Icons in diagram editor [message #486393] |
Thu, 17 September 2009 13:31 |
Originally posted by: eknews.web.de
I want to change the icons in my diagram editor. As advised in the
tutorial, I changed the default icon in the tool definition. This did
only change the icon in the palette.
It did not change the icons in the properties view, at the labels, and
in the popup menu. I made a screenshot, green circle shows the changed
icon, red circles shows the wrong (old) icons.
Reading the posts in this newsgroup advised this as correct behaviour.
I uploaded the screenshot to
http://axbench.isst.fraunhofer.de/editor.jpg
for I did not know, if binaries are allowed in here.
Now my questions:
1. is this still the correct behaviour of the gmf generator?
2. can I change the other icons via a mapping or do I have to change the
generated code?
3. How do I change the default file extension from "gif" to "png"?
4. How do I change the default directory for icons?
Thanks, regards,
Ekkart.
Re: Icons in diagram editor [message #486557 is a reply to message #486465] |
Fri, 18 September 2009 08:21 |
Alex Shatalin wrote:
> Try changind icon files in emf.edit plugin generated by EMF (just
> replace existing files with your icons).
> In the same plugin you can change ???ItemProvider and modify .gif ->
> .png icons.
OK, I will try that. Thanks for the answer,
Ekkart.
FUDForum. Page generated in 0.02981 seconds
