text transformation) » JET comments (redux)
JET comments (redux) [message #49674] Tue, 16 September 2008 11:38 Go to next message
I found this old discussion about comments in JET templates (from 2004):
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg0 6495.html
There was a request to support template-only comments in the JET syntax,
comments that are meant for documenting the template itself and are NOT
emitted to the generated code.
Did this request ever go anywhere? Was there a Bugzilla entered for it?
Eric
Re: JET comments (redux) [message #49764 is a reply to message #49674] Tue, 16 September 2008 14:15 Go to previous messageGo to next message
Eric:
First, JET (aka org.eclipse.jet, aka JET2) allows a comment style:
Late in 0.9.0, I resolved this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205811, which was about
copying this comments to the generated Java code, in particular to get
copyright notices inserted at the head of the file. This now does the trick:
<%-- @copyright
However, it my enthusiasm, I ended up writing all comments to the generated
Java output (as Java comments).
This, in turn, has led to a request that I stop doing this, which leads me
to think that I need an options like:
<%-- @inline
your comment goes here
Paul
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:gaojs4$ago$1@build.eclipse.org...
> Eric
Re: JET comments (redux) [message #49824 is a reply to message #49764] Tue, 16 September 2008 15:39 Go to previous messageGo to next message
Paul Elder wrote:
> Eric:
> <%-- @copyright
> <%-- @inline
So do I understand correctly:
In 0.8.x, this line in the template
<%-- This comment will not appear in the template output --%>
will NOT show up in the output, but in 0.9 it WILL show up in the
output? Is that correct?
Why not do what JSP does and have a different comment syntax for
comments that are not rendered than for comments that are rendered?
Eric
>> Eric
Re: JET comments (redux) [message #49854 is a reply to message #49824] Tue, 16 September 2008 22:43 Go to previous messageGo to next message
No, a <%-- .. --%> comment will never show in the template output. But, as
of JET 0.9.0, it will show up as a Java comment in the compiled Java class
for the template.
So, template mytemplate.jet with comment
<%-- this is a comment --%>
It gets compiled to a Java class _jet_mytemplate.java (I made this name up
- can't remember exactly what the compiler does) that would have a comment
somewhere in its code body:
// this is a comment
But, when you run the template, the output will not have that text.
I think the confusion is between the 'template output' and 'compiled
template class'. The compiled template class is a Java class that
implements the template. The template output is the result of executing
the compiled template class with a particular output. So, to be clear...
While comments are now copied to the compiled template class (as Java
comments), this has no impact on the template output.
Hope this clarifies things.
Paul
Re: JET comments (redux) [message #49918 is a reply to message #49854] Wed, 17 September 2008 09:22 Go to previous message
Yes, it does. I was definitely confused by the way it is stated in the
online Help
(< http://help.eclipse.org/ganymede/topic/org.eclipse.jet.doc/r eferences/syntax/jetSyntaxComments.xhtml>)
but now I get it.
Eric
Previous Topic:Could not load JET template loader: EMF+JET
Next Topic:cannot use dropins to change jet/M2T version !
Current Time: Mon Jul 14 11:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.45511 seconds
