Re: [EMF Compare] resourceURISimilarity fails with empty URI [message #484401 is a reply to message #484400] |
Mon, 07 September 2009 11:47 |
--------------040308000700000102030400
Hi Guillaume,
Can't say this is "by design", it's more that we didn't protect the code
against empty URI resources since most of the code assumes your compared
resources are contained within a resource set, and they have legal URIs.
Do you have a legit use case where we should be able to compare
resources with no URI? If yes, then please raise a bug with the
information and (if possible) sample models for which the code should be
functional.
Laurent Goubet
Obeo
Guillaume Chatelet a
Re: [EMF Compare] resourceURISimilarity fails with empty URI [message #621359 is a reply to message #484400] |
Hi Guillaume,
functional.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03961 seconds
