Home » Eclipse Projects » Mylyn » context test suite and classpath
context test suite and classpath [message #49238] Fri, 23 May 2008 08:14 Go to next message
Originally posted by: pereza.gsicommerce.com
Hi all,
When Mylyn creates its context test suite it's missing various
parameters from the classpath (thinks like loading the mock jar, etc).
These are necessary for the tests to run correctly. The context tests
cannot run successfully without this.
Is there a way to somehow set up these additions to the classpath ahead
of time? So that the auto-created tests have the correct path?
tia,
arturo
Re: context test suite and classpath [message #50221 is a reply to message #49238] Tue, 17 June 2008 12:51 Go to previous message
You should be able to set the classpath in the same way as you set it
for normal unit test launch configurations (e.g. via the Arguments tab).
If that's not working or not sufficient please file a new bug.
Mik
Arturo Perez wrote:
> Hi all,
> tia,
> arturo
Re: context test suite and classpath [message #590127 is a reply to message #49238] Tue, 17 June 2008 12:51 Go to previous message
Mik
Arturo Perez wrote:
> Hi all,
> tia,
> arturo
Previous Topic:Error with JIRA
Next Topic:Re: using landmarks in Mylyr
Current Time: Sat Jul 26 07:37:56 EDT 2025
Powered by FUDForum. Page generated in 0.06162 seconds
