Home » Eclipse Projects » Mylyn » can't connect
can't connect [message #49034] Thu, 22 May 2008 15:19 Go to next message
I'm trying to set up the Web Connector to our internal webpage. I'm getting
a "HTTP 401.2 - Unauthorized: Logon failed due to server configuration"
error. I can view the page using IE. What should I be trying to change?
Re: can't connect [message #49085 is a reply to message #49034] Thu, 22 May 2008 15:52 Go to previous message
You need to configure auth. The following wiki document has section on
that
http://wiki.eclipse.org/Mylyn_User_Guide#Generic_Web_Reposit ory_Connector
Also see troubleshooting tips at
http://wiki.eclipse.org/Mylyn_FAQ#Generic_Web_Repository_Con nector
regards,
Eugene
Re: can't connect [message #589707 is a reply to message #49034] Thu, 22 May 2008 15:52 Go to previous message
that
regards,
Eugene
Previous Topic:Context Test Suites
Next Topic:Mylyn 3.0 Endgame
Current Time: Mon Jul 21 21:00:45 EDT 2025
Powered by FUDForum. Page generated in 0.06546 seconds
