Home » Language IDEs » Java Development Tools (JDT) » Source not found when debugging with attached source in 2.1?
Source not found when debugging with attached source in 2.1? [message #49566] Wed, 04 June 2003 22:10
Originally posted by: norrie.quinn.tumbleweed.com
I have just upgraded to Eclipse 2.1 and I now can't debug a 3rd party jar
with attached source.
I go to Project/Properties/Java Build Path/Libraries and select an external
jar that I want to debug. I expand it, select the correct source attachment
location, and now the package explorer can locate the source for any
class/method in that jar. When I set a breakpoint on this source, the
breakpoint is hit and execution stops, but the Source Window has a red
"Source not found" message.
This worked before I upgraded to Eclipse 2.1, any ideas what I might be
doing wrong?
Norrie
Previous Topic:Updating The Outline View
Next Topic:Syntax highlighting for classes
Current Time: Thu Jul 31 02:32:24 EDT 2025
Powered by FUDForum. Page generated in 0.05063 seconds
