Home » Eclipse Projects » GEF » more documentation/ressources for writing an editor
more documentation/ressources for writing an editor [message #4311] Tue, 28 May 2002 06:34 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
I need more information/documentation for writing an editor extention. Any
one knows where I can find more? The Plugin Developer Guide of Eclipse Help
System is not so useful because it gives just a short overview with
TextEditor but I need to start from EditorPart (for GEF).
I also miss a full API reference (ex. EditorPart). Do I need to build on
myself or can I download it somewhere?
Cu, Gunnar
Re: more documentation/ressources for writing an editor [message #4451 is a reply to message #4311] Tue, 28 May 2002 10:06 Go to previous messageGo to next message
Originally posted by: none.ibm.com
Run the Eclipse Workbench in which you installed GEF. From there, you will
find a Developer guide from GEF. It is integrated into the Help system.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:acvljf$kjr$1@rogue.oti.com...
> Hi!
Help
> Cu, Gunnar
Re: more documentation/ressources for writing an editor [message #4730 is a reply to message #4451] Tue, 28 May 2002 16:29 Go to previous messageGo to next message
May I suggest to include in current docs a few additional words about method
paramters: I found myself frequently lost deeply in SWT internals trying to
understand style bits or something like this. I need to dig in sources what
does it mean "int style", then that's not always clear which SWT.XXXX
constant I must use for particular case - short explanations to any int or
Object parameters can be very helpful. Worst of all that for SWT constants
(why not to split this huge pile into different classes?) I frequetntly ends
somewere in MSDN... :(
Another thing that puzzled me is draw2d.resource - can you provide a short
snippet to demonstrate SharedCursor usage? I have no problem with direct
usage of swt cursors.
as
P.S. GEF download link now points to CDT page. Is there any live link to GEF
distribution?
"Randy Hudson" <none@ibm.com>
Re: more documentation/ressources for writing an editor [message #4799 is a reply to message #4730] Tue, 28 May 2002 16:36 Go to previous messageGo to next message
Originally posted by: peter_burka.oti.com
Alex,
All of the SWT style bits should be documented in the JavaDoc for each
Widget.
Have you encountered widgets which didn't include this information?
/peter
Peter Burka
Object Technology International, Inc.
"Alex Selkov" <as@empproject.com> wrote in message
news:ad0og2$86e$1@rogue.oti.com...
method
to
what
ends
> as
GEF
> distribution?
Re: more documentation/ressources for writing an editor [message #4867 is a reply to message #4730] Tue, 28 May 2002 18:45 Go to previous messageGo to next message
SharedCursor has been deleted. We will drop an update GEF download this
week.
GEF
> distribution?
Thanks, we'll fix soon.
Re: more documentation/ressources for writing an editor [message #4936 is a reply to message #4867] Tue, 28 May 2002 19:07 Go to previous messageGo to next message
Re: more documentation/ressources for writing an editor [message #5004 is a reply to message #4799] Tue, 28 May 2002 21:23 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
The documentation, like the software, is a marvel of brevity. In the SWT
class, it often consists of a terse sentence that gives little more
information than the constant it describes. For instance,
RADIO - Wouldn't hurt to mention that radio button peers in a Composite form
a "radio group". A FAQ.
TOOL - Whatizzit?
PRIMARY_MODAL, APPLICATION_MODAL, SYSTEM_MODAL - What's the diff?
NO_BACKGROUND - Might as well add, "This doesn't do what you want." ;-}
DBCS, ALPHA, NATIVE, PHONETIC - At least a link, please.
Ok, I was kidding about NO_BACKGROUND. But a comment that it doesn't make a
canvas transparent wrt other widgets would save lots of people time.
Bob
"Peter Burka" <peter_burka@oti.com> wrote in message
news:ad0ov6$8c7$1@rogue.oti.com...
> Alex,
> Widget.
> /peter
> Peter Burka
> method
> to
> what
or
constants
> ends
short
> > as
> GEF
> > distribution?
Re: more documentation/ressources for writing an editor [message #5073 is a reply to message #4936] Tue, 28 May 2002 21:26 Go to previous messageGo to next message
> 2. Antialiasing. Our tool needs to draw a lot of arcs and angled lines -
> looks ugly after Swing :( Any chance that GDI+ will be supported?
Please add yourself to this bug:
http://dev.eclipse.org/bugs/show_bug.cgi?id=7075
Re: more documentation/ressources for writing an editor [message #5140 is a reply to message #5004] Tue, 28 May 2002 21:30 Go to previous messageGo to next message
They're trying to keep the download times small ;-)
BTW, this is the newsgroup for complaining about GEF documentation, not SWT.
Your points are valid and *EVERYONE* has been affected by the lack of
documentation at some point. I think there is an "Arrow" constant and an
"ARROW" constant, and they mean different things. But I digress...
"Bob Foster" <bob@objfac.com> wrote in message
news:ad19dd$d9h$1@rogue.oti.com...
form
> TOOL - Whatizzit?
a
> Bob
> > Alex,
> > Widget.
> > /peter
> > Peter Burka
> > method
trying
> > to
> > what
int
> or
> constants
frequetntly
> > ends
> short
direct
> > > as
to
> > GEF
> > > distribution?
Re: more documentation/ressources for writing an editor [message #5210 is a reply to message #5073] Tue, 28 May 2002 21:48 Go to previous messageGo to next message
  • Attachment: image001.png
    (Size: 6.88KB, Downloaded 121 times)
Re: more documentation/ressources for writing an editor [message #5277 is a reply to message #5210] Tue, 28 May 2002 23:33 Go to previous messageGo to next message
You did that using what language?
I think it is unlikely that SWT will bind to anything but the win32 API. Is
it in that API?
> Will pray for higher priority :) Just downloaded .net sdk and wrote simple
> tests with SmoothingMode.AntiAlias - look at the picture attached. All
lines
> and curves looks ideal, arcs - very good. And all of this supported on
> W98/2K/XP (other then XP must have .net runtime? anyway windowsupdate try
to
> push this beast to everyone) - I have W2K.
Re: more documentation/ressources for writing an editor [message #5402 is a reply to message #5210] Wed, 29 May 2002 00:50 Go to previous messageGo to next message
Looks nice!
Bob
news:ad1b5r$dl5$1@rogue.oti.com...
Re: more documentation/ressources for writing an editor [message #5405 is a reply to message #4451] Wed, 29 May 2002 03:08 Go to previous messageGo to next message
Hi!
"Randy Hudson" <none@ibm.com> schrieb im Newsbeitrag
news:ad020n$r4n$1@rogue.oti.com...
will
I know about this guide. I also know about the other guides. That's why I'm
asking for more informations. These guides give in some case only a shot
overview of a topic. I'm looking for deeper guides or docs.
Meanwhile I started generating my own JavaDoc out of the Eclipse PlugIns.
Someone have written a tool, which automatically extract zipped sources and
generates a packages.txt for the JavaDoc tool. I think you should provide a
full JavaDoc zip of the public API for download. There are important API
reference docs missing in the Eclipse Help System.
Cu, Gunnar
Re: more documentation/ressources for writing an editor [message #5411 is a reply to message #5405] Wed, 29 May 2002 03:14 Go to previous messageGo to next message
Hi!
I was talking about the Eclipse Plattform help not GEF. The GEF API doc is
all in Eclipse help.
Cu, Gunnar
Re: more documentation/ressources for writing an editor [message #5417 is a reply to message #5405] Wed, 29 May 2002 03:35 Go to previous messageGo to next message
Hi Gunnar,
in F1 i found the API docs in the plugin
org.eclipse.platform.doc.isv_2.0.0. They are packed in the
doc.zip.
Martin
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> schrieb im
Newsbeitrag news:ad1trr$io6$1@rogue.oti.com...
> Hi!
there, you
> will
Help system.
That's why I'm
only a shot
Eclipse PlugIns.
sources and
should provide a
important API
> Cu, Gunnar
Re: more documentation/ressources for writing an editor [message #5428 is a reply to message #5405] Wed, 29 May 2002 09:10 Go to previous messageGo to next message
Both Eclipse and GEF and fully generated JavaDOC in the Integrated Help. It
just takes some looking around for Eclipse.
Of course, JavaDOC was only generated for the source that we commented
fully. We're working on this.
Re: more documentation/ressources for writing an editor [message #5445 is a reply to message #5277] Wed, 29 May 2002 10:03 Go to previous messageGo to next message
It was C#. But AFAIK the most important part is gdiplus.dll, included in XP
and shipped with .net runtime for other windowses.
Re: more documentation/ressources for writing an editor [message #5492 is a reply to message #5428] Wed, 29 May 2002 20:13 Go to previous messageGo to next message
Where to look for Eclipse?
Bob
"Randy Hudson" <none@ibm.com> wrote in message
news:ad2j3l$ub4$1@rogue.oti.com...
It
Re: more documentation/ressources for writing an editor [message #5503 is a reply to message #5492] Wed, 29 May 2002 20:34 Go to previous messageGo to next message
www.eclipsecorner.org
news:ad3pmj$h7v$1@rogue.oti.com...
> Bob
> It
Re: more documentation/ressources for writing an editor [message #5665 is a reply to message #5503] Wed, 29 May 2002 21:14 Go to previous messageGo to next message
This took me to the eclipse.org homepage. Not helpful. I'll try again.
Where to look within the Integerated Help for the fully generated JavaDOC
for eclipse?
Bob
"Guy Slade" <gslade@us.ibm.com> wrote in message
news:ad3r7d$hkv$1@rogue.oti.com...
> > Bob
Help.
> > It
Re: more documentation/ressources for writing an editor [message #5695 is a reply to message #5492] Wed, 29 May 2002 22:30 Go to previous messageGo to next message
Re: more documentation/ressources for writing an editor [message #5747 is a reply to message #5665] Thu, 30 May 2002 04:13 Go to previous messageGo to next message
Originally posted by: shane_fitzgibbon.versata.com.au
I think that there might be a problem with the doc in the draw2d and GEF
plugins. I just added the plugins to a fresh Eclipse 2.0 F1 install and the
draw2d User Guide has errors and doesn't display any thing under it's
sections and the GEF User Guide doesn't show up at all in the Help menu.
The following is what I have in my .log file
!SESSION May 30, 2002
14:26:22.892 ---------------------------------------------
java.version=1.3.1
Command-line arguments: -os win32 -ws win32 -arch x86 -feature
org.eclipse.platform -install file:E:/eclipse/f1/eclipse/
!ENTRY org.eclipse.core.resources 1 4 May 30, 2002 14:26:22.892
!MESSAGE Reference action not found: additions
!ENTRY org.eclipse.help 4 0 May 30, 2002 14:27:44.630
!MESSAGE Document
/org.eclipse.platform.doc.isv/reference/extension-points/org _eclipse_ant_cor
e_antObjects.html cannot be read.
!ENTRY org.eclipse.help 4 0 May 30, 2002 14:27:48.946
!MESSAGE Document /org.eclipse.platform.doc.isv/questions/index.html cannot
be read.
!ENTRY org.eclipse.help 4 0 May 30, 2002 14:27:49.326
!MESSAGE Document
/org.eclipse.platform.doc.isv/samples/org.eclipse.update.exa mples/doc-html/u
pdate_install_ex.html cannot be read.
!ENTRY org.eclipse.help 4 0 May 30, 2002 14:27:54.784
!MESSAGE Document /org.eclipse.jdt.doc.isv/questions/index.html cannot be
read.
!ENTRY org.eclipse.help 4 0 May 30, 2002 14:27:57.07
!MESSAGE Document
/org.eclipse.platform.doc.isv/reference/extension-points/org _eclipse_help_co
ntributions.html cannot be read.
!ENTRY org.eclipse.help 4 0 May 30, 2002 14:27:57.839
!MESSAGE Document
/org.eclipse.jdt.doc.isv/reference/extension-points/org_ecli pse_debug_core_l
aunchers.html cannot be read.
14:31:53.117 ---------------------------------------------
java.version=1.3.1
!ENTRY org.eclipse.core.runtime 2 1 May 30, 2002 14:31:53.117
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 May 30, 2002 14:31:53.117
!MESSAGE Unable to satisfy prerequisite constraint from
com.ibm.etools.gef.doc.isv to com.ibm.etools.gef.
!ENTRY org.eclipse.core.resources 1 4 May 30, 2002 14:31:59.646
17:47:26.83 ----------------------------------------------
java.version=1.3.1
!ENTRY org.eclipse.core.resources 1 4 May 30, 2002 17:47:26.83
Re: more documentation/ressources for writing an editor [message #5787 is a reply to message #5747] Thu, 30 May 2002 09:45 Go to previous messageGo to next message
The ISV Doc pre-reqs GEF. Why? Because we have Views that are only meant
for developers, not for shipping the final product. Since Eclipse has no
way of adding Views programatically, we had to declare them in the ISV DOC
plugin.xml, which we assumed only developers would have on their
installation.
The 2 "developer" Views are a CommandStack viewer and a trace console.
"Shane Fitzgibbon" <shane_fitzgibbon@versata.com.au> wrote in message
news:ad4ls4$p4v$1@rogue.oti.com...
the
> java.version=1.3.1
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !MESSAGE Document
cannot
> be read.
> !MESSAGE Document
> read.
> !MESSAGE Document
> !MESSAGE Document
> java.version=1.3.1
> java.version=1.3.1
Re: more documentation/ressources for writing an editor [message #8016 is a reply to message #5445] Wed, 05 June 2002 17:35 Go to previous message
Originally posted by: mike_wilson.oti.com
Maybe somebody should write .net based version of SWT... ;-)
McQ.
> "Randy Hudson" <none@ibm.com> ÓÏÏÂÝÉÌ/ÓÏÏÂÝÉÌÁ × ÎÏ×ÏÓÔÑÈ ÓÌÅÄÕÀÝÅÅ:
> news:ad1ham$fco$1@rogue.oti.com...
> Is
>>it in that API?
> simple
>>lines
> try
>>to
Previous Topic:ManhattanConnectionRouter example?
Next Topic:How to move a figure
Current Time: Thu Jul 17 19:47:01 EDT 2025
Powered by FUDForum. Page generated in 1.30799 seconds
