Creating a BIRT plugin? [message #485479] |
Fri, 11 September 2009 21:21 |
Originally posted by: ddd.asd.com
I am using the PDE framework to create a BIRT plugin. Its basically just a
button that creates a .rptdesign file when the user presses the button and
supplies a XML file (used as dataSource) as input to a filechooser box. But
when a .rptdesign file is created the Birt Runtime is used.
My idea was to make the whole Birt Runtime as a jar file and wrap it into a
plugin using the PDE tools. But is this the best approach or are the some
better way to create the above plugin?
Re: Creating a BIRT plugin? [message #485480 is a reply to message #485479] |
Fri, 11 September 2009 21:46 |
Basically my problem is that I have made and application that creates a
..rptdesign file but when the last line below is executed:
designConfig.setProperty("BIRT_HOME", engineDir);
designEngine = designFactory.createDesignEngine(designConfig);
nothing happens. The application is wrapped into a plugin and used in a PDE
plugin. I have made the wrapped application as a fat jar so all the birt
library files are included. Maybe it has something to do with 'engineDir'.
This string is referring to the location of the BIRT ReportEngine but I am
not sure this makes sense inside a plugin...
Any ideas are most welcome!
"klm" <ddd@asd.com> wrote in message news:h8ef1a$rm2$1@build.eclipse.org...
> a plugin using the PDE tools. But is this the best approach or are the
> some better way to create the above plugin?
Re: Creating a BIRT plugin? [message #485731 is a reply to message #485480] |
Mon, 14 September 2009 17:00 |
If you are building an RCP/Eclipse based application and already have
the BIRT plugins loaded you can set the BIRT_HOME to "" and you do not
have to include the runtime at all, because it is already there.
Jason
> PDE plugin. I have made the wrapped application as a fat jar so all the
> birt library files are included. Maybe it has something to do with
> 'engineDir'. This string is referring to the location of the BIRT
> ReportEngine but I am not sure this makes sense inside a plugin...
>> just a button that creates a .rptdesign file when the user presses the
>> button and supplies a XML file (used as dataSource) as input to a
>> filechooser box. But when a .rptdesign file is created the Birt
>> Runtime is used.
>> into a plugin using the PDE tools. But is this the best approach or
>> are the some better way to create the above plugin?
Re: Creating a BIRT plugin? [message #485765 is a reply to message #485731] |
Mon, 14 September 2009 21:14 |
I have now tried:
designConfig = new DesignConfig();
reportConfig = new EngineConfig();
try {
designConfig.setProperty("BIRT_HOME", "");
IDesignEngineFactory designFactory = (IDesignEngineFactory)
Platform.createFactoryObject (
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
But the last line gives a NullPointerException.
I have also tried adding:
Platform.startup( designConfig );
after:
But then I get:
org.eclipse.birt.core.exception.BirtException: Cant startup the OSGI
framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:91)
Cant startup the OSGI framework.
My BIRT PDF Plugin project contains the following dependencies (from the
MANIFEST.MF file):
org.eclipse.ui
org.eclipse.core.runtime
org.eclipse.birt.core(2.5.0)
org.eclipse.birt.report.engine(2.5.0)
org.eclipse.birt.report.model.adapter.oda(2.5.0)
PDE_wrap(1.0.0)
where PDE_wrap is the application (that creates the ReportDesignHandle)
wrapped to a PDE plugin. Any ideas?
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:h8lspk$d36$2@build.eclipse.org...
> If you are building an RCP/Eclipse based application and already have the
> BIRT plugins loaded you can set the BIRT_HOME to "" and you do not have to
> Jason
>>> a button that creates a .rptdesign file when the user presses the button
>>> and supplies a XML file (used as dataSource) as input to a filechooser
>>> box. But when a .rptdesign file is created the Birt Runtime is used.
>>> into a plugin using the PDE tools. But is this the best approach or are
Re: Creating a BIRT plugin? [message #485775 is a reply to message #485765] |
Mon, 14 September 2009 21:52 |
I have now moved the dependencies to the PDE wrapped jar (which is
included as a dependency in the main PDE plugin project) and now it does not
give the previous error.
To make this call:
session = designEngine.newSessionHandle(ULocale.ENGLISH); // never
work I had to include:
com.ibm : icu 4.0.1
"klm" <ddd@asd.com> wrote in message news:h8mbo4$75q$1@build.eclipse.org...
>I have now tried:
> try {
> after:
> But then I get:
> framework
> MANIFEST.MF file):
> org.eclipse.ui
> PDE_wrap(1.0.0)
>> Jason
>>>> filechooser box. But when a .rptdesign file is created the Birt Runtime
>>>> is used.
Re: Creating a BIRT plugin? [message #485909 is a reply to message #485775] |
Tue, 15 September 2009 14:03 |
Is it working now?
> not
> To make this call:
> com.ibm : icu 4.0.1
>> I have now tried:
>> try {
>> after:
>> But then I get:
>> framework
>> the MANIFEST.MF file):
>> org.eclipse.ui
>> PDE_wrap(1.0.0)
>> ReportDesignHandle) wrapped to a PDE plugin. Any ideas?
>>> not have to include the runtime at all, because it is already there.
>>> Jason
>>>> creates a .rptdesign file but when the last line below is executed:
>>>> in a PDE plugin. I have made the wrapped application as a fat jar so
>>>> all the birt library files are included. Maybe it has something to
>>>> do with 'engineDir'. This string is referring to the location of the
>>>> BIRT ReportEngine but I am not sure this makes sense inside a plugin...
>>>>> the button and supplies a XML file (used as dataSource) as input to
>>>>> a filechooser box. But when a .rptdesign file is created the Birt
>>>>> Runtime is used.
>>>>> it into a plugin using the PDE tools. But is this the best approach
>>>>> or are the some better way to create the above plugin?
Re: Creating a BIRT plugin? [message #485993 is a reply to message #485909] |
Tue, 15 September 2009 20:30 |
Originally posted by: asd.asd.com
Yes all the dependencies needs to be made on the wrapped jar (application
jar). Next this wrapped jar can be made a dependency in the main plugin.
As long as I make sure to add the engine, model and the icu dependencies to
the application jar I don't need to specify a path to the birt report
engine.
news:h8o6n9$glt$1@build.eclipse.org...
> Is it working now?
>> not
>> To make this call:
>> com.ibm : icu 4.0.1
>>> I have now tried:
>>> try {
>>> after:
>>> But then I get:
>>> framework
>>> MANIFEST.MF file):
>>> org.eclipse.ui
>>> PDE_wrap(1.0.0)
>>>> Jason
>>>>> a PDE plugin. I have made the wrapped application as a fat jar so all
>>>>> the birt library files are included. Maybe it has something to do with
>>>>>> the button and supplies a XML file (used as dataSource) as input to a
>>>>>> Runtime is used.
FUDForum. Page generated in 0.02999 seconds
