Home » Archived » XML Schema Definition (XSD) » NullPointerException in XSDECoreBuilder
NullPointerException in XSDECoreBuilder [message #49555] Tue, 27 July 2004 13:33 Go to next message
Hi there. I've been given a pretty large schema, distributed among a large
number of files. No validation errors are reported on the file that
represents the "root" of the schema. However, when I try to create a new
EMF project from that schema, I get the stack trace shown below.
After taking a look at XSDECoreBuilder under the debugger, it looks as if
the failure is occurring on an attribute that is or extends a type
("lang","space") from the xml namespace
(http://www.w3.org/XML/1998/namespace).
Given the size of what I'm looking at, it's been hard to narrow it down
much more. I'm wondering if anyone's seen something like this before, any
hint would be good. Or, maybe someone on the xsd development team could
have a look at the xsd files i'm working with... Thanks!
P.S. i'm using the 2.0.0 versions of both emf & xsd. and yes, the library
example works fine for me, and i'm using an ibm jre :-)
java.lang.reflect.InvocationTargetException
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:386)
org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard$20.execute(EMFProjectWizard.java:1607)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:91)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:105)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard$XMLSchemaModelPage.refreshXMLSchemaModel(EMFProject Wizard.java:1677)
org.eclipse.emf.codegen.ecore.genmodel.presentation.EMFProje ctWizard$16.widgetSelected(EMFProjectWizard.java:1456)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Inlined Compiled
Code))
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:111)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
Code))
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Caused by: java.lang.NullPointerException
org.eclipse.xsd.ecore.XSDEcoreBuilder.initialize(XSDEcoreBui lder.java:1550)
org.eclipse.xsd.ecore.XSDEcoreBuilder.createFeature(XSDEcore Builder.java:1428)
org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClass(XSDEcore Builder.java:1118)
org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClassifier(XSD EcoreBuilder.java:333)
org.eclipse.xsd.ecore.XSDEcoreBuilder.getEClassifier(XSDEcor eBuilder.java:285)
org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClass(XSDEcore Builder.java:728)
org.eclipse.xsd.ecore.XSDEcoreBuilder.computeEClass(XSDEcore Builder.java:950)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:1946)
org.eclipse.xsd.ecore.XSDEcoreBuilder.generate(XSDEcoreBuild er.java:1875)
... 44 more
Root exception:
Code))
Code))
Code))
Code))
Code))
Code))
Re: NullPointerException in XSDECoreBuilder [message #49675 is a reply to message #49555] Wed, 28 July 2004 09:10 Go to previous messageGo to next message
If you make your schemas available, I'll try them out and fix any
problem I can reproduce. If the schemas are confidential, you can send
them to me directly, rather than posting them in public.
>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>at
>at
>at
>at
>at
>at
>at
>at
>Code))
>Code))
>Code))
>Code))
>at
>at
>at
>Code))
>Code))
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>.. 44 more
>Root exception:
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>Code))
>Code))
>Code))
>Code))
>at
>at
>at
>Code))
>Code))
>at
>at
>at
>at
>at
>at
Re: NullPointerException in XSDECoreBuilder [message #49705 is a reply to message #49675] Thu, 29 July 2004 16:44 Go to previous message
Thanks Ed. I've opened a bug with a more-digestible sample than my
original: https://bugs.eclipse.org/bugs/show_bug.cgi?id=71116
Ed Merks wrote:
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >Code))
> >Code))
> >Code))
> >Code))
> >at
> >at
> >at
> >Code))
> >Code))
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >.. 44 more
> >Root exception:
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >Code))
> >Code))
> >Code))
> >Code))
> >at
> >at
> >at
> >Code))
> >Code))
> >at
> >at
> >at
> >at
> >at
> >at
Re: NullPointerException in XSDECoreBuilder [message #589961 is a reply to message #49555] Wed, 28 July 2004 09:10 Go to previous message
>at
>at
>at
>at
>at
>at
>at
>at
>Code))
>Code))
>Code))
>Code))
>at
>at
>at
>Code))
>Code))
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>.. 44 more
>Root exception:
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>at
>Code))
>Code))
>Code))
>Code))
>at
>at
>at
>Code))
>Code))
>at
>at
>at
>at
>at
>at
Re: NullPointerException in XSDECoreBuilder [message #589971 is a reply to message #49675] Thu, 29 July 2004 16:44 Go to previous message
Ed Merks wrote:
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >Code))
> >Code))
> >Code))
> >Code))
> >at
> >at
> >at
> >Code))
> >Code))
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >.. 44 more
> >Root exception:
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >at
> >Code))
> >Code))
> >Code))
> >Code))
> >at
> >at
> >at
> >Code))
> >Code))
> >at
> >at
> >at
> >at
> >at
> >at
Previous Topic:XSDSimpleFinal has no EXTENSION
Next Topic:How to get declaration in the order defined in XML Schema file
Current Time: Tue Jul 22 13:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.07586 seconds
