Home » Modeling » GMF (Graphical Modeling Framework) » Error during Code generation: "A resource exists with a different case"
Error during Code generation: "A resource exists with a different case" [message #49208] Sat, 16 September 2006 07:39 Go to next message
Originally posted by: dont.spam.net
I've tried to reproduce the Editor described in this Article:
http://www.eclipse.org/articles/Article-FromFrontendToCode-M DSDInPractice/article.html
I tried to create all the models by myself and I thought I was not too
bad (all models valid etc...). But then I started the Code Generation
and got this funny error:
Error
Sat Sep 16 13:30:13 CEST 2006
A resource exists with a different case:
/com.xxx.statemachine.diagram/src/statemachine2/diagram/edit /policies/Statemachine2GraphicalNodeEditPolicy.java.
eclipse.buildId=M20060629-1905
java.version=1.5.0_08
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
There is no stacktrace available and I have absolutely no Idea what's wrong.
Cheers!
Christian
Re: Error during Code generation: "A resource exists with a different case" [message #49237 is a reply to message #49208] Sat, 16 September 2006 08:23 Go to previous messageGo to next message
--------------020802050403050604020903
Christian,
Perhaps you changed the *case *of some property? Try deleting *this
*file and regenerating
A resource exists with a different *case*:
/com.xxx.statemachine.diagram/src/statemachine2/diagram/edit /policies/*Statemachine2GraphicalNodeEditPolicy*.java.
Christian Barth wrote:
> Error
> wrong.
> Cheers!
> Christian
<html>
<head>
http-equiv="Content-Type">
</head>
Christian,<br>
<br>
Perhaps you changed the <b>case </b>of some property? Try deleting <b>this
</b>file and regenerating<br>
<blockquote>A resource exists with a different <b>case</b>:
/com.xxx.statemachine.diagram/src/statemachine2/diagram/edit /policies/ <b>Statemachine2GraphicalNodeEditPolicy</b>.java.
<br>
</blockquote>
<br>
<br>
<blockquote cite="mideegnok$khj$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/articles/Article-FromFrontendToCode-M DSDInPractice/article.html"> http://www.eclipse.org/articles/Article-FromFrontendToCode-M DSDInPractice/article.html</a>
<br>
<br>
<br>
<br>
<br>
Error
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Re: Error during Code generation: "A resource exists with a different case" [message #49349 is a reply to message #49237] Sun, 17 September 2006 05:35 Go to previous messageGo to next message
Hi Ed,
I have deleted the file like you suggested. The Code Generation Process
stopps still with the same error message. Deleting the whole generated
Code doesn't help at all.
I guess I messed up the naming somewhere in the model.
All my model files are named statemachine2.xxx and the NS Prefix in the
ecore-model is also named statemachine2.
When I look at the package the error message points to, I'll find there
several different writings. For example:
StateMachineCanonicalEditPolicy.java
StateMachine2CanonicalEditPolicy.java
StateMachine3CanonicalEditPolicy.java
Some names are also found with a lower case "m" like
State*m*achine2GraphicalNodeEditPolicy.java
State*m*achine2ExtNodeLabelhosteLayoutEditPolicy.java
Maybe it's worth to mention that the files with a lower case "m" are
never with a 3 or without a number.
To which part of the models does this policy stuff belong?
Ed Merks schrieb:
> Christian,
>> Error
>> wrong.
>> Cheers!
>> Christian
Re: Error during Code generation: "A resource exists with a different case" [message #49409 is a reply to message #49349] Sun, 17 September 2006 08:35 Go to previous messageGo to next message
Christian,
You also deleted them from the file system, not just from the
workspace? I'm not familiar enough with GMF to know what might give
rise to a problem like this...
> Hi Ed,
> Process stopps still with the same error message. Deleting the whole
> generated Code doesn't help at all.
> the ecore-model is also named statemachine2.
> there several different writings. For example:
> Ed Merks schrieb:
>> Christian,
>>> Hi,
>>> too bad (all models valid etc...). But then I started the Code
>>> Generation and got this funny error:
>>> Error
>>> what's wrong.
>>> Cheers!
>>> Christian
Re: Error during Code generation: "A resource exists with a different case" [message #49468 is a reply to message #49349] Sun, 17 September 2006 11:07 Go to previous messageGo to next message
You may fix it by setting the editpart/edit policies class names manually in
the gen-model editor (see attached screenshot).
However, after examining the code that produces default values I can not
explain why there may be default values with different cases. If possible,
please post your models (mapping + graph + tool) here for further
investigations.
Michael
"Christian Barth" <dont@spam.net> wrote in message
news:eej4r8$u3q$1@utils.eclipse.org...
> Hi Ed,
> Ed Merks schrieb:
>> Christian,
>>> Hi,
>>> Error
>>> wrong.
>>> Cheers!
>>> Christian
Re: Error during Code generation: "A resource exists with a different case" [message #50736 is a reply to message #49468] Tue, 19 September 2006 06:52 Go to previous message
--------------040609050801040001030601
I've found the problem. If you look at my model, you will see that I
have defined:
1) a *namespace* called statemachine2
2) a *element* called StateMachine
It seems that the Code Generator produces some similar named files which
leads to this crash.
I've renamed the element from StateMachine to Machine. Now I can
generate the code without an error (I've found a few new problems, but
therefore I'll make a different posting :D ).
Christian
Michael Golubev schrieb:
> investigations.
> Michael
>> Hi Ed,
>> Ed Merks schrieb:
>>> Christian,
>>>> Hi,
>>>> Error
>>>> wrong.
>>>> Cheers!
>>>> Christian
Content-Type: text/xml;
name="statemachine2.ecore"
Content-Disposition: inline;
filename="statemachine2.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="statemachine2"
nsURI="http://openarchitectureware.org/statemachine2" nsPrefix="statemachine2">
<eClassifiers xsi:type="ecore:EClass" name="Named" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Machine" eSuperTypes="#//CompositeState #//Named"/>
<eClassifiers xsi:type="ecore:EClass" name="CompositeState" eSuperTypes="#//State">
<eStructuralFeatures xsi:type="ecore:EReference" name="states" lowerBound="1"
upperBound="-1" eType="#//AbstractState" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="transitions" upperBound="-1"
eType="#//Transition" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AbstractState" abstract="true">
<eStructuralFeatures xsi:type="ecore:EReference" name="inTransitions" upperBound="-1"
eType="#//Transition" eOpposite="#//Transition/to"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="outTransitions" upperBound="-1"
eType="#//Transition" eOpposite="#//Transition/from"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="actions" upperBound="-1"
eType="#//Action" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="State" eSuperTypes="#//AbstractState #//Named"/>
<eClassifiers xsi:type="ecore:EClass" name="StartState" eSuperTypes="#//AbstractState"/>
<eClassifiers xsi:type="ecore:EClass" name="StopState" eSuperTypes="#//AbstractState #//Named"/>
<eClassifiers xsi:type="ecore:EClass" name="Transition" eSuperTypes="#//Named">
<eStructuralFeatures xsi:type="ecore:EReference" name="from" lowerBound="1" eType="#//AbstractState"
eOpposite="#//AbstractState/outTransitions"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="to" lowerBound="1" eType="#//AbstractState"
eOpposite="#//AbstractState/inTransitions"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="event" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="guard" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Action" eSuperTypes="#//Named">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="kind" lowerBound="1" eType="#//ActionKind"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ActionKind">
<eLiterals name="ENTRY" value="1"/>
<eLiterals name="EXIT" value="2"/>
</eClassifiers>
</ecore:EPackage>
--------------040609050801040001030601--
Previous Topic:Deleting Figures doesnt update my constraint self->size()
Next Topic:generalization
Current Time: Tue Jul 15 07:30:39 EDT 2025
Powered by FUDForum. Page generated in 0.49481 seconds
