Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » java.lang.NoClassDefFoundError: org/elver/store/StoreException
java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49355] Fri, 08 September 2006 04:26 Go to next message
Originally posted by: varunkumarm.gmail.com
I'm using Elver Plug-in along with the latest beta2 version of jpox
plug-in.
1) When i clicked enable auto-enhancement it gives a warning as
"No JDO Meta-Data files specified!"
2) And when i click on the ecore file and say generate OR Mapping the
below error appears.
Exception in thread "main"
I followed all the instructions given in the site clearly but the error
appears.
I'm just using the same Library model given in the example.
I would be very glad to download and use the teneo version if someone can
guide me how to download.
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49415 is a reply to message #49355] Fri, 08 September 2006 06:59 Go to previous messageGo to next message
The right mouse click on the ecore file uses the classpath of the project in which the ecore file
resides.
In your model plugin containing the ecore file did you add a dependency to
org.elver.store.jpox.runtime? See here:
http://www.elver.org/jpox/installation.html#Using+the+runtim e+plugin+in+an+EMF+model+plugin
The teneo version is currently only available in cvs at eclipse.org (see technology and then
org.eclipse.emft/teneo.
I am pretty far with the build procedure at eclipse so I expect that there will be a downloadable
version somewhere next week.
gr. Martin
> plug-in.
> appears.
> can guide me how to download.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49444 is a reply to message #49415] Fri, 08 September 2006 09:25 Go to previous messageGo to next message
Yes.. i did add "org.elver.store.jpox.runtime" as the dependency..But
still i'm getting the same error. I followed all the instructions
well..There is no information in any log-files also..
In order to set the classpath for JPOX-Plug-in i added
org.elver.store.jpox.jar which i found from the runtime plug-in.
I added the dependency and also added the RegistryBuddy line to
Manifest.MF file also.
I'm not able to understand what is the sequence to follow also..when i say
enable auto-enhance it says "No JDO Meta-Data Files" and when i say create
the OR Mapping from ecore file a dialog appears saying pacakge.jdo file is
created in model folder but at the same time a dialog named Java Virtual
Machine Launcher pops saying no main class found and program will exit.
What is the class that should have a main, i did not have any class having
any main in my model..There are just Library,Books and Writer interfaces
and classes.
When i ran the enhancer in verbose mode this is the output iam seeing on
console.
JPOX Enhancer (version 1.1.0-rc-1) : Enhancement of classes
JPOX Enhancer : Classpath
>> F:\workspaces\EMFTests\Library\bin
>> F:\eclipse\plugins\org.eclipse.core.runtime_3.2.0.v20060603. jar
>> F:\eclipse\plugins\org.eclipse.osgi_3.2.0.v20060601.jar
>> F:\eclipse\plugins\org.eclipse.equinox.common_3.2.0.v2006060 3.jar
>> F:\eclipse\plugins\org.eclipse.core.jobs_3.2.0.v20060603.jar
F:\eclipse\plugins\org.eclipse.core.runtime.compatibility.re gistry_3.2.0.v20060603\runtime_registry_compatibility.jar
>> F:\eclipse\plugins\org.eclipse.equinox.registry_3.2.0.v20060 601.jar
>> F:\eclipse\plugins\org.eclipse.equinox.preferences_3.2.0.v20 060601.jar
>> F:\eclipse\plugins\org.eclipse.core.contenttype_3.2.0.v20060 603.jar
>> F:\eclipse\plugins\org.eclipse.emf.ecore_2.2.0.v200606271057 .jar
>> F:\eclipse\plugins\org.eclipse.emf.common_2.2.0.v20060627105 7.jar
F:\eclipse\plugins\org.elver.store.jpox.runtime_0.7.2\org.el ver.store.jpox.jar
>> F:\eclipse\plugins\org.elver.store_0.7.2.jar
F:\eclipse\plugins\org.elver.store.annotations_0.7.2\org.elv er.store.annotations.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\bcel -5.1.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\dom4 j-1.6.1.jar
F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\jdo2 -api-2.0-rc1.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\jpox -1.1.0-rc-1.jar
F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\jpox -enhancer-1.1.0-rc-1.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\log4 j-1.2.13.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\comm ons-logging.jar
C:\eclipse\plugins\org.elver.store.jpox.runtime_0.7.2\org.el ver.store.jpox.jar
JPOX Enhancer : Input JDO Files
Where am i going wrong. All the searching and poiners on net leads me to
Elver project. I want to make it work and thank your help.
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49474 is a reply to message #49444] Fri, 08 September 2006 10:52 Go to previous messageGo to next message
Do you have a plugin: org.elver.store installed?
btw, the sequence is first to generate a jdo file, then copy the jdo file to your source tree of the
to-be-enhanced classes, ensure that the build copies it to the build directory, then the
auto-enhancement (and the jpox runtime) will automatically pick it up.
gr. Martin
> say enable auto-enhance it says "No JDO Meta-Data Files" and when i say
> create the OR Mapping from ecore file a dialog appears saying
> pacakge.jdo file is created in model folder but at the same time a
> dialog named Java Virtual Machine Launcher pops saying no main class
> having any main in my model..There are just Library,Books and Writer
> interfaces and classes.
> console.
> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49504 is a reply to message #49474] Fri, 08 September 2006 11:03 Go to previous messageGo to next message
As an extra remark the org.elver.store.jpox.jar does not need to be in the jpox preferences and
should not need to be listed separately (imported in the project or so).
You can set the jpox plugin to use the classpath of the project (at least in the version I have)
then you don't need to list them separately in the jpox preferences.
gr. Martin
Martin Taal wrote:
> file to your source tree of the to-be-enhanced classes, ensure that the
> build copies it to the build directory, then the auto-enhancement (and
> gr. Martin
>> say create the OR Mapping from ecore file a dialog appears saying
>> on console.
>> to Elver project. I want to make it work and thank your help.
>> Regards,
>> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49534 is a reply to message #49504] Fri, 08 September 2006 11:16 Go to previous messageGo to next message
But the problem is while i'm generating the JDO file first. The exception
is shown again while i'm generating the JDO file. Why am I getting
storeException?.
And Yes, i have the org.elver.store plug-in installed.
Should there be a class with main method, (i'm asking this as the JVM
launcher dialog says no class with main) in my model code. What is the
main class that is not being available, and is there a way to debug and
find where i'm going wrong.
The only step i didn't do is to place a JDBC driver. I don't think it is
the problem.
Thanks and Regards,
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49563 is a reply to message #49534] Fri, 08 September 2006 11:40 Go to previous messageGo to next message
No storexception occurs but a noclassdeffoundexceptin, the error is that the storeexception class
can not be found:
What does your remark mean:
In order to set the classpath for JPOX-Plug-in i added org.elver.store.jpox.jar which i found from
I added the dependency and also added the RegistryBuddy line to Manifest.MF file also.
Why did you take the jar out of the plugin (at least that is what I understand)?
The dependency should be to the org.elver.store.jpox.runtime plugin not to its internal jar files.
This because the org.elver.store.jpox.runtime plugin defines its own dependencies to other plugins
(one of which is org.elver.store).
In my opinion you only need to do:
1) to manifest.mf add a plugin dependency to the org.elver.store.jpox.runtime plugin with
registerbuddy set
2) set the jpox enhance to use the classpath of the project
Did you exactly do this (and nothing more)?
gr. Martin
> exception is shown again while i'm generating the JDO file. Why am I
> getting storeException?.
> And Yes, i have the org.elver.store plug-in installed. Should there be a
> class with main method, (i'm asking this as the JVM launcher dialog says
> no class with main) in my model code. What is the main class that is not
> being available, and is there a way to debug and find where i'm going
> wrong.
> the problem.
> Thanks and Regards,
> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49593 is a reply to message #49563] Fri, 08 September 2006 12:15 Go to previous messageGo to next message
Yes, offcourse i didnot remove a jar from the plug-in folder :-)
I just set the property of enhancer to use the class-path of project and
then added the plug-in dependency and registerbuddy in manifest.mf
Exactly what is said and nothing more and
now my Manifest.MF looks like this.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %pluginName
Bundle-SymbolicName: Library; singleton:=true
Bundle-Version: 1.0.0
Bundle-ClassPath: .
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Export-Package: org.eclipse.example.library,
org.eclipse.example.library.impl,
org.eclipse.example.library.util
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
Eclipse-LazyStart: true
Eclipse-RegisterBuddy: org.elver.store.jpox.runtime
I'm sorry i misinterpreted the error, Yes, it was a noclassfound error.
But the class is rite there and the corresponding plug-in is also shown in
the plug-in dependencies tree view. What might be probably going wrong.
We are a team of 5 and all started to install elver independently and all
were struck right at this point.
And one more thing, why am i getting the Java Virtual Machine Launcher
Dialog saying "Could Not Find Main Class: Program will exit"
See the print screen of the working environment also showing the expanded
tree view of plug-in dependencies.
http://img406.imageshack.us/img406/1863/elvererrordh8.jpg
Thanks and Regards,
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49649 is a reply to message #49593] Fri, 08 September 2006 15:08 Go to previous messageGo to next message
--------------040903010501090008050707
Good to hear that :-).
What seems strange in your screendump is the location of the org.elver.store jar file.
In your screendump it seems that the org.elver.store._0.7.2.jar has not been unpacked.
I just installed elver on a fresh callisto release and it all worked fine.
In the attached screendump it seems that the org.elver.store_0.7.2.jar is installed differently (it
is unpacked) than in your case.
Can you unpack the org.elver.store_0.7.2.jar manually in the plugins directory?
gr. Martin
> Bundle-ClassPath: .
> in the plug-in dependencies tree view. What might be probably going wrong.
> all were struck right at this point.
> expanded tree view of plug-in dependencies.
> Thanks and Regards,
> VarunKumar.M
The Netherlands
Content-Type: image/jpeg;
name="elverscreendump.jpg"
Content-Disposition: inline;
filename="elverscreendump.jpg"
/9j/4AAQSkZJRgABAQEASwBLAAD/4QAWRXhpZgAATU0AKgAAAAgAAAAAAAD/ 2wBDAAUDBAQE
AwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEPERETFhwXExQaFRERGCEYGh0d Hx8fExciJCIe
JBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh4eHh4e
Hh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCALGBUoDASIAAhEBAxEB/8QAHQAB AAIDAQEBAQAA
AAAAAAAAAAUGAwQHCAIBCf/EAGsQAAICAQQAAwQDCAsNBQIBHQECAwQFAAYR EhMUIQcVIjEW
VZQjMkFRk9HS0xg3UlNUVmF0dZWzJDM0NTZCcYGRkqGytBclcnaxCENic8LF JsHjRmWCg8NF
Y5ai4fAoZNQ4Z4WltcTV4vH/xAAZAQEBAQEBAQAAAAAAAAAAAAAAAQIDBAX/ xAA4EQEAAgEC
BQMBBgUEAgIDAAAAARECEiEDMUFR8AQTYQUicYGRodEyQrHB4RQVUvEGIxYk YnKi/9oADAMB
AAIRAxEAPwDov/s0exzZm0vZriM3lcPjshm8lQW1at2UE6qkoWRUUMoAAUJ+ Dnnt6nn1te5s
37NdvWFhyGz6HZhzzHia5HH4/XjW3tpZZPY1t6OIFm9w0DwB+AQRk/i1wP2j bwwsVx4M1DYM
8Xw8PQk+X8nFtede30HpMPUZTqazy0YW9G7Zqez3cmLTJYjAbfsV2PUkY2EF WHzBHX0OpT6L
bS/itgf6uh/R1yX/ANlfrNt/L5alTlq465PH5fxKzw+IVDdnAaeXkeqjkdfk fnrsvdvx68vq
uFjweLlhjygwmcsban0W2l/FbA/1dD+jp9FtpfxWwP8AV0P6Otvu349O7fj1 wapqfRbaX8Vs
D/V0P6On0W2l/FbA/wBXQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/Fb A/1dD+jrb7t+
PTu349Cmp9FtpfxWwP8AV0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9Ftpfx WwP9XQ/o6fRb
aX8VsD/V0P6Otvu349O7fj0Kan0W2l/FbA/1dD+jp9FtpfxWwP8AV0P6Otvu 349O7fj0Kan0
W2l/FbA/1dD+jp9FtpfxWwP9XQ/o62+7fj07t+PQpqfRbaX8VsD/AFdD+jp9 FtpfxWwP9XQ/
o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9 FtpfxWwP9XQ/
o6fRbaX8VsD/AFdD+jrb7t+PTu349Cmp9FtpfxWwP9XQ/o6fRbaX8VsD/V0P 6Otvu349O7fj
0Kan0W2l/FbA/wBXQ/o6fRbaX8VsD/V0P6Otvu349O7fj0Kan0W2l/FbA/1d D+jp9FtpfxWw
P9XQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/FbA/wBXQ/o62+7fj07t +PQpqfRbaX8V
sD/V0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9FtpfxWwP8AV0P6On0W2l/F bA/1dD+jrb7t
+PTu349Cmp9FtpfxWwP9XQ/o6fRbaX8VsD/V0P6Otvu349O7fj0Kan0W2l/F bA/1dD+jp9Ft
pfxWwP8AV0P6Otvu349O7fj0Kan0W2l/FbA/1dD+jp9FtpfxWwP9XQ/o62+7 fj07t+PQpqfR
baX8VsD/AFdD+jp9FtpfxWwP9XQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0 W2l/FbA/1dD+
jrb7t+PTu349Cmp9FtpfxWwP9XQ/o6fRbaX8VsD/AFdD+jrb7t+PTu349Cmp 9FtpfxWwP9XQ
/o6fRbaX8VsD/V0P6Otvu349O7fj0Kan0W2l/FbA/wBXQ/o6fRbaX8VsD/V0 P6Otvu349O7f
j0Kan0W2l/FbA/1dD+jp9FtpfxWwP9XQ/o62+7fj07t+PQpqfRbaX8VsD/V0 P6On0W2l/FbA
/wBXQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/FbA/1dD+jrb7t+PTu3 49Cmp9FtpfxW
wP8AV0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9FtpfxWwP9XQ/o6hN9JsPZ 21bm48ntDFTV
KnTxEr4yBpD3dUHAYAfNh+H5c6s3dvx6qfte27kN4ezvKbdxs1aK1b8Hw3sM VjHSZHPJUE/J
T+D56CCj3Z7NfNpQtbCjpZA5eriZac+HrCSGWyrNE7cEr0IUnlST/Jq2eV9m v8B2f/hvu/8A
vFb/AAr94+X99/8Agfffyaquf9mdbnDSbfKpYg3FTy2RsXrUs01hIA447t2J YBuADwPn6jUP
P7N90jOAQXMO2J+mibmLPJIs/HPxR9QhXkD5evr/ACabJu6BBB7Mp8mMXBT2 bLfMjxiqkNYy
l0HLr0A55UepHHoPnr83HT2PgvdvmtpYR/eF+KhF1pVV4kk54J79eR6fJezf iU6497M9sZ6n
7QtrQe6JRQwEmSeXIy0Za8kyzqwTxDIoDvy3HCFgB6866JufYk9mlt2piL88 iY3clbLztk70
07mOMEMqM3Y8/LhfQfP1HOkcoWecwnIo/ZfLkfd0VbZkl3xng8usVUy+In3y deOew/CPmNae
+32LtClQs3NkUbzZC/Hj68NLF1mkaaQMVHx9RwepHz+ZGqePZflhcN0SYkWT vv6QGbs3c0+S
fC56c9+ST1+9/l1bPart7M7jpYE4R6ItYrN18n1uSMiOIg/w8qrHklh+D5c6 bJubfvezXLUs
jYl23hsS+LkEeQgyeNggkqkjle/I68EfIgkH8epavS9m9hab18dtGZbxZaZS vWYWCo5YR8D4
+ADzxzxrnec9ludzlTMZPI5SiucyeTqXnhrvKlXpWRo0i7jiT1VyS4HPIHA1 s1/Zxl6uxGoY
/wB14/N1s0mXx7rannhSUdAfEdx3bsA4PAA9R6fM6TX9P8rUrpYHssrxiSxB sqFDO1cM8dVR
4q+jR+o++HI5X5jnWvM/s+h3o+1Ztq4eO0mJOWew+OriusAk8M8sfUNz6/Lj j8OueZP2NXjU
wgrT07zVsU1K9Xs3Z66SSvIZZJQ8YLN2Z2BVh6gL+LW/uj2V5fNSNGmQpU4D tCDCAxtIxWeO
wkvyI5MRCdeSxb1+R0mogjeV7X/ssahHkFh2Uack4rx2BHV8NpSORGG44LcA /D89JP8Asrjq
1rUkOyUgtCRq8rR1QkwT78oeOGC/h4+X4dcm3X7P9y15quSehjZ7eT3Ti5pK OOryS06sUEUi
F3+EHoe3LHgAfj9dTm3fZXlau48Flco+Gngr5XJ5G7UjDGOM2Y0WOOIMvDBS gPr14/BzxqzE
MxMuh0avs0vW1p0qOz7Vl4hMsMMFZ3aM/JwoHJX+X5a+alf2ZXK9uxUp7OsQ 0lLW5IoazLAA
CSXIHCgAE+vHyOuZ4P2P5Wph9p0ZbeMrS46tloMlZrFu8nm0ZImQlB2Khhz2 68cenOs21vZV
mMTic1UkXErZubfnxMVlL1mUyM6gKWVx1jT0JIUNxz6enoWy70vN277JquHy GWFbZ1itj64s
WPLwVZGVSPh9APm3ICj/ADiQB89bm1q3s63PhocthMJtu3WlVSTHRgYxsVDd HAB6uAw5U+o5
1RKXsrvwuY/ExUMEux/cE3hBiTcLcmbjqAy8+vYntz+DV39mmMy+C2fSw+Xh xkU9KKOurUHZ
klRI1UO3ZFIckHkcH8HrqbG6Z+i20v4rYH+rof0dRMUfsvlvtQjrbMe4kkkb QLFVMiun36le
OeV/CPwfh1IbexMODpPUrWshYR5DIWu3JLDgkAcBpCSB6fL5fP8AHriNP2d7 p3BkM8YlqYRI
95XMjDds1nFpgAfDMYK8PCxbn58eh+eiuwY2D2ZZOOxJjaezbqVh2navDWkE Q/GxUHqPQ/PU
Vlcn7LqVfF2K2D27lYcllocTFJjqdWZY55OeO5HoAOPXjk+o9DrnFH2L7nlT KJkczSia/ghQ
aaO3PO7TrPHKGPdRwjCPggccdiAD8zad1bD3FujauIxFtMDhpKear25mxMki DwI42RmjJjBE
vxfCCOBwPXTZN9lsnm9k0H9/GxovurQ/GtRfjX0ZfX/OHI5HzGs2Ui9mGKkE eUq7MouYxKFs
xVYz0J4DcMB6c+nPy51yzNeyre+QxFTDnI4NaNHGzUII4Z5q6uSSUsOqJ6sQ QGQkrzy3ryRq
t732NuavBc2/SxZy1vJYzE1HnFKZlglrIisYpyvhiM9SSWKn8HX8OnWjepl3 00PZyMwMOcZt
IZIjsKflq3jccc89OO3y9flrDuOnsfBe7fNbSwj+8L8VCLrSqrxJJzwT368j 0+S9m/Ep1Ql9
lmRh9ocue70LtWTNrlUlnu2ElgPYMVES/c2I4IViR6ehBHprc9olXdmTv7Xp 3aMNp4d5Q3q7
4+GVo4aEPPDTuw4WT4/Uc8H/ADeeDpG5OyftZD2YxbvxW14cDt+7eyT2Ywat KtIld4E7usvH
qh4+Q4Pr8+NTGJoezrLmYYnGbSyBgbrMK1avL4Z/E3UHg+h+euU4r2P7hr2s RUmvYZKGOiyk
BuweILky24nRXcFeCyl/l29APQnVl9l2wsztvcUeWyk2JjFXCRYeKLHh+Jwj hvHk7KPjPAHp
z8z66R8rLoH0W2l/FbA/1dD+jqobkyeyMNu1NrxezhMrkWoC/wBaOKplViMh j5JkZPXsP+I1
aa+Jhgz9jNLayDT2IxG0T3JGrqB19ViJ6KfhHqBz6n8Z1QvaBsPKZz2jw7li xW28xSTELR8r
lpZF6yCZn8QBY3HyPH+s6bIuCVPZyclDipMVtSHJyoHWjJXrCxwR2+845+X4 tQO2M17Odw1t
uWKWzcdGm4fNeVE+Ppo6eXJD9l7djz1PHQN/L11r7L2dm9t7qyNlYMBZx2Rv Needw/m6xZOP
CT4eCin0X1HAJ9PXjUZsj2cZ7B/9nfmreOf6M+8/OeFI57+Z7dPD5Qc8c+vP X+TnVmki12xq
ey7JuUxtbZd1hEZiteKrIRGDwX+EH4QQRz8tfNUeyy1Ss3a0Gyp6tTjzM0cd Vkh5+XdgOF54
Pz1yD2W+zjcNvbW37eTx+Px8dGhk4TVswyw2bL2O8YSwOAQgHBBB54I4H4dS yeyXcs217WKs
ZLHQpHeqWcfUimkZFSFXUxPOEWTqe/I9D1I9PmdKjz71h1nHYTYuSpx3Mdgt s3K0g5SaClBI
jf6GCkHVJq7s9ms24GxT7CjrxjNPgxekw9byzXFPHhgqS3r+AlR8/Xj11Oey vbVnamAtUbEF
Ou8917PStZmsL8SoCS8vDFiVJPoB/r5JhdnezOtRz+WzWfK3LEu4bGVx8cdq UwwhyCjtEeE8
UfF68Hj09fQcNrN2/t3N+yfMbZx2fkxW2cRXyPieXiydapBK3SRoz6eoPqp+ RPzGvvI5n2Q4
3dT7byNTadO4lQWneerWjiVSQAhcgAOQQwX59SD8tc5k9ju8m2ficCcxjHjq Y21WkhFqeOMT
STySLKCiAyDq6qVYADgng/hteJ2DnMXunbeZRMHdSpt2thclHYZweY2UtLH8 B7ngcDt1/B8v
wSKXdubQ3X7I9yU796HCbfx1KnIkbWMhVpwq5cuF4HYsvPQkdwpI+XPrxY7M fsvqzRQ2a2zI
ZZolmiSSKqrSRs3VXUEeqlvQEehPprneJ9ledxe1dnxQtgbWWwEttp4LHc1L QnZ+CzdOxKBh
xyvz51v+zv2W2tt7kw97I2MfkquO2+2PBZSXFhrTzFlUrwFCuyg88/yDViuq TfRcyPZYLb1D
DsrzCSSRPF4dXurp9+pHHIK/hHzH4db2Lw+wsrTW5jMJte9WYkLNXp15EJHz 4ZQRrmk/soyE
8sss4w0sk2+PfsjP2Jej6/cSenq3qfh+99fnq5+zPbV3a0W4orMlUx5HPWsh WWuTxHDJ16qQ
QOGHU8gcj+XTY3WL6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HqLTU +i20v4rYH+ro
f0dPottL+K2B/q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof 0dbfdvx6d2/H
oU1PottL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof 0dPottL+K2B/
q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/Ho U1PottL+K2B/
q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q 6H9HW33b8end
vx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q 6H9HT6LbS/it
gf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW33b8endv x6FNT6LbS/it
gf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q6H9HT6LbS/itg f6uh/R1t92/H
p3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW33b8endvx6FNT6LbS/itg f6uh/R0+i20v
4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp 3b8ehTU+i20v
4rYH+rof0dPottL+K2B/q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4 rYH+rof0dbfd
vx6d2/HoU1PottL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4 rYH+rof0dPot
tL+K2B/q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdv x6d2/HoU1Pot
tL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPott L+K2B/q6H9HW
33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1Pott L+K2B/q6H9HT
6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW3 3b8endvx6FNT
6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q6H9HT6 LbS/itgf6uh/
R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW33b8endvx6FITM 7f27C9GrR2vt
pJ7lnwVkmxkTJGBG8hYqAC3pGQByPUg8+nBfQip/ANmf/e0v63WfNSFcpgiz gf3e4HP4zWnA
/wCOoneOe31jMnHX27sRtwVGhDvZ96w1ej9mBTq4JPACnn5fFx+DVikbzbIr dT0x2yi3Hwg7
bUAn/T4utHG4jC5tq/u/bO1aCtj69yQz4iOckzd+EAHTjr0PJ9eeR6DjUls7 KbjyGMkt7l26
du2I5iogN2OyGjCqfELoAB6lhx/8Hn8Oo7Ykjf3Oit8ZwOOIH4SB4/P/AKj/ AG6bCl5beXso
xWUt4u/ldmQ26c7154/oXO3SRGKsOQSDwQfUHjVwr4fBtiMdnYcTtDI4261Y p4eAFd3jnZVR
wWZuOO6twV+XI9DrDt65uPB1bePk2ZnLf/ed6dJq81Pw5EltSyoR3nVvvXHo QDzrLi6l3E+z
LbeLyKeBarR4qvLGWB6yJJAGUEeh46n5c/LTYftjD4NcRkc7NidoY7G0msl/ EwAsOkcDMruS
rLzz0ZuAvy4HqdRbTbEFDBXRe2G8GfnWviym2ezWJGPXgKJOV4YhWLABSQG4 Ppqy4qzdh2xk
J8bV8/bhs32irCQJ4sgsSlYyx9F7Hgcn5c865D7PvZhvHaG9MXvQYjD258lN ImSxsCLEMOkz
c94GLEHovKkL68EovYN3DYdA3d7Ndp7jiO2Nybd29ZgtVprEFjH48U5YJE6x kghm5PE3IPPA
I+R9OP56bk9n2TxO4slihZqOKduWv28Rjz0crz96PxfiGv6Y25G+luORm+MU LRI/CAZK/H/o
f9mvDHtF/bB3H/Str+1bSyntz2bfta7U/oOj/wBPHrZym2dtZSRJMnt/E3nQ 9kaxSjkKn8Y7
A8a1PZ0ePZntT+hKP/TprR9qeUyWL2ebOImsw3HyOPrK1ZYmlKzXIYnVBKDH 2KOwBb0BIPp8
9IymJ2k6LZBFDBCkMMaRRoOFRFAVR+IAfLX3yNcr3dubO4HbF1FsZiLJDa+Z ycUmQ8mZIpa3
gCMssKGNj915HDccchgxI6zN/fs0W9JNv0tv3r0Na3BTt2YoZ28J5VR+w6xN F0VZUZi0iEDt
wDwOYL3yNORrD31X/aVlLmH9nO5stjpvAu0sRbs15eobpIkLMrcMCDwQDwQR qLSzcjTkaoNf
N5fA4G/kcpW3Hal8atXqQ5Z6CeJLNKIkVWqA9VLyJ2Lg8D1APqNaGN3duM52 1RvVoRbbc7Y2
vVjtL4EajDC0FaXwezI0gZueoYdx8wvRqOm8jTkaqfsszOZz3s/weazsFSK3 eoV7HNaYusge
JG7kFF6MST8A7AenxHVm76gzcjTka55mMvmqO+emWvZjG4aS5Whx0tSrXlpz dwi+HOxVpUdp
WZAR0Xgx8HknW9j97TWs9WrNiFjxl3J2sXUti1zK9iuJTJ2i6gKhNeYBg5J6 jkDt6I3J2XXk
acjXObXtL8DaOOz/ALl7ed2ja3J4HmuOngR138Dt09e3mOO/A46fenn0l7e5 M7DZxuKXA0mz
OQjnsJXbJMsMUERjDM8oiJ7cyxjqqMOSfXgc6tIt/I05Guf7r3/dweSjxcW2 rWTvxUIr12Gm
tibors6hImjgYOxMUnHieEDwPUcni9d9RWbkacjWHvrjfs89oN8Yinls1mct k6ybRbN5UXMc
lYxyqsTf3NxFH4qENNyR3UcR/EOw5DtXI05GuUZrfm6rm2LL43APibwyGNqr PZ8eKMx2rKwn
wzPVHMikgEeGyqHVuX46GWyu+5cFuKvg7FX3jXS1UoTXkeV5llnMaI0oSuII yWkUkGRT1IIX
1VTa3pOlug8jTkaqeL3FmsxYuS4rC0WxtezZqJPZyLRSyTQs8bfc1iYBPFQr 2Lc8At1PoDX9
p733Pe2ntVpsJjrmczWJ94hVyDRQtCkUBeRm8I9HLzoBGAwHP3/A1OlrTpnI 05GqRt7e1ncO
ap1sRh42x8+Go5eS1Yt+G6R2jMFQRhG7MBDz98B6n1HA5uPfVmKSN2bkacjV P9q9/M0tlu+3
sguOyc+QoVILLQrKIvHuQwsSrAgjq5/+ZwfXVdxftDu2LGbuSpWiWhiccZMf YlKLXuvauQTx
l0jd2PaJFUBW7cL1Hx8lWw6lyNORqgYL2iC+IPOYh6IGXOKuPI0iLXlNcTxt xLFG5Vg6Jyyo
ezDgEEE6lP2jSzQXMh7rn6vj8ZYo1jYXrKbtuxBX5PhhkLdImYksFDcAcqS6 ldK5GnI1z6Xf
uSgpZPzOFow5ChmExfl/PzSrOzVY7HaPw67SOeJPvBHzwpYkcEDVwe+s7ntz bdjxuKqRY69S
yLXY7ViSOaOWrchryFQYefh7N1Vuhbt8XhleCHS+RpyNUTYG/Zt2XU8Pb96r jrNQ3Kl14Z1R
07KFVzJEiB2VwwEbSAgN6+g5uvfUGbkacjVW9oFnPwYuq+BjuN/dai6aSQta Wv0fkxLN8Bbv
4fIIPwluATxqvS7/ABjsLhosamS3HdvrbZXtVZY5VFeURyiVK9dyro7rHx4Y HIPJH4RTpXI0
5Gub7r9pcmBx9fIvgpHh91Jk7lZzOLtSMglg8SQOqEBWHMjxgsrDkdSdSc+9 LFe5uua1iY48
Ntnt5q2LRaWXrUisnpF049BLx6uPkCOeSBaRdeRpyNUDdO4d3UdpjJSYqlj7 TZLGRQRQXvMN
Ik12GOSNy0SqhKOV5BbjsSCOATPbUztnLtla1+hFSu4u75OxHDYM0ZJhimVl cohIKTJ81HB5
HrxyVCw8jTkaw99cx3/uDclfeOYxuDyGXFmthKlrGUKmNWeCxakltqRPIYmM aN4UQ5LxgDsQ
eQdIiydnVORpyNUKLfOQODyeZlwEKVa+UlxVJVvdpLU63TTQsPDAjRn4JPLE cn0PAJ+628bU
+WxuNt0DTujPvibkcFlZYgRj5LasHaMM6lfD9AIyGPzIBDKF65GnI1zbAe1G PI427mrO38jV
wsGKly0VzwJ+HhjAbq3iRIndlbsoR5AQG9RwOdjdO497Y/bMOQTBYapZlyeN rpG2UeT7nPaj
idXPgcK3xqvp2A7MwJ6gNFdB5GnI1q1ZJ2qxNajjisFAZUjkLorceoViFLAH 5Egc/iHy1k76
FM3I05GuHbM9ouYg2zHm7uRyecMOzJM7fgv0kpc2ESJ1WuwhTvG3MoLASBeI /X4h2vm697S4
XI5GhXxHnZqiYoxjzIj8Vr1ySqF+9PXoY+3Przzx8PHOrSLryNORqvbTztnL tla1+hFSu4u7
5OxHDYM0ZJhimVlcohIKTJ81HB5HrxyZvvqKzcjTka55l8luCf2qTYenZzq4 2vjaFhlx6UfD
jeWe0rtMbA8QqViT0j5ICt6ckc4LHtFnqU60VfE2sjkLV/KxxxESuFip3GgZ ia9d2A5MYUFP
QHhnJHZko6VyNORrnMu+b1fJZG1LRtCE4bCz1MZYVYZY7V2zZh6SNwSp7CFW 5569SQPnzF5X
fOYo4bdC5fI0MJf+kNfD0JWmjeGkJKlWRnDuih+oeaYdx68dT6cDSdppelut cjTka5fj/aVZ
bZ2BySwY669pJob+QluGCjFPAwjfmVI5AA79mQkBSqk9vkDY13XZO/H23Jj6 1WEHiOezaeOW
19y8QtBH4RSQA/CfugYdXPXgDmzFSkbwtvI05GucYHf9yzU2kJMdFHFmcXSt tdyFwxBnnA5i
Rkg8OSYfPqfCDF16j1PWW9meb3Bm8RdtZ6pj4GiyV2tC1Wy0nYQ25ourAxpx 1EagNyS3zIU+
moq48jTkaw99V32h5S7htt+96U/hLTt1pbfwKwNXxkE/PIPHEZduRwfh+ehS 0cjTka5Fjt6b
ht5UYo3AJsrm4JcZIIU4THeLYLIPT4u0NKRux9QbA4I4XiZpb2zFm5UxmLws eQt2psyQ1vIC
FY1pXlrgEpCfRu44+HkcAEseX0jeLJ2mnRORpyNcp3d7SMnPsHIZTauOCzrt MZ5rFidVaos0
UpgKoUZZWBiclT1Hwj1PPGrDkt7TVM7ZrJiFlxlLJVMXbtm11kSxZ8Lw+kXU hkHmIeWLqR2P
APX1tb0i68jTka5fkPazDTltQPhWM1aG2GTzI5a1FLOkNcfD6mUVZmDfgAX0 PbXSlc9R2AB4
9QDzqL1pm5GnI1h765btDe25cnifZo13G5Ks2Y8L3hemFXwrvONsTHqsbs6d pEVx8Cei8Hjn
qQ6xyNORrklv2nZLK7F3HlsVhb2OSLbtvKYvIvXmKApHzH38WFY+57KwVGlU hW5PAHNgtb5u
19wZGq2CjOLx+YqYma4Lv3UyWY65jZYunBAeyity44HqOfUC0i98jTkaw99O +otM3I05GsPf
TvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNOR rD3076FM3I05
GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTN yNORrD3076FM
3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O +hTNyNORrD30
76FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTka w99O+hTNyNOR
rD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzc jTkaw99O+hTN
yNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTv oUzcjTkaw99O
+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05Gs PfTvoUzcjTka
w99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hT9t1q1yu1e3BFYhf jtHKgZW4PI5B
9PmBqP8Ao3tz6hxX2OP82t/vp30KaH0b259Q4r7HH+bW3kMbjcj094UKtvw+ enjwq/Xnjnjk
enPA/wBmsnfTvoU0Po3tz6hxX2OP82stTCYSnYWxUxGPrzJz1kirIrLyODwQ OfkTra76d9Cm
rbwmEuWGsW8Rj7Ez8dpJayMzcDgckjn5AaxfRvbn1Divscf5tb/fTvoUx47G 43H9/d9CrU8T
jv4EKp245454Hrxyf9uvB3tF/bB3H/Str+1bXviJuW/1a8D+0X9sHcf9K2v7 VtWB7Y9n549m
O0/6Eo/9Omv3deNlzOFalXlqxTrYgswyWoHmjSSGZJUYokkbNwyA8dwOeOeR yD++zqKKb2Z7
UWaJJFGEonhlBHPl01NGlQEhjNSsHChivhrzweeDx+I8H/YdSbshVPo02Wpz rvGTH5azLUs4
/wASlWmpp5SwI/FiKmaQ8sYl+MMCOBxx6k7trbuIsZoZhorUVztGztBcmhSY p94ZERgknHy+
MH09Plqf8jS/gdf8kPzaeRpfwOv+SH5tTctg76j9y49M1tzJ4aXwjHfqS1mE qsycOhU9gjKx
Hr6hWU/iIPrqX8jS/gdf8kPzaeRpfwOv+SH5tNy1H27tC1BjMljdy5SLNVbo jARTcUx9STyD
PamIPPUgoUIK8+p44ksZtLb+Nmjmq1JvGjyByQkmtzSubJrmuZCzsSx8IleD yPw8c+urN5Gl
/A6/5Ifm08jS/gdf8kPzabiH29h8fgMauOxSTRVEP3OKSzJKIhwAFTux6IAA Ai8KPwAake+s
/kaX8Dr/AJIfm08jS/gdf8kPzabraiZfaOTv7zTNe9qBoLagseSnr25OTGF9 eBbWHvyvKt4J
6kKeGK8marbYwVbOtmoabLcMjyjmeQxJI44eRYi3RXYcgsqgnk8n1PNh8jS/ gdf8kPzaeRpf
wOv+SH5tXdNlOj9n+0kisQjGzNFPj58a0bXp2RKs3XxIUUvxGp6LwE468fDx qXzuFxua8ub8
U3i1mLQTV7MleaMkcN1kjZWAI+YB4Ppzqa8jS/gdf8kPzaChSJAFKuSfkPCH 5tTctXMjtbC3
zWexHdWWvXFZZochYhleIf5jyI4aQc+vxk+pJ+ZOpzvrKtOgwJWrWbhip4jX 0IPBH+kEEa+v
I0v4HX/JD82i2wd9QsW18BFRxVFcchrYmqadONnZgkBjEZjbk/GpUAEPyCVB PqARYfI0v4HX
/JD82nkaX8Dr/kh+bSi1Zq7SwVemaaxXZa/jVpljsZCxMEavIJYendz0Cuqn qvAPHBBHpr8y
Wz9u5HLHKW6czWTZgtsFuTJG88JQxSNGrhGdfDQdiOSFAPI9NWfyNL+B1/yQ /Np5Gl/A6/5I
fm03TZW325SgvWspiTLSyM3eRSbE5qmZlK+JJWWRY3PyJ+RPHzB9RDYDYNOv gIcXmpY7ZrSu
aj4+S3U8vEyKhhQtZkdU4X7xXCccfAOOTffI0v4HX/JD82nkaX8Dr/kh+bSl tEY7EYvHXGt0
aaV5WqQUvuZIUQQmQxIF+9AXxZPkPw+vyHEh31n8jS/gdf8AJD82nkaX8Dr/ AJIfm1ZuU2Qe
68bLmcK1KvLVinWxBZhktQPNGkkMySoxRJI2bhkB47gc8c8jkGv4jY6G5n7m 42xN6xnPKmzJ
jqdikzNXJMbEmxJwykqVZOhBHPJPHF88jS/gdf8AJD82nkaX8Dr/AJIfm1Ft UpNjbXkwGTwc
2Plmo5Swtq6styZ3mlURgOZC5cMPCj9QR6rz8yedrMbaxN+vkR5SBZ71KKmz v3KBIWkaH4VZ
eOjyuwKlW9R8Q4BFj8jS/gdf8kPzaeRpfwOv+SH5tNy1E2/sDH0sVZq5W1Pf sWcn7zaxDPPA
8c3grCDG/itKv3NOCTISezcng8ak6Oztu0Uxy0qk9f3bLNLWaK7MrKZpfFlD MH5dXcBijcqe
B6cAas7UqCRvI1SsqIpZ2MagKB8yT+Aa/fI0v4HX/JD82m6WgMLt3EYa29jG xWoOysoh85M0
EYZgxCQsxjj9R/mqNTHfWfyNL+B1/wAkPzaeRpfwOv8Akh+bTctFZrGVMvWS vca2qxyCRGrW
5a7huCPv4mVuOCfTnjUdJtLb746nQWpPBHSZ3ryV7k0M6NISZD4yMJCXJJbl viPqeTqzeRpf
wOv+SH5tPI0v4HX/ACQ/NpubOcb59n0u4JFiqXsdXpHHLj54rcFyZ54lLcLI 8VuLxFAY8dwx
BLHty2rlDisbE2TK1UYZWXxbquS6zN4SQ+oPI48ONF4Hp6fLkkmV8jS/gdf8 kPzaeRpfwOv+
SH5tFvqrVXaeDr0TRWK7LW8avOsU+RsTLG8EiyxdA7noFdVPVeAeACCPTUnR oU6Vq/Zqw+HL
kLAs2m7E+JIIkiDcE+nwRIOBwPTn5kkyXkaX8Dr/AJIfm08jS/gdf8kPzau6 bMHfVazOHz53
HNmdv5TC0JLFSGtYN3FzWncRPKycFbMagDxn9OvPqeSRwBbPI0v4HX/JD82n kaX8Dr/kh+bU
3EG238M2Es4VqQNCzNNPLEZG9ZJZWmdw3PKnxGLAgjqeOvHA4jV2jTr5HCzY +U16+NvzZCVJ
C881qd68kAZ5ncseElbnt2J4QAgLwbd5Gl/A6/5Ifm1+NSoKFLVKy926rzGv xHgngfy8An/V
qxcGyu43a+Dxzz+VrTCGeN4nqvblkrBHPLKsDMY0B/Eqj8Xy1jj2hgUxM+K8 O/JTmMR8OXJW
ZPCMTB4zEWkJi6sAR0K8FR+IcWfyNL+B1/yQ/Np5Gl/A6/5Ifm1KW2nVjStW irxtKyRIEUyS
NI5AHA7MxLMfxkkk/hOsvfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03S3N6ex80sGH x93JbXsYvF1/
JRV0wllG8o0YieHu11uQ0YA+MOOQrEEqNTtPZO2qpmZKdmV52qNJJYvzzOxq ymav8TuT8Dkn
jn1+R5Hpq1GlQEhjNSsHChivhrzweeDx+I8H/YdfvkaX8Dr/AJIfm03NkbRo U6Vq/Zqw+HLk
LAs2m7E+JIIkiDcE+nwRIOBwPTn5kk7ffWfyNL+B1/yQ/Np5Gl/A6/5Ifm03 LVPM4fPncc2Z
2/lMLQksVIa1g3cXNadxE8rJwVsxqAPGf068+p5JHAGextPATVooPKzwiKzY tRyV7c0MqSTy
NJMVkRg4DM7EqDx8hxwBxZfI0v4HX/JD82nkaX8Dr/kh+bTctXZ9r4KeGzFP SaUWaUFGYvPI
zNFAztEOxbkMrSOwcHtyQeeQOMWI2ht7F3Vu1Kc3mVsva8Wa3NMxmeJIWkJk Y8sY41Xk/Ic8
ffNzZ/I0v4HX/JD82nkaX8Dr/kh+bTctV8ns7b2SNsWqtkpdleW1FHenijnZ kSNg6I4VlKxo
CpBU+vpyzc7cmAxcmfjzkqWZbsTF4u9yZoo3MZjLLEW8NW6Fl7BQeGb19TzO NSoKFLVKy926
rzGvxHgngfy8An/Vr98jS/gdf8kPzau5srEez9vxw4qBK1kVsTFXhp1/PT+C iwEGHtH36uyk
AhnBPIB59Brfw+Hx+InuS49JovOTNPNGbMjx+IzMzMiMxVCzOzHqByTyedTH kaX8Dr/kh+bT
yNL+B1/yQ/NqbmzB31C70xl7Obes4ilax0CW0aC0L1OSxHJA6MroFjliYE8j 4u3p6+nryLD5
Gl/A6/5Ifm08jS/gdf8AJD82m625nU2RuWrbw9uDM7TSfC1DTx7+4LR8GEqq lfW/8XooHLck
evr6nm4Y/b+HoXortSn4diHzfhv4rnjzU6zz+hPHxSKrfyccDgemps0qAkMZ qVg4UMV8NeeD
zwePxHg/7Dr98jS/gdf8kPzau6bKfkNgbSvYitibGMlFKtjxjEiiuTxdqoXq InKODIoHy7k8
Ekj1JOt+3tjBW84uZnps1wPHIeJ5BG8kf3jvEG6O6+nDMpI4HB9BxYfI0v4H X/JD82nkaX8D
r/kh+bU3LVe1sza9q3NbsYmN558jDk5HMj8mzCAI3+fpwB96PhPJ5B5PNh76 zihSJAFKuSfk
PCH5tfK06DAlatZuGKniNfQg8Ef6QQRpVFsXfVK29tXN0H2/Vv5Tb9jF4Hjy NeribEMkXWu8
CcSPbk54SRh8StyCfkeGF88jS/gdf8kPzaeRpfwOv+SH5tNzZVV2Ztxad+iK lryV+rNUnqef
n8ARS/3xUj79IufxoFI/BxrBV2Vil3RlNwXTJbsXcjFeijMkiRxNHXhhQMgb pIVMRdWZeVLe
nqOTcfI0v4HX/JD82vxqVBI3kapWVEUs7GNQFA+ZJ/ANWLg2lh76d9Z/I0v4 HX/JD82nkaX8
Dr/kh+bU3LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/wAk PzaeRpfwOv8A
kh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/JD82nk aX8Dr/kh+bTc
tg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/ACQ/Np5Gl/A6 /wCSH5tNy2Dv
p31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5 tNy2Dvp31n8j
S/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8AJD82nkaX8Dr/AJIfm03L YO+nfWfyNL+B
1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfW fyNL+B1/yQ/N
p5Gl/A6/5Ifm03LYO+nfWfyNL+B1/wAkPzaeRpfwOv8Akh+bTctg76d9Z/I0 v4HX/JD82nka
X8Dr/kh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/J D82nkaX8Dr/k
h+bTctg76d9Z/I0v4HX/ACQ/Np5Gl/A6/wCSH5tNy2Dvp31n8jS/gdf8kPza eRpfwOv+SH5t
Ny2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8kPzaeRpfwO v+SH5tNy2Dvp
31n8jS/gdf8AJD82nkaX8Dr/AJIfm03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5I fm03LYO+nfWf
yNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LY O+nfWfyNL+B1
/wAkPzaeRpfwOv8Akh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d 9Z/I0v4HX/JD
82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v 4HX/ACQ/Np5G
l/A6/wCSH5tNy2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf 8kPzaeRpfwOv
+SH5tNy2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8AJD82 nkaX8Dr/AJIf
m03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/yQ/Np5Gl/ A6/5Ifm03LYO
+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/wAkPzay+7sfGOZa Vdm/AgRfT/T6
f8NNy2n30762zWqfgo0wPxeXT82vzy1T+BU/s6fm1S2r30762vLVP4FT+zp+ bTy1T+BU/s6f
m0LavfTvra8tU/gVP7On5tPLVP4FT+zp+bQtq99O+try1T+BU/s6fm08tU/g VP7On5tC2r30
762vLVP4FT+zp+bTy1T+BU/s6fm0LavfTvra8tU/gVP7On5tPLVP4FT+zp+b Qtq99O+try1T
+BU/s6fm08tU/gVP7On5tC2r30762vLVP4FT+zp+bTy1T+BU/s6fm0LavfTv ra8tU/gVP7On
5tPLVP4FT+zp+bQtq99O+try1T+BU/s6fm08tU/gVP7On5tC2Kq3Mh/0a8Ge 0X9sHcf9K2v7
Vte+kigjPMVevGflzHEqn/aBrwL7Rf2wdx/0ra/tW0ge3fZr+1rtT+g6P/Tx 6lj/AJRWv5lW
/wDWTUT7Nf2tdqf0HR/6ePUsf8orX8yrf+smkpDFm8vQwtVLWRlkjieQRqUh eU9iCfkgJ+QP
r8tasO5sVYpG1V85OPkka05RJK3BPVVZQSeAT/oBJ4A51+7ip0shbwtO/Ugt wSXyDHNGHUkQ
TEeh9Pwak22tt1cdYonC0Y6k6dZI44AgP4uOvBB/ER6g/L11vLRPAymNso/L k4zlxI4sRtp/
VioXBZMsTxtDZgYrLEwI49SAy8gdkPU9W44PH4CCBtap2c2TtjdWFzu1s7h4 bFGS74kqEnus
zwxuZVbnlX5c8EH0Hp8vTVX9insF2b7MLc+Sp+LlsvI7CK9cRe8ERJ4RAPRT x6FvmfX5A8a8
3pss8uFE8Tm9PEiIy+zydZ1hMrmboiIR36cs5Hr17fiP4NZtR08nWWYhupWY FfTn1KKOP+Ou
8MN2VpkZAEiPc8D7ofnxz+L+Q6+onEkSSAcBlBH+vUfFO7zqsrjlfiAHX19O PmGP49blE80Y
D/8Ac1/9NJGbXwWfoXCBgDxwD6/Pj5a+LrdYOeSB3UHg8ehYA60ZYldQnwFR yAWIY8ck+vZT
pECSRg6hhyOfxjg6zVv8Ij/8Y/8AXUdWbi0B2PLq7MO5I+Y445+Xz/BqRrf4 RH/4x/66CNwn
+Byfzqx/bPqK3tvHB7Vxlua9kaIvRVWsQUJLSxzWCAeqqvqx7MOoIB9efxal cJ/gcn86sf2z
6qXtjr5lsCk2EvA3XtVoqtGWBZFaUTBvFj6jxBIigufVl6Rvyh9WDGLpnizM YzMc1mw2fxmY
u2K+MnFpa8MMrzxkNH917FU5B+/CqGKkDgOh/DqV1wLK5DbmVtYyrt3DQy5M 3IuKBkaKyZ0b
rJ5gjmRJUHiN4/qyEOefU97X7UvY9t32p7TqVs/RlxOapxeDWvpN5iaHqSOD ITzNGfvh34Yh
uT0YkCYzqi6px4HH92J+HUtfhIAJJ4A1UPZT7ONr+zXbq4fbdIIW4Nm3Jw09 lx/nO3+3gDgD
n0Gp3ddazd2tlqdL/Cp6U0UPrx8bIQvr+D1I0l3ymYxmVbn33ZsVp7+DwRvY 2Bwj2p7JhUk8
9SoCOep49CePwfLkczW0tzU9wxTCKGWtar9fHgk4JUNzwwI9GU8Hg/yHkDXO vYvueltn2eZ2
7uWRJFa0Ioq3X4pyY+PDCkev4efwD151r+xmGXN7pzVizjK0WKkpywy0x2ki CysnWM9+e3wp
Jzz+6+QBA14eFxeJrxubienZ8vg+ryyyw+1ero7Vprh+D/8AZh9m2L9oku6R Wms0uRJWw8/D
VoJeeS3r6uvy4RvQevPI4A7eAAAAAAPQAa976qv5fcckObbCYjHe8sikHjyR mYRqi8c8c8MS
3HrwB+Efj1+bQ3VW3A09fwDVuQeskJfuCOeOQeBz6+h5AI/F66rGZx2X217T 7e96OPuZaK1S
MSV4AW6TdFQBgOSF+EHkA/h1Utq7lt4rcec3PnJEnveUeWxWPaHpy55QAIQp HgcfH1Hr6tyH
C+KeLlhxPtTt51ef02HqvU8f2+FjM1M3ttEdJt3bTXMPa17Ltl+2fbcM9ljD djVkpZWCPiWL
hiCjA8dk7BuUPHB544Prqf8AZT7ONr+zXbq4fbdIIW4Nm3Jw09lx/nO3+3gD gDn0GvZExMXD
05YzjM45RUws2b/ydy38yk/9NbWtXN/5O5b+ZSf+mtrTqdHxNIsS8sQCeeoJ 47EAngf6gdVv
bW7TmcDRygxFuNp4RNPFEjy+ArMAo5C/ExDq/XgHpy34u2nkrVmnBm4qV26M hJkVq15ei2GR
HijlZFjeRF6/E3yPIABPovIhfcuPx+1qGPXB5Fjj4liltWJaq+JCJBI4ceIR wCO6g+gKgElS
4ZxOFxs+BPsReWqI67RW99O3dzjiY48WI4k1jXxzdKhkjmiSaGRZI3UMjqeQ wPqCD+Ea/LU8
VatLZnfpFEhd2454UDkn0/k1805/M04bPhSw+LGr+HKvV05HPDD8BH4RqK36 bC7JzT1ZYopF
pSt2kjLjqFJYcBh6leQDz6Eg8HjgzK8Yl1wiMsoh8jdeJOQjpr5wl4Wl8Q1Z Ao4ZFC+oBLMX
HUAHngj58A72NyItuYZq81SfqJFimQqWQhTyOQOSOyhgPvW9D+AnmkyZtt3U g2exUkbY2ZX7
0yyspMYKEd/Xken4vQ+h55Fy9mtasmCe5CkfaeZ4y4X4ukJMSqWJPYKE4Hy9 Pny3Zm+fwePx
uLxYiKrr55+L18bgYcPC4WjUBn9147E3hjxBcyF7oHatTjDuin5FuSAOfwcn k6n9clqX8pTv
b7xFTI1MbuKe8s9GWy4jMsBbngOTx95wB6j8X4Dx7s8piNnyfU8aeHEV1/Zf qm4o54xO+Ov1
qyt0mlmi9IW+L5leV6r0IZueFJUH/O6zmuS7UOQt+0ClTytzH52zHAlq7ZrK CkTRxskYcgES
SKW4D8+vJ+fUFdL2of8As47C33vGtuWdbGMnabxMlHT4Vb4+fxfuHJ45cepH PPqQw5ennizq
9yue3nn3u3C42HFwicL+b7uz61cp/fMT/PX/ALB9Ytv4bFbfw9bD4WhBQoVU 6QwQp1VB/wDN
P4ST6k+p1lyn98xP89f+wfXobbWoCPLWLmQuw1bkESVioKCn5t/V5U9RBOXA 5hc8sij1A9WV
gs/qlPL5qfKQFzc8KRD4XbzHT7vbHPTtZ6/Ljnwo/veOfh8OPtwuDjxbjL9n Li8SeHUwncfd
uPlIa806TRSwzP642ao6tG0Q+UjEsCJPmBx6fP56mNUrac+P+k4xtCRJLFGG 2MgsNcLHBI0k
CqvZIYlYkRMflz8J9SANXXXDTGOWUYzcXt16fu3w+JHEwjKGqf8AKK1/Mq3/ AKyazzSRwxPL
LIscaKWd2PAUD5kn8A1gP+UVr+ZVv/WTUZu23DUkw8ll1WA3yZO7cL8EE0gJ /B8LIrA/gKg/
g1y4/F9nhzn2duHhryjFWrntVw0O5JcTFEk8cMhSWZbA5AH3zheOOo9TyWHo CfxauGGzuLzD
SpQss8kQBeOSJ4nAJIB6uAeCQfXjj0OuY7m2XDnL1/LYup7unvcOHlvFCW7B jI0fgswLFeeO
4PryQrcgSHsf2pfxWdyGTu3fMRpB5WJo5GeN2LgycFgDypRR6DjksOeQQOf+ 5em4/Eww9P23
583Pj8H1XCzj7H2Os3H7/wBnUNNNQO4RmLkM3uuF3o1lJsPBKyzSMD6onA5P Xjk9TyT6Dkgq
e3E4uOFX15NY4zk+8jnTFkEo0YIrUx79u8xQDqOSAQrc8cgEnhQWUE8sAZPG W0v42rejHCWI
UlUc8+jAEf8ArqjbDktZnzVATN7mqlCjAks5bsTGH/COOrH15AcfgI4v8aJG ioiqqKAFVRwA
PxDXn9NPqJzy93l0/wAfH39bduNHDiI08/P1a+U/vmJ/nr/2D6y2ZhBA0pRn I4CovHLMTwAO
eBySQPUgaxZT++Yn+ev/AGD6w7gkMWMMwB4jmidj+5USKWJ/kABJP4hr0cXK cMMso6R/Zywx
1ZRDM1ixBL0s1W6kEh66ySgEceh+AHk8+nAPyPPHpzkr2Yp2ZULh1ALI6MjA Hng8MAeDwfX+
Q/i1FRZZr7xQ0byAOJGaWNlYjp0+AEhgCTIp5IPABHHryPmuhtXJaebq1J5L 1Dw5kR/FhlSM
8OGRlHAbxvvfiBHI9OPX53pfXzxcsccp5/m9PF9PoiZ7J3TXD8H/AOzD7NsX 7RJd0itNZpci
Sth5+GrQS88lvX1dflwjeg9eeRwB28AAAAAAegA19Z42sf8AKK1/Mq3/AKya 2j6Dk61T/lFa
/mVb/wBZNfGcjty4izHQcpZZCIyGCnn/AEkH/wDL8I+YuGOrKIuiVT3l7UNu 7UyMNPKVskfF
AZZYYVZep/z+CwYr8xyFI9Dq3YfJUcxjIMnjLKWalhe8UqfJhryfv24lTdGR gzsFhrAk5WWV
WYPH1HXqfF+QXgccDjj5DXdP/Z6oXKWxFkngkrVrUzT1oXBUqp9CepLEduOf vvXn5D1LfX9f
6Dg+n4UZY5XP9WYymZqqdLrf4RH/AOMf+uo3Cf4HJ/OrH9s+pKt/hEf/AIx/ 66jcJ/gcn86s
f2z6+M0y5G5DRqmeYO3LKiIg5aR2PCqo/CSSB/68DUDb3Pap41crYxUb0fiM hr2xLLEA3Xhl
6he3IPw9vwNxyQRrZ3wbsGMgyNBGeajZWcqF5JXqyt/wYnn+TXCt1byuZOSz USCEwT2ROrRD
79iT1UKvqG9SOB6N2/CdejhcHPLTOON43WU9vn/Lw8fjZxnlhjNTVx2nztFT 1ejMfbrX6UN2
nMs1eZA8ci/JgdfGb/ydy38yk/8ATUL7MsbcxGxcXQyCsllI2Z0bjlO7s4U8 fhAYD/Vqazf+
TuW/mUn/AKa4ZVc1ye7G9rbWsDSv3cjr0SRYyvHqeevrzz6fffi/BrPrQELK jQANJ2bt4pYn
5cepPPPI4HoPn/J68QbvYenIYcngcgj/APL5a+ta/HVoV5Y8MB2b5nhT6k8f PUVltrYzI30t
yK8TduZVj9BL/p/Ef5R/+PSVhO6xzOyAdE7seeF545PBPHP+rSCGGvCsMESR RIOFRRwANY7r
OoQ9VaIsFcE8E8kAfg9R6+o0R9wTd4EkkiMbMOxXxFPA59PXn/8ALnX2jdgT +JiP9hI1rJKx
mmC9UjB447nktwDyB6cfP19fn/r5+bFOtkKMle3EskbO/ofwHsfUfiOg3dNQ +A27j8OWkiBm
nYniWQDlR+Ifi/0/h/4amNIWUYM/hPOy0/elQTRL2cGQAD1lBHPyJHgTcgHl fDbkDW5QtwXa
wsVy5jLMnxxsjBlYqwKsAQQQR6j8Gqc+26OI9oR3RZksSC11UO/Up4xY/BIO vAHArCMjj4oF
5bs3x7TX9vvPYaKruBubEviGqMgYvE7t4nHh/D9/2549OedfN9V9Rx4PG9vG L2+f025O/B9P
lnhqmFu01qYY3DiKRyI4u+Xj8wPT0k6jt976fPn5emsWerz2KiCGMWI0kDz1 SQPMx8HmPk+g
9SDwfRuvViFYke7LiTHD1xH4dXKMY1aZl9Y/JwXbc0EMcoWONJUlYAJMjlwG T15I5RvUgcjg
jkEE72qxeyeJzGQ4Xa/vyaKBGaUwQExKXkUIfGZWBDI/K8eh554OtTK7Jwu7 trZLA7nwMS4q
5Y8SvRbqGqARqvZOhKxt2DsCh/z/AF9Sw14vR+sz401ONxvvvX9K+Ocu3G4M YRd1Pbz9ly01
yb2KewXZvswtz5Kn4uWy8jsIr1xF7wREnhEA9FPHoW+Z9fkDxrrOvovMaxwT LMgYBl5Abhvn
wfkdaxjAZvFoeOxYnvwh5BPp8zz6Dgf6tfUcq2BCYF6hQD2446KeD1/1j8H4 Pn+LkNvTUFlt
rYzI30tyK8TduZVj9BL/AKfxH+Uf/j1MwQw14VhgiSKJBwqKOABpurJpppoh pppoGmmmgaaa
aBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpp poGmmmgaaaaB
pppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmvuJO78E8KPVj+IaD6j+5J4p++ Pog/+brFr7mf
u3oOFA4A/k18aoaaaag18jcr4/H2b9uQx1q0TTTOFLdUUEseByT6A+g9dQ1D eWBvOVryZD0H
zkxlmMEkgAAtGASSQAPmSQBrY3x0+hWd8RQye7rHYEcgjw251FYnbmNTcFwY 3Y2GqcUYOyTr
FCeHaYEjwlcEMBweSPl8tdcPbnHKJvV07deblxJ4kZRpquvdP43Ii25hmrzV J+okWKZCpZCF
PI5A5I7KGA+9b0P4Cd/Vb2Vj48dZzdXy8UUsF1IT1kMhEYrwtGncqpYKr8Dk f6eSSxsmvJ6f
3Pbj3eb0Z6b+zyNNNNdmDTTTQNNNNA0000DTTTQNNNNBA763PV2fgGzuQx+S t4+CRRckpQiU
1IT99YdOQxjT5t0DMByepAJGptTfmC3Hn8hgqrTV8hUjS1FHOU4vU348O5Wd GZZYG547A8qf
RgpIBkd27Zwm68bFjNw0vP0UsR2TWeV1ileNuyiRFIEqc8Ho4ZSQCQeBpgds 4TB5LL5PG0vD
vZiwLOQsySvLLO4XqoLuSQij0VAQqAkKBydUTGvAXtF/bB3H/Str+1bXv3Xg L2i/tg7j/pW1
/atpA9u+zX9rXan9B0f+nj1JwyCbO3JUSUIteCLs8TKCymTkDkDn5j1Hp66j PZr+1rtT+g6P
/Tx6m7ViCrCZrMyQxr82duBqSQxZChWvLCLAl5hk8WNopniZW4K8hkIPyYj5 /h1926y2oFhl
mtgL8mjtSRuP/qlYN/x1r+9qn73d+xTfo6e9qn73d+xTfo6zOOOXOF3hlx1C tQWUV/HJmk8S
R5p3mdm6heSzkn5Ko+f4NbWtD3tU/e7v2Kb9HT3tU/e7v2Kb9HV2Klv61LFF JpGfxZU7EMQv
HBI44PqD+Iax+9qn73d+xTfo6e9qn73d+xTfo6tlP33cnieJ5mft+P4f5P8A 4P8AINbcMYih
SJSSEUKOfn6a0/e1T97u/Ypv0dPe1T97u/Ypv0dLKbc8STwtFIOUYcEa0Pcl X98m/wDwfzay
e9qn73d+xTfo6e9qn73d+xTfo6WUyUaEFNmaPszMOOW4+X+oa3EkWFhK/bqh 7N1UseB+ID1P
+gaj/e1T97u/Ypv0dPe1T97u/Ypv0dLKfuD7eQLMjp3nmcB0KngyuQeD6j0I Ot7Wh72qfvd3
7FN+jp72qfvd37FN+jqXBT8wOHpYama9RCWd3lnmcDxJpHdnd2IAHJd2PAAA 54AA4GpDWh72
qfvd37FN+jr8kzNKONpJBbRFBLM1OYAAfhPw6twkQkNNRtfN4+zEJa5tTRn0 DR1JWH+0LrJ7
0rfvV77DN+jpcLUorMbH2tlrr3LmKXx35MjwzSQlyfmW8Nl7H+U8nUxicZj8 TSWnjacNWBTz
0jXgE/hJ/Gf5T66+Pelb96vfYZv0dPelb96vfYZv0dZiMYm4c8eDhjlqxxiJ +5vaa0felb96
vfYZv0dPelb96vfYZv0dauHSm9rnGb9je0svmbWVsyX1sWZ2sP0MXCux5JXt GSPX+X8A/ENX
n3pW/er32Gb9HT3pW/er32Gb9HWM8MM/4nfgep43p5meFlVsW1sJS23gKuEx 3ieVqqRH3IJ9
WLH5AD5k/IDUnrR96Vv3q99hm/R18yZenHG0ki3ERQWZmpTAAD5knrrUVEVD lnllnlOWW8y+
89IFwV+IJK7z13ijWOJnJYj0Hwg8f6T6a3daPvSt+9XvsM36OnvSt+9XvsM3 6Ols0i8ntOrc
zE2ViyWRpTzKBIIGjKkgAdgJEbqSFQHrwD0XkcjX3j9sQVrcdizk8hkBGQ6R WTF0VweQ3CIv
JHzHPIB4PHIBEj70rfvV77DN+jp70rfvV77DN+jr0R6riRjo1bOc8HGZ1Vu3 tfMiJLG0ciK6
OCrKw5BB+YI1p+9K371e+wzfo6e9K371e+wzfo689w6bo9tmbSa0lk7axPdE ZABVQLwxUnle
OpPwjgkcj1445PMzUrV6dZK1SvFXgjHCRxIFVR+IAeg1re9K371e+wzfo6e9 K371e+wzfo6k
RjHJqcssuct7UPuHbOC3AYzl8dHYeL0SQMyOo/F2Ug8fyc8a2velb96vfYZv 0dPelb96vfYZ
v0dWanm55YRlFZRcMeAwWJwNVq2Jox1Y3PZ+vJZz+NmPJb/WdSWtH3pW/er3 2Gb9HT3pW/er
32Gb9HSKgxxjGKiNm9rSyMge5jIESVmjsPK5ETdVUxOvJbjj5/g551+e9K37 1e+wzfo6e9K3
71e+wzfo6W1Te1G3MNUt2XsS2MmjvxyIcnYiQcDj0VHCj/UP5dZPelb96vfY Zv0dPelb96vf
YZv0dLhKfuHxdDE1nr0IPCSSVppCzs7ySMeWdmYlmY/jJJ4AHyA1u60felb9 6vfYZv0dPelb
96vfYZv0dLgjGoqIfsMgmztyVElCLXgi7PEygspk5A5A5+Y9R6euvzNYnH5m otXI1xNGkiyx
kMyPG6/JlZSGU/P1BB4JHyJ096Vv3q99hm/R096Vv3q99hm/R1JjHKKy3hqJ mJuEd9EML+PK
/wBb2v1mpyCKKCFIII0iijUIiIoCqoHAAA+QGtT3pW/er32Gb9HT3pW/er32 Gb9HWOHweFwv
4MYj7oprPiZ5/wAUzLe19LI6wGBWKxnkkD0+Z5PrqP8Aelb96vfYZv0dPelb 96vfYZv0dbyx
xyisotjdlxdCnjMfDQoV0r1oF6xxp8gP/mkn1JPqSSTrZ1o+9K371e+wzfo6 e9K371e+wzfo
6u0G8v3IyB7mMgRJWaOw8rkRN1VTE68luOPn+DnnW7rR96Vv3q99hm/R096V v3q99hm/R0sp
kv0Kt4J5hHJTnqySNGw5+Y7KQeDwPT5eg/ENfFDF0qUrSwJIZCvXvLM8hA/C AWJ4B4HPHz4H
4hr896Vv3q99hm/R096Vv3q99hm/R1j2+Hq11F9+rWrOtN7N7TWj70rfvV77 DN+jp70rfvV7
7DN+jrpcM0/YZBNnbkqJKEWvBF2eJlBZTJyByBz8x6j09dbutH3pW/er32Gb 9HT3pW/er32G
b9HUsp8XsDg79tLd7DY61YjPKSzVUd1P4wSOR8tSOtH3pW/er32Gb9HT3pW/ er32Gb9HWpyv
nJTfSRYWEr9uqHs3VSx4H4gPU/6BrQwfbyBZkdO88zgOhU8GVyDwfUehB096 Vv3q99hm/R09
6Vv3q99hm/R1mym9qPhwmGhvnIQ4jHx3CeTYSsgkP/1QHP4Tr9GWqFiojukg AkeSm9OeeP8A
N/kP+zX770rfvV77DN+jpsU3taWekC4K/EEld567xRrHEzksR6D4QeP9J9Nf nvSt+9XvsM36
OnvSt+9XvsM36OllN7WuKVbx1nMYaVeeGPzAJJI/4nWH3pW/er32Gb9HT3pW /er32Gb9HVsp
tGJOysBwVPI4/wBBH/zdZNaPvSt+9XvsM36OnvSt+9XvsM36OllN7XxNGssZ RuQPQgj5gg8g
/wC3Wp70rfvV77DN+jp70rfvV77DN+jpcFNqCIQqQGZix5Zm+ZPy/B6fIDWT Wj70rfvV77DN
+jp70rfvV77DN+jpcFN7TWj70rfvV77DN+jp70rfvV77DN+jpcFNueKKeCSC eNJYpFKOjqGV
lI4IIPzBH4NYMXQq4yktOmjpCrMwDyM7EsxZiWYkkkkn1P4dY/elb96vfYZv 0dbNWxBahE1a
ZJo2+TI3I1nTjOWqt1uaroy6awW7VeogaxKqdj1UfNmP4lA9Sf5BrB70rfvV 77DN+jrVpTYi
qVYbM9qKtDHPY6+NKqAPJ1HC9j8zwPQc/LWbWj70rfvV77DN+jp70rfvV77D N+jqRUciblva
a0felb96vfYZv0dPelb96vfYZv0dW4Kb2vmNEjQJGioo+QUcAa0/elb96vfY Zv0dPelb96vf
YZv0dLgpvaa0felb96vfYZv0dPelb96vfYZv0dLgpvaa0felb96vfYZv0dPe lb96vfYZv0dL
gpvaa0felb96vfYZv0dPelb96vfYZv0dLgpvaa0felb96vfYZv0dPelb96vf YZv0dLgpvaa0
felb96vfYZv0dPelb96vfYZv0dLgpvaajZ85j4Cgma1EZG6p3qSjsfxDlfU6 2PPJ/Bcl/V8/
6GllNrTWr55P4Lkv6vn/AENPPJ/Bcl/V8/6Gg2tNavnk/guS/q+f9DTzyfwX Jf1fP+hoNrTW
r55P4Lkv6vn/AENPPJ/Bcl/V8/6Gg2tNavnk/guS/q+f9DTzyfwXJf1fP+ho NrTWr55P4Lkv
6vn/AENPPJ/Bcl/V8/6Gg2tNavnk/guS/q+f9DWrBn8ZPK8UEliWSM8OqVZS V/0gL6aXBSU0
1o+9K371e+wzfo6e9K371e+wzfo6XBTe01o+9K371e+wzfo6e9K371e+wzfo 6XBTe01o+9K3
71e+wzfo6e9K371e+wzfo6XBTe01o+9Kv71e+wzfoae9Kv71e+xTfoaXBTe0 1pe9Kv71e+xT
foae9an7zf8AsU36GlwU3dNaXvWp+83/ALFN+hp71qfvN/7FN+hpcFN3TWl7 1qfvN/7FN+hp
71p/vN/7FN+hpcFN3TWl71p/vN/7FN+hr9960/3m/wDY5v0NLgqW5prT960/ 3nIfY5v0NPet
P94yH2Ob9DS4Kluaa0/etL94yH2Ob9DT3rS/eMh9jm/Q0uCpbmmtP3rS/eMh 9jm/Q1++9aX7
xkPsc36GlwVLb01qe9aP7xkPsk36GnvWj/B8j9km/Q0uCpbemtT3rR/g+R+y S/oae9aP8HyP
2SX9DS4Klt6a1PetD+D5H7JL+r0960P4Pkfskv6vS4Klt6a1fe1D+D5H7JL+ r097Y/8Ag2R+
yy/q9LgqW2is7dVHJ1kchI/DUgk/fkfh/k1oNmaxUqsFxFPzAozev+vrrH70 rfvV77DN+jpc
FS3tNaPvSt+9XvsM36OnvSt+9XvsM36OlwU3tNaPvSt+9XvsM36OnvSt+9Xv sM36OlwUz5Cp
Xv0LFC3H4lezE0MqdiOyMCCOR6j0J+WopdrYxZWmW1nFkZVRnGcuAlV5IBPi /Idm4H8p/Hre
96Vv3q99hm/R096Vv3q99hm/R1LhKfuJxdTFpOtTzBNiXxpXnsyTu79VXktI zN96ij5/g1u6
0felb96vfYZv0dPelb96vfYZv0dLhab2mtH3pW/er32Gb9HT3pW/er32Gb9H VuCm9prR96Vv
3q99hm/R096Vv3q99hm/R0uCm9prR96Vv3q99hm/R096Vv3q99hm/R0uCm9p rR96Vv3q99hm
/R096Vv3q99hm/R0uCm9prR96Vv3q99hm/R096Vv3q99hm/R0uCm9prR96Vv 3q99hm/R096V
v3q99hm/R0uCm9prR96Vv3q99hm/R1mqXa1pnSGXmRPv42Uq6/i5U8Ef6xpZ TY14C9ov7YO4
/wClbX9q2vfuvAXtF/bB3H/Str+1bVhHt32a/ta7U/oOj/08epCtF5rLWppT 2FV1ihU/JCUD
Mw/lPcD+Tg+vqRqP9mv7Wu1P6Do/9PHqYw682sof/wBLH9jFp1IY3vY+Nbby 24oUqSCKw8rd
FjYqrAEngeodf9vHz19Y+3RyNfzGPuVrkPPHiQSq688A8cg8fIj/AG6om8Gw SWNx+ezhoXly
dVoYhkGj7AR1SD4QmjBHIIL8ggDnn4RxI+w1aLbOY4+/Ndh8aMd5fmvFeEBf 77J/mhSR2HBJ
HC8ca4ZcXKPURwq2mLd8eFE8GeJ1iaXPw9PD1H5KO1Lk7ENYWTIK0ZiKTdUj YtJ8TDkc/Ifg
Py1kjvTnJRwlVeCWaSFXCdeCoYn/ADiTx1I+9A/+b6HBueHp4etGee3Nt+1e 8WONXqSSRrGp
DxnqSOW5+Y/0D119tdneuJIwivJP4UcRj7OCASQ3xKAeBz8+APx6Db8PTw9a Ve9Ysx1gghik
k8YuzjlfubdSBwfmfn8zxwfnrGuRvzQ1jXqpJI9SOw49ACW59Byw4Hp8/i+Y /wBYSPh6eHrB
mklLUY4ieZLBUqJmj7Dw3PBZfX8AP+rWK/YnxtaD4IyXLIVaVn6n5hyx9So/ DyPTn+T1Dc8P
Tw9abXLSWplY12jhsxQFQpDN3VPX5+nBbn5fIf69fNexZKpBHJGHeW03iTAs AqSkBfmPxj8P
oBoW3vD08PWvRtWblmPoIoojVhnYMpLcv29OeR+5/FrWjyN9sdYvGqixCq88 Zbj0IHIU8MSf
5fReOP5dKLSPh6eHrNBHMI/u7Iz/APwFIA/k9Sdc63ngsBJ7TYcxYMCXRieL +T5SKfb1WDzE
sV6OdgViVpGkieJ+VnXkkGOCdXtJa6WcXVmlM4j8Gwf/AH8R6SfLgeo+Y/kP I9B6a+YLFiCd
KuQKFn/vUyL1WQ8eq8cnq3z9OfUeo/CBTdmYLAR+02bMVzA904nihk+Uln3D Vn8vLLeknUBZ
VWRY4kiThYF4IAjngVOiWasVmBoJ0DxsPUfL/QQfwEfMEfLUnFbY9NacTzU5 1p3XLhzxBYI4
8T/4LficD/aPUfhA3NZDTXAs1Nuo7O3VncZNuKqaUm5TayM2XZoJIY2upAkE XisY3R1g4YJH
wIm4J59eiZXeV6nJnIxHSD0dz4zEV1cNy8NnyPdj8Xq48zNwRwPgHIPB5swL zprnlLeOesbo
xMXOJTF5DcF7EeW8J/NRrWhsnxC/fqez1weOnorr8yeRK5HciWcntXyEN1Ib uakpzC3Vs1HA
Wham5COELDmNR8QZfnwOygrBbtaO4P8AEOQ/msv/ACnXP9qby3jfxGGs2quF t285tSbN0q9e
N4FjmjWvxE7vIwKubK+vC9ep+++ep3AZi7mNn5z3lYikv1DLXsxJj3qGu3gK /hsjSScnhw3Z
WKkMOPkdJjZYXHTTTRDTTTQNNNNA0000DTTTQNNNNA0000DTTTQNNNNA0000 DTTTQNNNNA00
00DTTTQNfKur89WVuDweDzwfxax2GIZEJKxseGYf8B/Jz+P/AFfMjWGR6scr gXRATxygZAB6
AD0I/EBoNzTWKq7SQBmPPqQD+6AJAP8ArHB1l0H4xCqWYgADkk/g0UhlDKQQ RyCPw60PGglg
6z3/AA2deJI+yDqSPUeo5GtosFshYvUNyXX8C/8Awv8AWfwfh+f4DoM2vl2V F7MeBr61gsni
Svzx/fPw/wDhbQZEkVyQOwI+YZSD/sOvvUK1+N38Z64b4unlzBy/y5/Fzzx6 /i/9dSlM8wn8
QdwP5AGIGg/If8Otf/Eof/WXWWR0jRndlVFBLMx4AH4zrFD/AIda/wDiUP8A 6y6xZz/El7+b
Sf8AKdWIuaD3ri/rKn+XX8+tmCWKeISwyJLG3yZGBB/1jVT8/ha3iHLNueSe SxYINKtkJ4wo
ndQOYFZFIC/e+h44PHqOZHbT0nv2WxrZEU5K0Uqx3VnSRXMk4YlJgHXnqD6g c+h9eedeni+n
0Y6nm4XqIzy0p7WjkcnBSljjaOWZmeNXEQB8ISOI1ZuSOAWPA/CeDwCFbje1 U93RTUqcsAsV
loZK5EZnsNDzCe6Fz925Vx0Q8AhmUgAArwI/l+s4vE4XCnLCLe/gYY551K2a aoeE9z43cniU
pnvU4YAZbtZawihZ+/Al8CNT14QkliVBKkgEKwvmnpfU+/jM8pie9nG4XtzE I3c+cxu28Bcz
uYlmix9KPxbMkVeScxoPm3SNWYgfMkDgAEngAnVfve0vbVGAT3ae7KsRkjiD zbSyiKXdwiLy
a/zZ2VQPmSwA9Tq5ar2I2lj8bfgmS1dnqUe3urHzOprYvspV/AUKCOVJVe5b w0Zo4vDjZkPr
cVh1Xc3vLCYjNNhrEeas3krx2ZIsdhLl7w4pGdUZjBE4XsYpAASCep1YtV3N 7NwmXzTZmxJm
q1568daSXHZu5R8SKNnZFYQSoG6mWQgkEjsdAwm8sJl80uGrx5qteevJZjiy OEuUfEijZFdl
M8SBupljBAJI7DW3ufceL25DUkyZuk3bHlq0VOhPblll8N5Oqxwo7nhI3Ynj gBTrUwmzcJiM
0uZryZqzeSvJWjlyObuXvDikZGdVE8rhexijJIAJ6jUB7ZPor5/Y3019y+4P pE/m/e/heU/x
be6d/F+D7/pxz/nccevGnUSn/aFt5Zq8diruamLFiKtHLc2xka8XiyyLHGrS SQKi9ndVBYgc
kanbKeXy9WeI9RZZoplHychCysf5QEI/lBHr6Aa5Vvb/ALAvIYr6Ff8AZl7/ APpFhvKe6PI+
b/xlW79PC+P7zvzx/m88+nOur5L/AAzGfzpv7GXTKKIl84pPGlsXpT3kaaSJ Of8A3aI5XqP9
JUsf9I554Gsa52g1UWljyJgKeIJRjrHQrxz256cccevOs2E/wOT+dWP7Z9co 4u4S7Z3HiIsd
LJJtzHeZbIWI4UjE5WF+OQncdaqcK8yBWLccl+NXhcHPjZacJiNuvfb5jume eOEXMOxxSRyx
JLE6yRuoZHU8hgfkQfwjX1qsezqaSbDzNIkEbF4XaOCXxIUZ6sEjiNuzAr3d iOCQeeeTzzqv
1s1fi9oFmi00s0M28hSVZJpOIYvcC2OqAMBx4ik9WBXlmbjtwwxjq5Zc4/s1 Nc45Oj6a4ptf
fm5sX7K6N65ZxuVsfQSbN1piJGdZa0UQK2GLkyl2kBJHQ8o49fmLfurO7rwy Y6jFYxtrL2or
Fl4YMYWTwYvD7HmS3EqhDIoLFiW7DhRwdamKi5Zib5L5prn+z92bg3XlqJpr jKGOm23jMzKk
sDzTd7ZscxqwdQABCPUg/h9Dz8O3sLduR3JkjTlrVoWxtPw8z0VvgyHishij JPoq+FIx55JW
WEg+p5VvRa66a5Tj/aLnlqVsver4uzSubWv7hipVYnWzF4DQdIGYuwY8TMpI UfEvoBx67Q3d
vqDbdm7dxGPgnkuYuGhNKqCOVbdtIH5SKxKeFVwQ/Ydu33vwnmRus7c3TNNc 5fde6xkosCj4
VsiNzHDy2zUlEJiOMa8JFi8XsGHKrwXIPB+XI6/W3d2bnsXsI2TGIapkc1fw rpXryJIJKotf
dwzSEBWNRvufBIDj4zwebRbommuXY32i5lcMM1kKlC1Bb2zb3BVq1FdJa4g8 M+XlYswd2EoH
YKnDI46n8GtZ3ZuTB5XdFy/bo5ievicL5aGiGjrI9m1ajL9JJSB80LN3XsqL yVHqJ55+S+ef
m61prnMOY3XNkdpx56q2Mnfcs1Z0idUFqAYy1KpeOOaUKO4Hwl29Y1b05AHR tVDTTTUGLZ0S
2zZy83xStK8MQPr4SKeCB/pI5Pp/J68a2F3Vh2qi0vvEwFPEEoxlnoV457c+ Hxxx686xbB/x
E/8AO5/7Q6pmPviLA4x/MqAcbApjkn+AgwKDyhsIvyP7kfj/AJdXHDiZzGOE xG08/wAPlMss
cd8nUIZYp4UmhkSSKRQyOjAqyn1BBHzGvvVX9nLJ5HIxQkCGO2nhorcqvetD I3X4mABZ2b0Y
jlj6n56rt/e24K27MzCDhmxWL3FjsP5XwpPNyrbiqnxO/fqOr2Wbjoeyow9C Ox1hqmPtRvy/
Wv6plUcnStNczx+/c0/tCoYl4ILWEyWWu4uCylMQFJa8c7uAxsu8nUwMhPgo pJ5DccBtTMbi
3RlvYXuTeRyVClBa2xduUa9KGSO3Sk8BmTtP4vBkTjhuqKQ49D6eurR1fTXN Jt85y3gkyGPW
pWuXcucdRxjUTYtI6RyO8UwM8KJKVjL+rBVUehfsp1iwW/twZ7H4CKpHicZe vDKvamuIZIR5
CwK7Kqxy8BnLd+RI4VVb1fjnUmYiLWpunUNNcer+0je+UxWAfA7cq3b9ra9L PXEAjWKRpw3M
SNLYjMSgoeX4m6915X91ft3ZKajn9n1YlBTI5mStKS7rwooW5eeFYBviiX0c Mv4eOwVlqTtN
LHpri1Xfu4Tcxu7b0lWejLsnLZ2HEUvERl6SUmSObl2DyKCyBwq8FpAF+fN7 2Tnczcz2TwWb
mxVuenSp3ktY6J44mWwZh4fVnc8qYCe3b1V19B+FE2sxS3a1MjjMfkQBdqRT FRwrsvxp/wCF
vmv+o6pXtzxOKym28a9/GUs1cpZJbGLwtyBZosra8GaMVmRgR8UckrCT72Eo Jn5SJwazmMBt
XIbkwKWM39IKePzaw++rlqK7LhbdWaGSvjEcDmB5ZOFeaXtLIEWGR3eWAoRf rsFrC/dJZWtY
7kgyMCZIB+DuefiX/wCF8x+Hn1OtkEEAggg+oI1PMAylWAII4IP4dVi9UbBO ZIwWxTH1HzNU
/q/+X/R8ucxTcTba01+AggEEEH1BGv3UDTTTQNNNNA0000DTTTQNNNNA0000 DTTTQNNNNA00
00DTTTQNNNNA0000DTTTQNNNNA0000DTTTQNNNNA0000DTTTQNNNNA0000DT TTQNRG59x4vb
kNSTJm6TdseWrRU6E9uWWXw3k6rHCjueEjdieOAFOpfURufbmL3HDUjyYug0 rHma0tO/PUli
l8N4+yyQujjlJHUjnghjoIn/ALQtvLNXjsVdzUxYsRVo5bm2MjXi8WWRY41a SSBUXs7qoLED
kjVhzeTo4XC3szk5/Ao0K8lmzL0ZukSKWduFBJ4AJ4AJ1Xv+z3bzTV5LFrc1 wV7EVmOK5ufI
2IvFikWSNmjknZG6uisAwI5A18+239pjfH/l2/8A9NJq7D7+n+F+qd5//edl f/1bUg+Qo5ja
1Xc2IseLBJUW/SsBGUyQsgcejAEBl49CPTkEjkaqf/5rH/7mf/5brb9mX/7P W2P/ACnU/wCk
TTKKgxndfdeAvaL+2DuP+lbX9q2vfuvAXtF/bB3H/Str+1bSB7d9mv7Wu1P6 Do/9PHqe2+va
fKH/APTB/YxagfZr+1rtT+g6P/Tx6se2uokypb+Gj+wi0jmdHxY2/QsR5CKw J3S9ZjsygStG
VdFjVSrJwy8eEh+fPPP+jX1t/A43A0jTxcEkMBYMVeZ5D6IqD1ck8BUUAfIA ame0f4/+GnaP
8f8Aw1ZwxnLVW/cjPKMdN7NUQIJDIEUOwCluPUgc8Dn/AFn/AGnWMUKgseYF WETc8+IIx254
455+fyPGt7tH+P8A4ado/wAf/DWmWh7vp9pH8pB2lBWQ+GOXB+YP4wdfstGr N38WtDJ347dk
B7cfLn8fGsW59wYTbOGlzOdvx0cfC8UcliQHqhkkWNOeAeAWdRz8hzyeACdS KSwyIro4ZWHK
sPUEfjGlQXKOt4utPVWuqLCit2UJGh4PrzwGBA+ZPPz19e7KRrw13qxSRwqF jEiBuoA4/D/o
1I9o/wAf/DURPujbUEkkdjN0YZI3ZHjlmCOpUkHlT6/g/wBY9R6HWOJxeHw4 vPKI++Vxxyy5
Q27FOvZQJYgjmUHsBIgYA/j9f9J1+JSrIoVK0SqFKgBAAFPqR/oOsuPvUshU S3TmE0D89HAP
DcEgkc/Mcj5/h+Y1sdo/x/8ADWsZxyiJibiUm4mpRsGLqQ2HsLAhkZwwJQcp wirwvp6DhR/x
1kko1ZY/CkrQunYv1aMEdiSSePx8k/7db3aP8f8Aw07R/j/4ao1RBGHLhFDk BSwHqQOeB/q5
P+06xe76faRvKQdpQVkPhjlwfmD+PnW/2j/H/wANO0f4/wDhoNfw/wCTUDkd mbfyG54tyXKc
8uQjjhi/wyYQSCF3khMkAfwpGjeR3RnUlWIZSCARZu0f4/8Ahp2j/H/w0FZx 2zNv4/c8u5Kd
OeLISRzRf4ZMYIxM6STGOAv4UbSPGjuyKCzAsxJJJnvD/k1sdo/x/wDDTtH+ P/hoNK1UhtV3
rzxh43HqD6f6CD+Ag+oI9QdQztNjZBXvF3iJAitdfRgTwA5A4VuSByeA3I49 eQLN2j/H/wAN
fEqwSxPFKqvG6lWVl5DA/MEfhGpMWsSrjYzGtjrGNbH1DSs+L49Ywr4Uvilm l7Lxw3csxbn7
4seeeTrXubewF3JplLmDxlm/GUKWpaiPKvRgycORyOrAMPX0I5GpaXBVUBOP t2aLevCK3eLn
8A6NyAo/EnX09PxcY/duU+taP2F/1us1K3CstsjDvvmPd8hdr0TF4kWCBFVz EYu5dYxK56Mw
4d2A7HgDgcWGerWsS15Z68MslaQywO6BjE5VkLKT96ersvI/AxHyJ1l925T6 1o/YX/W6e7cp
9a0fsL/rdNzZo+5cN5aGr7poeBBUalFF5ZOkddgoaFRxwIyEQFR6Hqvp6DWp ZxeMw+1chTxG
Op4+sK8reDVgWJOSp5PVQBydTPu3KfWtH7C/63WK5hsjaqTVpMtTCTRtGxWi 3IBHB4+66lSR
TNpr8925T61o/YX/AFunu3KfWtH7C/63VqTZ+6a/PduU+taP2F/1unu3KfWt H7C/63SpNn7p
r8925T61o/YX/W6e7cp9a0fsL/rdKk2fumvz3blPrWj9hf8AW6e7cp9a0fsL /rdKk2fumvz3
blPrWj9hf9bp7tyn1rR+wv8ArdKk2fumvz3blPrWj9hf9bp7tyn1rR+wv+t0 qTZ+6a/PduU+
taP2F/1unu3KfWtH7C/63SpNn7pr8925T61o/YX/AFunu3KfWtH7C/63SpNn 7pr8925T61o/
YX/W6e7cp9a0fsL/AK3SpNn7pr8925T61o/YX/W6e7cp9a0fsL/rdKk2fumv z3blPrWj9hf9
bp7tyn1rR+wv+t0qTZ+6a/PduU+taP2F/wBbp7tyn1rR+wv+t0qTZ+6a/Pdu U+taP2F/1unu
3KfWtH7C/wCt0qTZ+6a/PduU+taP2F/1unu3KfWtH7C/63SpNhlDKVYAqRwQ R6HWOvCsIcKz
t3bsex5/ABx/sA1k925T61o/YX/W6e7cp9a0fsL/AK3SpNn7pr8925T61o/Y X/W6e7cp9a0f
sL/rdKk2fM0YlheJiQrqVPHz9dIY1iTqvJJPLMfmx/GdfXu3KfWtH7C/63T3 blPrWj9hf9bp
Umz918yIkiFHVWU/MMORr9925T61o/YX/W6e7cp9a0fsL/rdKk2Rd7DJNL4l aRK5JDEeF2HY
fIgcjj+X8B/28yUCGOCONmDFVAJC9QeB+L8H+jX17tyn1rR+wv8ArdPduU+t aP2F/wBbpubM
MP8Ah1r/AOJQ/wDrLrJPFHPBJDKvaORSrDnjkEcHQYrJCRnGUo9nChj5F/UD nj/3v/wj/t19
e7cp9a0fsL/rdNzZH4yvl8ZA9alfo+AZpJVE9R5HHdy3BbxRzxz8+NZa0F05 Ge9es15pJYY4
gIYDGqhC5/C7ck9z/s1t+7cp9a0fsL/rdPduU+taP2F/1utTnlPNmMcY5P3W nksbVyITzAnV
o+erwWJIXAPzHZCG4PA5HPB4H4hrb925T61o/YX/AFunu3KfWtH7C/63XPLC M405RcNxlpm4
lXUwF2HLTJWyFqPEzwRiQSXppZw6s/YIXJ6BgyAsG5HU8AEhlsEMccMSQwxr HGihURRwFA9A
APwDX17tyn1rR+wv+t0925T61o/YX/W65cH0vD4MzOGNW3nxcs61S/dNfnu3 KfWtH7C/63T3
blPrWj9hf9brvUuez901+e7cp9a0fsL/AK3T3blPrWj9hf8AW6VJs/dNfnu3 KfWtH7C/63Wh
k5ZMcitbzdNS79ERMZLI7t8+FVZCSfQ/Iam4kNaOS/wzGfzpv7GXUecyo+eQ sj/Tti9rOrtb
91X4snVu1mtug8Kq8TBhDLyD2ckEcEEEA6kq2cJ/gcn86sf2z6qVvYMl3HVK d+fBWmqQRQQ2
XxUi2EWPgrxKs4ZfUc/CR8z+PVqxNW61JpUyNWCN7Vjqj1GcjiZ+fUSD/wBN bflb31xR/q9/
1utYZZYTeM1KZRE80XtDBtgcfLUM8Mqs6FBFE0axokMcSqAzuTwIx6lvXnW/ 7sxvmvNe76nm
PMea8XwV7+N4Xg+Jzxz38P7n2+fX4fl6a2zi8qCAcpR9TwP7hf8AW6/fdOX+ tKP2Fv1ulSbI
altbbNKpaqUtuYetXtwCvZiipRok0QUqI3AHDL1JHU+nB41s5fDYfMLCuXxV HICB/EhFquko
jb90vYHg/wAo1Ie6cv8AWlH7C363T3Tl/rSj9hb9bpUlw06GMxuP6+Qx9Sp1 rx1V8CFU4hj7
eHGOB94vZuq/Idjx8zrQ2/tuhiInJaTIW5Lj3pbltYzM87J4ff4VVVIj4jHU D4Rx+E8zfunL
/WlH7C363T3Tl/rSj9hb9bpU9jZV8FsjD4jdd3csBd7tpJY+PAgiSNZXV3A8 KNC5JRPikLt8
I9fU8yFDbG2qEcsdHb2JqpNLHNKsNKNA8kbd43YAerKwDKT6g+o9dTHunL/W lH7C363T3Tl/
rSj9hb9bpUmzT92Y3zXmvd9TzHmPNeL4K9/G8LwfE5457+H9z7fPr8Py9NI8 ZjY/B8PH1E8C
xJah6wqPDmk7+JIvp6O3iScsPU925++Otz3Tl/rSj9hb9bp7py/1pR+wt+t0 qS4R+PwuHx9m
1Zx+JoVJ7jdrUsFdEac8k8uQOWPJPz/GdYMdtrbmNgswY7b+Jpw2oxFYjgpx xrMg7cK4AHYf
G/of3TfjOpf3Tl/rSj9hb9bp7py/1pR+wt+t0qexcIvG7ewGMhhhx2DxlKOC c2IUr1EjWOUo
UMihQOGKMy9h68Ej5HUnr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905f 60o/YW/W6e6c
v9aUfsLfrdKkuHxsH/ET/wA7n/tDqEobKztOrUrx7kplakUcUfNGcAhFAHKr ZCn5Dn04OrVt
3GNicd5V5xOxkeQuE6DlmJ+XJ/H+PUjreNxTGVSh9rYi1iY7zXb0Nye5a8wz RVzCq/co4woU
ux+UfPPP4dYKOztv1dy5DcZx1ezlbtsW/MzwxvJXYV4q/WJ+vZVKQqSOT6s3 rweBP6asRQio
9s7cjzRzce38SmUMhlN1acYnLlChbxOO3PVmXnn5Ej5HXwNq7XFm/ZG28P4+ RieG9J5GPtaj
f79JD15dW49Q3IP4dTGmgi8nt3b+TFkZLBYu6LRjNgWKkcnjGPnoX7A9uvJ4 5+XPpqM3JsbB
Zjb0GCirwYunBYNiJalGqwR27liqyxOiks7MWVQ3JJ59TzZ9NBAfQzaj4TFY a3t/G36WJrpX
ox3ayT+CiKqgKXB4PCr6/h41myG28fcz2NzDGSGXH2pLojhVFSew1c1xLKev ZmWJmQfEBwfU
HqvEzppYi6G3NvUMlNk6GBxdW9OHE1mGpGksgdgz9nA5PYqpPJ9SoJ+WsuEw uGwdd62FxNDG
QSP4jx066QqzcAdiFABPAHr/ACa39NBDbs2xiN0V6cOXS7/cVnzVaWnfnpyx S+G8fZZIHRxy
ksikc8EMedaWT2FtPIWMXNLifL+6/LCrFTsS1YutaQSV0eOJlSVInHZEcMqE t1A7NzZtNA1+
MAylWAII4IP4dfumgrFylLhZC9eKWbGMeekal3rH+QD1KfyD73/R8s0Esc8K TQurxuOVZTyC
NWHUTZ2/j5JWmr+NRmZuzPWfoGP4yh5Qk/jKk6xOPZqJ7tfTRcPllHUZaq4H yMlIliP5eJAO
f9AGv33Tl/rSj9hb9bqVPZbh+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+a a/fdOX+tKP2F
v1ununL/AFpR+wt+t0qS4fmmv33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv3 3Tl/rSj9hb9b
p7py/wBaUfsLfrdKkuH5pr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905 f60o/YW/W6e6
cv8AWlH7C363SpLh+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+aa/fdOX+t KP2Fv1ununL/
AFpR+wt+t0qS4fmmv33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv33Tl/rSj9 hb9bp7py/wBa
UfsLfrdKkuH5pr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905f60o/YW/ W6e6cv8AWlH7
C363SpLh+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+aa/fdOX+tKP2Fv1un unL/AFpR+wt+
t0qS4fmmv33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv33Tl/rSj9hb9bp7py /wBaUfsLfrdK
kuH5pr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905f60o/YW/W6e6cv8A WlH7C363SpLh
+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+aa/fdOX+tKP2Fv1ununL/AFpR +wt+t0qS4fmm
v33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv33Tl/rSj9hb9br5kxmUjQu+Vo hR8z5F/1ulSX
D901DWsktezJXOYSaSM8SCtg7M4Q8c8ExsQDwR6HWOPMQtKkb5kQF2CK1jA2 oU5J4A7OwHJP
8uotJ3WjuD/EOQ/msv8AynWx5W99cUf6vf8AW6083TvHB5FvelORUqSsyrSd SQFPIBMh4/2H
SbI5pLXgL2i/tg7j/pW1/atr37rwF7Rf2wdx/wBK2v7VtWEe3fZr+1rtT+g6 P/Tx6sO3vvsp
/PR/YRar3s1/a12p/QdH/p49WHb332U/no/sItOp0SmmmmtIaaaaCk+2yzTp bFjuZGWGGlBn
MNLYklICJGuTqli3PpwADzr59ktS9Xp5GWKCahtqecPgsdZUietDx8XPPqkb H4kiPqi+hI5C
Jb8lQpZKr5XIVYbUHiRy+HKgZe8bh0bg/hDKrD+UDWzqo18jcrY7H2chdlEV arE000hBPRFB
LHgevoAflrmuyt+YTJ4lKWJyVexm7DQNZ8SF26tJLHGzN97269wB8X4B+Aav 26cLX3DgrGHt
z2IIZyhZ4CocdXVxx2BHzUc8g+nOqdU9keEq3a9yHN5xZq8qzRMDXHDqeQfS H19fwH01w4vE
40fYwxuJ63Uw3jwccpjOeJVdNN3+NxX5Sn9pyz0bbYax2likWSxUlEDQKEVk V4xGxLIFLDr+
Ag+nAA55UntA3T9DM7koNxebycOy8jlshX8rD/3BkolQxV+AnI9WmHWbux8v z8ieetYDatXD
5RshFetTyGOROjxQRpy5jLMRFGnLHwkHJ59Bqw664xMTM3Mx882ejm28clld u3sDjMnvixjq
VuK3NZzE9esC9hPC8GqAY+iq4eZgOO58LgNzyda0e8s63/s+4fcNW1Xt7lmw eKuXWbqpiWz4
Ylssio3RVHjuD0K/c2+FgpXXQdwYalnaHkb73lh7dj5S9NVY+hHBaF1Yjgn4 SeD6enoNbWPq
VcfQr0KMEderWiWGCGNeFjRQAqgfgAAA1edkbOTVN17gTZtexb3lh56cu4BT tZ7G2Ybgx9M1
/E7SSeDHD4njBY+xi6qsqEgkE6jvabk0ix7ZbF7gi3EIPZ7umWDIypXnSdkk okdlRBC4BHUj
rwevBB9ee46aDjuR3lmYfaTmsbDuntYqbnx2PpYDy8P3epNXptYfnp4reGJp pewb4enxcqQB
lr7wz8Of3lSrZX6RZWhj8jbx2OoyV5aiGKQCGCVUQTxT+qp1d2DnxSvHAC9Q x+Lo4+3kbdSD
w5slZFq23dj4koijhDcE8D7nDGvA4Hw8/Mknd1Z5EbS5r7Ity5C/Hkpc5vHb +Xqr5QQNWyMc
8sE0rOhjkKQQKnZvDCIVL9uwJPKgR+1t07qv+1OXHZDO4SnXTJ3azYSa6gtt WjEngyxweXEn
LBY5C5mZCrNwoPAXrWml72nSnn+tvzd1rG2Tjt0yXs7LsjMZOxiY6ddmxeUh NYRQBRH25jaW
ROkhYtxy3PI4n9xb8jzOdyUW381j8piK021DEYo4p4lks5iSOYhiDyxjSIA8 8oVBXqwJ11Sb
F0Zs3VzUkHa/VrTVYZe7fDFM0TSLxzweTBEeSOR19OOTzu6kbLLlG2s9uhs1 gr13cM1urld3
ZrDNRarAsUVeu2QMJVlQOXXyaLyWIIJ5BPxajdo73yt6vJJlN4mISbcs382R Vg521dR4gsIA
Tnkd5x0m7s3l+R6E89p00ncjZz72Rboy+ZoWH3jYixuekspAcM6LEa33HugT nlpDIivL8268
Mnzjc65zt/2jbnn9l9rNVd4e+8h/2fWs1dk8pXHurIRwxtCvVEAHfvK3WQNz 4PK8KeNeh9aW
CxdHB4ShhcXB5ehj60dWrF3ZvDijUKi8sSTwAByST+PWr3SnN/aXld17ZXBY 2LdMMEFwWpLm
byVivSSOVBH4UAc1pY1DBpWAZOx8Pjvz84qp75bd2f3a8lXcefx2wsdexteC GOSr5uUXg3lm
6CULI0IA+LlhIQ3ICBO1aazO9rG1OH4/dm7bG0chNX3xhL875PB1q9ijZhuz 1PNX44ZxKorQ
ooKNwqMhcHvy33vG97Tdxbv2/uCDDUt1YvGV4cWlivks7bhqpfsmWQPG/FV1 kCKsRKReC3Ev
oT817Fpq3ukRs5RmM9uivuHcWQi3DMtHF7vxGIgxwqweE8FpMcsvdyniE825 HUhhwR68j0Ep
tHcEmR3lcq5jeXkcnFkrdeDbPFaPvXjLiKThkM794ws3ZXC+vHHCka6HpqK4 lsHeG9MvSy1n
Jbq2xTve4rNmTHWLqyS4i4pXr4sS143ihjJYOJHlJ4Xq3HJN49j2dkz23rk0 2Vt5WWteau9q
aWrNE5EcbfcZa0aJJH8f33UMG7qfveBddRWfxd7JeD5PceUwvh9u/ko6zeLz xx28aKT5cHjr
x8zzz6cIJc1/9oxMDNipgbW2BuCOkzQVbFZXy1lST4aUZO4eGUsHCMEk4cg8 Dg82f2tZ3YuO
2xJY3fDispBWvR14qVoxOr3Wj5jiIkPRWKP25fgKp7ngDnVtxNWelj4q1nJW slKnPazZWNZJ
OST6iNET0B49FHoBzyeSdvV6UnW3MMYLFH2D3sdtzN4/I5ubEZOzixjLQlQS dpGWKuQeWjhe
WOFSPkFQEAkDXz7KrO16u4s7LtSxRg2o1LFxwtC6rXN93nSRefl4zK1RWH3x YqD8R11HTS95
+TpHw5PS3Pdvbgy21NyXoxQ27Hfn3JYmiRY5qci801Y8ABWgkdmZePirMPkS DV8dY2/lNlbp
zu03xVLAXLGKSfEYuSPmDHpaHmbE8UR4ieaBpeV4BEcSdviDKvoDTU6UvW/P PPv4X/3L7ufj
yP8A2dfTUc8dfd/kfdw/+o8D3h8/8ztz+DWjc8ZttbVXI3cDU2oJM3JE24IG lougt/8AdqFO
6BuaxcoGPHABAJVdegtNJ5V5yOtvPm9rFW3g/NX8THhsjNsanJs/HOvV6eUP jFoa44HEyN5J
eFAbgfIDnUxuOw1f2wWp8zV29lJ/fWNr4bH3axkvis6QB7NVi3CLFK08jMEJ IiYFl6rrtemr
tt96d3FdteV/7Scd4Xh/Sz6T5b331/wj3X4dry3ifh8HjyHTn4eeOPXnUh7G M3sCjlvaDQ25
mtuRY+DMC8kVO5D4aVxjaIkn+FuOgk7hn+Xbtyeedda006RB1mXH907nv4uf dixZMYo/S+vR
iuK1arFErYmrLzYnlglAUsSA7IzFjGgIHAGPYe6N1btt7QrybialHYq56S9J Shhk82aWQr1o
WDyRenKuxJVE57HhV+Hr1TEYfH4mS/JRhdJMhba5ad5XkaWVlVSxLEkAKiKF HoqqoAAAGpDS
6Ji0fk79qpbpwV8LfyEdiTpLPXeAJVHIHaQSSKxHqT8Ac/CfT5Awe5eclv3b WGHJip+Pl7PH
qp8NfBiRh/K85kH8sH8mrZrCtWstyS6teFbUsaxSTBB3dFLFVLfMgF3IH4Ox /GdTr55zXpPn
mzz7id2ZvB+yzakNLN+63q7BxlzDU/Aif35eMRBq/GpZuOkA6xFX+788+g10 WXcEj+0q/isx
vL6OpWt1YsVjOKye9Y3jjZn7TIzv2laSHiIqV8P8bA66Hpp0OrjOK33mH9sF DCx5pZ6N3N3s
bNjrVmA2a6wwWJFkEMddXjQmBejSTOXRgevryul7PLuSb2dbeyOGpm/b2v7O Ks1OtwWWxesV
VZE4Hr2Va6j09eLP8uu56wwVa0EtiaCvDFJZkEk7ogUyuFVAzEffHqqryfwK B8gNJ5EVbjmD
3huo7M3BkU3VhM20HkOk1Kyl6bHpLN0syyrHXgAEcXMixspYGN+xI4AmJ7lG 7lvZ/Lj94/Sy
IbrnU3fFrSdD7nvHw+a6InpyD6jn4vnxxrqOmrPNI5POVLfufqbVxbRbpix9 uH2fYXKYzFRU
aypk78osgwKvh8gSeFEgji6kc8p14PPRW3Heh9ta4C1uLx61iTpVxlCWsxgA qGRjbjaPx0BY
MyyI/Q9olIBJ7XuHF0Yc3azUcHW/arQ1Zpe7fFFC0rRrxzwODPKeQOT29eeB xu6Dh+yfaDuo
4/KZrPZfCWp4MLPbm2/FdR7tW4roEg8IV42iXszRkSPKSxj6txyTLz2JNqXM VtHLb4O1cXRw
cDxZIishydsu6zgyWEdOV6o5UAMxnJ54Gup26ta5EIbdeGxGJEkCSoGAdGDo 3B/CrKrA/gIB
HqNZtSPP1WfP0cZ3xvvMYj2mrj6GaWOGPNYuhLjLlmBTNHaeBHkghFcyugEx +6GdQJFYcEL1
NXy9uahgsxfr+EZq2B9oc0fiwpKnZcvER2RwVYcj1VgQfkQRr0dpoOZXc9kT 7YJNtS7rlSK5
2ipU8XJUeSn/AHGXL2YpImlU9gzLIGMZJiVl9T2p2y9zWKPs12JUs+0eXH05 cO3vPKzeUkel
eir1umPYtGVU/HMxWQGU+Hx29dd+00mLioIcJ3/mttZnb226G6IsBht+53BV 5pbuQaOvJhEZ
eZJkeQhkdJGcRop7M6+vwqzL3G5E89SaCKzLVkkjZFniCl4iRwGUMCvI+Y7A j09QflrLqA9w
5X3t536a57wPH8XyXg0vB69ufC58v4nTj4ee/bj/ADufXWpm0iKcW29unPY7 2W7BqY/etcRz
4zplcpkr9aAY+3FXr9aLSmtKqt8crdZU8Q9Dy/Pobdkd2ZmpuHZyZHddJ48j Tx4lp4WauZLN
iWTq8wjnjMklRuV+KJlZFWRjz6FetaazHysuG7QeS3jfobY3VczF+3vC4t6p ZeAyUqsF+1Z7
OkaKwSdIo1+LleJh0Cr6akNkbyzOQ3pVpNun3pNNuPM0LuI8vCvkaVeW0IZ+ UQSejRQR92Yq
3i8cdhzrrj1az3Irj14WsxRvHHMUBdEcqWUN8wCUQkfh6r+IawYfF0cRUepj oPAhksz2mXuz
cyzyvNK3JJPrJI7cfIc8DgADVjZJi5cDxG/Lm0vYqiPm4Ma8Pssxl3b6ypHz JeWtZ8Uxhh90
K9apKnsAODwAx5tG+N45jH70tUl3T7qmh3BhqNHEeBAfP0rE1VZ5+XQyHkyz x9lIC+F+6POu
w6h8ttvEZbLU8nkIrU81N0khiNyYVw6MWRzAH8NmVjyGZSQQpB9BxFc227kd x5jO4zB0twy4
WvZm3XNO9KjW7ua2YjhhI7xsoIWVux4JckluWPYYMfvzM2m9n2RyO4Y68eex GKnlxmOesLMl
iww7u0MyM71z2UExMrIFkY8+hXtGmrCGmmmoppppoGqxaAO/KBIBIx90j+T7 rW1Z9UTeOUs4
nduMsVacVp3q24ykk5iABkrnnkK34vlx+HUymlx5qtifabmcl7Ure259gbnp 4DgRU8xNirCJ
JMCexflOFjb0Csfxcn0b4bbigBbuAAAfSHn0/o5NaEm6sy//ANo6A/8A4k/6 nWbatma3HPYs
QxwyvuA9kSQuo4x6j0Ygc/L8Q1iconk1UxG6y4v/ABPH/OrX9u+s2sOL/wAT x/zq1/bvrNqs
pTKWY6VVrkyzNFAryusMLzSEKjEhUQFnb09FUEk+gBOoPZ+dyu5LEuUiq0qm 3vusVXvIz3Z5
Ek6M0sfAFbqySDwmLyHsA4geN4zYpfv4v/H/APGnWhXwGGrbis7hq46GvlLc Qit2IR4bWgOo
UzBeBKyhAEZwSgLBSAzA9WFSwtjdlTd97GwZ36VeFjZZb4sxRVKtHIExNWrR PFGXRJEeZmVz
YkjRYGJ+NTLDJ7W8rb2hufcmL2pSnh2rjXbMRT5ZomhykAL28evEDB/CjHPj j4HZkVfQsydG
hwdKKjkqaz5MxZKWWWdnydhpEMg4YROXLQKP81YioQ+qhTqv2vZfsqxi3xbY 67HSkwkGAkhg
ytqJZKELExwsEkHbjs47H4irupJVmBDSwntGs3N1w4DI7Vu4x2yTYuSV7UMg S01I344+EJ54
rD7o33qSsqIZl7SLKbAvZOznd70cjkpr8WN3AIKZljjVoYXo1LHhDw1XsqvO 4BbluOOWYjnW
bG7D2zj8uuWgq3XurZitiSxkrM/3eOo1NZSJJCC5gYozEcvwpYsyqQ2nsXb+ 18pcyWIbNeZu
+tk3M5duLK3VF7sk8rqXCxRqH47BVCg8emgk91W8zR27dubew8OZykMXevQl ueVWwR80EpVg
rEc8cjgngEqCWFGl9qcyV48vFhaV3AVtorufK3KuQk8WvE8crxJDDLAnjeJ4 UnUs0ZARy6xn
oH6Zqv4TZe18NRztGjh4RUz96xfysEzNPHamnAExZZCw6sAAUHC8fg9dBWdj +0Dce4717G2N
lTULaUZLNSWSPIw1HdSqiKWa1RgKMxdSvhpKeqyEgdVD7vs+3hujdG1ae6p9 mQ0sXfxCZCnX
iyyzX5nZFdY/DMaQqrct1czA8dO6xlmVJPFbHwuN835e7uZ/NVnrSeZ3NkbH VG45KeJO3hv6
ekicOvrwRydYcP7Otq4rauQ2tVr5OTC36Pu+anazFyzGtfo0fhxeLK3gr0Yj 7n19OP3I4CF9
nftCzu5d1HC5XasOIi8jLaSYzXY5GKPEvURXKVZnX7pyXj7hCFD9TInbNht7 X6O3t+5vduP8
u+1rMjWatG4ttBFHj69kiF2hgJ5WQniQE9y3xdeoWwbb2dg8Bee9SGTsW2iM Kz5LLWr8kSEg
skbWJHMasVQsE4DFE7c9V408F7Otq4abJyV6+TtLlomiyEOSzFy/DaDIiMZI rErozFI0TsRz
1HXnr6aDBQ3Nupc4dv5rbmFq5a1jbN7GLUzMtivL4DQo6TSNWjaLlrEPBVJP TuSAVAaG2n7T
srmsHRyNvaPu6TL7blz2Jri61l5UiWDxElEMLMnLWYvD8NZXdCSyI48I2bFb F2/jfNtA2amm
tVnqmzbzl21YhifjusMssrPB2IUkxspJRCfVFIw4D2dbVwV7CXMZXycUuCov j8cr5i5LHDXc
8tGUeUq6+i/fA8COIDgRp1CL9nG+s/ufOTUMptX3RDHWaZZvCyi9mDKOvNrH 10+TE+jlvT0U
jkrp+yXHe1ivkMfNv7cfnKybbg83X8lVj8TKS2Jnl+KI8jwIhDF6fBJ27jgg 66ZpoKZ7Mshu
S1f3fQ3NlKWRs4vNpVhkp0jViWJqFOYKqF5G++mcks7Ekn5DhRJ+0rN2ttez rcu46McMlvFY
i1dgSYExs8ULOoYAgleVHPBB4/CNYdp7F2/tfKXMliGzXmbvrZNzOXbiyt1R e7JPK6lwsUah
+OwVQoPHprNhNl7Xw1HO0aOHhFTP3rF/KwTM08dqacATFlkLDqwABQcLx+D1 0ENh2zmB9ouO
25d3Rk9w1MniLt1nyUFVJK71pqiKIzXhiHVhaft3DHlE6lfi7Rnslx3tYr5D Hzb+3H5ysm24
PN1/JVY/EyktiZ5fiiPI8CIQxenwSdu44IOrZtvZ2DwF571IZOxbaIwrPkst avyRISCyRtYk
cxqxVCwTgMUTtz1XiwaCM3Zm6u2tq5bcd6OaSpiqM12dIQDIyRIXYKCQC3Cn jkgc/hGqZsf2
gbj3HevY2xsqahbSjJZqSyR5GGo7qVURSzWqMBRmLqV8NJT1WQkDqofoF+pV v0bFG9WhtVLM
TQzwTRh45UYcMjKfRlIJBB9CDqv4rY+Fxvm/L3dzP5qs9aTzO5sjY6o3HJTx J28N/T0kTh19
eCOToKlgfa7JLtWDcu4drTYmjb2tPuapHBdS1O9eukLTq68IqMfMRmLhm7qS XELDpqaubw3R
gaOVye7tmQ1MXi8Raylm9i8styMiEKywIskcMhlZRMx5UIoVPjYuQmbH+y/Z VH3WsWOuyw4v
Gy4qrWs5W1YrinLz4kDxSSMkiEdRw6t6Rxj5RoF3cVsPbOP832q3cn5us9SX 3xkrOS+4Px4k
S+Zkk6o/C91XgP0TsD1XgIW/v7K7b94fTfb1Kl5bCXc3F7nyTXvEgp+F46t4 sMHV/u8fQDsG
+PkpwO2HD5ve7e2HHYfcNOHG0bW37tnytK7HcqSSQ2KirIsjQRTrKBPIHUjw +piKkt362DFb
D2zj/N9qt3J+brPUl98ZKzkvuD8eJEvmZJOqPwvdV4D9E7A9V4w4f2dbVxW4 qm4qtfJyZipF
LDHdtZi5ZmaGTr2hdpZWMkQKhljflUbllAYkkMGyc7uTKRbuiyGNpRZjFZLy sVNcmZanY0q0
yKswrRuqEzDsWjdlYvxyvVRX8D7XZJdqwbl3DtabE0be1p9zVI4LqWp3r10h adXXhFRj5iMx
cM3dSS4hYdNWfBezzbeEmyc2Ok3AsuViaO48u4shM0hZETxAZJm6yhI0USrw 6hQAwGsGP9l+
yqPutYsddlhxeNlxVWtZytqxXFOXnxIHikkZJEI6jh1b0jjHyjQKEZb3xvTH bihwWT2RjI7E
mIv5UT1c1NZhZK3hKIkVKnjPKZJkDKIuApBQytzGM3s431n9z5yahlNq+6IY 6zTLN4WUXswZ
R15tY+unyYn0ct6eikclcPs79mljbm6juXL5qHK5FKMtGGaOK34hhleJ2WSW 3asyOqtCpRVZ
FQvMepMhI6NoOWezTEe10tWXfG7pvCba0SWDDRpJIuVmnmeR1KhlDV4hDGOV aOQt245DDUNs
+9vnPUdgoPaDk4Le4NiXMnPK+PpPGLvFTwpSghUlUN0noGUMIYgefuhftmq/ tvZu3dvXnuYq
nNHKYjDCstyaaOpCSCYa6SOy14j1T7nEEXiOMccIvAUzaOM3nf3RuWrL7UNw SVMLlzQEcuPx
xaWGTGQShgyVl6ypNZDhuCpEYVkbknUZ/wCz9m965nace9N25nc0lNMajSUL uNqyecZ6tWyL
dXykKv05eeNYuZWb056upQdGx2zsHjptwTUxk45dwymbIv72tMzOU6d4yZD4 DBOqgxdCAiAc
BF43dq4HGbY27S2/hYpocdRi8GtFLZknaNB8kDyMzFR8gCeAAAOAAAFZy/tD oPtXcN7ER5Oj
bxmIs30nzm3clUqIY0JBdnhUsoPBKJy5UN1B41Gez7Kbph3xHhM9PuZYbeNs Wo4tyJjfMO0M
sC9q5xw6BAJyJBMexLQ+HyBLx0a/Uq36NijerQ2qlmJoZ4Jow8cqMOGRlPoy kEgg+hB1C7b2
dg8Bee9SGTsW2iMKz5LLWr8kSEgskbWJHMasVQsE4DFE7c9V4Cp+yXHe1ivk MfNv7cfnKybb
g83X8lVj8TKS2Jnl+KI8jwIhDF6fBJ27jgg63MLJuyPd97Dwbq9+dcbK9+xZ x8Qq4rIExNWh
iSLo5RkkmdonlkkVEg5kXxFaToGoyHB0oqOSprPkzFkpZZZ2fJ2GkQyDhhE5 ctAo/wA1YioQ
+qhToIzae6JsnlLmBy2M8jm6HraSm8lukAVRlC2vDRQ5WVCYpBHL82CGMpI9 m1pYTE4rB4uH
F4TGUsZQg7eFVpwLDFH2YseqKAByxJPA+ZJ1u6BpppoGmmmgaaaaBpppoGmm mgaaaaBpppoG
mmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGsGQ/ wN/9X/qNZ9YM
h/gb/wCr/wBRqTyIc5u56Ta/s8yWYrYXJZmzHfveDSx9Z5pZ5DalCjhASB+N j6AD8PoDXtv7
sye8fZLlbuf2xk9vZaKjMlupdpywqXEbEPGZAOyn5/hIPofwE2/bb58YycUs djJq/vG70ebI
PG5/uqXnlRCwHrz+E/8AzNae9DuM7Vy/j43FJF5GbuyZGRmC9G5IBhHJ/k5H +ka5zydY5rbr
DlP8Q5f+YTf8p1m1hyn+Icv/ADCb/lOjLNrwF7Rf2wdx/wBK2v7Vte/deAva L+2DuP8ApW1/
atqwPbvs1/a12p/QdH/p49WHb332U/no/sItV72a/ta7U/oOj/08erDt777K fz0f2EWnU6JT
TTTWkNNNNBWPadmcvgdpG/goKtjIvkKFWCKyxWNzPchhIZh6ryJD8XB4+fB4 41vbT3DT3FQe
eCOararyGC7SnAWapMACY3A/D6ggjkMCGBIIOoz2s0szf2aI8BRjvZKHK4y1 DBJL4aP4N6CV
uzevChUYkgE8A8An01t7N237lNzI37QyGeybI+SvFOviFQQkaL/mRICQq8nj kkkszE1Fh1S0
m3TkntWcbcHlBM4gc2I0V059OFNdyOPlyW9SCR6Eamd9Zz6ObSyOZCo0leLi ISfeeIxCJ29R
8PZl59flzriG0faDamWht3cHuP3YZasQaKXuT0mjJMvY8deivyePnx+DXi9X xODWjPOYy6RE
1brw8ONMxlhw5nHrNXEO57St2bmEje9L4lyN3jsDgco4Y/CeAASAQOQOD8x6 HSLc+2pVyTRb
hxLjFKzZErdjIpheexl9fuYHVue3HHU/i1W9kZXHWNztUxM1VIpK08k9eq0P g9keERyKkbv0
5V2B5ILFeeOANVVvZfuSbZ1rb8s+FiNTZt/bOOnjlkJuGwIws9geGPDI8FSQ vieskh5/AfTw
tvsz0253+vX+rEze/n5Olybs2tHQTISblwyU5JzWSw16MRtMPnGG7cF/Q/D8 /TW+mTxsmIXM
JkKjY14BZW4JlMJhK9hIH569Ovr25449dUn2m1bWJvYTcuLx0V9cdVtY73f5 SxKpScRHuq14
pWBXy4XgqFIkYFl5HOlj9mZvIewbBbKtrFj7dPC4lS3mXVvM1jG8kLmMAohM Sr3Ri3xtwB1H
bfdI+V5j3Jt2TBNno8/inxCc9r63IzXXg9TzJz1+fp8/nqMu7729AYXrW4sh WnxN7Kx261mE
1mhqPCko8VnCA9plAJIUdW7MvGq3BsbKQ4qrZqY7GVcpU3AMya0+atX4rrCs a/3WxNH4isFI
K8IwUxRng+uvv2gbO3Lu/H2HkXEULljaebwrRLbkljSe41bwWD+EpKAQMWPU EEgAN89EXQ7k
26M37jOexQyvfw/Im5H4/boJOvh89uejK3HH3pB+R19VNwYG3mLOGqZvGWMn VUtYpxWkaeFQ
QCXQHsoBZfmPwj8eucDa24crvndiijRqYqbduMyXnp/EWw61alCTiJenWRGe Jo+3cdfuvox9
NSD7Gz1qfdWMW3Xw2381RyEAhr3ZLTeZsvyLSq8a+Aw7SsyK7KzSc+nXk2eW 3nnJY57r1g85
hc7DLPhMxj8nFE/hyPTspMqNxz1JUng8EemsZ3DgBnhgDnMYMww5FDzaeYI6 9ufD57fegn5f
Ic6rPs+2zlNvPetTYehFespUrvKNw3b3ixRM/J5sITEFEjska8gk8Fh98Nra GGz+3speoiri
bWHt5O3kDeNp0tgzu8nRovCKv1ZggbxB8Cr6enBTzSOSZi3PtqVck0W4cS4x Ss2RK3YyKYXn
sZfX7mB1bntxx1P4tfE+7dqwYv3rPubCxY/xjB5p70Sw+KOeU7luOw4Ppzz6 a5o3sv3JNs61
t+WfCxGps2/tnHTxyyE3DYEYWewPDHhkeCpIXxPWSQ8/gNq9omzLeZyWCyWJ SNxioLNXyPvW
zjUeOYRfEJqwLAr4IAUqVIdvkQDqdLOq6zWa0NN7k1iKOskZkeZ3ARUA5LFj 6AcevOouDdu1
Z8JNnIdzYWXFQSeHNdS9EYI39PhaQN1B+JfQn/OH49QeY2lbu+zqvtKpWx2P hpVcf5WPx5J4
fErSJIa79lDNCREidySzK7cqOPi/c/id1Zunh8hPj8HWyuHy4vQ0xkJZa1lP Aki4eUwKyMPG
ZhxG3BjT8fonmvRN5Ddm1sdTrXMhuXDVK1uEz1pp70SJNGOoLoxbhlHdPUen xr+Ma1629trW
N4zbSizlBsxFWhs+X8wnZ0lEjKEHPLELGXIA9FZG+TDVe2hsO9is3gMjffHT LRqZrzEcfYiO
bIXYLIWLlfWNFSWPsepI6/D6kCIwns33FT26MBPbx/g39jUds5C3DYkEtWav FZXxoVMfEqs1
n/OaMgLz688aTsRvzdArbs2tZxs2Tr7lw01GCZYJrMd6Joo5GZVVGcNwGJZQ ATySwH4dRuU9
o+xcdHiZ7O6sN5bLWpKtWyt6Iwl443dyX7cADp1J/AzIvzYaqlb2c5KbCWat rG4ytanu4WSa
Vs7cyIsQUrqTuh8wnMY6iQIi9gS/DHj11IZHZu4ItyWM/jPddiVd1jN1q09m SFXiOHWgyM6x
v0fuXf0VgQB6gk8WaSLWHae/NobpVvce4cbbkFqaqIUtRmRnjeRTwoJJDCGR 1P8AnIOw9Nbc
u7tpxXY6Uu58JHakk8JIWvxB2fxHi6he3JPiRyJx+6Rh8wRrn25cFuXC7Ku0 6dWGbKw7jnye
27NNJrDNPZuTzlbCCMCCPpM8LuXK9WY8qSAY3J+zzNHLZ3amFqVGxtvZmOw0 uVv91dWM1/xZ
oyqMJZh3EjISvxPGSw59WO/Mnbk67ZzmEq5ivhrOYx8GTsr2gpyWUWeUevqq E9mHofkPwH8W
ty1I8NaWZIJLDohZYo+veQgc9R2IHJ+Q5IH4yNc6yewLk3tDuZxq0GToXslS yDCfOXKvlHrr
Eo4rxgxT8GFZF79fiJB5HGrLW3ttfKu1Hbu6dt5TLSRuatSPKxsZXVS3B6Fm A9OSQp4AJ4PG
p0XqzbZ3PHmcpkMTNicjicjj44ZZ61wws3hy9xG4aGR0IJiccduR19QAQTiX dqx7kq4W/gcx
jxdsy1aNywITBakjR5CF6SM68pFIwLooIX8ZAMPsHauR23kczkK+GwGHgyJq ImIxlh/KxGNn
E1jt4KDxXR1HURgHwUBb1LL9YzDbtn9pM2d3DSwljHwPLDiWhyUpelAVI7+C YArTycAM3ifC
p6r/AJ3eokd273xm27z1rVPIWVrVBdyE1ZEKUKxYqJpezKevKueEDNxG549N WKa3VhswVZrM
Mc9gsIInkAeXqOW6g+p4HqePkNc/3xs7cWffKmqcVAu5dvx4TMLJZkPlFVpi ZICI/ux4tTDh
hHzwh5HqNTPtEwu4M1iVmwJxtXOYrIR28PNZlcxNwnSQS9U5Xskk8fA7ehVu eTwsuoWrmvPL
fe5N70sJUsZL3VkcjhqkMk13KUWgkr1Vjd1l7cyh2KGN+yorEcccc+mvrIb3 xlLcbYeSnkHj
itV6dm+iIa1axPx4MLksH7N3j+9UgeInJHOq1mdmbmiobe2viq2HyW1MZTjF uC7kpa02QsIf
TxSsEgaLkd2HILseG+EEPuZnZmatbkvrXmx4wmUzePzduV5HFmKWp5fiNECl WV/KQfEXUry/
ofTV6xHz55/XknRM0d74y5uRcMlPIJHLbnpVr7onlrFmFWaWFCGL9lCSepUK TG4BPGmO3rRu
UreXONyNbAV6stsZmbwhWmij++ZAJDLwRywJQAqOQTyOYbE7MzVXctBZpsf7 kxecv5urKkjm
zLLbWwDE6FQqqptzHsHJIVB1Hrqv7d9kM1HEXdu9MZi8VJtmzgHmoyO82R8U IqWrClFCyRoj
ADs/99cBgAAZPKPuair35WudPf8Ai3xuStZDH5TEzY+KCaSnciQzuk5KwFFj dwTI6sirz27K
QQDrYtbualiorV/bWbqXLN0UqeOc1msWpCvflCkzRheocks68CNufwc1jJ7D zm5aWcs7mGIX
IX4MXClWtPI9dxQsPZXu5RWUSSSOpAU9V44LHTG7FzuPx8FulBhal2luI5ih iIbEgo1o2qGq
9dZPDBUMHll5EQAeQjrx6mzV/Hnn9mYvTvz88/usy7xFjb1bN4rbuYykMvjL NHAa0clV4mKS
JIJZkHZXV1PUt6qfwcE79bcmNs7Yxm467lqGTFRqzOyQkrZdFjJ8RlAP3Rfh 57H5KGYhTULO
y8idjQbeubc2ruU2Ld2/djylh0hgsWZ5JiYvuEhYKZ5FDfA3AHy5PH1urE5q psLbW2pfMZmx
WyGAja8iySS2Hr3YJLE0qhSI1EcBfuznksV9D172uZa40dybdv5efD0c/irW SrlhNThuRvNE
VPDdkB7Dg+h5Hpr7wWeweehebB5nHZSJApZ6dpJlXsOy8lSfmPUfjGqBBsfd kntJxOfv3a1i
njs1cu+K2Wslnry17McUS1OogjZPGjBYElghYkElTb/ZlgJtq+znbe2rPljZ xeLrVLDV+fDa
VI1V2UkAkFgTyQCefUanQnmsWq3i95YrI5+HD14bYkmXINHMyqIiKU8ME3r2 5/vkwA9PXo/y
9OduGtlcNt+8Uv5Dcl5Eklrrb8vFJIwT4YgY0jQAkfNh82PJ444pdz2bXrWI xmKOTiiSLaGT
wdy2OfFazcNQmwF44PLQyu3JB5ZfnySJ3XsvOM3Ft/KY6xk
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49680 is a reply to message #49649] Fri, 08 September 2006 17:10 Go to previous messageGo to next message
Originally posted by: varunkumarm.gmail.com
I too installed elver on a callisto release and used the update site for
elver.
Do you mean to say that i have to manually unzip the said jar file into
the plug-ins directory??
Then in that case there are two more plug-ins named
org.elver.store.eclipse_0.7.2
and org.elver.store.jpox.eclipse_0.7.2 along with it.
Do i need to unpack them as well..
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49710 is a reply to message #49680] Fri, 08 September 2006 17:31 Go to previous messageGo to next message
In my installation these are not unpacked. I do not understand why the plugins are not unpacked. In
the feature.xml I have the unpack="false" is not set for this plugin.
So only for the org.elver.store plugin I saw a difference with my install.
gr. Martin
> elver.
> VarunKumar.M
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49738 is a reply to message #49649] Fri, 08 September 2006 17:41 Go to previous messageGo to next message
Thanks a lot martin..I'm very excited to see the package.jdo getting
created
Plz clear the same doubt which i had so that i dont encounter new problems.
i.e that there are two more plug-ins which are named
org.elver.store.eclipse_0.7.2.jar and
org.elver.store.jpox.eclipse_0.7.2.jar
Should i unpack these jar's also or are they supposed to be like that.
And by the way, plz try to find out why the installation hadn't unpacked
the jar files.I'm informing you again because it happened on all the five
systems on which we have installed.
Any way..a million thanks for your quick help.
All the best for TENEO. I checked out the project from repository just now
and am thinking of using it if i didn't succeed here.
I'm awaiting the release of TENEO and i will inform you soon about how we
applied Elver for our project.
Regards and Thanks,
VarunKumar.M
PS: When i first tried creating the JDO File i got the error saying
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/emf/ecore/xmi/impl/EcoreResourceFactoryImpl
org.elver.store.mapper.PersistenceMappingBuilderImpl.buildMa pping(PersistenceMappingBuilderImpl.java:52)
org.elver.store.jpox.mapper.GenerateJDO.createORMapperFile(G enerateJDO.java:101)
at org.elver.store.jpox.mapper.GenerateJDO.main(GenerateJDO.jav a:82)
and i then included org.eclipse.emf.ecore.xmi also in the build path in
order to successfully generate the JDO file.
Give a thought for this also. :-)
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49767 is a reply to message #49738] Fri, 08 September 2006 17:49 Go to previous messageGo to next message
Good that it works.
With me the org.eclipse.emf.ecore.xmi plugin was added automatically to the plugin dependencies when
creating the emf project/generating the source code.
Maybe you did not create a new emf project but a new emf model in an existing project?
gr. Martin
> created
> five systems on which we have installed.
> now and am thinking of using it if i didn't succeed here.
> we applied Elver for our project.
> Regards and Thanks,
> VarunKumar.M
> at
> at
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49797 is a reply to message #49710] Fri, 08 September 2006 18:18 Go to previous messageGo to next message
Ya that's fine and ok as the two plug-ins which i have mentioned have the
code directly in them in contrast to all the other plug-ins(like the one i
unpacked) where the .jar file is provided inside the folder and the src is
provided as .zip .
But why this inconsistency..couldn't all the plug-ins be made as unpacked
format in which the classes are jared and src is zipped.
That's just a suggestion. I dont know if there were particular reasons
which forced to do like that.
Thank you very much,
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #49827 is a reply to message #49797] Fri, 08 September 2006 18:28 Go to previous message
No particular reason, it is more the advice from the eclipse side that plugins should be preferably
shipped as jarred.
gr. Martin
> the code directly in them in contrast to all the other plug-ins(like the
> one i unpacked) where the .jar file is provided inside the folder and
> the src is provided as .zip .
> unpacked format in which the classes are jared and src is zipped.
> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590570 is a reply to message #49355] Fri, 08 September 2006 06:59 Go to previous message
The right mouse click on the ecore file uses the classpath of the project in which the ecore file
resides.
In your model plugin containing the ecore file did you add a dependency to
org.elver.store.jpox.runtime? See here:
http://www.elver.org/jpox/installation.html#Using+the+runtim e+plugin+in+an+EMF+model+plugin
The teneo version is currently only available in cvs at eclipse.org (see technology and then
org.eclipse.emft/teneo.
I am pretty far with the build procedure at eclipse so I expect that there will be a downloadable
version somewhere next week.
gr. Martin
varunkumar wrote:
> I'm using Elver Plug-in along with the latest beta2 version of jpox
> plug-in.
> 1) When i clicked enable auto-enhancement it gives a warning as
> "No JDO Meta-Data files specified!"
> 2) And when i click on the ecore file and say generate OR Mapping the
> below error appears.
> I followed all the instructions given in the site clearly but the error
> appears.
> I'm just using the same Library model given in the example.
> I would be very glad to download and use the teneo version if someone
> can guide me how to download.
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590586 is a reply to message #49415] Fri, 08 September 2006 09:25 Go to previous message
Yes.. i did add "org.elver.store.jpox.runtime" as the dependency..But
still i'm getting the same error. I followed all the instructions
well..There is no information in any log-files also..
In order to set the classpath for JPOX-Plug-in i added
org.elver.store.jpox.jar which i found from the runtime plug-in.
I added the dependency and also added the RegistryBuddy line to
Manifest.MF file also.
I'm not able to understand what is the sequence to follow also..when i say
enable auto-enhance it says "No JDO Meta-Data Files" and when i say create
the OR Mapping from ecore file a dialog appears saying pacakge.jdo file is
created in model folder but at the same time a dialog named Java Virtual
Machine Launcher pops saying no main class found and program will exit.
What is the class that should have a main, i did not have any class having
any main in my model..There are just Library,Books and Writer interfaces
and classes.
When i ran the enhancer in verbose mode this is the output iam seeing on
console.
JPOX Enhancer (version 1.1.0-rc-1) : Enhancement of classes
JPOX Enhancer : Classpath
>> F:\workspaces\EMFTests\Library\bin
>> F:\eclipse\plugins\org.eclipse.core.runtime_3.2.0.v20060603. jar
>> F:\eclipse\plugins\org.eclipse.osgi_3.2.0.v20060601.jar
>> F:\eclipse\plugins\org.eclipse.equinox.common_3.2.0.v2006060 3.jar
>> F:\eclipse\plugins\org.eclipse.core.jobs_3.2.0.v20060603.jar
F:\eclipse\plugins\org.eclipse.core.runtime.compatibility.re gistry_3.2.0.v20060603\runtime_registry_compatibility.jar
>> F:\eclipse\plugins\org.eclipse.equinox.registry_3.2.0.v20060 601.jar
>> F:\eclipse\plugins\org.eclipse.equinox.preferences_3.2.0.v20 060601.jar
>> F:\eclipse\plugins\org.eclipse.core.contenttype_3.2.0.v20060 603.jar
>> F:\eclipse\plugins\org.eclipse.emf.ecore_2.2.0.v200606271057 .jar
>> F:\eclipse\plugins\org.eclipse.emf.common_2.2.0.v20060627105 7.jar
F:\eclipse\plugins\org.elver.store.jpox.runtime_0.7.2\org.el ver.store.jpox.jar
>> F:\eclipse\plugins\org.elver.store_0.7.2.jar
F:\eclipse\plugins\org.elver.store.annotations_0.7.2\org.elv er.store.annotations.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\bcel -5.1.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\dom4 j-1.6.1.jar
F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\jdo2 -api-2.0-rc1.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\jpox -1.1.0-rc-1.jar
F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\jpox -enhancer-1.1.0-rc-1.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\log4 j-1.2.13.jar
>> F:\eclipse\plugins\org.elver.store.jpox.libraries_1.1.0\comm ons-logging.jar
C:\eclipse\plugins\org.elver.store.jpox.runtime_0.7.2\org.el ver.store.jpox.jar
JPOX Enhancer : Input JDO Files
Where am i going wrong. All the searching and poiners on net leads me to
Elver project. I want to make it work and thank your help.
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590592 is a reply to message #49444] Fri, 08 September 2006 10:52 Go to previous message
Do you have a plugin: org.elver.store installed?
btw, the sequence is first to generate a jdo file, then copy the jdo file to your source tree of the
to-be-enhanced classes, ensure that the build copies it to the build directory, then the
auto-enhancement (and the jpox runtime) will automatically pick it up.
gr. Martin
> say enable auto-enhance it says "No JDO Meta-Data Files" and when i say
> create the OR Mapping from ecore file a dialog appears saying
> pacakge.jdo file is created in model folder but at the same time a
> dialog named Java Virtual Machine Launcher pops saying no main class
> having any main in my model..There are just Library,Books and Writer
> interfaces and classes.
> console.
> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590609 is a reply to message #49474] Fri, 08 September 2006 11:03 Go to previous message
As an extra remark the org.elver.store.jpox.jar does not need to be in the jpox preferences and
should not need to be listed separately (imported in the project or so).
You can set the jpox plugin to use the classpath of the project (at least in the version I have)
then you don't need to list them separately in the jpox preferences.
gr. Martin
Martin Taal wrote:
> file to your source tree of the to-be-enhanced classes, ensure that the
> build copies it to the build directory, then the auto-enhancement (and
> gr. Martin
>> say create the OR Mapping from ecore file a dialog appears saying
>> on console.
>> to Elver project. I want to make it work and thank your help.
>> Regards,
>> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590620 is a reply to message #49504] Fri, 08 September 2006 11:16 Go to previous message
But the problem is while i'm generating the JDO file first. The exception
is shown again while i'm generating the JDO file. Why am I getting
storeException?.
And Yes, i have the org.elver.store plug-in installed.
Should there be a class with main method, (i'm asking this as the JVM
launcher dialog says no class with main) in my model code. What is the
main class that is not being available, and is there a way to debug and
find where i'm going wrong.
The only step i didn't do is to place a JDBC driver. I don't think it is
the problem.
Thanks and Regards,
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590629 is a reply to message #49534] Fri, 08 September 2006 11:40 Go to previous message
No storexception occurs but a noclassdeffoundexceptin, the error is that the storeexception class
can not be found:
What does your remark mean:
In order to set the classpath for JPOX-Plug-in i added org.elver.store.jpox.jar which i found from
I added the dependency and also added the RegistryBuddy line to Manifest.MF file also.
Why did you take the jar out of the plugin (at least that is what I understand)?
The dependency should be to the org.elver.store.jpox.runtime plugin not to its internal jar files.
This because the org.elver.store.jpox.runtime plugin defines its own dependencies to other plugins
(one of which is org.elver.store).
In my opinion you only need to do:
1) to manifest.mf add a plugin dependency to the org.elver.store.jpox.runtime plugin with
registerbuddy set
2) set the jpox enhance to use the classpath of the project
Did you exactly do this (and nothing more)?
gr. Martin
> exception is shown again while i'm generating the JDO file. Why am I
> getting storeException?.
> And Yes, i have the org.elver.store plug-in installed. Should there be a
> class with main method, (i'm asking this as the JVM launcher dialog says
> no class with main) in my model code. What is the main class that is not
> being available, and is there a way to debug and find where i'm going
> wrong.
> the problem.
> Thanks and Regards,
> VarunKumar.M
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590653 is a reply to message #49563] Fri, 08 September 2006 12:15 Go to previous message
Yes, offcourse i didnot remove a jar from the plug-in folder :-)
I just set the property of enhancer to use the class-path of project and
then added the plug-in dependency and registerbuddy in manifest.mf
Exactly what is said and nothing more and
now my Manifest.MF looks like this.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %pluginName
Bundle-SymbolicName: Library; singleton:=true
Bundle-Version: 1.0.0
Bundle-ClassPath: .
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Export-Package: org.eclipse.example.library,
org.eclipse.example.library.impl,
org.eclipse.example.library.util
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
Eclipse-LazyStart: true
Eclipse-RegisterBuddy: org.elver.store.jpox.runtime
I'm sorry i misinterpreted the error, Yes, it was a noclassfound error.
But the class is rite there and the corresponding plug-in is also shown in
the plug-in dependencies tree view. What might be probably going wrong.
We are a team of 5 and all started to install elver independently and all
were struck right at this point.
And one more thing, why am i getting the Java Virtual Machine Launcher
Dialog saying "Could Not Find Main Class: Program will exit"
See the print screen of the working environment also showing the expanded
tree view of plug-in dependencies.
http://img406.imageshack.us/img406/1863/elvererrordh8.jpg
Thanks and Regards,
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590668 is a reply to message #49593] Fri, 08 September 2006 15:08 Go to previous message
--------------040903010501090008050707
Good to hear that :-).
What seems strange in your screendump is the location of the org.elver.store jar file.
In your screendump it seems that the org.elver.store._0.7.2.jar has not been unpacked.
I just installed elver on a fresh callisto release and it all worked fine.
In the attached screendump it seems that the org.elver.store_0.7.2.jar is installed differently (it
is unpacked) than in your case.
Can you unpack the org.elver.store_0.7.2.jar manually in the plugins directory?
gr. Martin
> Bundle-ClassPath: .
> in the plug-in dependencies tree view. What might be probably going wrong.
> all were struck right at this point.
> expanded tree view of plug-in dependencies.
> Thanks and Regards,
> VarunKumar.M
The Netherlands
Content-Type: image/jpeg;
name="elverscreendump.jpg"
Content-Disposition: inline;
filename="elverscreendump.jpg"
/9j/4AAQSkZJRgABAQEASwBLAAD/4QAWRXhpZgAATU0AKgAAAAgAAAAAAAD/ 2wBDAAUDBAQE
AwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEPERETFhwXExQaFRERGCEYGh0d Hx8fExciJCIe
JBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh4eHh4e
Hh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCALGBUoDASIAAhEBAxEB/8QAHQAB AAIDAQEBAQAA
AAAAAAAAAAUGAwQHCAIBCf/EAGsQAAICAQQAAwQDCAsNBQIBHQECAwQFAAYR EhMUIQcVIjEW
VZQjMkFRk9HS0xg3UlNUVmF0dZWzJDM0NTZCcYGRkqGytBclcnaxCENic8LF JsHjRmWCg8NF
Y5ai4fAoZNQ4Z4WltcTV4vH/xAAZAQEBAQEBAQAAAAAAAAAAAAAAAQIDBAX/ xAA4EQEAAgEC
BQMBBgUEAgIDAAAAARECEiEDMUFR8AQTYQUicYGRodEyQrHB4RQVUvEGIxYk YnKi/9oADAMB
AAIRAxEAPwDov/s0exzZm0vZriM3lcPjshm8lQW1at2UE6qkoWRUUMoAAUJ+ Dnnt6nn1te5s
37NdvWFhyGz6HZhzzHia5HH4/XjW3tpZZPY1t6OIFm9w0DwB+AQRk/i1wP2j bwwsVx4M1DYM
8Xw8PQk+X8nFtede30HpMPUZTqazy0YW9G7Zqez3cmLTJYjAbfsV2PUkY2EF WHzBHX0OpT6L
bS/itgf6uh/R1yX/ANlfrNt/L5alTlq465PH5fxKzw+IVDdnAaeXkeqjkdfk fnrsvdvx68vq
uFjweLlhjygwmcsban0W2l/FbA/1dD+jp9FtpfxWwP8AV0P6Otvu349O7fj1 wapqfRbaX8Vs
D/V0P6On0W2l/FbA/wBXQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/Fb A/1dD+jrb7t+
PTu349Cmp9FtpfxWwP8AV0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9Ftpfx WwP9XQ/o6fRb
aX8VsD/V0P6Otvu349O7fj0Kan0W2l/FbA/1dD+jp9FtpfxWwP8AV0P6Otvu 349O7fj0Kan0
W2l/FbA/1dD+jp9FtpfxWwP9XQ/o62+7fj07t+PQpqfRbaX8VsD/AFdD+jp9 FtpfxWwP9XQ/
o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9 FtpfxWwP9XQ/
o6fRbaX8VsD/AFdD+jrb7t+PTu349Cmp9FtpfxWwP9XQ/o6fRbaX8VsD/V0P 6Otvu349O7fj
0Kan0W2l/FbA/wBXQ/o6fRbaX8VsD/V0P6Otvu349O7fj0Kan0W2l/FbA/1d D+jp9FtpfxWw
P9XQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/FbA/wBXQ/o62+7fj07t +PQpqfRbaX8V
sD/V0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9FtpfxWwP8AV0P6On0W2l/F bA/1dD+jrb7t
+PTu349Cmp9FtpfxWwP9XQ/o6fRbaX8VsD/V0P6Otvu349O7fj0Kan0W2l/F bA/1dD+jp9Ft
pfxWwP8AV0P6Otvu349O7fj0Kan0W2l/FbA/1dD+jp9FtpfxWwP9XQ/o62+7 fj07t+PQpqfR
baX8VsD/AFdD+jp9FtpfxWwP9XQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0 W2l/FbA/1dD+
jrb7t+PTu349Cmp9FtpfxWwP9XQ/o6fRbaX8VsD/AFdD+jrb7t+PTu349Cmp 9FtpfxWwP9XQ
/o6fRbaX8VsD/V0P6Otvu349O7fj0Kan0W2l/FbA/wBXQ/o6fRbaX8VsD/V0 P6Otvu349O7f
j0Kan0W2l/FbA/1dD+jp9FtpfxWwP9XQ/o62+7fj07t+PQpqfRbaX8VsD/V0 P6On0W2l/FbA
/wBXQ/o62+7fj07t+PQpqfRbaX8VsD/V0P6On0W2l/FbA/1dD+jrb7t+PTu3 49Cmp9FtpfxW
wP8AV0P6On0W2l/FbA/1dD+jrb7t+PTu349Cmp9FtpfxWwP9XQ/o6hN9JsPZ 21bm48ntDFTV
KnTxEr4yBpD3dUHAYAfNh+H5c6s3dvx6qfte27kN4ezvKbdxs1aK1b8Hw3sM VjHSZHPJUE/J
T+D56CCj3Z7NfNpQtbCjpZA5eriZac+HrCSGWyrNE7cEr0IUnlST/Jq2eV9m v8B2f/hvu/8A
vFb/AAr94+X99/8Agfffyaquf9mdbnDSbfKpYg3FTy2RsXrUs01hIA447t2J YBuADwPn6jUP
P7N90jOAQXMO2J+mibmLPJIs/HPxR9QhXkD5evr/ACabJu6BBB7Mp8mMXBT2 bLfMjxiqkNYy
l0HLr0A55UepHHoPnr83HT2PgvdvmtpYR/eF+KhF1pVV4kk54J79eR6fJezf iU6497M9sZ6n
7QtrQe6JRQwEmSeXIy0Za8kyzqwTxDIoDvy3HCFgB6866JufYk9mlt2piL88 iY3clbLztk70
07mOMEMqM3Y8/LhfQfP1HOkcoWecwnIo/ZfLkfd0VbZkl3xng8usVUy+In3y deOew/CPmNae
+32LtClQs3NkUbzZC/Hj68NLF1mkaaQMVHx9RwepHz+ZGqePZflhcN0SYkWT vv6QGbs3c0+S
fC56c9+ST1+9/l1bPart7M7jpYE4R6ItYrN18n1uSMiOIg/w8qrHklh+D5c6 bJubfvezXLUs
jYl23hsS+LkEeQgyeNggkqkjle/I68EfIgkH8epavS9m9hab18dtGZbxZaZS vWYWCo5YR8D4
+ADzxzxrnec9ludzlTMZPI5SiucyeTqXnhrvKlXpWRo0i7jiT1VyS4HPIHA1 s1/Zxl6uxGoY
/wB14/N1s0mXx7rannhSUdAfEdx3bsA4PAA9R6fM6TX9P8rUrpYHssrxiSxB sqFDO1cM8dVR
4q+jR+o++HI5X5jnWvM/s+h3o+1Ztq4eO0mJOWew+OriusAk8M8sfUNz6/Lj j8OueZP2NXjU
wgrT07zVsU1K9Xs3Z66SSvIZZJQ8YLN2Z2BVh6gL+LW/uj2V5fNSNGmQpU4D tCDCAxtIxWeO
wkvyI5MRCdeSxb1+R0mogjeV7X/ssahHkFh2Uack4rx2BHV8NpSORGG44LcA /D89JP8Asrjq
1rUkOyUgtCRq8rR1QkwT78oeOGC/h4+X4dcm3X7P9y15quSehjZ7eT3Ti5pK OOryS06sUEUi
F3+EHoe3LHgAfj9dTm3fZXlau48Flco+Gngr5XJ5G7UjDGOM2Y0WOOIMvDBS gPr14/BzxqzE
MxMuh0avs0vW1p0qOz7Vl4hMsMMFZ3aM/JwoHJX+X5a+alf2ZXK9uxUp7OsQ 0lLW5IoazLAA
CSXIHCgAE+vHyOuZ4P2P5Wph9p0ZbeMrS46tloMlZrFu8nm0ZImQlB2Khhz2 68cenOs21vZV
mMTic1UkXErZubfnxMVlL1mUyM6gKWVx1jT0JIUNxz6enoWy70vN277JquHy GWFbZ1itj64s
WPLwVZGVSPh9APm3ICj/ADiQB89bm1q3s63PhocthMJtu3WlVSTHRgYxsVDd HAB6uAw5U+o5
1RKXsrvwuY/ExUMEux/cE3hBiTcLcmbjqAy8+vYntz+DV39mmMy+C2fSw+Xh xkU9KKOurUHZ
klRI1UO3ZFIckHkcH8HrqbG6Z+i20v4rYH+rof0dRMUfsvlvtQjrbMe4kkkb QLFVMiun36le
OeV/CPwfh1IbexMODpPUrWshYR5DIWu3JLDgkAcBpCSB6fL5fP8AHriNP2d7 p3BkM8YlqYRI
95XMjDds1nFpgAfDMYK8PCxbn58eh+eiuwY2D2ZZOOxJjaezbqVh2navDWkE Q/GxUHqPQ/PU
Vlcn7LqVfF2K2D27lYcllocTFJjqdWZY55OeO5HoAOPXjk+o9DrnFH2L7nlT KJkczSia/ghQ
aaO3PO7TrPHKGPdRwjCPggccdiAD8zad1bD3FujauIxFtMDhpKear25mxMki DwI42RmjJjBE
vxfCCOBwPXTZN9lsnm9k0H9/GxovurQ/GtRfjX0ZfX/OHI5HzGs2Ui9mGKkE eUq7MouYxKFs
xVYz0J4DcMB6c+nPy51yzNeyre+QxFTDnI4NaNHGzUII4Z5q6uSSUsOqJ6sQ QGQkrzy3ryRq
t732NuavBc2/SxZy1vJYzE1HnFKZlglrIisYpyvhiM9SSWKn8HX8OnWjepl3 00PZyMwMOcZt
IZIjsKflq3jccc89OO3y9flrDuOnsfBe7fNbSwj+8L8VCLrSqrxJJzwT368j 0+S9m/Ep1Ql9
lmRh9ocue70LtWTNrlUlnu2ElgPYMVES/c2I4IViR6ehBHprc9olXdmTv7Xp 3aMNp4d5Q3q7
4+GVo4aEPPDTuw4WT4/Uc8H/ADeeDpG5OyftZD2YxbvxW14cDt+7eyT2Ywat KtIld4E7usvH
qh4+Q4Pr8+NTGJoezrLmYYnGbSyBgbrMK1avL4Z/E3UHg+h+euU4r2P7hr2s RUmvYZKGOiyk
BuweILky24nRXcFeCyl/l29APQnVl9l2wsztvcUeWyk2JjFXCRYeKLHh+Jwj hvHk7KPjPAHp
z8z66R8rLoH0W2l/FbA/1dD+jqobkyeyMNu1NrxezhMrkWoC/wBaOKplViMh j5JkZPXsP+I1
aa+Jhgz9jNLayDT2IxG0T3JGrqB19ViJ6KfhHqBz6n8Z1QvaBsPKZz2jw7li xW28xSTELR8r
lpZF6yCZn8QBY3HyPH+s6bIuCVPZyclDipMVtSHJyoHWjJXrCxwR2+845+X4 tQO2M17Odw1t
uWKWzcdGm4fNeVE+Ppo6eXJD9l7djz1PHQN/L11r7L2dm9t7qyNlYMBZx2Rv Needw/m6xZOP
CT4eCin0X1HAJ9PXjUZsj2cZ7B/9nfmreOf6M+8/OeFI57+Z7dPD5Qc8c+vP X+TnVmki12xq
ey7JuUxtbZd1hEZiteKrIRGDwX+EH4QQRz8tfNUeyy1Ss3a0Gyp6tTjzM0cd Vkh5+XdgOF54
Pz1yD2W+zjcNvbW37eTx+Px8dGhk4TVswyw2bL2O8YSwOAQgHBBB54I4H4dS yeyXcs217WKs
ZLHQpHeqWcfUimkZFSFXUxPOEWTqe/I9D1I9PmdKjz71h1nHYTYuSpx3Mdgt s3K0g5SaClBI
jf6GCkHVJq7s9ms24GxT7CjrxjNPgxekw9byzXFPHhgqS3r+AlR8/Xj11Oey vbVnamAtUbEF
Ou8917PStZmsL8SoCS8vDFiVJPoB/r5JhdnezOtRz+WzWfK3LEu4bGVx8cdq UwwhyCjtEeE8
UfF68Hj09fQcNrN2/t3N+yfMbZx2fkxW2cRXyPieXiydapBK3SRoz6eoPqp+ RPzGvvI5n2Q4
3dT7byNTadO4lQWneerWjiVSQAhcgAOQQwX59SD8tc5k9ju8m2ficCcxjHjq Y21WkhFqeOMT
STySLKCiAyDq6qVYADgng/hteJ2DnMXunbeZRMHdSpt2thclHYZweY2UtLH8 B7ngcDt1/B8v
wSKXdubQ3X7I9yU796HCbfx1KnIkbWMhVpwq5cuF4HYsvPQkdwpI+XPrxY7M fsvqzRQ2a2zI
ZZolmiSSKqrSRs3VXUEeqlvQEehPprneJ9ledxe1dnxQtgbWWwEttp4LHc1L QnZ+CzdOxKBh
xyvz51v+zv2W2tt7kw97I2MfkquO2+2PBZSXFhrTzFlUrwFCuyg88/yDViuq TfRcyPZYLb1D
DsrzCSSRPF4dXurp9+pHHIK/hHzH4db2Lw+wsrTW5jMJte9WYkLNXp15EJHz 4ZQRrmk/soyE
8sss4w0sk2+PfsjP2Jej6/cSenq3qfh+99fnq5+zPbV3a0W4orMlUx5HPWsh WWuTxHDJ16qQ
QOGHU8gcj+XTY3WL6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HqLTU +i20v4rYH+ro
f0dPottL+K2B/q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof 0dbfdvx6d2/H
oU1PottL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof 0dPottL+K2B/
q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/Ho U1PottL+K2B/
q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q 6H9HW33b8end
vx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q 6H9HT6LbS/it
gf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW33b8endv x6FNT6LbS/it
gf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q6H9HT6LbS/itg f6uh/R1t92/H
p3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW33b8endvx6FNT6LbS/itg f6uh/R0+i20v
4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp 3b8ehTU+i20v
4rYH+rof0dPottL+K2B/q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4 rYH+rof0dbfd
vx6d2/HoU1PottL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4 rYH+rof0dPot
tL+K2B/q6H9HW33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdv x6d2/HoU1Pot
tL+K2B/q6H9HT6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPott L+K2B/q6H9HW
33b8endvx6FNT6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1Pott L+K2B/q6H9HT
6LbS/itgf6uh/R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW3 3b8endvx6FNT
6LbS/itgf6uh/R0+i20v4rYH+rof0dbfdvx6d2/HoU1PottL+K2B/q6H9HT6 LbS/itgf6uh/
R1t92/Hp3b8ehTU+i20v4rYH+rof0dPottL+K2B/q6H9HW33b8endvx6FITM 7f27C9GrR2vt
pJ7lnwVkmxkTJGBG8hYqAC3pGQByPUg8+nBfQip/ANmf/e0v63WfNSFcpgiz gf3e4HP4zWnA
/wCOoneOe31jMnHX27sRtwVGhDvZ96w1ej9mBTq4JPACnn5fFx+DVikbzbIr dT0x2yi3Hwg7
bUAn/T4utHG4jC5tq/u/bO1aCtj69yQz4iOckzd+EAHTjr0PJ9eeR6DjUls7 KbjyGMkt7l26
du2I5iogN2OyGjCqfELoAB6lhx/8Hn8Oo7Ykjf3Oit8ZwOOIH4SB4/P/AKj/ AG6bCl5beXso
xWUt4u/ldmQ26c7154/oXO3SRGKsOQSDwQfUHjVwr4fBtiMdnYcTtDI4261Y p4eAFd3jnZVR
wWZuOO6twV+XI9DrDt65uPB1bePk2ZnLf/ed6dJq81Pw5EltSyoR3nVvvXHo QDzrLi6l3E+z
LbeLyKeBarR4qvLGWB6yJJAGUEeh46n5c/LTYftjD4NcRkc7NidoY7G0msl/ EwAsOkcDMruS
rLzz0ZuAvy4HqdRbTbEFDBXRe2G8GfnWviym2ezWJGPXgKJOV4YhWLABSQG4 Ppqy4qzdh2xk
J8bV8/bhs32irCQJ4sgsSlYyx9F7Hgcn5c865D7PvZhvHaG9MXvQYjD258lN ImSxsCLEMOkz
c94GLEHovKkL68EovYN3DYdA3d7Ndp7jiO2Nybd29ZgtVprEFjH48U5YJE6x kghm5PE3IPPA
I+R9OP56bk9n2TxO4slihZqOKduWv28Rjz0crz96PxfiGv6Y25G+luORm+MU LRI/CAZK/H/o
f9mvDHtF/bB3H/Str+1bSyntz2bfta7U/oOj/wBPHrZym2dtZSRJMnt/E3nQ 9kaxSjkKn8Y7
A8a1PZ0ePZntT+hKP/TprR9qeUyWL2ebOImsw3HyOPrK1ZYmlKzXIYnVBKDH 2KOwBb0BIPp8
9IymJ2k6LZBFDBCkMMaRRoOFRFAVR+IAfLX3yNcr3dubO4HbF1FsZiLJDa+Z ycUmQ8mZIpa3
gCMssKGNj915HDccchgxI6zN/fs0W9JNv0tv3r0Na3BTt2YoZ28J5VR+w6xN F0VZUZi0iEDt
wDwOYL3yNORrD31X/aVlLmH9nO5stjpvAu0sRbs15eobpIkLMrcMCDwQDwQR qLSzcjTkaoNf
N5fA4G/kcpW3Hal8atXqQ5Z6CeJLNKIkVWqA9VLyJ2Lg8D1APqNaGN3duM52 1RvVoRbbc7Y2
vVjtL4EajDC0FaXwezI0gZueoYdx8wvRqOm8jTkaqfsszOZz3s/weazsFSK3 eoV7HNaYusge
JG7kFF6MST8A7AenxHVm76gzcjTka55mMvmqO+emWvZjG4aS5Whx0tSrXlpz dwi+HOxVpUdp
WZAR0Xgx8HknW9j97TWs9WrNiFjxl3J2sXUti1zK9iuJTJ2i6gKhNeYBg5J6 jkDt6I3J2XXk
acjXObXtL8DaOOz/ALl7ed2ja3J4HmuOngR138Dt09e3mOO/A46fenn0l7e5 M7DZxuKXA0mz
OQjnsJXbJMsMUERjDM8oiJ7cyxjqqMOSfXgc6tIt/I05Guf7r3/dweSjxcW2 rWTvxUIr12Gm
tibors6hImjgYOxMUnHieEDwPUcni9d9RWbkacjWHvrjfs89oN8Yinls1mct k6ybRbN5UXMc
lYxyqsTf3NxFH4qENNyR3UcR/EOw5DtXI05GuUZrfm6rm2LL43APibwyGNqr PZ8eKMx2rKwn
wzPVHMikgEeGyqHVuX46GWyu+5cFuKvg7FX3jXS1UoTXkeV5llnMaI0oSuII yWkUkGRT1IIX
1VTa3pOlug8jTkaqeL3FmsxYuS4rC0WxtezZqJPZyLRSyTQs8bfc1iYBPFQr 2Lc8At1PoDX9
p733Pe2ntVpsJjrmczWJ94hVyDRQtCkUBeRm8I9HLzoBGAwHP3/A1OlrTpnI 05GqRt7e1ncO
ap1sRh42x8+Go5eS1Yt+G6R2jMFQRhG7MBDz98B6n1HA5uPfVmKSN2bkacjV P9q9/M0tlu+3
sguOyc+QoVILLQrKIvHuQwsSrAgjq5/+ZwfXVdxftDu2LGbuSpWiWhiccZMf YlKLXuvauQTx
l0jd2PaJFUBW7cL1Hx8lWw6lyNORqgYL2iC+IPOYh6IGXOKuPI0iLXlNcTxt xLFG5Vg6Jyyo
ezDgEEE6lP2jSzQXMh7rn6vj8ZYo1jYXrKbtuxBX5PhhkLdImYksFDcAcqS6 ldK5GnI1z6Xf
uSgpZPzOFow5ChmExfl/PzSrOzVY7HaPw67SOeJPvBHzwpYkcEDVwe+s7ntz bdjxuKqRY69S
yLXY7ViSOaOWrchryFQYefh7N1Vuhbt8XhleCHS+RpyNUTYG/Zt2XU8Pb96r jrNQ3Kl14Z1R
07KFVzJEiB2VwwEbSAgN6+g5uvfUGbkacjVW9oFnPwYuq+BjuN/dai6aSQta Wv0fkxLN8Bbv
4fIIPwluATxqvS7/ABjsLhosamS3HdvrbZXtVZY5VFeURyiVK9dyro7rHx4Y HIPJH4RTpXI0
5Gub7r9pcmBx9fIvgpHh91Jk7lZzOLtSMglg8SQOqEBWHMjxgsrDkdSdSc+9 LFe5uua1iY48
Ntnt5q2LRaWXrUisnpF049BLx6uPkCOeSBaRdeRpyNUDdO4d3UdpjJSYqlj7 TZLGRQRQXvMN
Ik12GOSNy0SqhKOV5BbjsSCOATPbUztnLtla1+hFSu4u75OxHDYM0ZJhimVl cohIKTJ81HB5
HrxyVCw8jTkaw99cx3/uDclfeOYxuDyGXFmthKlrGUKmNWeCxakltqRPIYmM aN4UQ5LxgDsQ
eQdIiydnVORpyNUKLfOQODyeZlwEKVa+UlxVJVvdpLU63TTQsPDAjRn4JPLE cn0PAJ+628bU
+WxuNt0DTujPvibkcFlZYgRj5LasHaMM6lfD9AIyGPzIBDKF65GnI1zbAe1G PI427mrO38jV
wsGKly0VzwJ+HhjAbq3iRIndlbsoR5AQG9RwOdjdO497Y/bMOQTBYapZlyeN rpG2UeT7nPaj
idXPgcK3xqvp2A7MwJ6gNFdB5GnI1q1ZJ2qxNajjisFAZUjkLorceoViFLAH 5Egc/iHy1k76
FM3I05GuHbM9ouYg2zHm7uRyecMOzJM7fgv0kpc2ESJ1WuwhTvG3MoLASBeI /X4h2vm697S4
XI5GhXxHnZqiYoxjzIj8Vr1ySqF+9PXoY+3Przzx8PHOrSLryNORqvbTztnL tla1+hFSu4u7
5OxHDYM0ZJhimVlcohIKTJ81HB5HrxyZvvqKzcjTka55l8luCf2qTYenZzq4 2vjaFhlx6UfD
jeWe0rtMbA8QqViT0j5ICt6ckc4LHtFnqU60VfE2sjkLV/KxxxESuFip3GgZ ia9d2A5MYUFP
QHhnJHZko6VyNORrnMu+b1fJZG1LRtCE4bCz1MZYVYZY7V2zZh6SNwSp7CFW 5569SQPnzF5X
fOYo4bdC5fI0MJf+kNfD0JWmjeGkJKlWRnDuih+oeaYdx68dT6cDSdppelut cjTka5fj/aVZ
bZ2BySwY669pJob+QluGCjFPAwjfmVI5AA79mQkBSqk9vkDY13XZO/H23Jj6 1WEHiOezaeOW
19y8QtBH4RSQA/CfugYdXPXgDmzFSkbwtvI05GucYHf9yzU2kJMdFHFmcXSt tdyFwxBnnA5i
Rkg8OSYfPqfCDF16j1PWW9meb3Bm8RdtZ6pj4GiyV2tC1Wy0nYQ25ourAxpx 1EagNyS3zIU+
moq48jTkaw99V32h5S7htt+96U/hLTt1pbfwKwNXxkE/PIPHEZduRwfh+ehS 0cjTka5Fjt6b
ht5UYo3AJsrm4JcZIIU4THeLYLIPT4u0NKRux9QbA4I4XiZpb2zFm5UxmLws eQt2psyQ1vIC
FY1pXlrgEpCfRu44+HkcAEseX0jeLJ2mnRORpyNcp3d7SMnPsHIZTauOCzrt MZ5rFidVaos0
UpgKoUZZWBiclT1Hwj1PPGrDkt7TVM7ZrJiFlxlLJVMXbtm11kSxZ8Lw+kXU hkHmIeWLqR2P
APX1tb0i68jTka5fkPazDTltQPhWM1aG2GTzI5a1FLOkNcfD6mUVZmDfgAX0 PbXSlc9R2AB4
9QDzqL1pm5GnI1h765btDe25cnifZo13G5Ks2Y8L3hemFXwrvONsTHqsbs6d pEVx8Cei8Hjn
qQ6xyNORrklv2nZLK7F3HlsVhb2OSLbtvKYvIvXmKApHzH38WFY+57KwVGlU hW5PAHNgtb5u
19wZGq2CjOLx+YqYma4Lv3UyWY65jZYunBAeyity44HqOfUC0i98jTkaw99O +otM3I05GsPf
TvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNOR rD3076FM3I05
GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTN yNORrD3076FM
3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O +hTNyNORrD30
76FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTka w99O+hTNyNOR
rD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTvoUzc jTkaw99O+hTN
yNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05GsPfTv oUzcjTkaw99O
+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hTNyNORrD3076FM3I05Gs PfTvoUzcjTka
w99O+hTNyNORrD3076FM3I05GsPfTvoUzcjTkaw99O+hT9t1q1yu1e3BFYhf jtHKgZW4PI5B
9PmBqP8Ao3tz6hxX2OP82t/vp30KaH0b259Q4r7HH+bW3kMbjcj094UKtvw+ enjwq/Xnjnjk
enPA/wBmsnfTvoU0Po3tz6hxX2OP82stTCYSnYWxUxGPrzJz1kirIrLyODwQ OfkTra76d9Cm
rbwmEuWGsW8Rj7Ez8dpJayMzcDgckjn5AaxfRvbn1Divscf5tb/fTvoUx47G 43H9/d9CrU8T
jv4EKp245454Hrxyf9uvB3tF/bB3H/Str+1bXviJuW/1a8D+0X9sHcf9K2v7 VtWB7Y9n549m
O0/6Eo/9Omv3deNlzOFalXlqxTrYgswyWoHmjSSGZJUYokkbNwyA8dwOeOeR yD++zqKKb2Z7
UWaJJFGEonhlBHPl01NGlQEhjNSsHChivhrzweeDx+I8H/YdSbshVPo02Wpz rvGTH5azLUs4
/wASlWmpp5SwI/FiKmaQ8sYl+MMCOBxx6k7trbuIsZoZhorUVztGztBcmhSY p94ZERgknHy+
MH09Plqf8jS/gdf8kPzaeRpfwOv+SH5tTctg76j9y49M1tzJ4aXwjHfqS1mE qsycOhU9gjKx
Hr6hWU/iIPrqX8jS/gdf8kPzaeRpfwOv+SH5tNy1H27tC1BjMljdy5SLNVbo jARTcUx9STyD
PamIPPUgoUIK8+p44ksZtLb+Nmjmq1JvGjyByQkmtzSubJrmuZCzsSx8IleD yPw8c+urN5Gl
/A6/5Ifm08jS/gdf8kPzabiH29h8fgMauOxSTRVEP3OKSzJKIhwAFTux6IAA Ai8KPwAake+s
/kaX8Dr/AJIfm08jS/gdf8kPzabraiZfaOTv7zTNe9qBoLagseSnr25OTGF9 eBbWHvyvKt4J
6kKeGK8marbYwVbOtmoabLcMjyjmeQxJI44eRYi3RXYcgsqgnk8n1PNh8jS/ gdf8kPzaeRpf
wOv+SH5tXdNlOj9n+0kisQjGzNFPj58a0bXp2RKs3XxIUUvxGp6LwE468fDx qXzuFxua8ub8
U3i1mLQTV7MleaMkcN1kjZWAI+YB4Ppzqa8jS/gdf8kPzaChSJAFKuSfkPCH 5tTctXMjtbC3
zWexHdWWvXFZZochYhleIf5jyI4aQc+vxk+pJ+ZOpzvrKtOgwJWrWbhip4jX 0IPBH+kEEa+v
I0v4HX/JD82i2wd9QsW18BFRxVFcchrYmqadONnZgkBjEZjbk/GpUAEPyCVB PqARYfI0v4HX
/JD82nkaX8Dr/kh+bSi1Zq7SwVemaaxXZa/jVpljsZCxMEavIJYendz0Cuqn qvAPHBBHpr8y
Wz9u5HLHKW6czWTZgtsFuTJG88JQxSNGrhGdfDQdiOSFAPI9NWfyNL+B1/yQ /Np5Gl/A6/5I
fm03TZW325SgvWspiTLSyM3eRSbE5qmZlK+JJWWRY3PyJ+RPHzB9RDYDYNOv gIcXmpY7ZrSu
aj4+S3U8vEyKhhQtZkdU4X7xXCccfAOOTffI0v4HX/JD82nkaX8Dr/kh+bSl tEY7EYvHXGt0
aaV5WqQUvuZIUQQmQxIF+9AXxZPkPw+vyHEh31n8jS/gdf8AJD82nkaX8Dr/ AJIfm1ZuU2Qe
68bLmcK1KvLVinWxBZhktQPNGkkMySoxRJI2bhkB47gc8c8jkGv4jY6G5n7m 42xN6xnPKmzJ
jqdikzNXJMbEmxJwykqVZOhBHPJPHF88jS/gdf8AJD82nkaX8Dr/AJIfm1Ft UpNjbXkwGTwc
2Plmo5Swtq6styZ3mlURgOZC5cMPCj9QR6rz8yedrMbaxN+vkR5SBZ71KKmz v3KBIWkaH4VZ
eOjyuwKlW9R8Q4BFj8jS/gdf8kPzaeRpfwOv+SH5tNy1E2/sDH0sVZq5W1Pf sWcn7zaxDPPA
8c3grCDG/itKv3NOCTISezcng8ak6Oztu0Uxy0qk9f3bLNLWaK7MrKZpfFlD MH5dXcBijcqe
B6cAas7UqCRvI1SsqIpZ2MagKB8yT+Aa/fI0v4HX/JD82m6WgMLt3EYa29jG xWoOysoh85M0
EYZgxCQsxjj9R/mqNTHfWfyNL+B1/wAkPzaeRpfwOv8Akh+bTctFZrGVMvWS vca2qxyCRGrW
5a7huCPv4mVuOCfTnjUdJtLb746nQWpPBHSZ3ryV7k0M6NISZD4yMJCXJJbl viPqeTqzeRpf
wOv+SH5tPI0v4HX/ACQ/NpubOcb59n0u4JFiqXsdXpHHLj54rcFyZ54lLcLI 8VuLxFAY8dwx
BLHty2rlDisbE2TK1UYZWXxbquS6zN4SQ+oPI48ONF4Hp6fLkkmV8jS/gdf8 kPzaeRpfwOv+
SH5tFvqrVXaeDr0TRWK7LW8avOsU+RsTLG8EiyxdA7noFdVPVeAeACCPTUnR oU6Vq/Zqw+HL
kLAs2m7E+JIIkiDcE+nwRIOBwPTn5kkyXkaX8Dr/AJIfm08jS/gdf8kPzau6 bMHfVazOHz53
HNmdv5TC0JLFSGtYN3FzWncRPKycFbMagDxn9OvPqeSRwBbPI0v4HX/JD82n kaX8Dr/kh+bU
3EG238M2Es4VqQNCzNNPLEZG9ZJZWmdw3PKnxGLAgjqeOvHA4jV2jTr5HCzY +U16+NvzZCVJ
C881qd68kAZ5ncseElbnt2J4QAgLwbd5Gl/A6/5Ifm1+NSoKFLVKy926rzGv xHgngfy8An/V
qxcGyu43a+Dxzz+VrTCGeN4nqvblkrBHPLKsDMY0B/Eqj8Xy1jj2hgUxM+K8 O/JTmMR8OXJW
ZPCMTB4zEWkJi6sAR0K8FR+IcWfyNL+B1/yQ/Np5Gl/A6/5Ifm1KW2nVjStW irxtKyRIEUyS
NI5AHA7MxLMfxkkk/hOsvfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03S3N6ex80sGH x93JbXsYvF1/
JRV0wllG8o0YieHu11uQ0YA+MOOQrEEqNTtPZO2qpmZKdmV52qNJJYvzzOxq ymav8TuT8Dkn
jn1+R5Hpq1GlQEhjNSsHChivhrzweeDx+I8H/YdfvkaX8Dr/AJIfm03NkbRo U6Vq/Zqw+HLk
LAs2m7E+JIIkiDcE+nwRIOBwPTn5kk7ffWfyNL+B1/yQ/Np5Gl/A6/5Ifm03 LVPM4fPncc2Z
2/lMLQksVIa1g3cXNadxE8rJwVsxqAPGf068+p5JHAGextPATVooPKzwiKzY tRyV7c0MqSTy
NJMVkRg4DM7EqDx8hxwBxZfI0v4HX/JD82nkaX8Dr/kh+bTctXZ9r4KeGzFP SaUWaUFGYvPI
zNFAztEOxbkMrSOwcHtyQeeQOMWI2ht7F3Vu1Kc3mVsva8Wa3NMxmeJIWkJk Y8sY41Xk/Ic8
ffNzZ/I0v4HX/JD82nkaX8Dr/kh+bTctV8ns7b2SNsWqtkpdleW1FHenijnZ kSNg6I4VlKxo
CpBU+vpyzc7cmAxcmfjzkqWZbsTF4u9yZoo3MZjLLEW8NW6Fl7BQeGb19TzO NSoKFLVKy926
rzGvxHgngfy8An/Vr98jS/gdf8kPzau5srEez9vxw4qBK1kVsTFXhp1/PT+C iwEGHtH36uyk
AhnBPIB59Brfw+Hx+InuS49JovOTNPNGbMjx+IzMzMiMxVCzOzHqByTyedTH kaX8Dr/kh+bT
yNL+B1/yQ/NqbmzB31C70xl7Obes4ilax0CW0aC0L1OSxHJA6MroFjliYE8j 4u3p6+nryLD5
Gl/A6/5Ifm08jS/gdf8AJD82m625nU2RuWrbw9uDM7TSfC1DTx7+4LR8GEqq lfW/8XooHLck
evr6nm4Y/b+HoXortSn4diHzfhv4rnjzU6zz+hPHxSKrfyccDgemps0qAkMZ qVg4UMV8NeeD
zwePxHg/7Dr98jS/gdf8kPzau6bKfkNgbSvYitibGMlFKtjxjEiiuTxdqoXq InKODIoHy7k8
Ekj1JOt+3tjBW84uZnps1wPHIeJ5BG8kf3jvEG6O6+nDMpI4HB9BxYfI0v4H X/JD82nkaX8D
r/kh+bU3LVe1sza9q3NbsYmN558jDk5HMj8mzCAI3+fpwB96PhPJ5B5PNh76 zihSJAFKuSfk
PCH5tfK06DAlatZuGKniNfQg8Ef6QQRpVFsXfVK29tXN0H2/Vv5Tb9jF4Hjy NeribEMkXWu8
CcSPbk54SRh8StyCfkeGF88jS/gdf8kPzaeRpfwOv+SH5tNzZVV2Ztxad+iK lryV+rNUnqef
n8ARS/3xUj79IufxoFI/BxrBV2Vil3RlNwXTJbsXcjFeijMkiRxNHXhhQMgb pIVMRdWZeVLe
nqOTcfI0v4HX/JD82vxqVBI3kapWVEUs7GNQFA+ZJ/ANWLg2lh76d9Z/I0v4 HX/JD82nkaX8
Dr/kh+bU3LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/wAk PzaeRpfwOv8A
kh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/JD82nk aX8Dr/kh+bTc
tg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/ACQ/Np5Gl/A6 /wCSH5tNy2Dv
p31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5 tNy2Dvp31n8j
S/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8AJD82nkaX8Dr/AJIfm03L YO+nfWfyNL+B
1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfW fyNL+B1/yQ/N
p5Gl/A6/5Ifm03LYO+nfWfyNL+B1/wAkPzaeRpfwOv8Akh+bTctg76d9Z/I0 v4HX/JD82nka
X8Dr/kh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/J D82nkaX8Dr/k
h+bTctg76d9Z/I0v4HX/ACQ/Np5Gl/A6/wCSH5tNy2Dvp31n8jS/gdf8kPza eRpfwOv+SH5t
Ny2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8kPzaeRpfwO v+SH5tNy2Dvp
31n8jS/gdf8AJD82nkaX8Dr/AJIfm03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5I fm03LYO+nfWf
yNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LY O+nfWfyNL+B1
/wAkPzaeRpfwOv8Akh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d 9Z/I0v4HX/JD
82nkaX8Dr/kh+bTctg76d9Z/I0v4HX/JD82nkaX8Dr/kh+bTctg76d9Z/I0v 4HX/ACQ/Np5G
l/A6/wCSH5tNy2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf 8kPzaeRpfwOv
+SH5tNy2Dvp31n8jS/gdf8kPzaeRpfwOv+SH5tNy2Dvp31n8jS/gdf8AJD82 nkaX8Dr/AJIf
m03LYO+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/yQ/Np5Gl/ A6/5Ifm03LYO
+nfWfyNL+B1/yQ/Np5Gl/A6/5Ifm03LYO+nfWfyNL+B1/wAkPzay+7sfGOZa Vdm/AgRfT/T6
f8NNy2n30762zWqfgo0wPxeXT82vzy1T+BU/s6fm1S2r30762vLVP4FT+zp+ bTy1T+BU/s6f
m0LavfTvra8tU/gVP7On5tPLVP4FT+zp+bQtq99O+try1T+BU/s6fm08tU/g VP7On5tC2r30
762vLVP4FT+zp+bTy1T+BU/s6fm0LavfTvra8tU/gVP7On5tPLVP4FT+zp+b Qtq99O+try1T
+BU/s6fm08tU/gVP7On5tC2r30762vLVP4FT+zp+bTy1T+BU/s6fm0LavfTv ra8tU/gVP7On
5tPLVP4FT+zp+bQtq99O+try1T+BU/s6fm08tU/gVP7On5tC2Kq3Mh/0a8Ge 0X9sHcf9K2v7
Vte+kigjPMVevGflzHEqn/aBrwL7Rf2wdx/0ra/tW0ge3fZr+1rtT+g6P/Tx 6lj/AJRWv5lW
/wDWTUT7Nf2tdqf0HR/6ePUsf8orX8yrf+smkpDFm8vQwtVLWRlkjieQRqUh eU9iCfkgJ+QP
r8tasO5sVYpG1V85OPkka05RJK3BPVVZQSeAT/oBJ4A51+7ip0shbwtO/Ugt wSXyDHNGHUkQ
TEeh9Pwak22tt1cdYonC0Y6k6dZI44AgP4uOvBB/ER6g/L11vLRPAymNso/L k4zlxI4sRtp/
VioXBZMsTxtDZgYrLEwI49SAy8gdkPU9W44PH4CCBtap2c2TtjdWFzu1s7h4 bFGS74kqEnus
zwxuZVbnlX5c8EH0Hp8vTVX9insF2b7MLc+Sp+LlsvI7CK9cRe8ERJ4RAPRT x6FvmfX5A8a8
3pss8uFE8Tm9PEiIy+zydZ1hMrmboiIR36cs5Hr17fiP4NZtR08nWWYhupWY FfTn1KKOP+Ou
8MN2VpkZAEiPc8D7ofnxz+L+Q6+onEkSSAcBlBH+vUfFO7zqsrjlfiAHX19O PmGP49blE80Y
D/8Ac1/9NJGbXwWfoXCBgDxwD6/Pj5a+LrdYOeSB3UHg8ehYA60ZYldQnwFR yAWIY8ck+vZT
pECSRg6hhyOfxjg6zVv8Ij/8Y/8AXUdWbi0B2PLq7MO5I+Y445+Xz/BqRrf4 RH/4x/66CNwn
+Byfzqx/bPqK3tvHB7Vxlua9kaIvRVWsQUJLSxzWCAeqqvqx7MOoIB9efxal cJ/gcn86sf2z
6qXtjr5lsCk2EvA3XtVoqtGWBZFaUTBvFj6jxBIigufVl6Rvyh9WDGLpnizM YzMc1mw2fxmY
u2K+MnFpa8MMrzxkNH917FU5B+/CqGKkDgOh/DqV1wLK5DbmVtYyrt3DQy5M 3IuKBkaKyZ0b
rJ5gjmRJUHiN4/qyEOefU97X7UvY9t32p7TqVs/RlxOapxeDWvpN5iaHqSOD ITzNGfvh34Yh
uT0YkCYzqi6px4HH92J+HUtfhIAJJ4A1UPZT7ONr+zXbq4fbdIIW4Nm3Jw09 lx/nO3+3gDgD
n0Gp3ddazd2tlqdL/Cp6U0UPrx8bIQvr+D1I0l3ymYxmVbn33ZsVp7+DwRvY 2Bwj2p7JhUk8
9SoCOep49CePwfLkczW0tzU9wxTCKGWtar9fHgk4JUNzwwI9GU8Hg/yHkDXO vYvueltn2eZ2
7uWRJFa0Ioq3X4pyY+PDCkev4efwD151r+xmGXN7pzVizjK0WKkpywy0x2ki CysnWM9+e3wp
Jzz+6+QBA14eFxeJrxubienZ8vg+ryyyw+1ero7Vprh+D/8AZh9m2L9oku6R Wms0uRJWw8/D
VoJeeS3r6uvy4RvQevPI4A7eAAAAAAPQAa976qv5fcckObbCYjHe8sikHjyR mYRqi8c8c8MS
3HrwB+Efj1+bQ3VW3A09fwDVuQeskJfuCOeOQeBz6+h5AI/F66rGZx2X217T 7e96OPuZaK1S
MSV4AW6TdFQBgOSF+EHkA/h1Utq7lt4rcec3PnJEnveUeWxWPaHpy55QAIQp HgcfH1Hr6tyH
C+KeLlhxPtTt51ef02HqvU8f2+FjM1M3ttEdJt3bTXMPa17Ltl+2fbcM9ljD djVkpZWCPiWL
hiCjA8dk7BuUPHB544Prqf8AZT7ONr+zXbq4fbdIIW4Nm3Jw09lx/nO3+3gD gDn0GvZExMXD
05YzjM45RUws2b/ydy38yk/9NbWtXN/5O5b+ZSf+mtrTqdHxNIsS8sQCeeoJ 47EAngf6gdVv
bW7TmcDRygxFuNp4RNPFEjy+ArMAo5C/ExDq/XgHpy34u2nkrVmnBm4qV26M hJkVq15ei2GR
HijlZFjeRF6/E3yPIABPovIhfcuPx+1qGPXB5Fjj4liltWJaq+JCJBI4ceIR wCO6g+gKgElS
4ZxOFxs+BPsReWqI67RW99O3dzjiY48WI4k1jXxzdKhkjmiSaGRZI3UMjqeQ wPqCD+Ea/LU8
VatLZnfpFEhd2454UDkn0/k1805/M04bPhSw+LGr+HKvV05HPDD8BH4RqK36 bC7JzT1ZYopF
pSt2kjLjqFJYcBh6leQDz6Eg8HjgzK8Yl1wiMsoh8jdeJOQjpr5wl4Wl8Q1Z Ao4ZFC+oBLMX
HUAHngj58A72NyItuYZq81SfqJFimQqWQhTyOQOSOyhgPvW9D+AnmkyZtt3U g2exUkbY2ZX7
0yyspMYKEd/Xken4vQ+h55Fy9mtasmCe5CkfaeZ4y4X4ukJMSqWJPYKE4Hy9 Pny3Zm+fwePx
uLxYiKrr55+L18bgYcPC4WjUBn9147E3hjxBcyF7oHatTjDuin5FuSAOfwcn k6n9clqX8pTv
b7xFTI1MbuKe8s9GWy4jMsBbngOTx95wB6j8X4Dx7s8piNnyfU8aeHEV1/Zf qm4o54xO+Ov1
qyt0mlmi9IW+L5leV6r0IZueFJUH/O6zmuS7UOQt+0ClTytzH52zHAlq7ZrK CkTRxskYcgES
SKW4D8+vJ+fUFdL2of8As47C33vGtuWdbGMnabxMlHT4Vb4+fxfuHJ45cepH PPqQw5ennizq
9yue3nn3u3C42HFwicL+b7uz61cp/fMT/PX/ALB9Ytv4bFbfw9bD4WhBQoVU 6QwQp1VB/wDN
P4ST6k+p1lyn98xP89f+wfXobbWoCPLWLmQuw1bkESVioKCn5t/V5U9RBOXA 5hc8sij1A9WV
gs/qlPL5qfKQFzc8KRD4XbzHT7vbHPTtZ6/Ljnwo/veOfh8OPtwuDjxbjL9n Li8SeHUwncfd
uPlIa806TRSwzP642ao6tG0Q+UjEsCJPmBx6fP56mNUrac+P+k4xtCRJLFGG 2MgsNcLHBI0k
CqvZIYlYkRMflz8J9SANXXXDTGOWUYzcXt16fu3w+JHEwjKGqf8AKK1/Mq3/ AKyazzSRwxPL
LIscaKWd2PAUD5kn8A1gP+UVr+ZVv/WTUZu23DUkw8ll1WA3yZO7cL8EE0gJ /B8LIrA/gKg/
g1y4/F9nhzn2duHhryjFWrntVw0O5JcTFEk8cMhSWZbA5AH3zheOOo9TyWHo CfxauGGzuLzD
SpQss8kQBeOSJ4nAJIB6uAeCQfXjj0OuY7m2XDnL1/LYup7unvcOHlvFCW7B jI0fgswLFeeO
4PryQrcgSHsf2pfxWdyGTu3fMRpB5WJo5GeN2LgycFgDypRR6DjksOeQQOf+ 5em4/Eww9P23
583Pj8H1XCzj7H2Os3H7/wBnUNNNQO4RmLkM3uuF3o1lJsPBKyzSMD6onA5P Xjk9TyT6Dkgq
e3E4uOFX15NY4zk+8jnTFkEo0YIrUx79u8xQDqOSAQrc8cgEnhQWUE8sAZPG W0v42rejHCWI
UlUc8+jAEf8ArqjbDktZnzVATN7mqlCjAks5bsTGH/COOrH15AcfgI4v8aJG ioiqqKAFVRwA
PxDXn9NPqJzy93l0/wAfH39bduNHDiI08/P1a+U/vmJ/nr/2D6y2ZhBA0pRn I4CovHLMTwAO
eBySQPUgaxZT++Yn+ev/AGD6w7gkMWMMwB4jmidj+5USKWJ/kABJP4hr0cXK cMMso6R/Zywx
1ZRDM1ixBL0s1W6kEh66ySgEceh+AHk8+nAPyPPHpzkr2Yp2ZULh1ALI6MjA Hng8MAeDwfX+
Q/i1FRZZr7xQ0byAOJGaWNlYjp0+AEhgCTIp5IPABHHryPmuhtXJaebq1J5L 1Dw5kR/FhlSM
8OGRlHAbxvvfiBHI9OPX53pfXzxcsccp5/m9PF9PoiZ7J3TXD8H/AOzD7NsX 7RJd0itNZpci
Sth5+GrQS88lvX1dflwjeg9eeRwB28AAAAAAegA19Z42sf8AKK1/Mq3/AKya 2j6Dk61T/lFa
/mVb/wBZNfGcjty4izHQcpZZCIyGCnn/AEkH/wDL8I+YuGOrKIuiVT3l7UNu 7UyMNPKVskfF
AZZYYVZep/z+CwYr8xyFI9Dq3YfJUcxjIMnjLKWalhe8UqfJhryfv24lTdGR gzsFhrAk5WWV
WYPH1HXqfF+QXgccDjj5DXdP/Z6oXKWxFkngkrVrUzT1oXBUqp9CepLEduOf vvXn5D1LfX9f
6Dg+n4UZY5XP9WYymZqqdLrf4RH/AOMf+uo3Cf4HJ/OrH9s+pKt/hEf/AIx/ 66jcJ/gcn86s
f2z6+M0y5G5DRqmeYO3LKiIg5aR2PCqo/CSSB/68DUDb3Pap41crYxUb0fiM hr2xLLEA3Xhl
6he3IPw9vwNxyQRrZ3wbsGMgyNBGeajZWcqF5JXqyt/wYnn+TXCt1byuZOSz USCEwT2ROrRD
79iT1UKvqG9SOB6N2/CdejhcHPLTOON43WU9vn/Lw8fjZxnlhjNTVx2nztFT 1ejMfbrX6UN2
nMs1eZA8ci/JgdfGb/ydy38yk/8ATUL7MsbcxGxcXQyCsllI2Z0bjlO7s4U8 fhAYD/Vqazf+
TuW/mUn/AKa4ZVc1ye7G9rbWsDSv3cjr0SRYyvHqeevrzz6fffi/BrPrQELK jQANJ2bt4pYn
5cepPPPI4HoPn/J68QbvYenIYcngcgj/APL5a+ta/HVoV5Y8MB2b5nhT6k8f PUVltrYzI30t
yK8TduZVj9BL/p/Ef5R/+PSVhO6xzOyAdE7seeF545PBPHP+rSCGGvCsMESR RIOFRRwANY7r
OoQ9VaIsFcE8E8kAfg9R6+o0R9wTd4EkkiMbMOxXxFPA59PXn/8ALnX2jdgT +JiP9hI1rJKx
mmC9UjB447nktwDyB6cfP19fn/r5+bFOtkKMle3EskbO/ofwHsfUfiOg3dNQ +A27j8OWkiBm
nYniWQDlR+Ifi/0/h/4amNIWUYM/hPOy0/elQTRL2cGQAD1lBHPyJHgTcgHl fDbkDW5QtwXa
wsVy5jLMnxxsjBlYqwKsAQQQR6j8Gqc+26OI9oR3RZksSC11UO/Up4xY/BIO vAHArCMjj4oF
5bs3x7TX9vvPYaKruBubEviGqMgYvE7t4nHh/D9/2549OedfN9V9Rx4PG9vG L2+f025O/B9P
lnhqmFu01qYY3DiKRyI4u+Xj8wPT0k6jt976fPn5emsWerz2KiCGMWI0kDz1 SQPMx8HmPk+g
9SDwfRuvViFYke7LiTHD1xH4dXKMY1aZl9Y/JwXbc0EMcoWONJUlYAJMjlwG T15I5RvUgcjg
jkEE72qxeyeJzGQ4Xa/vyaKBGaUwQExKXkUIfGZWBDI/K8eh554OtTK7Jwu7 trZLA7nwMS4q
5Y8SvRbqGqARqvZOhKxt2DsCh/z/AF9Sw14vR+sz401ONxvvvX9K+Ocu3G4M YRd1Pbz9ly01
yb2KewXZvswtz5Kn4uWy8jsIr1xF7wREnhEA9FPHoW+Z9fkDxrrOvovMaxwT LMgYBl5Abhvn
wfkdaxjAZvFoeOxYnvwh5BPp8zz6Dgf6tfUcq2BCYF6hQD2446KeD1/1j8H4 Pn+LkNvTUFlt
rYzI30tyK8TduZVj9BL/AKfxH+Uf/j1MwQw14VhgiSKJBwqKOABpurJpppoh pppoGmmmgaaa
aBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpp poGmmmgaaaaB
pppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmvuJO78E8KPVj+IaD6j+5J4p++ Pog/+brFr7mf
u3oOFA4A/k18aoaaaag18jcr4/H2b9uQx1q0TTTOFLdUUEseByT6A+g9dQ1D eWBvOVryZD0H
zkxlmMEkgAAtGASSQAPmSQBrY3x0+hWd8RQye7rHYEcgjw251FYnbmNTcFwY 3Y2GqcUYOyTr
FCeHaYEjwlcEMBweSPl8tdcPbnHKJvV07deblxJ4kZRpquvdP43Ii25hmrzV J+okWKZCpZCF
PI5A5I7KGA+9b0P4Cd/Vb2Vj48dZzdXy8UUsF1IT1kMhEYrwtGncqpYKr8Dk f6eSSxsmvJ6f
3Pbj3eb0Z6b+zyNNNNdmDTTTQNNNNA0000DTTTQNNNNBA763PV2fgGzuQx+S t4+CRRckpQiU
1IT99YdOQxjT5t0DMByepAJGptTfmC3Hn8hgqrTV8hUjS1FHOU4vU348O5Wd GZZYG547A8qf
RgpIBkd27Zwm68bFjNw0vP0UsR2TWeV1ileNuyiRFIEqc8Ho4ZSQCQeBpgds 4TB5LL5PG0vD
vZiwLOQsySvLLO4XqoLuSQij0VAQqAkKBydUTGvAXtF/bB3H/Str+1bXv3Xg L2i/tg7j/pW1
/atpA9u+zX9rXan9B0f+nj1JwyCbO3JUSUIteCLs8TKCymTkDkDn5j1Hp66j PZr+1rtT+g6P
/Tx6m7ViCrCZrMyQxr82duBqSQxZChWvLCLAl5hk8WNopniZW4K8hkIPyYj5 /h1926y2oFhl
mtgL8mjtSRuP/qlYN/x1r+9qn73d+xTfo6e9qn73d+xTfo6zOOOXOF3hlx1C tQWUV/HJmk8S
R5p3mdm6heSzkn5Ko+f4NbWtD3tU/e7v2Kb9HT3tU/e7v2Kb9HV2Klv61LFF JpGfxZU7EMQv
HBI44PqD+Iax+9qn73d+xTfo6e9qn73d+xTfo6tlP33cnieJ5mft+P4f5P8A 4P8AINbcMYih
SJSSEUKOfn6a0/e1T97u/Ypv0dPe1T97u/Ypv0dLKbc8STwtFIOUYcEa0Pcl X98m/wDwfzay
e9qn73d+xTfo6e9qn73d+xTfo6WUyUaEFNmaPszMOOW4+X+oa3EkWFhK/bqh 7N1UseB+ID1P
+gaj/e1T97u/Ypv0dPe1T97u/Ypv0dLKfuD7eQLMjp3nmcB0KngyuQeD6j0I Ot7Wh72qfvd3
7FN+jp72qfvd37FN+jqXBT8wOHpYama9RCWd3lnmcDxJpHdnd2IAHJd2PAAA 54AA4GpDWh72
qfvd37FN+jr8kzNKONpJBbRFBLM1OYAAfhPw6twkQkNNRtfN4+zEJa5tTRn0 DR1JWH+0LrJ7
0rfvV77DN+jpcLUorMbH2tlrr3LmKXx35MjwzSQlyfmW8Nl7H+U8nUxicZj8 TSWnjacNWBTz
0jXgE/hJ/Gf5T66+Pelb96vfYZv0dPelb96vfYZv0dZiMYm4c8eDhjlqxxiJ +5vaa0felb96
vfYZv0dPelb96vfYZv0dauHSm9rnGb9je0svmbWVsyX1sWZ2sP0MXCux5JXt GSPX+X8A/ENX
n3pW/er32Gb9HT3pW/er32Gb9HWM8MM/4nfgep43p5meFlVsW1sJS23gKuEx 3ieVqqRH3IJ9
WLH5AD5k/IDUnrR96Vv3q99hm/R18yZenHG0ki3ERQWZmpTAAD5knrrUVEVD lnllnlOWW8y+
89IFwV+IJK7z13ijWOJnJYj0Hwg8f6T6a3daPvSt+9XvsM36OnvSt+9XvsM3 6Ols0i8ntOrc
zE2ViyWRpTzKBIIGjKkgAdgJEbqSFQHrwD0XkcjX3j9sQVrcdizk8hkBGQ6R WTF0VweQ3CIv
JHzHPIB4PHIBEj70rfvV77DN+jp70rfvV77DN+jr0R6riRjo1bOc8HGZ1Vu3 tfMiJLG0ciK6
OCrKw5BB+YI1p+9K371e+wzfo6e9K371e+wzfo689w6bo9tmbSa0lk7axPdE ZABVQLwxUnle
OpPwjgkcj1445PMzUrV6dZK1SvFXgjHCRxIFVR+IAeg1re9K371e+wzfo6e9 K371e+wzfo6k
RjHJqcssuct7UPuHbOC3AYzl8dHYeL0SQMyOo/F2Ug8fyc8a2velb96vfYZv 0dPelb96vfYZ
v0dWanm55YRlFZRcMeAwWJwNVq2Jox1Y3PZ+vJZz+NmPJb/WdSWtH3pW/er3 2Gb9HT3pW/er
32Gb9HSKgxxjGKiNm9rSyMge5jIESVmjsPK5ETdVUxOvJbjj5/g551+e9K37 1e+wzfo6e9K3
71e+wzfo6W1Te1G3MNUt2XsS2MmjvxyIcnYiQcDj0VHCj/UP5dZPelb96vfY Zv0dPelb96vf
YZv0dLhKfuHxdDE1nr0IPCSSVppCzs7ySMeWdmYlmY/jJJ4AHyA1u60felb9 6vfYZv0dPelb
96vfYZv0dLgjGoqIfsMgmztyVElCLXgi7PEygspk5A5A5+Y9R6euvzNYnH5m otXI1xNGkiyx
kMyPG6/JlZSGU/P1BB4JHyJ096Vv3q99hm/R096Vv3q99hm/R1JjHKKy3hqJ mJuEd9EML+PK
/wBb2v1mpyCKKCFIII0iijUIiIoCqoHAAA+QGtT3pW/er32Gb9HT3pW/er32 Gb9HWOHweFwv
4MYj7oprPiZ5/wAUzLe19LI6wGBWKxnkkD0+Z5PrqP8Aelb96vfYZv0dPelb 96vfYZv0dbyx
xyisotjdlxdCnjMfDQoV0r1oF6xxp8gP/mkn1JPqSSTrZ1o+9K371e+wzfo6 e9K371e+wzfo
6u0G8v3IyB7mMgRJWaOw8rkRN1VTE68luOPn+DnnW7rR96Vv3q99hm/R096V v3q99hm/R0sp
kv0Kt4J5hHJTnqySNGw5+Y7KQeDwPT5eg/ENfFDF0qUrSwJIZCvXvLM8hA/C AWJ4B4HPHz4H
4hr896Vv3q99hm/R096Vv3q99hm/R1j2+Hq11F9+rWrOtN7N7TWj70rfvV77 DN+jp70rfvV7
7DN+jrpcM0/YZBNnbkqJKEWvBF2eJlBZTJyByBz8x6j09dbutH3pW/er32Gb 9HT3pW/er32G
b9HUsp8XsDg79tLd7DY61YjPKSzVUd1P4wSOR8tSOtH3pW/er32Gb9HT3pW/ er32Gb9HWpyv
nJTfSRYWEr9uqHs3VSx4H4gPU/6BrQwfbyBZkdO88zgOhU8GVyDwfUehB096 Vv3q99hm/R09
6Vv3q99hm/R1mym9qPhwmGhvnIQ4jHx3CeTYSsgkP/1QHP4Tr9GWqFiojukg AkeSm9OeeP8A
N/kP+zX770rfvV77DN+jpsU3taWekC4K/EEld567xRrHEzksR6D4QeP9J9Nf nvSt+9XvsM36
OnvSt+9XvsM36OllN7WuKVbx1nMYaVeeGPzAJJI/4nWH3pW/er32Gb9HT3pW /er32Gb9HVsp
tGJOysBwVPI4/wBBH/zdZNaPvSt+9XvsM36OnvSt+9XvsM36OllN7XxNGssZ RuQPQgj5gg8g
/wC3Wp70rfvV77DN+jp70rfvV77DN+jpcFNqCIQqQGZix5Zm+ZPy/B6fIDWT Wj70rfvV77DN
+jp70rfvV77DN+jpcFN7TWj70rfvV77DN+jp70rfvV77DN+jpcFNueKKeCSC eNJYpFKOjqGV
lI4IIPzBH4NYMXQq4yktOmjpCrMwDyM7EsxZiWYkkkkn1P4dY/elb96vfYZv 0dbNWxBahE1a
ZJo2+TI3I1nTjOWqt1uaroy6awW7VeogaxKqdj1UfNmP4lA9Sf5BrB70rfvV 77DN+jrVpTYi
qVYbM9qKtDHPY6+NKqAPJ1HC9j8zwPQc/LWbWj70rfvV77DN+jp70rfvV77D N+jqRUciblva
a0felb96vfYZv0dPelb96vfYZv0dW4Kb2vmNEjQJGioo+QUcAa0/elb96vfY Zv0dPelb96vf
YZv0dLgpvaa0felb96vfYZv0dPelb96vfYZv0dLgpvaa0felb96vfYZv0dPe lb96vfYZv0dL
gpvaa0felb96vfYZv0dPelb96vfYZv0dLgpvaa0felb96vfYZv0dPelb96vf YZv0dLgpvaa0
felb96vfYZv0dPelb96vfYZv0dLgpvaajZ85j4Cgma1EZG6p3qSjsfxDlfU6 2PPJ/Bcl/V8/
6GllNrTWr55P4Lkv6vn/AENPPJ/Bcl/V8/6Gg2tNavnk/guS/q+f9DTzyfwX Jf1fP+hoNrTW
r55P4Lkv6vn/AENPPJ/Bcl/V8/6Gg2tNavnk/guS/q+f9DTzyfwXJf1fP+ho NrTWr55P4Lkv
6vn/AENPPJ/Bcl/V8/6Gg2tNavnk/guS/q+f9DWrBn8ZPK8UEliWSM8OqVZS V/0gL6aXBSU0
1o+9K371e+wzfo6e9K371e+wzfo6XBTe01o+9K371e+wzfo6e9K371e+wzfo 6XBTe01o+9K3
71e+wzfo6e9K371e+wzfo6XBTe01o+9Kv71e+wzfoae9Kv71e+xTfoaXBTe0 1pe9Kv71e+xT
foae9an7zf8AsU36GlwU3dNaXvWp+83/ALFN+hp71qfvN/7FN+hpcFN3TWl7 1qfvN/7FN+hp
71p/vN/7FN+hpcFN3TWl71p/vN/7FN+hr9960/3m/wDY5v0NLgqW5prT960/ 3nIfY5v0NPet
P94yH2Ob9DS4Kluaa0/etL94yH2Ob9DT3rS/eMh9jm/Q0uCpbmmtP3rS/eMh 9jm/Q1++9aX7
xkPsc36GlwVLb01qe9aP7xkPsk36GnvWj/B8j9km/Q0uCpbemtT3rR/g+R+y S/oae9aP8HyP
2SX9DS4Klt6a1PetD+D5H7JL+r0960P4Pkfskv6vS4Klt6a1fe1D+D5H7JL+ r097Y/8Ag2R+
yy/q9LgqW2is7dVHJ1kchI/DUgk/fkfh/k1oNmaxUqsFxFPzAozev+vrrH70 rfvV77DN+jpc
FS3tNaPvSt+9XvsM36OnvSt+9XvsM36OlwU3tNaPvSt+9XvsM36OnvSt+9Xv sM36OlwUz5Cp
Xv0LFC3H4lezE0MqdiOyMCCOR6j0J+WopdrYxZWmW1nFkZVRnGcuAlV5IBPi /Idm4H8p/Hre
96Vv3q99hm/R096Vv3q99hm/R1LhKfuJxdTFpOtTzBNiXxpXnsyTu79VXktI zN96ij5/g1u6
0felb96vfYZv0dPelb96vfYZv0dLhab2mtH3pW/er32Gb9HT3pW/er32Gb9H VuCm9prR96Vv
3q99hm/R096Vv3q99hm/R0uCm9prR96Vv3q99hm/R096Vv3q99hm/R0uCm9p rR96Vv3q99hm
/R096Vv3q99hm/R0uCm9prR96Vv3q99hm/R096Vv3q99hm/R0uCm9prR96Vv 3q99hm/R096V
v3q99hm/R0uCm9prR96Vv3q99hm/R1mqXa1pnSGXmRPv42Uq6/i5U8Ef6xpZ TY14C9ov7YO4
/wClbX9q2vfuvAXtF/bB3H/Str+1bVhHt32a/ta7U/oOj/08epCtF5rLWppT 2FV1ihU/JCUD
Mw/lPcD+Tg+vqRqP9mv7Wu1P6Do/9PHqYw682sof/wBLH9jFp1IY3vY+Nbby 24oUqSCKw8rd
FjYqrAEngeodf9vHz19Y+3RyNfzGPuVrkPPHiQSq688A8cg8fIj/AG6om8Gw SWNx+ezhoXly
dVoYhkGj7AR1SD4QmjBHIIL8ggDnn4RxI+w1aLbOY4+/Ndh8aMd5fmvFeEBf 77J/mhSR2HBJ
HC8ca4ZcXKPURwq2mLd8eFE8GeJ1iaXPw9PD1H5KO1Lk7ENYWTIK0ZiKTdUj YtJ8TDkc/Ifg
Py1kjvTnJRwlVeCWaSFXCdeCoYn/ADiTx1I+9A/+b6HBueHp4etGee3Nt+1e 8WONXqSSRrGp
DxnqSOW5+Y/0D119tdneuJIwivJP4UcRj7OCASQ3xKAeBz8+APx6Db8PTw9a Ve9Ysx1gghik
k8YuzjlfubdSBwfmfn8zxwfnrGuRvzQ1jXqpJI9SOw49ACW59Byw4Hp8/i+Y /wBYSPh6eHrB
mklLUY4ieZLBUqJmj7Dw3PBZfX8AP+rWK/YnxtaD4IyXLIVaVn6n5hyx9So/ DyPTn+T1Dc8P
Tw9abXLSWplY12jhsxQFQpDN3VPX5+nBbn5fIf69fNexZKpBHJGHeW03iTAs AqSkBfmPxj8P
oBoW3vD08PWvRtWblmPoIoojVhnYMpLcv29OeR+5/FrWjyN9sdYvGqixCq88 Zbj0IHIU8MSf
5fReOP5dKLSPh6eHrNBHMI/u7Iz/APwFIA/k9Sdc63ngsBJ7TYcxYMCXRieL +T5SKfb1WDzE
sV6OdgViVpGkieJ+VnXkkGOCdXtJa6WcXVmlM4j8Gwf/AH8R6SfLgeo+Y/kP I9B6a+YLFiCd
KuQKFn/vUyL1WQ8eq8cnq3z9OfUeo/CBTdmYLAR+02bMVzA904nihk+Uln3D Vn8vLLeknUBZ
VWRY4kiThYF4IAjngVOiWasVmBoJ0DxsPUfL/QQfwEfMEfLUnFbY9NacTzU5 1p3XLhzxBYI4
8T/4LficD/aPUfhA3NZDTXAs1Nuo7O3VncZNuKqaUm5TayM2XZoJIY2upAkE XisY3R1g4YJH
wIm4J59eiZXeV6nJnIxHSD0dz4zEV1cNy8NnyPdj8Xq48zNwRwPgHIPB5swL zprnlLeOesbo
xMXOJTF5DcF7EeW8J/NRrWhsnxC/fqez1weOnorr8yeRK5HciWcntXyEN1Ib uakpzC3Vs1HA
Wham5COELDmNR8QZfnwOygrBbtaO4P8AEOQ/msv/ACnXP9qby3jfxGGs2quF t285tSbN0q9e
N4FjmjWvxE7vIwKubK+vC9ep+++ep3AZi7mNn5z3lYikv1DLXsxJj3qGu3gK /hsjSScnhw3Z
WKkMOPkdJjZYXHTTTRDTTTQNNNNA0000DTTTQNNNNA0000DTTTQNNNNA0000 DTTTQNNNNA00
00DTTTQNfKur89WVuDweDzwfxax2GIZEJKxseGYf8B/Jz+P/AFfMjWGR6scr gXRATxygZAB6
AD0I/EBoNzTWKq7SQBmPPqQD+6AJAP8ArHB1l0H4xCqWYgADkk/g0UhlDKQQ RyCPw60PGglg
6z3/AA2deJI+yDqSPUeo5GtosFshYvUNyXX8C/8Awv8AWfwfh+f4DoM2vl2V F7MeBr61gsni
Svzx/fPw/wDhbQZEkVyQOwI+YZSD/sOvvUK1+N38Z64b4unlzBy/y5/Fzzx6 /i/9dSlM8wn8
QdwP5AGIGg/If8Otf/Eof/WXWWR0jRndlVFBLMx4AH4zrFD/AIda/wDiUP8A 6y6xZz/El7+b
Sf8AKdWIuaD3ri/rKn+XX8+tmCWKeISwyJLG3yZGBB/1jVT8/ha3iHLNueSe SxYINKtkJ4wo
ndQOYFZFIC/e+h44PHqOZHbT0nv2WxrZEU5K0Uqx3VnSRXMk4YlJgHXnqD6g c+h9eedeni+n
0Y6nm4XqIzy0p7WjkcnBSljjaOWZmeNXEQB8ISOI1ZuSOAWPA/CeDwCFbje1 U93RTUqcsAsV
loZK5EZnsNDzCe6Fz925Vx0Q8AhmUgAArwI/l+s4vE4XCnLCLe/gYY551K2a aoeE9z43cniU
pnvU4YAZbtZawihZ+/Al8CNT14QkliVBKkgEKwvmnpfU+/jM8pie9nG4XtzE I3c+cxu28Bcz
uYlmix9KPxbMkVeScxoPm3SNWYgfMkDgAEngAnVfve0vbVGAT3ae7KsRkjiD zbSyiKXdwiLy
a/zZ2VQPmSwA9Tq5ar2I2lj8bfgmS1dnqUe3urHzOprYvspV/AUKCOVJVe5b w0Zo4vDjZkPr
cVh1Xc3vLCYjNNhrEeas3krx2ZIsdhLl7w4pGdUZjBE4XsYpAASCep1YtV3N 7NwmXzTZmxJm
q1568daSXHZu5R8SKNnZFYQSoG6mWQgkEjsdAwm8sJl80uGrx5qteevJZjiy OEuUfEijZFdl
M8SBupljBAJI7DW3ufceL25DUkyZuk3bHlq0VOhPblll8N5Oqxwo7nhI3Ynj gBTrUwmzcJiM
0uZryZqzeSvJWjlyObuXvDikZGdVE8rhexijJIAJ6jUB7ZPor5/Y3019y+4P pE/m/e/heU/x
be6d/F+D7/pxz/nccevGnUSn/aFt5Zq8diruamLFiKtHLc2xka8XiyyLHGrS SQKi9ndVBYgc
kanbKeXy9WeI9RZZoplHychCysf5QEI/lBHr6Aa5Vvb/ALAvIYr6Ff8AZl7/ APpFhvKe6PI+
b/xlW79PC+P7zvzx/m88+nOur5L/AAzGfzpv7GXTKKIl84pPGlsXpT3kaaSJ Of8A3aI5XqP9
JUsf9I554Gsa52g1UWljyJgKeIJRjrHQrxz256cccevOs2E/wOT+dWP7Z9co 4u4S7Z3HiIsd
LJJtzHeZbIWI4UjE5WF+OQncdaqcK8yBWLccl+NXhcHPjZacJiNuvfb5jume eOEXMOxxSRyx
JLE6yRuoZHU8hgfkQfwjX1qsezqaSbDzNIkEbF4XaOCXxIUZ6sEjiNuzAr3d iOCQeeeTzzqv
1s1fi9oFmi00s0M28hSVZJpOIYvcC2OqAMBx4ik9WBXlmbjtwwxjq5Zc4/s1 Nc45Oj6a4ptf
fm5sX7K6N65ZxuVsfQSbN1piJGdZa0UQK2GLkyl2kBJHQ8o49fmLfurO7rwy Y6jFYxtrL2or
Fl4YMYWTwYvD7HmS3EqhDIoLFiW7DhRwdamKi5Zib5L5prn+z92bg3XlqJpr jKGOm23jMzKk
sDzTd7ZscxqwdQABCPUg/h9Dz8O3sLduR3JkjTlrVoWxtPw8z0VvgyHishij JPoq+FIx55JW
WEg+p5VvRa66a5Tj/aLnlqVsver4uzSubWv7hipVYnWzF4DQdIGYuwY8TMpI UfEvoBx67Q3d
vqDbdm7dxGPgnkuYuGhNKqCOVbdtIH5SKxKeFVwQ/Ydu33vwnmRus7c3TNNc 5fde6xkosCj4
VsiNzHDy2zUlEJiOMa8JFi8XsGHKrwXIPB+XI6/W3d2bnsXsI2TGIapkc1fw rpXryJIJKotf
dwzSEBWNRvufBIDj4zwebRbommuXY32i5lcMM1kKlC1Bb2zb3BVq1FdJa4g8 M+XlYswd2EoH
YKnDI46n8GtZ3ZuTB5XdFy/bo5ievicL5aGiGjrI9m1ajL9JJSB80LN3XsqL yVHqJ55+S+ef
m61prnMOY3XNkdpx56q2Mnfcs1Z0idUFqAYy1KpeOOaUKO4Hwl29Y1b05AHR tVDTTTUGLZ0S
2zZy83xStK8MQPr4SKeCB/pI5Pp/J68a2F3Vh2qi0vvEwFPEEoxlnoV457c+ Hxxx686xbB/x
E/8AO5/7Q6pmPviLA4x/MqAcbApjkn+AgwKDyhsIvyP7kfj/AJdXHDiZzGOE xG08/wAPlMss
cd8nUIZYp4UmhkSSKRQyOjAqyn1BBHzGvvVX9nLJ5HIxQkCGO2nhorcqvetD I3X4mABZ2b0Y
jlj6n56rt/e24K27MzCDhmxWL3FjsP5XwpPNyrbiqnxO/fqOr2Wbjoeyow9C Ox1hqmPtRvy/
Wv6plUcnStNczx+/c0/tCoYl4ILWEyWWu4uCylMQFJa8c7uAxsu8nUwMhPgo pJ5DccBtTMbi
3RlvYXuTeRyVClBa2xduUa9KGSO3Sk8BmTtP4vBkTjhuqKQ49D6eurR1fTXN Jt85y3gkyGPW
pWuXcucdRxjUTYtI6RyO8UwM8KJKVjL+rBVUehfsp1iwW/twZ7H4CKpHicZe vDKvamuIZIR5
CwK7Kqxy8BnLd+RI4VVb1fjnUmYiLWpunUNNcer+0je+UxWAfA7cq3b9ra9L PXEAjWKRpw3M
SNLYjMSgoeX4m6915X91ft3ZKajn9n1YlBTI5mStKS7rwooW5eeFYBviiX0c Mv4eOwVlqTtN
LHpri1Xfu4Tcxu7b0lWejLsnLZ2HEUvERl6SUmSObl2DyKCyBwq8FpAF+fN7 2Tnczcz2TwWb
mxVuenSp3ktY6J44mWwZh4fVnc8qYCe3b1V19B+FE2sxS3a1MjjMfkQBdqRT FRwrsvxp/wCF
vmv+o6pXtzxOKym28a9/GUs1cpZJbGLwtyBZosra8GaMVmRgR8UckrCT72Eo Jn5SJwazmMBt
XIbkwKWM39IKePzaw++rlqK7LhbdWaGSvjEcDmB5ZOFeaXtLIEWGR3eWAoRf rsFrC/dJZWtY
7kgyMCZIB+DuefiX/wCF8x+Hn1OtkEEAggg+oI1PMAylWAII4IP4dVi9UbBO ZIwWxTH1HzNU
/q/+X/R8ucxTcTba01+AggEEEH1BGv3UDTTTQNNNNA0000DTTTQNNNNA0000 DTTTQNNNNA00
00DTTTQNNNNA0000DTTTQNNNNA0000DTTTQNNNNA0000DTTTQNNNNA0000DT TTQNRG59x4vb
kNSTJm6TdseWrRU6E9uWWXw3k6rHCjueEjdieOAFOpfURufbmL3HDUjyYug0 rHma0tO/PUli
l8N4+yyQujjlJHUjnghjoIn/ALQtvLNXjsVdzUxYsRVo5bm2MjXi8WWRY41a SSBUXs7qoLED
kjVhzeTo4XC3szk5/Ao0K8lmzL0ZukSKWduFBJ4AJ4AJ1Xv+z3bzTV5LFrc1 wV7EVmOK5ufI
2IvFikWSNmjknZG6uisAwI5A18+239pjfH/l2/8A9NJq7D7+n+F+qd5//edl f/1bUg+Qo5ja
1Xc2IseLBJUW/SsBGUyQsgcejAEBl49CPTkEjkaqf/5rH/7mf/5brb9mX/7P W2P/ACnU/wCk
TTKKgxndfdeAvaL+2DuP+lbX9q2vfuvAXtF/bB3H/Str+1bSB7d9mv7Wu1P6 Do/9PHqe2+va
fKH/APTB/YxagfZr+1rtT+g6P/Tx6se2uokypb+Gj+wi0jmdHxY2/QsR5CKw J3S9ZjsygStG
VdFjVSrJwy8eEh+fPPP+jX1t/A43A0jTxcEkMBYMVeZ5D6IqD1ck8BUUAfIA ame0f4/+GnaP
8f8Aw1ZwxnLVW/cjPKMdN7NUQIJDIEUOwCluPUgc8Dn/AFn/AGnWMUKgseYF WETc8+IIx254
455+fyPGt7tH+P8A4ado/wAf/DWmWh7vp9pH8pB2lBWQ+GOXB+YP4wdfstGr N38WtDJ347dk
B7cfLn8fGsW59wYTbOGlzOdvx0cfC8UcliQHqhkkWNOeAeAWdRz8hzyeACdS KSwyIro4ZWHK
sPUEfjGlQXKOt4utPVWuqLCit2UJGh4PrzwGBA+ZPPz19e7KRrw13qxSRwqF jEiBuoA4/D/o
1I9o/wAf/DURPujbUEkkdjN0YZI3ZHjlmCOpUkHlT6/g/wBY9R6HWOJxeHw4 vPKI++Vxxyy5
Q27FOvZQJYgjmUHsBIgYA/j9f9J1+JSrIoVK0SqFKgBAAFPqR/oOsuPvUshU S3TmE0D89HAP
DcEgkc/Mcj5/h+Y1sdo/x/8ADWsZxyiJibiUm4mpRsGLqQ2HsLAhkZwwJQcp wirwvp6DhR/x
1kko1ZY/CkrQunYv1aMEdiSSePx8k/7db3aP8f8Aw07R/j/4ao1RBGHLhFDk BSwHqQOeB/q5
P+06xe76faRvKQdpQVkPhjlwfmD+PnW/2j/H/wANO0f4/wDhoNfw/wCTUDkd mbfyG54tyXKc
8uQjjhi/wyYQSCF3khMkAfwpGjeR3RnUlWIZSCARZu0f4/8Ahp2j/H/w0FZx 2zNv4/c8u5Kd
OeLISRzRf4ZMYIxM6STGOAv4UbSPGjuyKCzAsxJJJnvD/k1sdo/x/wDDTtH+ P/hoNK1UhtV3
rzxh43HqD6f6CD+Ag+oI9QdQztNjZBXvF3iJAitdfRgTwA5A4VuSByeA3I49 eQLN2j/H/wAN
fEqwSxPFKqvG6lWVl5DA/MEfhGpMWsSrjYzGtjrGNbH1DSs+L49Ywr4Uvilm l7Lxw3csxbn7
4seeeTrXubewF3JplLmDxlm/GUKWpaiPKvRgycORyOrAMPX0I5GpaXBVUBOP t2aLevCK3eLn
8A6NyAo/EnX09PxcY/duU+taP2F/1us1K3CstsjDvvmPd8hdr0TF4kWCBFVz EYu5dYxK56Mw
4d2A7HgDgcWGerWsS15Z68MslaQywO6BjE5VkLKT96ersvI/AxHyJ1l925T6 1o/YX/W6e7cp
9a0fsL/rdNzZo+5cN5aGr7poeBBUalFF5ZOkddgoaFRxwIyEQFR6Hqvp6DWp ZxeMw+1chTxG
Op4+sK8reDVgWJOSp5PVQBydTPu3KfWtH7C/63WK5hsjaqTVpMtTCTRtGxWi 3IBHB4+66lSR
TNpr8925T61o/YX/AFunu3KfWtH7C/63VqTZ+6a/PduU+taP2F/1unu3KfWt H7C/63SpNn7p
r8925T61o/YX/W6e7cp9a0fsL/rdKk2fumvz3blPrWj9hf8AW6e7cp9a0fsL /rdKk2fumvz3
blPrWj9hf9bp7tyn1rR+wv8ArdKk2fumvz3blPrWj9hf9bp7tyn1rR+wv+t0 qTZ+6a/PduU+
taP2F/1unu3KfWtH7C/63SpNn7pr8925T61o/YX/AFunu3KfWtH7C/63SpNn 7pr8925T61o/
YX/W6e7cp9a0fsL/AK3SpNn7pr8925T61o/YX/W6e7cp9a0fsL/rdKk2fumv z3blPrWj9hf9
bp7tyn1rR+wv+t0qTZ+6a/PduU+taP2F/wBbp7tyn1rR+wv+t0qTZ+6a/Pdu U+taP2F/1unu
3KfWtH7C/wCt0qTZ+6a/PduU+taP2F/1unu3KfWtH7C/63SpNhlDKVYAqRwQ R6HWOvCsIcKz
t3bsex5/ABx/sA1k925T61o/YX/W6e7cp9a0fsL/AK3SpNn7pr8925T61o/Y X/W6e7cp9a0f
sL/rdKk2fM0YlheJiQrqVPHz9dIY1iTqvJJPLMfmx/GdfXu3KfWtH7C/63T3 blPrWj9hf9bp
Umz918yIkiFHVWU/MMORr9925T61o/YX/W6e7cp9a0fsL/rdKk2Rd7DJNL4l aRK5JDEeF2HY
fIgcjj+X8B/28yUCGOCONmDFVAJC9QeB+L8H+jX17tyn1rR+wv8ArdPduU+t aP2F/wBbpubM
MP8Ah1r/AOJQ/wDrLrJPFHPBJDKvaORSrDnjkEcHQYrJCRnGUo9nChj5F/UD nj/3v/wj/t19
e7cp9a0fsL/rdNzZH4yvl8ZA9alfo+AZpJVE9R5HHdy3BbxRzxz8+NZa0F05 Ge9es15pJYY4
gIYDGqhC5/C7ck9z/s1t+7cp9a0fsL/rdPduU+taP2F/1utTnlPNmMcY5P3W nksbVyITzAnV
o+erwWJIXAPzHZCG4PA5HPB4H4hrb925T61o/YX/AFunu3KfWtH7C/63XPLC M405RcNxlpm4
lXUwF2HLTJWyFqPEzwRiQSXppZw6s/YIXJ6BgyAsG5HU8AEhlsEMccMSQwxr HGihURRwFA9A
APwDX17tyn1rR+wv+t0925T61o/YX/W65cH0vD4MzOGNW3nxcs61S/dNfnu3 KfWtH7C/63T3
blPrWj9hf9brvUuez901+e7cp9a0fsL/AK3T3blPrWj9hf8AW6VJs/dNfnu3 KfWtH7C/63Wh
k5ZMcitbzdNS79ERMZLI7t8+FVZCSfQ/Iam4kNaOS/wzGfzpv7GXUecyo+eQ sj/Tti9rOrtb
91X4snVu1mtug8Kq8TBhDLyD2ckEcEEEA6kq2cJ/gcn86sf2z6qVvYMl3HVK d+fBWmqQRQQ2
XxUi2EWPgrxKs4ZfUc/CR8z+PVqxNW61JpUyNWCN7Vjqj1GcjiZ+fUSD/wBN bflb31xR/q9/
1utYZZYTeM1KZRE80XtDBtgcfLUM8Mqs6FBFE0axokMcSqAzuTwIx6lvXnW/ 7sxvmvNe76nm
PMea8XwV7+N4Xg+Jzxz38P7n2+fX4fl6a2zi8qCAcpR9TwP7hf8AW6/fdOX+ tKP2Fv1ulSbI
altbbNKpaqUtuYetXtwCvZiipRok0QUqI3AHDL1JHU+nB41s5fDYfMLCuXxV HICB/EhFquko
jb90vYHg/wAo1Ie6cv8AWlH7C363T3Tl/rSj9hb9bpUlw06GMxuP6+Qx9Sp1 rx1V8CFU4hj7
eHGOB94vZuq/Idjx8zrQ2/tuhiInJaTIW5Lj3pbltYzM87J4ff4VVVIj4jHU D4Rx+E8zfunL
/WlH7C363T3Tl/rSj9hb9bpU9jZV8FsjD4jdd3csBd7tpJY+PAgiSNZXV3A8 KNC5JRPikLt8
I9fU8yFDbG2qEcsdHb2JqpNLHNKsNKNA8kbd43YAerKwDKT6g+o9dTHunL/W lH7C363T3Tl/
rSj9hb9bpUmzT92Y3zXmvd9TzHmPNeL4K9/G8LwfE5457+H9z7fPr8Py9NI8 ZjY/B8PH1E8C
xJah6wqPDmk7+JIvp6O3iScsPU925++Otz3Tl/rSj9hb9bp7py/1pR+wt+t0 qS4R+PwuHx9m
1Zx+JoVJ7jdrUsFdEac8k8uQOWPJPz/GdYMdtrbmNgswY7b+Jpw2oxFYjgpx xrMg7cK4AHYf
G/of3TfjOpf3Tl/rSj9hb9bp7py/1pR+wt+t0qexcIvG7ewGMhhhx2DxlKOC c2IUr1EjWOUo
UMihQOGKMy9h68Ej5HUnr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905f 60o/YW/W6e6c
v9aUfsLfrdKkuHxsH/ET/wA7n/tDqEobKztOrUrx7kplakUcUfNGcAhFAHKr ZCn5Dn04OrVt
3GNicd5V5xOxkeQuE6DlmJ+XJ/H+PUjreNxTGVSh9rYi1iY7zXb0Nye5a8wz RVzCq/co4woU
ux+UfPPP4dYKOztv1dy5DcZx1ezlbtsW/MzwxvJXYV4q/WJ+vZVKQqSOT6s3 rweBP6asRQio
9s7cjzRzce38SmUMhlN1acYnLlChbxOO3PVmXnn5Ej5HXwNq7XFm/ZG28P4+ RieG9J5GPtaj
f79JD15dW49Q3IP4dTGmgi8nt3b+TFkZLBYu6LRjNgWKkcnjGPnoX7A9uvJ4 5+XPpqM3JsbB
Zjb0GCirwYunBYNiJalGqwR27liqyxOiks7MWVQ3JJ59TzZ9NBAfQzaj4TFY a3t/G36WJrpX
ox3ayT+CiKqgKXB4PCr6/h41myG28fcz2NzDGSGXH2pLojhVFSew1c1xLKev ZmWJmQfEBwfU
HqvEzppYi6G3NvUMlNk6GBxdW9OHE1mGpGksgdgz9nA5PYqpPJ9SoJ+WsuEw uGwdd62FxNDG
QSP4jx066QqzcAdiFABPAHr/ACa39NBDbs2xiN0V6cOXS7/cVnzVaWnfnpyx S+G8fZZIHRxy
ksikc8EMedaWT2FtPIWMXNLifL+6/LCrFTsS1YutaQSV0eOJlSVInHZEcMqE t1A7NzZtNA1+
MAylWAII4IP4dfumgrFylLhZC9eKWbGMeekal3rH+QD1KfyD73/R8s0Esc8K TQurxuOVZTyC
NWHUTZ2/j5JWmr+NRmZuzPWfoGP4yh5Qk/jKk6xOPZqJ7tfTRcPllHUZaq4H yMlIliP5eJAO
f9AGv33Tl/rSj9hb9bqVPZbh+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+a a/fdOX+tKP2F
v1ununL/AFpR+wt+t0qS4fmmv33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv3 3Tl/rSj9hb9b
p7py/wBaUfsLfrdKkuH5pr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905 f60o/YW/W6e6
cv8AWlH7C363SpLh+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+aa/fdOX+t KP2Fv1ununL/
AFpR+wt+t0qS4fmmv33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv33Tl/rSj9 hb9bp7py/wBa
UfsLfrdKkuH5pr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905f60o/YW/ W6e6cv8AWlH7
C363SpLh+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+aa/fdOX+tKP2Fv1un unL/AFpR+wt+
t0qS4fmmv33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv33Tl/rSj9hb9bp7py /wBaUfsLfrdK
kuH5pr9905f60o/YW/W6e6cv9aUfsLfrdKkuH5pr9905f60o/YW/W6e6cv8A WlH7C363SpLh
+aa/fdOX+tKP2Fv1ununL/WlH7C363SpLh+aa/fdOX+tKP2Fv1ununL/AFpR +wt+t0qS4fmm
v33Tl/rSj9hb9bp7py/1pR+wt+t0qS4fmmv33Tl/rSj9hb9br5kxmUjQu+Vo hR8z5F/1ulSX
D901DWsktezJXOYSaSM8SCtg7M4Q8c8ExsQDwR6HWOPMQtKkb5kQF2CK1jA2 oU5J4A7OwHJP
8uotJ3WjuD/EOQ/msv8AynWx5W99cUf6vf8AW6083TvHB5FvelORUqSsyrSd SQFPIBMh4/2H
SbI5pLXgL2i/tg7j/pW1/atr37rwF7Rf2wdx/wBK2v7VtWEe3fZr+1rtT+g6 P/Tx6sO3vvsp
/PR/YRar3s1/a12p/QdH/p49WHb332U/no/sItOp0SmmmmtIaaaaCk+2yzTp bFjuZGWGGlBn
MNLYklICJGuTqli3PpwADzr59ktS9Xp5GWKCahtqecPgsdZUietDx8XPPqkb H4kiPqi+hI5C
Jb8lQpZKr5XIVYbUHiRy+HKgZe8bh0bg/hDKrD+UDWzqo18jcrY7H2chdlEV arE000hBPRFB
LHgevoAflrmuyt+YTJ4lKWJyVexm7DQNZ8SF26tJLHGzN97269wB8X4B+Aav 26cLX3DgrGHt
z2IIZyhZ4CocdXVxx2BHzUc8g+nOqdU9keEq3a9yHN5xZq8qzRMDXHDqeQfS H19fwH01w4vE
40fYwxuJ63Uw3jwccpjOeJVdNN3+NxX5Sn9pyz0bbYax2likWSxUlEDQKEVk V4xGxLIFLDr+
Ag+nAA55UntA3T9DM7koNxebycOy8jlshX8rD/3BkolQxV+AnI9WmHWbux8v z8ieetYDatXD
5RshFetTyGOROjxQRpy5jLMRFGnLHwkHJ59Bqw664xMTM3Mx882ejm28clld u3sDjMnvixjq
VuK3NZzE9esC9hPC8GqAY+iq4eZgOO58LgNzyda0e8s63/s+4fcNW1Xt7lmw eKuXWbqpiWz4
Ylssio3RVHjuD0K/c2+FgpXXQdwYalnaHkb73lh7dj5S9NVY+hHBaF1Yjgn4 SeD6enoNbWPq
VcfQr0KMEderWiWGCGNeFjRQAqgfgAAA1edkbOTVN17gTZtexb3lh56cu4BT tZ7G2Ybgx9M1
/E7SSeDHD4njBY+xi6qsqEgkE6jvabk0ix7ZbF7gi3EIPZ7umWDIypXnSdkk okdlRBC4BHUj
rwevBB9ee46aDjuR3lmYfaTmsbDuntYqbnx2PpYDy8P3epNXptYfnp4reGJp pewb4enxcqQB
lr7wz8Of3lSrZX6RZWhj8jbx2OoyV5aiGKQCGCVUQTxT+qp1d2DnxSvHAC9Q x+Lo4+3kbdSD
w5slZFq23dj4koijhDcE8D7nDGvA4Hw8/Mknd1Z5EbS5r7Ity5C/Hkpc5vHb +Xqr5QQNWyMc
8sE0rOhjkKQQKnZvDCIVL9uwJPKgR+1t07qv+1OXHZDO4SnXTJ3azYSa6gtt WjEngyxweXEn
LBY5C5mZCrNwoPAXrWml72nSnn+tvzd1rG2Tjt0yXs7LsjMZOxiY6ddmxeUh NYRQBRH25jaW
ROkhYtxy3PI4n9xb8jzOdyUW381j8piK021DEYo4p4lks5iSOYhiDyxjSIA8 8oVBXqwJ11Sb
F0Zs3VzUkHa/VrTVYZe7fDFM0TSLxzweTBEeSOR19OOTzu6kbLLlG2s9uhs1 gr13cM1urld3
ZrDNRarAsUVeu2QMJVlQOXXyaLyWIIJ5BPxajdo73yt6vJJlN4mISbcs382R Vg521dR4gsIA
Tnkd5x0m7s3l+R6E89p00ncjZz72Rboy+ZoWH3jYixuekspAcM6LEa33HugT nlpDIivL8268
Mnzjc65zt/2jbnn9l9rNVd4e+8h/2fWs1dk8pXHurIRwxtCvVEAHfvK3WQNz 4PK8KeNeh9aW
CxdHB4ShhcXB5ehj60dWrF3ZvDijUKi8sSTwAByST+PWr3SnN/aXld17ZXBY 2LdMMEFwWpLm
byVivSSOVBH4UAc1pY1DBpWAZOx8Pjvz84qp75bd2f3a8lXcefx2wsdexteC GOSr5uUXg3lm
6CULI0IA+LlhIQ3ICBO1aazO9rG1OH4/dm7bG0chNX3xhL875PB1q9ijZhuz 1PNX44ZxKorQ
ooKNwqMhcHvy33vG97Tdxbv2/uCDDUt1YvGV4cWlivks7bhqpfsmWQPG/FV1 kCKsRKReC3Ev
oT817Fpq3ukRs5RmM9uivuHcWQi3DMtHF7vxGIgxwqweE8FpMcsvdyniE825 HUhhwR68j0Ep
tHcEmR3lcq5jeXkcnFkrdeDbPFaPvXjLiKThkM794ws3ZXC+vHHCka6HpqK4 lsHeG9MvSy1n
Jbq2xTve4rNmTHWLqyS4i4pXr4sS143ihjJYOJHlJ4Xq3HJN49j2dkz23rk0 2Vt5WWteau9q
aWrNE5EcbfcZa0aJJH8f33UMG7qfveBddRWfxd7JeD5PceUwvh9u/ko6zeLz xx28aKT5cHjr
x8zzz6cIJc1/9oxMDNipgbW2BuCOkzQVbFZXy1lST4aUZO4eGUsHCMEk4cg8 Dg82f2tZ3YuO
2xJY3fDispBWvR14qVoxOr3Wj5jiIkPRWKP25fgKp7ngDnVtxNWelj4q1nJW slKnPazZWNZJ
OST6iNET0B49FHoBzyeSdvV6UnW3MMYLFH2D3sdtzN4/I5ubEZOzixjLQlQS dpGWKuQeWjhe
WOFSPkFQEAkDXz7KrO16u4s7LtSxRg2o1LFxwtC6rXN93nSRefl4zK1RWH3x YqD8R11HTS95
+TpHw5PS3Pdvbgy21NyXoxQ27Hfn3JYmiRY5qci801Y8ABWgkdmZePirMPkS DV8dY2/lNlbp
zu03xVLAXLGKSfEYuSPmDHpaHmbE8UR4ieaBpeV4BEcSdviDKvoDTU6UvW/P PPv4X/3L7ufj
yP8A2dfTUc8dfd/kfdw/+o8D3h8/8ztz+DWjc8ZttbVXI3cDU2oJM3JE24IG lougt/8AdqFO
6BuaxcoGPHABAJVdegtNJ5V5yOtvPm9rFW3g/NX8THhsjNsanJs/HOvV6eUP jFoa44HEyN5J
eFAbgfIDnUxuOw1f2wWp8zV29lJ/fWNr4bH3axkvis6QB7NVi3CLFK08jMEJ IiYFl6rrtemr
tt96d3FdteV/7Scd4Xh/Sz6T5b331/wj3X4dry3ifh8HjyHTn4eeOPXnUh7G M3sCjlvaDQ25
mtuRY+DMC8kVO5D4aVxjaIkn+FuOgk7hn+Xbtyeedda006RB1mXH907nv4uf dixZMYo/S+vR
iuK1arFErYmrLzYnlglAUsSA7IzFjGgIHAGPYe6N1btt7QrybialHYq56S9J Shhk82aWQr1o
WDyRenKuxJVE57HhV+Hr1TEYfH4mS/JRhdJMhba5ad5XkaWVlVSxLEkAKiKF HoqqoAAAGpDS
6Ji0fk79qpbpwV8LfyEdiTpLPXeAJVHIHaQSSKxHqT8Ac/CfT5Awe5eclv3b WGHJip+Pl7PH
qp8NfBiRh/K85kH8sH8mrZrCtWstyS6teFbUsaxSTBB3dFLFVLfMgF3IH4Ox /GdTr55zXpPn
mzz7id2ZvB+yzakNLN+63q7BxlzDU/Aif35eMRBq/GpZuOkA6xFX+788+g10 WXcEj+0q/isx
vL6OpWt1YsVjOKye9Y3jjZn7TIzv2laSHiIqV8P8bA66Hpp0OrjOK33mH9sF DCx5pZ6N3N3s
bNjrVmA2a6wwWJFkEMddXjQmBejSTOXRgevryul7PLuSb2dbeyOGpm/b2v7O Ks1OtwWWxesV
VZE4Hr2Va6j09eLP8uu56wwVa0EtiaCvDFJZkEk7ogUyuFVAzEffHqqryfwK B8gNJ5EVbjmD
3huo7M3BkU3VhM20HkOk1Kyl6bHpLN0syyrHXgAEcXMixspYGN+xI4AmJ7lG 7lvZ/Lj94/Sy
IbrnU3fFrSdD7nvHw+a6InpyD6jn4vnxxrqOmrPNI5POVLfufqbVxbRbpix9 uH2fYXKYzFRU
aypk78osgwKvh8gSeFEgji6kc8p14PPRW3Heh9ta4C1uLx61iTpVxlCWsxgA qGRjbjaPx0BY
MyyI/Q9olIBJ7XuHF0Yc3azUcHW/arQ1Zpe7fFFC0rRrxzwODPKeQOT29eeB xu6Dh+yfaDuo
4/KZrPZfCWp4MLPbm2/FdR7tW4roEg8IV42iXszRkSPKSxj6txyTLz2JNqXM VtHLb4O1cXRw
cDxZIishydsu6zgyWEdOV6o5UAMxnJ54Gup26ta5EIbdeGxGJEkCSoGAdGDo 3B/CrKrA/gIB
HqNZtSPP1WfP0cZ3xvvMYj2mrj6GaWOGPNYuhLjLlmBTNHaeBHkghFcyugEx +6GdQJFYcEL1
NXy9uahgsxfr+EZq2B9oc0fiwpKnZcvER2RwVYcj1VgQfkQRr0dpoOZXc9kT 7YJNtS7rlSK5
2ipU8XJUeSn/AHGXL2YpImlU9gzLIGMZJiVl9T2p2y9zWKPs12JUs+0eXH05 cO3vPKzeUkel
eir1umPYtGVU/HMxWQGU+Hx29dd+00mLioIcJ3/mttZnb226G6IsBht+53BV 5pbuQaOvJhEZ
eZJkeQhkdJGcRop7M6+vwqzL3G5E89SaCKzLVkkjZFniCl4iRwGUMCvI+Y7A j09QflrLqA9w
5X3t536a57wPH8XyXg0vB69ufC58v4nTj4ee/bj/ADufXWpm0iKcW29unPY7 2W7BqY/etcRz
4zplcpkr9aAY+3FXr9aLSmtKqt8crdZU8Q9Dy/Pobdkd2ZmpuHZyZHddJ48j Tx4lp4WauZLN
iWTq8wjnjMklRuV+KJlZFWRjz6FetaazHysuG7QeS3jfobY3VczF+3vC4t6p ZeAyUqsF+1Z7
OkaKwSdIo1+LleJh0Cr6akNkbyzOQ3pVpNun3pNNuPM0LuI8vCvkaVeW0IZ+ UQSejRQR92Yq
3i8cdhzrrj1az3Irj14WsxRvHHMUBdEcqWUN8wCUQkfh6r+IawYfF0cRUepj oPAhksz2mXuz
cyzyvNK3JJPrJI7cfIc8DgADVjZJi5cDxG/Lm0vYqiPm4Ma8Pssxl3b6ypHz JeWtZ8Uxhh90
K9apKnsAODwAx5tG+N45jH70tUl3T7qmh3BhqNHEeBAfP0rE1VZ5+XQyHkyz x9lIC+F+6POu
w6h8ttvEZbLU8nkIrU81N0khiNyYVw6MWRzAH8NmVjyGZSQQpB9BxFc227kd x5jO4zB0twy4
WvZm3XNO9KjW7ua2YjhhI7xsoIWVux4JckluWPYYMfvzM2m9n2RyO4Y68eex GKnlxmOesLMl
iww7u0MyM71z2UExMrIFkY8+hXtGmrCGmmmoppppoGqxaAO/KBIBIx90j+T7 rW1Z9UTeOUs4
nduMsVacVp3q24ykk5iABkrnnkK34vlx+HUymlx5qtifabmcl7Ure259gbnp 4DgRU8xNirCJ
JMCexflOFjb0Csfxcn0b4bbigBbuAAAfSHn0/o5NaEm6sy//ANo6A/8A4k/6 nWbatma3HPYs
QxwyvuA9kSQuo4x6j0Ygc/L8Q1iconk1UxG6y4v/ABPH/OrX9u+s2sOL/wAT x/zq1/bvrNqs
pTKWY6VVrkyzNFAryusMLzSEKjEhUQFnb09FUEk+gBOoPZ+dyu5LEuUiq0qm 3vusVXvIz3Z5
Ek6M0sfAFbqySDwmLyHsA4geN4zYpfv4v/H/APGnWhXwGGrbis7hq46GvlLc Qit2IR4bWgOo
UzBeBKyhAEZwSgLBSAzA9WFSwtjdlTd97GwZ36VeFjZZb4sxRVKtHIExNWrR PFGXRJEeZmVz
YkjRYGJ+NTLDJ7W8rb2hufcmL2pSnh2rjXbMRT5ZomhykAL28evEDB/CjHPj j4HZkVfQsydG
hwdKKjkqaz5MxZKWWWdnydhpEMg4YROXLQKP81YioQ+qhTqv2vZfsqxi3xbY 67HSkwkGAkhg
ytqJZKELExwsEkHbjs47H4irupJVmBDSwntGs3N1w4DI7Vu4x2yTYuSV7UMg S01I344+EJ54
rD7o33qSsqIZl7SLKbAvZOznd70cjkpr8WN3AIKZljjVoYXo1LHhDw1XsqvO 4BbluOOWYjnW
bG7D2zj8uuWgq3XurZitiSxkrM/3eOo1NZSJJCC5gYozEcvwpYsyqQ2nsXb+ 18pcyWIbNeZu
+tk3M5duLK3VF7sk8rqXCxRqH47BVCg8emgk91W8zR27dubew8OZykMXevQl ueVWwR80EpVg
rEc8cjgngEqCWFGl9qcyV48vFhaV3AVtorufK3KuQk8WvE8crxJDDLAnjeJ4 UnUs0ZARy6xn
oH6Zqv4TZe18NRztGjh4RUz96xfysEzNPHamnAExZZCw6sAAUHC8fg9dBWdj +0Dce4717G2N
lTULaUZLNSWSPIw1HdSqiKWa1RgKMxdSvhpKeqyEgdVD7vs+3hujdG1ae6p9 mQ0sXfxCZCnX
iyyzX5nZFdY/DMaQqrct1czA8dO6xlmVJPFbHwuN835e7uZ/NVnrSeZ3NkbH VG45KeJO3hv6
ekicOvrwRydYcP7Otq4rauQ2tVr5OTC36Pu+anazFyzGtfo0fhxeLK3gr0Yj 7n19OP3I4CF9
nftCzu5d1HC5XasOIi8jLaSYzXY5GKPEvURXKVZnX7pyXj7hCFD9TInbNht7 X6O3t+5vduP8
u+1rMjWatG4ttBFHj69kiF2hgJ5WQniQE9y3xdeoWwbb2dg8Bee9SGTsW2iM Kz5LLWr8kSEg
skbWJHMasVQsE4DFE7c9V408F7Otq4abJyV6+TtLlomiyEOSzFy/DaDIiMZI rErozFI0TsRz
1HXnr6aDBQ3Nupc4dv5rbmFq5a1jbN7GLUzMtivL4DQo6TSNWjaLlrEPBVJP TuSAVAaG2n7T
srmsHRyNvaPu6TL7blz2Jri61l5UiWDxElEMLMnLWYvD8NZXdCSyI48I2bFb F2/jfNtA2amm
tVnqmzbzl21YhifjusMssrPB2IUkxspJRCfVFIw4D2dbVwV7CXMZXycUuCov j8cr5i5LHDXc
8tGUeUq6+i/fA8COIDgRp1CL9nG+s/ufOTUMptX3RDHWaZZvCyi9mDKOvNrH 10+TE+jlvT0U
jkrp+yXHe1ivkMfNv7cfnKybbg83X8lVj8TKS2Jnl+KI8jwIhDF6fBJ27jgg 66ZpoKZ7Mshu
S1f3fQ3NlKWRs4vNpVhkp0jViWJqFOYKqF5G++mcks7Ekn5DhRJ+0rN2ttez rcu46McMlvFY
i1dgSYExs8ULOoYAgleVHPBB4/CNYdp7F2/tfKXMliGzXmbvrZNzOXbiyt1R e7JPK6lwsUah
+OwVQoPHprNhNl7Xw1HO0aOHhFTP3rF/KwTM08dqacATFlkLDqwABQcLx+D1 0ENh2zmB9ouO
25d3Rk9w1MniLt1nyUFVJK71pqiKIzXhiHVhaft3DHlE6lfi7Rnslx3tYr5D Hzb+3H5ysm24
PN1/JVY/EyktiZ5fiiPI8CIQxenwSdu44IOrZtvZ2DwF571IZOxbaIwrPkst avyRISCyRtYk
cxqxVCwTgMUTtz1XiwaCM3Zm6u2tq5bcd6OaSpiqM12dIQDIyRIXYKCQC3Cn jkgc/hGqZsf2
gbj3HevY2xsqahbSjJZqSyR5GGo7qVURSzWqMBRmLqV8NJT1WQkDqofoF+pV v0bFG9WhtVLM
TQzwTRh45UYcMjKfRlIJBB9CDqv4rY+Fxvm/L3dzP5qs9aTzO5sjY6o3HJTx J28N/T0kTh19
eCOToKlgfa7JLtWDcu4drTYmjb2tPuapHBdS1O9eukLTq68IqMfMRmLhm7qS XELDpqaubw3R
gaOVye7tmQ1MXi8Raylm9i8styMiEKywIskcMhlZRMx5UIoVPjYuQmbH+y/Z VH3WsWOuyw4v
Gy4qrWs5W1YrinLz4kDxSSMkiEdRw6t6Rxj5RoF3cVsPbOP832q3cn5us9SX 3xkrOS+4Px4k
S+Zkk6o/C91XgP0TsD1XgIW/v7K7b94fTfb1Kl5bCXc3F7nyTXvEgp+F46t4 sMHV/u8fQDsG
+PkpwO2HD5ve7e2HHYfcNOHG0bW37tnytK7HcqSSQ2KirIsjQRTrKBPIHUjw +piKkt362DFb
D2zj/N9qt3J+brPUl98ZKzkvuD8eJEvmZJOqPwvdV4D9E7A9V4w4f2dbVxW4 qm4qtfJyZipF
LDHdtZi5ZmaGTr2hdpZWMkQKhljflUbllAYkkMGyc7uTKRbuiyGNpRZjFZLy sVNcmZanY0q0
yKswrRuqEzDsWjdlYvxyvVRX8D7XZJdqwbl3DtabE0be1p9zVI4LqWp3r10h adXXhFRj5iMx
cM3dSS4hYdNWfBezzbeEmyc2Ok3AsuViaO48u4shM0hZETxAZJm6yhI0USrw 6hQAwGsGP9l+
yqPutYsddlhxeNlxVWtZytqxXFOXnxIHikkZJEI6jh1b0jjHyjQKEZb3xvTH bihwWT2RjI7E
mIv5UT1c1NZhZK3hKIkVKnjPKZJkDKIuApBQytzGM3s431n9z5yahlNq+6IY 6zTLN4WUXswZ
R15tY+unyYn0ct6eikclcPs79mljbm6juXL5qHK5FKMtGGaOK34hhleJ2WSW 3asyOqtCpRVZ
FQvMepMhI6NoOWezTEe10tWXfG7pvCba0SWDDRpJIuVmnmeR1KhlDV4hDGOV aOQt245DDUNs
+9vnPUdgoPaDk4Le4NiXMnPK+PpPGLvFTwpSghUlUN0noGUMIYgefuhftmq/ tvZu3dvXnuYq
nNHKYjDCstyaaOpCSCYa6SOy14j1T7nEEXiOMccIvAUzaOM3nf3RuWrL7UNw SVMLlzQEcuPx
xaWGTGQShgyVl6ypNZDhuCpEYVkbknUZ/wCz9m965nace9N25nc0lNMajSUL uNqyecZ6tWyL
dXykKv05eeNYuZWb056upQdGx2zsHjptwTUxk45dwymbIv72tMzOU6d4yZD4 DBOqgxdCAiAc
BF43dq4HGbY27S2/hYpocdRi8GtFLZknaNB8kDyMzFR8gCeAAAOAAAFZy/tD oPtXcN7ER5Oj
bxmIs30nzm3clUqIY0JBdnhUsoPBKJy5UN1B41Gez7Kbph3xHhM9PuZYbeNs Wo4tyJjfMO0M
sC9q5xw6BAJyJBMexLQ+HyBLx0a/Uq36NijerQ2qlmJoZ4Jow8cqMOGRlPoy kEgg+hB1C7b2
dg8Bee9SGTsW2iMKz5LLWr8kSEgskbWJHMasVQsE4DFE7c9V4Cp+yXHe1ivk MfNv7cfnKybb
g83X8lVj8TKS2Jnl+KI8jwIhDF6fBJ27jgg63MLJuyPd97Dwbq9+dcbK9+xZ x8Qq4rIExNWh
iSLo5RkkmdonlkkVEg5kXxFaToGoyHB0oqOSprPkzFkpZZZ2fJ2GkQyDhhE5 ctAo/wA1YioQ
+qhToIzae6JsnlLmBy2M8jm6HraSm8lukAVRlC2vDRQ5WVCYpBHL82CGMpI9 m1pYTE4rB4uH
F4TGUsZQg7eFVpwLDFH2YseqKAByxJPA+ZJ1u6BpppoGmmmgaaaaBpppoGmm mgaaaaBpppoG
mmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGmmmgaaaaBpppoGsGQ/ wN/9X/qNZ9YM
h/gb/wCr/wBRqTyIc5u56Ta/s8yWYrYXJZmzHfveDSx9Z5pZ5DalCjhASB+N j6AD8PoDXtv7
sye8fZLlbuf2xk9vZaKjMlupdpywqXEbEPGZAOyn5/hIPofwE2/bb58YycUs djJq/vG70ebI
PG5/uqXnlRCwHrz+E/8AzNae9DuM7Vy/j43FJF5GbuyZGRmC9G5IBhHJ/k5H +ka5zydY5rbr
DlP8Q5f+YTf8p1m1hyn+Icv/ADCb/lOjLNrwF7Rf2wdx/wBK2v7Vte/deAva L+2DuP8ApW1/
atqwPbvs1/a12p/QdH/p49WHb332U/no/sItV72a/ta7U/oOj/08erDt777K fz0f2EWnU6JT
TTTWkNNNNBWPadmcvgdpG/goKtjIvkKFWCKyxWNzPchhIZh6ryJD8XB4+fB4 41vbT3DT3FQe
eCOararyGC7SnAWapMACY3A/D6ggjkMCGBIIOoz2s0szf2aI8BRjvZKHK4y1 DBJL4aP4N6CV
uzevChUYkgE8A8An01t7N237lNzI37QyGeybI+SvFOviFQQkaL/mRICQq8nj kkkszE1Fh1S0
m3TkntWcbcHlBM4gc2I0V059OFNdyOPlyW9SCR6Eamd9Zz6ObSyOZCo0leLi ISfeeIxCJ29R
8PZl59flzriG0faDamWht3cHuP3YZasQaKXuT0mjJMvY8deivyePnx+DXi9X xODWjPOYy6RE
1brw8ONMxlhw5nHrNXEO57St2bmEje9L4lyN3jsDgco4Y/CeAASAQOQOD8x6 HSLc+2pVyTRb
hxLjFKzZErdjIpheexl9fuYHVue3HHU/i1W9kZXHWNztUxM1VIpK08k9eq0P g9keERyKkbv0
5V2B5ILFeeOANVVvZfuSbZ1rb8s+FiNTZt/bOOnjlkJuGwIws9geGPDI8FSQ vieskh5/AfTw
tvsz0253+vX+rEze/n5Olybs2tHQTISblwyU5JzWSw16MRtMPnGG7cF/Q/D8 /TW+mTxsmIXM
JkKjY14BZW4JlMJhK9hIH569Ovr25449dUn2m1bWJvYTcuLx0V9cdVtY73f5 SxKpScRHuq14
pWBXy4XgqFIkYFl5HOlj9mZvIewbBbKtrFj7dPC4lS3mXVvM1jG8kLmMAohM Sr3Ri3xtwB1H
bfdI+V5j3Jt2TBNno8/inxCc9r63IzXXg9TzJz1+fp8/nqMu7729AYXrW4sh WnxN7Kx261mE
1mhqPCko8VnCA9plAJIUdW7MvGq3BsbKQ4qrZqY7GVcpU3AMya0+atX4rrCs a/3WxNH4isFI
K8IwUxRng+uvv2gbO3Lu/H2HkXEULljaebwrRLbkljSe41bwWD+EpKAQMWPU EEgAN89EXQ7k
26M37jOexQyvfw/Im5H4/boJOvh89uejK3HH3pB+R19VNwYG3mLOGqZvGWMn VUtYpxWkaeFQ
QCXQHsoBZfmPwj8eucDa24crvndiijRqYqbduMyXnp/EWw61alCTiJenWRGe Jo+3cdfuvox9
NSD7Gz1qfdWMW3Xw2381RyEAhr3ZLTeZsvyLSq8a+Aw7SsyK7KzSc+nXk2eW 3nnJY57r1g85
hc7DLPhMxj8nFE/hyPTspMqNxz1JUng8EemsZ3DgBnhgDnMYMww5FDzaeYI6 9ufD57fegn5f
Ic6rPs+2zlNvPetTYehFespUrvKNw3b3ixRM/J5sITEFEjska8gk8Fh98Nra GGz+3speoiri
bWHt5O3kDeNp0tgzu8nRovCKv1ZggbxB8Cr6enBTzSOSZi3PtqVck0W4cS4x Ss2RK3YyKYXn
sZfX7mB1bntxx1P4tfE+7dqwYv3rPubCxY/xjB5p70Sw+KOeU7luOw4Ppzz6 a5o3sv3JNs61
t+WfCxGps2/tnHTxyyE3DYEYWewPDHhkeCpIXxPWSQ8/gNq9omzLeZyWCyWJ SNxioLNXyPvW
zjUeOYRfEJqwLAr4IAUqVIdvkQDqdLOq6zWa0NN7k1iKOskZkeZ3ARUA5LFj 6AcevOouDdu1
Z8JNnIdzYWXFQSeHNdS9EYI39PhaQN1B+JfQn/OH49QeY2lbu+zqvtKpWx2P hpVcf5WPx5J4
fErSJIa79lDNCREidySzK7cqOPi/c/id1Zunh8hPj8HWyuHy4vQ0xkJZa1lP Aki4eUwKyMPG
ZhxG3BjT8fonmvRN5Ddm1sdTrXMhuXDVK1uEz1pp70SJNGOoLoxbhlHdPUen xr+Ma1629trW
N4zbSizlBsxFWhs+X8wnZ0lEjKEHPLELGXIA9FZG+TDVe2hsO9is3gMjffHT LRqZrzEcfYiO
bIXYLIWLlfWNFSWPsepI6/D6kCIwns33FT26MBPbx/g39jUds5C3DYkEtWav FZXxoVMfEqs1
n/OaMgLz688aTsRvzdArbs2tZxs2Tr7lw01GCZYJrMd6Joo5GZVVGcNwGJZQ ATySwH4dRuU9
o+xcdHiZ7O6sN5bLWpKtWyt6Iwl443dyX7cADp1J/AzIvzYaqlb2c5KbCWat rG4ytanu4WSa
Vs7cyIsQUrqTuh8wnMY6iQIi9gS/DHj11IZHZu4ItyWM/jPddiVd1jN1q09m SFXiOHWgyM6x
v0fuXf0VgQB6gk8WaSLWHae/NobpVvce4cbbkFqaqIUtRmRnjeRTwoJJDCGR 1P8AnIOw9Nbc
u7tpxXY6Uu58JHakk8JIWvxB2fxHi6he3JPiRyJx+6Rh8wRrn25cFuXC7Ku0 6dWGbKw7jnye
27NNJrDNPZuTzlbCCMCCPpM8LuXK9WY8qSAY3J+zzNHLZ3amFqVGxtvZmOw0 uVv91dWM1/xZ
oyqMJZh3EjISvxPGSw59WO/Mnbk67ZzmEq5ivhrOYx8GTsr2gpyWUWeUevqq E9mHofkPwH8W
ty1I8NaWZIJLDohZYo+veQgc9R2IHJ+Q5IH4yNc6yewLk3tDuZxq0GToXslS yDCfOXKvlHrr
Eo4rxgxT8GFZF79fiJB5HGrLW3ttfKu1Hbu6dt5TLSRuatSPKxsZXVS3B6Fm A9OSQp4AJ4PG
p0XqzbZ3PHmcpkMTNicjicjj44ZZ61wws3hy9xG4aGR0IJiccduR19QAQTiX dqx7kq4W/gcx
jxdsy1aNywITBakjR5CF6SM68pFIwLooIX8ZAMPsHauR23kczkK+GwGHgyJq ImIxlh/KxGNn
E1jt4KDxXR1HURgHwUBb1LL9YzDbtn9pM2d3DSwljHwPLDiWhyUpelAVI7+C YArTycAM3ifC
p6r/AJ3eokd273xm27z1rVPIWVrVBdyE1ZEKUKxYqJpezKevKueEDNxG549N WKa3VhswVZrM
Mc9gsIInkAeXqOW6g+p4HqePkNc/3xs7cWffKmqcVAu5dvx4TMLJZkPlFVpi ZICI/ux4tTDh
hHzwh5HqNTPtEwu4M1iVmwJxtXOYrIR28PNZlcxNwnSQS9U5Xskk8fA7ehVu eTwsuoWrmvPL
fe5N70sJUsZL3VkcjhqkMk13KUWgkr1Vjd1l7cyh2KGN+yorEcccc+mvrIb3 xlLcbYeSnkHj
itV6dm+iIa1axPx4MLksH7N3j+9UgeInJHOq1mdmbmiobe2viq2HyW1MZTjF uC7kpa02QsIf
TxSsEgaLkd2HILseG+EEPuZnZmatbkvrXmx4wmUzePzduV5HFmKWp5fiNECl WV/KQfEXUry/
ofTV6xHz55/XknRM0d74y5uRcMlPIJHLbnpVr7onlrFmFWaWFCGL9lCSepUK TG4BPGmO3rRu
UreXONyNbAV6stsZmbwhWmij++ZAJDLwRywJQAqOQTyOYbE7MzVXctBZpsf7 kxecv5urKkjm
zLLbWwDE6FQqqptzHsHJIVB1Hrqv7d9kM1HEXdu9MZi8VJtmzgHmoyO82R8U IqWrClFCyRoj
ADs/99cBgAAZPKPuair35WudPf8Ai3xuStZDH5TEzY+KCaSnciQzuk5KwFFj dwTI6sirz27K
QQDrYtbualiorV/bWbqXLN0UqeOc1msWpCvflCkzRheocks68CNufwc1jJ7D zm5aWcs7mGIX
IX4MXClWtPI9dxQsPZXu5RWUSSSOpAU9V44LHTG7FzuPx8FulBhal2luI5ih iIbEgo1o2qGq
9dZPDBUMHll5EQAeQjrx6mzV/Hnn9mYvTvz88/usy7xFjb1bN4rbuYykMvjL NHAa0clV4mKS
JIJZkHZXV1PUt6qfwcE79bcmNs7Yxm467lqGTFRqzOyQkrZdFjJ8RlAP3Rfh 57H5KGYhTULO
y8idjQbeubc2ruU2Ld2/djylh0hgsWZ5JiYvuEhYKZ5FDfA3AHy5PH1urE5q psLbW2pfMZmx
WyGAja8iySS2Hr3YJLE0qhSI1EcBfuznksV9D172uZa40dybdv5efD0c/irW SrlhNThuRvNE
VPDdkB7Dg+h5Hpr7wWeweehebB5nHZSJApZ6dpJlXsOy8lSfmPUfjGqBBsfd kntJxOfv3a1i
njs1cu+K2Wslnry17McUS1OogjZPGjBYElghYkElTb/ZlgJtq+znbe2rPljZ xeLrVLDV+fDa
VI1V2UkAkFgTyQCefUanQnmsWq3i95YrI5+HD14bYkmXINHMyqIiKU8ME3r2 5/vkwA9PXo/y
9OduGtlcNt+8Uv5Dcl5Eklrrb8vFJIwT4YgY0jQAkfNh82PJ444pdz2bXrWI xmKOTiiSLaGT
wdy2OfFazcNQmwF44PLQyu3JB5ZfnySJ3XsvOM3Ft/KY6xk
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590683 is a reply to message #49649] Fri, 08 September 2006 17:10 Go to previous message
Originally posted by: varunkumarm.gmail.com
I too installed elver on a callisto release and used the update site for
elver.
Do you mean to say that i have to manually unzip the said jar file into
the plug-ins directory??
Then in that case there are two more plug-ins named
org.elver.store.eclipse_0.7.2
and org.elver.store.jpox.eclipse_0.7.2 along with it.
Do i need to unpack them as well..
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590692 is a reply to message #49680] Fri, 08 September 2006 17:31 Go to previous message
In my installation these are not unpacked. I do not understand why the plugins are not unpacked. In
the feature.xml I have the unpack="false" is not set for this plugin.
So only for the org.elver.store plugin I saw a difference with my install.
gr. Martin
> elver.
> VarunKumar.M
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590705 is a reply to message #49649] Fri, 08 September 2006 17:41 Go to previous message
Thanks a lot martin..I'm very excited to see the package.jdo getting
created
Plz clear the same doubt which i had so that i dont encounter new problems.
i.e that there are two more plug-ins which are named
org.elver.store.eclipse_0.7.2.jar and
org.elver.store.jpox.eclipse_0.7.2.jar
Should i unpack these jar's also or are they supposed to be like that.
And by the way, plz try to find out why the installation hadn't unpacked
the jar files.I'm informing you again because it happened on all the five
systems on which we have installed.
Any way..a million thanks for your quick help.
All the best for TENEO. I checked out the project from repository just now
and am thinking of using it if i didn't succeed here.
I'm awaiting the release of TENEO and i will inform you soon about how we
applied Elver for our project.
Regards and Thanks,
VarunKumar.M
PS: When i first tried creating the JDO File i got the error saying
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/emf/ecore/xmi/impl/EcoreResourceFactoryImpl
org.elver.store.mapper.PersistenceMappingBuilderImpl.buildMa pping(PersistenceMappingBuilderImpl.java:52)
org.elver.store.jpox.mapper.GenerateJDO.createORMapperFile(G enerateJDO.java:101)
at org.elver.store.jpox.mapper.GenerateJDO.main(GenerateJDO.jav a:82)
and i then included org.eclipse.emf.ecore.xmi also in the build path in
order to successfully generate the JDO file.
Give a thought for this also. :-)
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590718 is a reply to message #49738] Fri, 08 September 2006 17:49 Go to previous message
Good that it works.
With me the org.eclipse.emf.ecore.xmi plugin was added automatically to the plugin dependencies when
creating the emf project/generating the source code.
Maybe you did not create a new emf project but a new emf model in an existing project?
gr. Martin
> created
> five systems on which we have installed.
> now and am thinking of using it if i didn't succeed here.
> we applied Elver for our project.
> Regards and Thanks,
> VarunKumar.M
> at
> at
The Netherlands
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590725 is a reply to message #49710] Fri, 08 September 2006 18:18 Go to previous message
Ya that's fine and ok as the two plug-ins which i have mentioned have the
code directly in them in contrast to all the other plug-ins(like the one i
unpacked) where the .jar file is provided inside the folder and the src is
provided as .zip .
But why this inconsistency..couldn't all the plug-ins be made as unpacked
format in which the classes are jared and src is zipped.
That's just a suggestion. I dont know if there were particular reasons
which forced to do like that.
Thank you very much,
VarunKumar.M
Re: java.lang.NoClassDefFoundError: org/elver/store/StoreException [message #590742 is a reply to message #49797] Fri, 08 September 2006 18:28 Go to previous message
No particular reason, it is more the advice from the eclipse side that plugins should be preferably
shipped as jarred.
gr. Martin
> the code directly in them in contrast to all the other plug-ins(like the
> one i unpacked) where the .jar file is provided inside the folder and
> the src is provided as .zip .
> unpacked format in which the classes are jared and src is zipped.
> VarunKumar.M
The Netherlands
Previous Topic:CDO Resources
Next Topic:Cannot find operation xyz() for the type (abc)
Current Time: Sun Aug 31 09:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.07768 seconds
