Home » General (non-technical) » Eclipse Foundation » CVS repository level cvsignore not honored by Eclipse CVS interface
CVS repository level cvsignore not honored by Eclipse CVS interface [message #49528] Tue, 09 October 2007 11:00 Go to next message
I have a repository setup that has a $CVSROOT/CVSROOT/cvsignore file. When
users work with the repository through a standard command line interface,
the ignore rules in that file work for all projects as intended. However,
if a user accesses a project in the repository through Eclipse, the rules
are not honored. Does Eclipse not support the per-repository cvsignore
file? We are using 3.2.1 and extssh as the connection method.
Re: CVS repository level cvsignore not honored by Eclipse CVS interface [message #49560 is a reply to message #49528] Tue, 09 October 2007 11:22 Go to previous message
Josh,
Please use the platform newsgroup for technical questions. I've added
it to the "to" list of the reply.
> When users work with the repository through a standard command line
> interface, the ignore rules in that file work for all projects as
> intended. However, if a user accesses a project in the repository
> through Eclipse, the rules are not honored. Does Eclipse not support
> the per-repository cvsignore file? We are using 3.2.1 and extssh as
Previous Topic:Eclipse 3.3 for ia64 linux architecture
Next Topic:Eclipse ATF new name - vote here : http://www.surveymonkey.com/s.aspx?sm=xpcUsNQpBZ5J3a70bXHzyw_3d_3
Current Time: Sat Jul 26 09:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.05899 seconds
