PDF reports from webapplication [message #49174] |
Wed, 22 June 2005 09:09  |
Originally posted by: juergen.schwarz.gefasoft.de
I built BIRT into my web application and it work generating HTML
reports. But I need PDF format, so I changed to OUTPUT_FORMAT_PDF but I
don't get any output, just a blank screen.
In Eclipse preview, the PDF works.
What's going wrong?
Here's the log:
22.06.2005 15:05:28 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: Using org.apache.xerces.parsers.SAXParser as SAX2 Parser
22.06.2005 15:05:29 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: building formatting object tree
INFO: setting up fonts
22.06.2005 15:05:30 org.apache.avalon.framework.logger.Jdk14Logger error
SCHWERWIEGEND: property - "text-transform" is not implemented yet.
SCHWERWIEGEND: Error in letter-spacing property value 'normal':
org.apache.fop.fo.expr.PropertyException: No conversion
defined
SCHWERWIEGEND: property - "word-spacing" is not implemented yet.
defined
SCHWERWIEGEND: Error in column-width property value '20%':
org.apache.fop.fo.expr.PropertyException: No conversion defin
ed
SCHWERWIEGEND: Error in column-width property value '30%':
ed
ed
ed
22.06.2005 15:05:30 org.apache.avalon.framework.logger.Jdk14Logger info
INFO: [1]
SCHWERWIEGEND: At least one of minimum, optimum, or maximum IPD must be
specified on table.
specified on table.
INFO: area contents overflows area in line Beschreibung
INFO: area contents overflows area in line Typattribut?
specified on table.
INFO: Parsing of document complete, stopping renderer
22.06.2005 15:05:30 org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
Re: PDF reports from webapplication [message #52489 is a reply to message #52372] |
Tue, 28 June 2005 13:56  |
Originally posted by: adam.adam.com
Stanley,
Thanks for the response. I have been looking at the
setOutputStream method but I am not getting very far with it.
setOutputStream takes in parameters (OutputStream ostream). This is where
i am lost. Could you explain from my code earlier what else i have to put
in. Thanks. I will be continuing to look at it.
FUDForum. Page generated in 0.06421 seconds
