Home » Language IDEs » C / C++ IDE (CDT) » How to get ICProject out of IProject?
How to get ICProject out of IProject? [message #49471] Mon, 11 November 2002 13:45 Go to next message
Is there a way to get an ICProject object out of an IProject object?
I found a method createCProject in org.eclipse.cdt.core.CCorePlugin but
it returns an IProject and not an ICProject? Isn't this wrong?
Thanks for your help.
-Kiran
Re: How to get ICProject out of IProject? [message #49687 is a reply to message #49471] Tue, 12 November 2002 13:14 Go to previous messageGo to next message
"Kiran" <klingutla@hotmail.com> wrote in message
news:3DCFFADF.9030701@hotmail.com...
| Hi,
IProject is defined within the Eclipse framework and has no knowledge of
other plugins such as the CDT.
Therefore there is no way to get an ICProject (defined in the CDT) object
out of an IProject (defined in Eclipse Framework) object?
What exactly are you trying to do. There is probably another way to get what
you are looking for.
-Judy
Re: How to get ICProject out of IProject? [message #49717 is a reply to message #49687] Tue, 12 November 2002 14:24 Go to previous messageGo to next message
hi Judy,
Thanks for your reply. In JDT, there is a method JavaCore.create which
takes in IProject and returns IJavaProject. I was wondering if there is
such a method available in CDT.
I need this because my java project might contain some "c" code and to
process those "C" files, I am trying to create an ICProject object out
of an IProject object. I am not expecting to find a method in the
eclipse API to do this but I expect something similar to be in CDT.
As I said earlier, org.eclipse.cdt.core.CCorePlugin.createCProject takes
in IProject but it returns an IProject again instead of ICProject.
-Kiran
> | Hi,
> -Judy
> ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨ ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨
> Judy N. Green Software Engineer
> QNX Software Systems Ltd. www.qnx.com
> | -Kiran
Re: How to get ICProject out of IProject? [message #49745 is a reply to message #49717] Tue, 12 November 2002 14:24 Go to previous messageGo to next message
Yes, the same exists in CDT. CoreModel.create(IProject).
Kiran wrote:
> hi Judy,
> Thanks
> -Kiran
>> | Hi,
>> get what
>> -Judy
>> | -Kiran
Re: How to get ICProject out of IProject? [message #1832269 is a reply to message #49471] Mon, 14 September 2020 16:53 Go to previous message
Just In case I get here again :-s
ICProject cProject = CoreModel.getDefault().getCModel().getCProject(project.getName());
does the trick
Jantje
Previous Topic:Need help making interface look like C language
Next Topic:use mingw32-make.exe intead of make
Current Time: Wed Jul 16 20:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.03090 seconds
