Re: Cached report... [message #482721 is a reply to message #482543] |
Thu, 27 August 2009 16:51 |
Does it make any difference if you specify
__document=c:/temp/test.rptdocument in the url?
Jason
Whatty wrote:
> Good evening,
> I have just updated to the latest release of BIRT and was quickly
> throwing up a sample report based on an XML datasource and it seems that
> the report viewer is using a cached or the first saved report.
> The report works correctly when I preview it in Eclipse but when I try
> to access it from the viewer I am getting the original template that I
> based the report on.
> I have read several threads regarding setting the cached repoprts and
> have set both of the following:
> <context-param>
> <param-name>BIRT_OVERWRITE_DOCUMENT</param-name>
> <param-value>true</param-value>
> </context-param>
> and the overwrite flag on the URL
> /frameset?__report=usersReport.rptdesign&XMLSourceFile=C :\Temp\get_users_rpt-08-26-2009.xml&__overwrite=true& ;__sessionId=20090826_190350_702&__dpi=96
> but to no avail.
> I have cleaned my Tomcat directory and made sure the BIRT working
> folders were empty but again to avail.
> I have also searched my file system for a .rptdocument that may be
> hanging out and there are none.
> Please help.
> Whatty
Re: Cached report... [message #483252 is a reply to message #483251] |
Mon, 31 August 2009 18:08 |
Do you mean templates or libraries?
Whatty wrote:
> Nope unfortunately that did not help.
> The funny thing is that it works from the IDE and I see all my changes.
> When I run it from Tomcat I also see some of my changes (ie. changes in
> how I process the XML file elements) but the table header itself is
> still based upon the template I used.
> I went into the XML view of the report and I can't see those labels (ie.
> "Customer Listing") in the document at all so I have no idea WTF is
> going on.
> I deleted the header row in my table and recreated it and now I am
> getting now header row at but again it seems to work in the IDE.
> Please help
> "Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
> news:h76df4$v7m$2@build.eclipse.org...
>> Jason
>> Whatty wrote:
>>> Good evening,
>>> that the report viewer is using a cached or the first saved report.
>>> try to access it from the viewer I am getting the original template
>>> that I based the report on.
>>> <context-param>
>>> </context-param>
>>> but to no avail.
>>> Please help.
>>> Whatty
FUDForum. Page generated in 0.03884 seconds
