Problem Running Eclipse on Sun [message #49142] |
Tue, 27 May 2003 06:32  |
Originally posted by: olegkap.adelphia.net
Hi All !
I downloaded eclipse Sun version and tried to run it but I am getting
folwwing error :
java.lang.ExceptionInInitializerError: java.lang.NullPointerException
org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverte
r.java:75)
org.eclipse.ui.internal.WorkbenchPlugin.initializeDefaultPre ferences(Workben
chPlugin.java:441)
org.eclipse.ui.plugin.AbstractUIPlugin.initializeDefaultPlug inPreferences(Ab
stractUIPlugin.java:631)
org.eclipse.core.runtime.Plugin.getPluginPreferences(Plugin. java:347)
org.eclipse.ui.plugin.AbstractUIPlugin$CompatibilityPreferen ceStore.initiali
ze(AbstractUIPlugin.java:176)
org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(Ab stractUIPlugin.j
ava:568)
org.eclipse.ui.internal.Workbench.getPreferenceStore(Workben ch.java:701)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:844)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Any ideas of what may happend ?
I also insatlled jre1_3 and tried to execute it as follow :
../eclipse -vm /home/oleg/j2re1_3_1_08/bin/java
but no luck as well.
Any help will be appriciated.
Oleg.
FUDForum. Page generated in 0.30512 seconds
