Home » Eclipse Projects » Technology Project and PMC » Newbie: how te set up a minimal build
Newbie: how te set up a minimal build [message #49134] Thu, 13 March 2003 15:47 Go to next message
Originally posted by: dhaag23.hotmail.com
Just starting out with eclipse and have sucessfully downloaded and built the
source, built, run, debugged, and modified a new simple plugin and
everything is good so far.
Now I'd like to build a version with just the very minimum feature set that
will launch, so that we can then add on pieces from there as needed. I tried
a brute force approach but that quickly led to problems. We want to use
eclipse for a new specialized development platform that will have the
concept of projects and resources, will be editing files and have a number
of other views.
I know I'm lacking knowledge in many areas, but could someone push me in the
right direction on this one? Perhaps pointing to the apporpriate
documentation (which I have tried to search for before posting theis, of
course)
Thanks for any help,
Dirk
Re: Newbie: how te set up a minimal build [message #52023 is a reply to message #49134] Tue, 08 April 2003 11:27 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Here's an easy way to get a basic platform.
1) Start with an empty Eclipse workspace
2) File > Import > External plugins and fragments
3) Next... Next...
4) Select org.eclipse.ui from the list
5) Click "Add required plugins"
The selected set of plugins provides a basic platform with views,
editors, resources, but no specific tooling/programming support. From
there you can try cutting down further, or add back plugins that you may
need.
> of other views.
> course)
> Dirk
Re: Newbie: how te set up a minimal build [message #592699 is a reply to message #49134] Tue, 08 April 2003 11:27 Go to previous message
3) Next... Next...
need.
> of other views.
> course)
> Dirk
Previous Topic:Eclipse Update (2.0.2-->2.1.0) fails: java.util.zip.ZipException
Next Topic:BitTorrent : a better way to distribute Eclipse ?
Current Time: Wed Jul 16 07:55:39 EDT 2025
Powered by FUDForum. Page generated in 0.11125 seconds
