Home » Language IDEs » ServerTools (WTP) » WST compile errors under 1.5
WST compile errors under 1.5 [message #49405] |
Mon, 18 October 2004 21:06  |
Originally posted by: not_real.not_real.com
Any idea when WST will compile under JDK 1.5?
Thanks!
Here's a small sampling of the compiler errors I am getting:
2 Class must implement the inherited abstract method
Node.isSameNode(Node) Unrecognized.java
org.eclipse.wst.dtd.core/src/org/eclipse/wst/dtd/core line 18 October
18, 2004 11:07:55 AM
Node.lookupNamespaceURI(String) Unrecognized.java
Node.lookupPrefix(String) Unrecognized.java
Node.setTextContent(String) Unrecognized.java
Node.setUserData(String, Object, UserDataHandler) Unrecognized.java
2 Syntax error on token "enum", delete this token
BasicStructuredDocument.java
org.eclipse.wst.sse.core/src/org/eclipse/wst/sse/core/intern al/text
line 1244 October 18, 2004 11:12:09 AM
2 Syntax error on token "enum", invalid Expression
line 1245 October 18, 2004 11:12:09 AM
line 1246 October 18, 2004 11:12:09 AM
2 Syntax error on token "enum", delete this token Debug.java
org.eclipse.wst.sse.core/src/org/eclipse/wst/sse/core/util line 92
October 18, 2004 11:12:10 AM
2 Syntax error on token "enum", invalid Expression Debug.java
org.eclipse.wst.sse.core/src/org/eclipse/wst/sse/core/util line 93
org.eclipse.wst.sse.core/src/org/eclipse/wst/sse/core/util line 94
Re: WST compile errors under 1.5 [message #49919 is a reply to message #49405] |
Wed, 20 October 2004 12:40   |
Originally posted by: dominique.devito.objectweb.org
According to a on-going poll on wtp-dev, people prefer to build WTP on top
of Eclipse 3.1 instead of Eclipse 3.0.
Eclipse 3.1 is expected to run (and then, to compile) under JDK 1.5. See
< http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_1.html>
for XP OS.
And, as far as Eclipse 3.1 is choosen as the underlying platform, WTP will
have to compile under JDK 1.5.
Feel free to enter BugZilla entries for JDK 1.5 support. Thanks.
Dominique
> Thanks!
Re: WST compile errors under 1.5 [message #50041 is a reply to message #49949] |
Wed, 20 October 2004 16:12  |
> > for XP OS.
> AFAIK there are no plans to develop Eclipse 3.1 on JDK 1.5.
> The plan explictly states:
> "Since the code for Eclipse 3.1 will be based on J2SE 1.4..."
> Someone please correct me if I am wrong
> Darins
Oooops, I have made the typical confusion... Eclipse 3.1 should be running
on top of :
Microsoft Windows XP - Intel x86 - Win32 - Sun Java 2 Standard Edition 5.0
for Microsoft Windows
But compilation seems JDK 1.4 oriented.
Dominique
Current Time: Fri Jul 18 05:35:15 EDT 2025
Powered by FUDForum. Page generated in 0.24374 seconds
