Home » Archived » Test and Performance Tools Platform (TPTP) » Starting the Agent Controller make my JBoss crash
Starting the Agent Controller make my JBoss crash [message #49271] Thu, 05 January 2006 10:46 Go to next message
Originally posted by: nospam.mail.com
Hi all,
I'd like to profile a J2EE application running on a JBoss application
server.
I'm having problems starting the Agent Controller.
My config is :
Server Linux RedHat 9.0
Java 1.5.0_05
JBoss 3.2.7
RAServer 4.1.0.0
I start JBoss using the following command line :
/usr/local/jdk/bin/java -classic -Xdebug -Xnoagent -Djava.compiler=NONE
-Xrunjdwp:transport=dt_socket,address=8787,server=y,suspend= n -server
-Xms256m -Xmx824m -XrunpiAgent:server=enabled -Xdebug
-Dprogram.name=run.sh ... etc ...
Before launching RAServer, all is OK.
When I run ./RAStart.sh I get the message :
Starting Agent Controller
RAServer started successfully
But this make JBoss crash without any error message.
If I restart JBoss, I can begin profiling.
Any idea on how to solve this problem ?
A. ROY
Re: Starting the Agent Controller make my JBoss crash [message #49305 is a reply to message #49271] Thu, 05 January 2006 11:22 Go to previous message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0059DC2F852570ED_=
Content-Type: text/plain; charset="US-ASCII"
The Agent Controller has to be started before you can register any agents
with it. Try starting the Agent Controller first and then running JBoss
under enabled mode.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">The Agent Controller has to be started
before you can register any agents with it. &nbsp;Try starting the Agent
Controller first and then running JBoss under enabled mode.</font>
<br><font size=2 face="sans-serif"><br>
Navid Mehregani</font>
--=_alternative 0059DC2F852570ED_=--
Previous Topic:Internal Agent Controller
Next Topic:Profiling an IPlatformRunnable
Current Time: Wed Jul 30 15:22:51 EDT 2025
Powered by FUDForum. Page generated in 0.03589 seconds
