Home » Archived » M2M (model-to-model transformation) » [ATL] how to use entity reference in input model
[ATL] how to use entity reference in input model [message #4294] Fri, 29 December 2006 02:35 Go to next message
Hello ,
i have a simle input model file(bpmnModel.ecore) , which is generated
by a tool , and it conform to certain metamodel(bpmn.ecore). the input
file is follwoing.
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:bp="bpdm"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<bp:BusinessProcessDiagram Name="BusinessProcessDiagram1">
<Pools xmi:id="_45T0YJVvEdusYsgvXrrVmQ" Id="_uqHcgJVvEdusYsgvXrrVmQ"
Documenation="New Document" Name="Pool" >
<Process xmi:id="_45T0YZVvEdusYsgvXrrVmQ" Name="Process111">
<GraphicalElements xsi:type="bpdm:Task"
xmi:id="_45T0Y5VvEdusYsgvXrrVmQ" Id="_wQouYJVvEdusYsgvXrrVmQ"
Pool="_45T0YJVvEdusYsgvXrrVmQ" Name="task1"/>
</Process>
</Pools>
</bp:BusinessProcessDiagram>
</xmi:XMI>
i have written a simple rule for this model , which print name of
GraphicalElements that is type of bpdm:task. the rule is following.
rule bpmnSeq2bpelSeq
from input : bpdm!BusinessProcessDiagram
do {
input.Name -> println();
for(p3 in input.getGraphicalElement)
if(p3.oclIsTypeOf(bpdm!Task))
'true'->println();
p3.Name->println();
it gave this error.
An internal error occurred during: "Launching".
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:226)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:154)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:136)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:117)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:95)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
i think it give error because of Pool and Id entity of GraphicalElements.
when i remove both of these entity then it works fine.
Id is a type of EObject and Pool is a class.
Pool is container of Process , and Process contain GraphicalElements.
pls. help me
Brajesh K.
Re: [ATL] how to use entity reference in input model [message #4366 is a reply to message #4294] Fri, 29 December 2006 03:28 Go to previous messageGo to next message
If you only give the XMI of the model without giving the metamodel
(e.g., in XMI or KM3) then we cannot tell you if the model is correct or
not.
What tool do you use to create this model?
Frédéric Jouault
brajesh K. wrote:
> Hello ,
> file is follwoing.
> Id="_uqHcgJVvEdusYsgvXrrVmQ" Documenation="New Document" Name="Pool" >
> </Process>
> </Pools>
> </xmi:XMI>
> rule bpmnSeq2bpelSeq {
> do {
> 'true'->println();
> p3.Name->println();
> it gave this error.
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> when i remove both of these entity then it works fine. Id is a type of
> pls. help me
> Regards Brajesh K.
Re: [ATL] how to use entity reference in input model [message #4586 is a reply to message #4366] Fri, 29 December 2006 03:59 Go to previous messageGo to next message
Hi ,
thanks for response Frédéric.
actually my metamodel file is too big , nevertheless i give this metamodel.
MetaModel :bpmn.ecore
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="bpdm"
nsURI="bpdm" nsPrefix="bpdm">
<eClassifiers xsi:type="ecore:EClass" name="Activity"
eSuperTypes="#//FlowObject">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value=" * &#xD;&#xA; * @author
s&#xD;&#xA; * @version 5, Fri Dec 09 14:35:07 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="InputSets"
upperBound="-1"
eType="#//Input" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="OutputSets"
upperBound="-1"
eType="#//Output" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="IORules"
upperBound="-1"
eType="#//Expression" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Properties"
upperBound="-1"
eType="#//Property" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="StartQuantity"
lowerBound="1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EInt" defaultValueLiteral="1"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ActivityType"
lowerBound="1"
eType="#//ActivityType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Status"
lowerBound="1"
eType="#//ActivityStatus"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LoopType"
lowerBound="1"
eType="#//ActivityLoopType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="FlowObject"
eSuperTypes="#//GraphicalObject">
s&#xD;&#xA; * @version 8, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Pool"
lowerBound="1" eType="#//Pool"
<eStructuralFeatures xsi:type="ecore:EReference" name="Lanes"
upperBound="-1"
eType="#//Lane" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Assignments"
upperBound="-1"
eType="#//Assignment" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Name"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="String"/>
<eClassifiers xsi:type="ecore:EClass" name="AdHoc">
s&#xD;&#xA; * @version 1, Fri Dec 09 14:35:07 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Annotation"
eSuperTypes="#//Artifact">
s&#xD;&#xA; * @version 3, Fri Dec 09 14:35:07 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Text"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Artifact"
v1.0"/>
</eAnnotations>
eType="#//Pool" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Lane"
upperBound="-1" eType="#//Lane"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ArtifactType"
lowerBound="1"
eType="#//ArtifactType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="GraphicalObject"
eSuperTypes="#//BPDElement">
s&#xD;&#xA; * @version 3, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Categories"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Documenation"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Assignment">
s&#xD;&#xA; * @version 10, Fri Dec 09 14:35:07 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="From"
lowerBound="1" eType="#//Expression"
<eStructuralFeatures xsi:type="ecore:EReference" name="To"
lowerBound="1" eType="#//Property"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AssignTime"
eType="#//AssignTime"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="GraphicalConnectingObject"
s&#xD;&#xA; * @version 2, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="source"
lowerBound="1"
eType="#//Object" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="target"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Name"
eType="#//String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Association"
eSuperTypes="#//GraphicalConnectingObject">
s&#xD;&#xA; * @version 6, Fri Dec 09 14:35:07 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Direction"
lowerBound="1"
eType="#//AssociationDirection"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BPDElement"
eSuperTypes="#//Object">
s&#xD;&#xA; * @version 1, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Object">
s&#xD;&#xA; * @version 11, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Id"
lowerBound="1" eType="ecore:EClass
http://www.eclipse.org/emf/2002/Ecore#//EObject"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BusinessProcessDiagram">
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Pools"
lowerBound="1" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Id"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"
changeable="false" defaultValueLiteral="0"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Documentation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CreationDate"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDate"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="QueryLanguage"
name="ExpressionLanguage" eType="ecore:EDataType
name="ModificationDate" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Version"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Author"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Language"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Date">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Cancel"
eSuperTypes="#//Result">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Result">
s&#xD;&#xA; * @version 2, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
upperBound="-1" eType="#//String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Trigger">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CollapsedSubProcess"
eSuperTypes="#//SubProcess">
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Loop"
lowerBound="1" eType="#//Loop"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="MultiInstance"
lowerBound="1"
eType="#//MultiInstance"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Compensation"
lowerBound="1"
eType="#//Compensation"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AdHoc"
http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SubProcess"
eSuperTypes="#//Activity">
s&#xD;&#xA; * @version 3, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Transaction"
eType="#//Transaction"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="IsATransaction"
lowerBound="1"
defaultValueLiteral="false"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="SubProcessType"
lowerBound="1"
eType="#//SubProcessType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Collection">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Compensation"
s&#xD;&#xA; * @version 4, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ComplexDecision_Merge"
eSuperTypes="#//Gateway">
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Gates"
upperBound="-1"
eType="#//Gate" containment="true"/>
name="OutgoingSequenceFlow" lowerBound="1"
eType="#//SequenceFlow" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="outgoing2"
upperBound="-1"
eType="#//SequenceFlow"/>
upperBound="-1"
name="IncomingCondition" eType="#//Expression"/>
name="OutgoingCondition" eType="#//Expression"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Gateway"
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="GatewayType"
lowerBound="1"
eType="#//GatewayType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DataBasedGateway"
v1.0"/>
</eAnnotations>
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="DefaultGate"
eType="#//Gate"
<eStructuralFeatures xsi:type="ecore:EReference" name="Assignments1"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Assignments2"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="MarkerVisible"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="XORType"
lowerBound="1"
eType="#//XORType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ExclusiveDecision_Merge"
v1.0"/>
</eAnnotations>
lowerBound="1"
name="InstantiateFalse" lowerBound="1"
lowerBound="2" upperBound="-1"
eType="#//Gate"/>
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DataObject"
v1.0"/>
</eAnnotations>
upperBound="-1"
name="RequiredForStart" lowerBound="1"
defaultValueLiteral="true"/>
name="ProducedAtCompletion" lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="State"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EmbeddedSubProcess"
eSuperTypes="#//CollapsedSubProcess">
v1.0"/>
</eAnnotations>
name="GraphicalElements" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AdHocOrdering"
eType="#//AdHocOrdering"/>
name="AdHocCompletionCondition"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="End" eSuperTypes="#//Event">
<details key="documentation" value=" * 1) Constraint on
Implementation:-&#xD;&#xA;{ if (End.Result.Name == Messag&#xD;&#xA; * e)
}&#xD;&#xA;2) Constraint on ErrorCode:-&#xD;&#xA;{ if (End.Result.Name ==
Error)&#xD;&#xA; * }&#xD;&#xA;3) Constraint on LinkId:-&#xD;&#xA;{ if
(End.Result.Name == Link) }&#xD;&#xA; &#xD;&#xA; * &#xD;&#xA; * @author
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Activity"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Message"
lowerBound="1"
eType="#//Message" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="ProcessRef"
lowerBound="1"
eType="#//Process" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Result"
lowerBound="1"
eType="#//EndTriggers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LinkId"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ErrorCode"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Results"
lowerBound="2"
upperBound="-1" eType="#//EndTriggers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Implementation"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Event"
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="EventType"
lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//EString" defaultValueLiteral=""/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Entity">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Error"
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EventBasedGateway"
eSuperTypes="#//ExclusiveDecision_Merge">
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Gate"
upperBound="-1" eType="#//Gate"
name="outgoingSeqFlow" lowerBound="1"
name="IncomingSeqFlow" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="assignment3"
upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Instantiate"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean"
<eStructuralFeatures xsi:type="ecore:EReference" name="XORType"
upperBound="-1"
eType="#//String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ExpandedSubProcess"
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Expression">
s&#xD;&#xA; * @version 11, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Expression"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Gate">
s&#xD;&#xA; * @version 6, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="SequenceFlow"
lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Group"
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="InclusiveDecision_Merge"
v1.0"/>
</eAnnotations>
eType="#//Gate"
upperBound="-1"
eType="#//Gate"/>
name="OutgoingSequenceFlow2"
lowerBound="1" eType="#//SequenceFlow" containment="true"/>
upperBound="-1"
name="OutgoingSequenceFlow1"
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="IndependentSubProcess"
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="DiagramRef"
lowerBound="1"
eType="#//BusinessProcessDiagram" containment="true"/>
lowerBound="1"
name="InputPropertyMaps" upperBound="-1"
name="OutPutPropertyMaps" upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Input">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Intermediate"
Implementation:-&#xD;&#xA;{ if (Intermediate.Trigger.Name&#xD;&#xA; * ==
Message) }&#xD;&#xA;2) Constraint on TimeDate and TimeCycle:-&#xD;&#xA;{
if (In&#xD;&#xA; * termediate.Trigger.Name == Timer) }&#xD;&#xA;3)
Constraint on ErrorCode:-&#xD;&#xA; &#xD;&#xA; * { if
(Intermediate.Trigger.Name == Error }&#xD;&#xA;4) Constraint on
LinkI&#xD;&#xA; * d:-&#xD;&#xA;{ if (Intermediate.Trigger.Name == Link
}&#xD;&#xA; &#xD;&#xA; * &#xD;&#xA; * @author s&#xD;&#xA; * @version 3,
Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since v1.0"/>
</eAnnotations>
lowerBound="1"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="Target"
eType="#//Object"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="ErrorCode"
lowerBound="1"
eType="#//String"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="LinkId"
lowerBound="1"
eType="#//String"/>
lowerBound="1"
eType="#//ImplementationType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Trigger"
lowerBound="1"
eType="#//IntermediateTriggers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Triggers"
lowerBound="2"
upperBound="-1" eType="#//IntermediateTriggers"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="RuleName"
lowerBound="1"
eType="#//Rule"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TimeCycle"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TimeDate"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Lane"
eSuperTypes="#//Swimlane">
s&#xD;&#xA; * @version 5, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="parentpool"
lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="parentLane"
eType="#//Lane"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Swimlane"
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Link"
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Loop">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ManualTask"
eSuperTypes="#//Task">
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Performers"
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Task"
s&#xD;&#xA; * @version 4, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TaskType"
lowerBound="1"
eType="#//TaskType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Message"
eSuperTypes="#//Trigger">
s&#xD;&#xA; * @version 9, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
lowerBound="1" eType="#//Participant"
<eStructuralFeatures xsi:type="ecore:EReference" name="Property"
upperBound="-1"
lowerBound="1" eType="#//Participant"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MessageFlow"
s&#xD;&#xA; * @version 13, Fri Dec 09 14:35:08 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
eType="#//Message"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MultiInstance">
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MultiInstanceLoopActivity"
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LoopCounter"
lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//EInt" defaultValueLiteral="0"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="MI_Condition"
lowerBound="1"
name="ComplexMI_FlowCondition"
name="MI_FlowCondition" lowerBound="1"
eType="#//MIFlowConditionType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="MI_Ordering"
lowerBound="1"
eType="#//MIOrderingType"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Multiple"
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Output">
s&#xD;&#xA; * @version 1, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ParallerFork_Join"
v1.0"/>
</eAnnotations>
upperBound="-1"
eType="#//Gate"/>
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Participant">
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Entity"
eType="#//Entity"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="Role"
eType="#//Role"/>
name="ParticipantType" upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Pool"
s&#xD;&#xA; * @version 6, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Process"
eType="#//Process"
<eStructuralFeatures xsi:type="ecore:EReference" name="Participant"
lowerBound="1"
eType="#//Participant" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="lanes"
name="BoundaryVisible" lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Process">
s&#xD;&#xA; * @version 9, Fri Dec 09 14:35:09 2005&#xD;&#xA; * @since
v1.0"/>
</eAnnotations>
upperBound="-1"
upperBound="-1"
Re: [ATL] how to use entity reference in input model [message #4666 is a reply to message #4586] Fri, 29 December 2006 04:43 Go to previous messageGo to next message
Thanks for the metamodel.
But you are right: it is big.
It would help a lot if you could find the smallest metamodel exhibiting
the problematic behavior.
Frédéric Jouault
brajesh K. wrote:
> Hi ,
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> eType="#//String"/>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> name="IsATransaction" lowerBound="1"
> name="SubProcessType" lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> eType="#//Gate"
> upperBound="-1"
> upperBound="-1"
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> eType="#//Gate"/>
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> == Error)&#xD;&#xA; * }&#xD;&#xA;3) Constraint on LinkId:-&#xD;&#xA;{
> if (End.Result.Name == Link) }&#xD;&#xA; &#xD;&#xA; * &#xD;&#xA; *
> @author s&#xD;&#xA; * @version 4, Fri Dec 09 14:35:08 2005&#xD;&#xA; *
> @since v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> lowerBound="2"
> name="Implementation" lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> upperBound="-1"
> eType="#//String"/>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> eType="#//Gate"
> upperBound="-1"
> eType="#//Gate"/>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> == Message) }&#xD;&#xA;2) Constraint on TimeDate and
> TimeCycle:-&#xD;&#xA;{ if (In&#xD;&#xA; * termediate.Trigger.Name ==
> Timer) }&#xD;&#xA;3) Constraint on ErrorCode:-&#xD;&#xA; &#xD;&#xA; * {
> if (Intermediate.Trigger.Name == Error }&#xD;&#xA;4) Constraint on
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> eType="#//Object"
> lowerBound="1"
> lowerBound="1"
> eType="#//String"/>
> lowerBound="1"
> eType="#//String"/>
> lowerBound="1"
> lowerBound="2"
> lowerBound="1"
> eType="#//Rule"/>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> eType="#//Lane"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="Link" eSuperTypes="#//Result">
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> eType="#//Message"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> lowerBound="1"
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> </eClassifiers>
> v1.0"/>
> </eAnnotations>
> upperBound="-1"
> eType="#//Gate"/>
> upperBound="-1"
Re: [ATL] how to use entity reference in input model [message #4874 is a reply to message #4666] Tue, 02 January 2007 05:59 Go to previous message
Hi ,
here i am posting small meta model in km3 format.
class BusinessProcessDiagram
attribute Name:String;
reference pools[*] : Pool;
class Pool extends ObjectID
attribute Document:String;
reference Process[*] : Process;
class Process
attribute GraphicalElements:Task;
class Task extends ObjectID
class ObjectID
attribute Id:String;
my sample input model file:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:bp="bpdm">
<bp:BusinessProcessDiagram xmi:id="_tLfiYJVvEdusYsgvXrrVmQ" Name="BPD1">
Documenation="New Document" Name="Pool1">
<Process xmi:id="_WFoRwZcqEdusf_1zRX5pHw" Name="Process1">
<GraphicalElements xsi:type="bp:Task"
xmi:id="_eK1eUJcqEdusf_1zRX5pHw" Id="_aNhUMJcqEdusf_1zRX5pHw"
Pool="_45T0YJVvEdusYsgvXrrVmQ" Name="Task1"/>
</Process>
</Pools>
</xmi:XMI>
my rule for this input model:
helper context bpdm!BusinessProcessDiagram def : getGraphicalElement :
Sequence(bpdm!Object) =
self.Pools->collect(e|e)->asSequence()->collect(process|process.Process)- >asSequence()
->collect->(g|g.GraphicalElement)-> asSequence();
rule bpmn2bpel
do {
for(p in input.GraphicalElement)
p.Name->println();
i am just trying to get all GraphicalElement but it didn't display anything
but when i removed Pool entry from GraphicalElements then it print
GraphicalElements . can you tell me how to reference Pool from
GraphicalElements .
thanks
Brajesh K
Previous Topic:[ATL] ERROR: cannot find ASMEMFModel for...
Next Topic:[ATL] Is ATL some oo-language?
Current Time: Mon Jul 14 04:11:47 EDT 2025
Powered by FUDForum. Page generated in 0.12649 seconds
