Home » General (non-technical) » Eclipse Foundation » export: Deployable plug-ins and fragments fails to create correct jar
export: Deployable plug-ins and fragments fails to create correct jar [message #48998] Wed, 05 September 2007 20:02 Go to next message
when exporting one of my GMF diagram plug-ins (I have 2 and the other
exports fine), the resulting jar file has only 4 files:
dummy.txt
plugin.properties
plugin.xml
Manifest.mf
the dummy.txt file contains the line:
"this is here so that the src directory will be save on export"
What is wrong. this plugin works fine in testing, it just won't export!
As I mentioned above a similar GMF diagram plugin exports correctly,
they were both created in the same way.
Re: export: Deployable plug-ins and fragments fails to create correct jar [message #49054 is a reply to message #48998] Thu, 06 September 2007 07:28 Go to previous message
John,
Please don't use the foundation newsgroup for asking technical questions
and try to avoid cross posting questions to multiple newsgroup unless
it's really quite necessary.
Have a close look at what's in your build.properties since this file
determines what will be exported.
> dummy.txt
> plugin.properties
> plugin.xml
> Manifest.mf
Previous Topic:Using Amazon S3 for the infrastructure
Next Topic:PDT Project Webinar
Current Time: Sun Jul 13 19:22:52 EDT 2025
Powered by FUDForum. Page generated in 0.03017 seconds
