Home » Eclipse Projects » Technology Project and PMC » How to select a working set through api?
How to select a working set through api? [message #49484] Wed, 19 March 2003 17:00 Go to next message
I am writing a plugin that automatically creates some projects and puts
them into a working set.
All working fine, but I found no way to select this working set through
the eclipse api.
Has anyone done this before or knows where to seek?
Thank you,
rookie_no2
Re: How to select a working set through api? [message #49603 is a reply to message #49484] Thu, 20 March 2003 10:30 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
>the eclipse api.
What do you mean by "select this working set"? A working set is per view
or action (e.g. Search). What do you want to achieve?
Dani
Re: How to select a working set through api? [message #49692 is a reply to message #49603] Thu, 20 March 2003 14:47 Go to previous message
I wanted to achieve, that after the projects are created and put into the
working set, this working set is selected for the the current view (for
instance the package explorer or the navigator).
I thought that the selected working set is a property of the workbench
(applies for all views/perspectives), but as you said it is set per view...
OK, a think I can skip this feature :-)
Thanks and Regards
rookie_no2
Daniel Megert wrote:
> >the eclipse api.
> Dani
Re: How to select a working set through api? [message #591781 is a reply to message #49484] Thu, 20 March 2003 10:30 Go to previous message
>the eclipse api.
Dani
Re: How to select a working set through api? [message #591811 is a reply to message #49603] Thu, 20 March 2003 14:47 Go to previous message
Thanks and Regards
rookie_no2
> >the eclipse api.
> Dani
Previous Topic:Eclipse Branding - feature.xml Version Numbers
Next Topic:Invalid thread access
Current Time: Sat May 10 14:45:53 EDT 2025
Powered by FUDForum. Page generated in 0.03755 seconds
