Re: Disable "Preloading" of reports (pages) [message #485982 is a reply to message #485916] |
Tue, 15 September 2009 19:18 |
Tom,
Can you not run the report at an earlier time and then render it when
its needed? use the __document url parameter to render a previously
executed report.
Jason
Tom wrote:
> Hello,
> a little questions breaks my heart and i did not find anything about that.
> Is it possible to disable the preloading of reports? I have a few
> reports, that contains more than 1000 sites (every site contains
> explicit one data record - yes it is like the customer want) and the
> creation of that big reports will need a long time (minutes).
> I would like to have it on the following way: The customer choose any
> report, then the data, then the preloading will begin (Processing,
> please wait...). If everything has been loaded, the report displays that
> there are more than 1.000 pages. Each click on any page will display the
> corresponding data. This will be done very fast.
> In principle i would like to see the pages which are available (1 of
> 1000) and on clickthe data of the page will be displayed. Not all the
> data will be preloaded for a faster switch through the pages.
> I hope i do understood everything correct and anybody could help me with
> my questions. Or is there any documentation about that i didnt know/see?
> Best regards,
> Tom
Re: Disable "Preloading" of reports (pages) [message #486165 is a reply to message #486090] |
Wed, 16 September 2009 15:10 |
Tom,
When you are using the viewer a report document is created which
contains all the data and then when you request a specific page the data
is retrieved for that page. I do not know of a work around for your
issue except maybe to use drill through reports. Like one report list
all constellations and then the user selects one and a new report runs
for the details of the constellation.
Jason
Tom wrote:
> Dear Jason,
> no, this is unfortunately not possible. I have a lot of reports in a lot
> of different constellations. "Preloading" all data (and using it later
> by __document parameter) is not practicable.
> It is a big problem for me to handle this. Well, it is in normal cases a
> very useful feature to preload all data. So a page switch will be done
> much faster.
> But in my case i have reports with a looooot of pages, so preloading all
> is a little bit annoying.
> Do you know any other workaround for this?
> Best regards (and mandy thanks at all),
> Tom
FUDForum. Page generated in 0.03553 seconds
