Home » Archived » BIRT » PDF reports from webapplication
PDF reports from webapplication [message #49174] Wed, 22 June 2005 09:09 Go to next message
Originally posted by: juergen.schwarz.gefasoft.de
I built BIRT into my web application and it work generating HTML
reports. But I need PDF format, so I changed to OUTPUT_FORMAT_PDF but I
don't get any output, just a blank screen.
In Eclipse preview, the PDF works.
What's going wrong?
Here's the log:
22.06.2005 15:05:28 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: Using org.apache.xerces.parsers.SAXParser as SAX2 Parser
22.06.2005 15:05:29 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: building formatting object tree
INFO: setting up fonts
22.06.2005 15:05:30 org.apache.avalon.framework.logger.Jdk14Logger error
SCHWERWIEGEND: property - "text-transform" is not implemented yet.
SCHWERWIEGEND: Error in letter-spacing property value 'normal':
org.apache.fop.fo.expr.PropertyException: No conversion
defined
SCHWERWIEGEND: property - "word-spacing" is not implemented yet.
defined
SCHWERWIEGEND: Error in column-width property value '20%':
org.apache.fop.fo.expr.PropertyException: No conversion defin
ed
SCHWERWIEGEND: Error in column-width property value '30%':
ed
ed
ed
22.06.2005 15:05:30 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: [1]
SCHWERWIEGEND: At least one of minimum, optimum, or maximum IPD must be
specified on table.
specified on table.
INFO: area contents overflows area in line Beschreibung
INFO: area contents overflows area in line Typattribut?
specified on table.
INFO: Parsing of document complete, stopping renderer
22.06.2005 15:05:30 org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
Re: PDF reports from webapplication [message #49197 is a reply to message #49174] Wed, 22 June 2005 09:18 Go to previous messageGo to next message
Oh, I can see a .fo file in the temp directory but I get no PDF...
Re: PDF reports from webapplication [message #51674 is a reply to message #49197] Mon, 27 June 2005 12:56 Go to previous messageGo to next message
Do you at least see a PDF file?
Can you log a bugzilla entry with the report attached? If your report uses
special data sources, can you make sure to reproduce it with a
self-contained data source?
Stanley Wang
Re: PDF reports from webapplication [message #52113 is a reply to message #51674] Tue, 28 June 2005 07:47 Go to previous messageGo to next message
The strange thing is that from the delivered ViewerServlet it works, but
I can't find any real difference to my code.
So I think it's not a BIRT problem.
> uses special data sources, can you make sure to reproduce it with a
> Stanley Wang
Re: PDF reports from webapplication [message #52167 is a reply to message #52113] Tue, 28 June 2005 09:39 Go to previous messageGo to next message
Originally posted by: adam.adam.com
Juergen,
you think you can show me how you got the html to display on the
webapp. My jsp script runs and generates and output file but there is
nothing on the screen. If you can point me in the right direction I would
greatly appreciate it. Thanks
Re: PDF reports from webapplication [message #52191 is a reply to message #52167] Tue, 28 June 2005 09:45 Go to previous messageGo to next message
Adam schrieb:
> Juergen,
> would greatly appreciate it. Thanks
Hi Adam,
This is more or less code I copied from the ViewerServlet. It works with HTML but not with PDF:
<<<< cut here
* Process incoming HTTP GET requests
* @param request Object that encapsulates the request to the servlet
* @param response Object that encapsulates the response from the servlet
public void doGet(javax.servlet.http.HttpServletRequest request, javax.servlet.http.HttpServletResponse response) throws javax.servlet.ServletException, java.io.IOException {
PTIdentListData listData=null;
/*** Test BIRT **/
System.err.println("Start BIRT test...");
try {
EngineConfig config=new EngineConfig();
config.setEngineHome(getServletContext( ).getRealPath("")+"/birtreport");
ReportEngine engine=new ReportEngine(config);
IReportRunnable report = engine.openReportDesign(getServletContext( ).getRealPath("/birtreport/jsloc.rptdesign"));
// Render options:
IRenderOption option = new HTMLRenderOption( );
ServletOutputStream servletOutputStream = response.getOutputStream( );
option.setOutputStream( servletOutputStream );
option.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
// Run task
IRunAndRenderTask runTask = engine.createRunAndRenderTask( report );
HashMap params=new HashMap();
params.put("paramPartId",new Integer(1730)); // part ID of part to display
runTask.setParameterValues(params);
runTask.setRenderOption( option );
/** PDF:
response.setContentType( "application/pdf" );
/** HTML: **/
// Render context
response.setContentType( "text/html;charset=utf-8" );
response.setHeader( "cache-control", "no-cache" );
HTMLRenderContext renderContext = new HTMLRenderContext( );
renderContext.setImageDirectory(getServletContext( ).getRealPath( "/birtreport/images" ));
renderContext.setBaseImageURL( request.getContextPath( ) + "/birtreport/images");
runTask.setContext( renderContext );
runTask.run( );
servletOutputStream.flush();
servletOutputStream.close();
return;
catch(Throwable e) {
System.err.println("BIRT Exception: "+e.toString());
e.printStackTrace();
System.err.println("End BIRT test...");
<<<< cut here
Re: PDF reports from webapplication [message #52240 is a reply to message #52191] Tue, 28 June 2005 10:17 Go to previous messageGo to next message
Thanks for the code to help out. I am using java and I looked at all the
manuels and it looks like i am doing it right. The only thing is, is that
nothing displays on the webapp. I know that it runs since i have been
debuggin it and it is running all the way. Here is my code. If you can
see anything wrong please let me know. Remember i am running it from a
jsp script.
EngineConfig conf = new EngineConfig();
String home = "C:\\WWW\\Tomcat 5.5\\webapps\\birt\\WEB-INF";
conf.setEngineHome(home);
HTMLEmitterConfig hc = new HTMLEmitterConfig();
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler();
hc.setImageHandler(imageHandler);
conf.setEmitterConfiguration(HTMLRenderOption.OUTPUT_FORMAT_ HTML, hc);
ReportEngine rengine = new ReportEngine(null);
String fileName = "C:\\WWW\\Tomcat
5.5\\webapps\\birt\\reports\\report1.rptdesign";
IReportRunnable report = null;
try{
report = rengine.openReportDesign(fileName);
} catch (EngineException e){
out.println(e);
rengine.destroy();
return;
IRunAndRenderTask task = rengine.createRunAndRenderTask(report);
HTMLRenderOption option = new HTMLRenderOption();
option.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML);
option.setOutputFileName("c:/temp/sample.html");
task.setRenderOption(option);
try{
task.run();
out.println("Created Report ");
} catch(EngineException e){
out.println("Report" + fileName + "failed");
out.println(e);
Re: PDF reports from webapplication [message #52266 is a reply to message #52240] Tue, 28 June 2005 10:25 Go to previous messageGo to next message
It seems that you try to output the HTML in a file ("c:/temp/sample.html") instead of giwing it back from the jsp.
I have no experience with jsp but you should try to send it to the OutputStream, something like that (which is from a Servlet):
But I don't know how to get the output stream from within a jsp script.
> the manuels and it looks like i am doing it right. The only thing is,
> is that nothing displays on the webapp. I know that it runs since i
> have been debuggin it and it is running all the way. Here is my code.
> If you can see anything wrong please let me know. Remember i am running
> it from a jsp script.
> try{
> out.println(e);
> rengine.destroy();
> return;
> try{
> task.run();
> out.println(e);
Re: PDF reports from webapplication [message #52320 is a reply to message #52266] Tue, 28 June 2005 10:55 Go to previous messageGo to next message
Thanks for helping me out so far. What you described seems to be my
option.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML); part. my
option.setOutputFile works perfectly fine b/c i get an output file with
what the rptdesign documents looks like. I am still troubleshooting but
any suggestions would be of help. Thanks
Re: PDF reports from webapplication [message #52372 is a reply to message #52320] Tue, 28 June 2005 11:45 Go to previous messageGo to next message
Adam,
From the several emails you have posted, I assume you are trying to use
report engine in JSP page to display the output in a browser, but you
see nothing in the browser. However, you did see an HTML file generated
on disk, right?
If that is the case, you do need to pass your JSP output stream to the
engine for it to generate output to. That is what the function
setOutputStream is for (as compared to setOutputFileName).
There is a Viewer web-application shipped with BIRT. Please check out
that applicaiton for further details. That app is directly deployable.
Stanley Wang
BIRT Engine
Re: PDF reports from webapplication [message #52489 is a reply to message #52372] Tue, 28 June 2005 13:56 Go to previous message
Stanley,
Thanks for the response. I have been looking at the
setOutputStream method but I am not getting very far with it.
setOutputStream takes in parameters (OutputStream ostream). This is where
i am lost. Could you explain from my code earlier what else i have to put
in. Thanks. I will be continuing to look at it.
Previous Topic:Parameters - Script
Next Topic:Group By and Aggregate functions possible in SQL?
Current Time: Wed Nov 19 13:44:04 EST 2025
Powered by FUDForum. Page generated in 0.06719 seconds
