Mylyn not able to parse backup files !!! [message #49263] |
Thu, 29 May 2008 10:02  |
Originally posted by: chlache.talita.org
After updating from m7 to rc2 i got into an incredible mess.
First I ran into one crash(most likely due to Mylyn) after another reading my workspace.
Now it finally works but Mylyn cannot read its own backup data properly.
I guess thats the worst thing a software can do - not be able to read your own backup data.
All categories are empty. Everything is now put into uncategorized. Dozens of tasks.
Some tasks seems to be empty.
Mylyn seems to get more and more buggy. One time - after switching tasks - all editors gone
next time nothing changes at all - the editors stay the same.
And the newest thing: two tasks stay active all the time. I cannot turn the old task off.
Sorry I did not file a bug report. I am pissed and too busy and I lost my account data too.
Re: Mylyn not able to parse backup files !!! [message #49382 is a reply to message #49352] |
Thu, 29 May 2008 15:56  |
>> The account data is stored in the eclipse keystore. The default location
>> depends on your operating system but you can force it to a particular
>> location to share it between Eclipse installations, e.g.:
>> eclipse -keystore ~/.eclipsekeystore
> Didn't Eclipse Platform changed implementation and storage of that
> data in 3.4? I saw note for CVS plugin that users would have to re-enter
> credentials. Though Task Repositories details always been stored outside
> of keystore and shouldn't be lost.
Yes, Eclipse 3.4 includes the new Equinox Security framework that is used by
CVS. Mylyn does make not use of the new APIs at this point and is still
using the old keystore.
Steffen
Re: Mylyn not able to parse backup files !!! [message #589821 is a reply to message #49263] |
Thu, 29 May 2008 11:19  |
I went back to m7.
First Mylyn cannot create its TaskView - ERROR.
!ENTRY org.eclipse.ui.workbench 4 0 2008-05-29 16:06:36.703
!MESSAGE Unable to create view ID org.eclipse.mylyn.tasks.ui.views.tasks: An unexpected exception was thrown.
!STACK 0
at org.eclipse.mylyn.tasks.core.AbstractTaskContainer.getChildr en(AbstractTaskContainer.java:75)
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListContentPro vider.getFilteredRootChildren(TaskListContentProvider.java:1 91)
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListContentPro vider.getFilteredChildrenFor(TaskListContentProvider.java:17 3)
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListContentPro vider.getChildren(TaskListContentProvider.java:82)
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListContentPro vider.hasChildren(TaskListContentProvider.java:89)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:2076)
at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer .java:581)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:2102)
at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTreeViewer.java:2752)
at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.j ava:841)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:828)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:633)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitial izeTree(AbstractTreeViewer.java:1490)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree( TreeViewer.java:822)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1474)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1365)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:396)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1328)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1467)
at org.eclipse.ui.dialogs.FilteredTree$NotifyingTreeViewer.inpu tChanged(FilteredTree.java:905)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListView.creat ePartControl(TaskListView.java:779)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 0)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:53 1)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:668)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:271)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:964)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2557)
at org.eclipse.ui.internal.WorkbenchWindow$25.run(WorkbenchWind ow.java:2862)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2843)
at org.eclipse.ui.internal.WorkbenchWindow$19.runWithException( WorkbenchWindow.java:2160)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:132)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3759)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3384)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1365)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2305)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 10)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:494)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:489)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:112)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
I need to delete the .mylyn directory of the workspace.
Taskview shows up without errors.
Restore from Backup. Task Data are restored almost right.
One task is empty.
> Dozens of tasks.
> - all editors gone
> the old task off.
Re: Mylyn not able to parse backup files !!! [message #589835 is a reply to message #49270] |
Thu, 29 May 2008 13:53  |
Andreas:
It looks like your Mylyn was partially updated, either due to a network
problem or an install/p2 problem. Could you please file a bug against
Mylyn with this stack trace and let us know how up updated/installed?
In the meantime, if you have any more problems with the 3.0 RCs please
do the following:
1) Uninstall or delete the old plug-ins. Make sure you leave the
<workspace>/.mylyn directory around since it holds the snapshots.
2) Install Mylyn 2.3.x from: http://www.eclipse.org/mylyn/downloads/
3) Restore tasks from a backup if they disappeared, via the Task List's
view menu.
Mik
> I went back to m7.
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> One task is empty.
>> Dozens of tasks.
Re: Mylyn not able to parse backup files !!! [message #589850 is a reply to message #49263] |
Thu, 29 May 2008 14:04  |
> all editors gone next time nothing changes at all - the editors stay the
> same.
If you activate a task that has not been activated beforethe open editors
will remain open. Please file a bug if the activated task had been
activated before.
> the old task off.
I have filed a new bug and will investigate that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=234682
> account data too.
Steffen
Re: Mylyn not able to parse backup files !!! [message #589855 is a reply to message #49322] |
Thu, 29 May 2008 15:06  |
regards,
Eugene
Re: Mylyn not able to parse backup files !!! [message #589862 is a reply to message #49352] |
Steffen
FUDForum. Page generated in 0.06365 seconds
