Re: support for JUnit4? [message #4398 is a reply to message #4328] |
Thu, 06 November 2008 22:04  |
Technically you can still use JUnit 4 to write and run your tests, for
both plain SWT and RCP/plugins.
The problem arises if you'd like to run pde based SWTBot tests from the
command line via the eclipse test framework. More info on this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153429
-- Ketan
Joe Luebker wrote:
> I noticed in the users guide at
> http://swtbot.sourceforge.net/users-guide.html that there is a mention
> to "Ensure that you're using JUnit 3".
> Is there any planned support for JUnit 4? Or maybe that is already built
> in and that statement was made only so that the example runs correctly?
> Joe Luebker
FUDForum. Page generated in 0.03767 seconds
