Cannot get BIRT to work on a laptop [message #488897] |
Wed, 30 September 2009 15:57 |
No real name Messages: 1 Registered: September 2009 |
Junior Member |
Dropped 2.2.1 and 2.5.1 on my XP laptop. Clicking the executable should start the app, but I get errors. Log is below.
On another XP work laptop, no issue. Attempting to make this one work, I installed the all-in-one which also failed. That was uninstalled, but the stack trace suggests it's not entirely removed. I've checked this forumand other sources, and my java is 1.5.06. Suggestions?
java.lang.RuntimeException: Application "org.eclipse.birt.report.designer.ui.rcp.DesignerApplication " could not be found in the registry. The applications available are: org.eclipse.birt.report.engine.ReportExecutor, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:98)
at org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:112)
at org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at org.eclipse.equinox.internal.app.Activator.start(Activator.j ava:54)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.core.internal.runtime.PlatformActivator.startApp Container(PlatformActivator.java:47)
at org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:32)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
FUDForum. Page generated in 0.03446 seconds
