Home » Language IDEs » Java Development Tools (JDT) » Run ANT with different JVM
Run ANT with different JVM [message #48944] Wed, 04 June 2003 08:13 Go to next message
Originally posted by: schutzerj.hotmail.com
Can anybody tell me if it is possible to run Ant in another JVM then the one
that I use to run Eclipse. I need to use Java 1.4 to run Eclipse since some
nice plugins requires that but our applications must be compiled with Java
1.3.
Please help me with this since it prevents us from using Eclipse.
Joakim Andersson
Lorensbergs Communication
Re: Run ANT with different JVM [message #48974 is a reply to message #48944] Wed, 04 June 2003 13:10 Go to previous messageGo to next message
In the latest integration builds this is possible. It will be available in
the milestone 1 build that will be coming out (hopefully) at the end of this
week.
See the JRE tab that is now available for any Ant launch configuration.
But to achieve what you desire you do not need to launch Ant in a separate
VM.
The javac task of Ant support specifying a target attribute.
Use something like
<javac target="1.3" ...>
</javac>
This will generate 1.3 VM compatible class files.
HTH
Darins
"Joakim Andersson" <schutzerj@hotmail.com> wrote in message
news:bbl861$akp$1@rogue.oti.com...
one
some
> 1.3.
> Joakim Andersson
Re: Run ANT with different JVM [message #49833 is a reply to message #48974] Thu, 05 June 2003 04:35 Go to previous message
Thank you for that information. I guess that I have to wait then. I have
allready tested the target property of ant but it doesn't work. The problem
is the following:
[javac] bad class file:
C:\Progra~1\Java-1.4.1_02\jre\lib\rt.jar(java/util/TimerTask .class)
[javac] class file has wrong version 48.0, should be 47.0
[javac] Please remove or make sure it appears in the correct
subdirectory of the classpath.
[javac] import java.util.TimerTask;
It works if I run it through the 1.3 compiler but not through the 1.4
compiler.
/Joakim
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bbl94b$bev$1@rogue.oti.com...
this
> week.
> VM.
> Use something like
> </javac>
> HTH
> Darins
> one
> some
Java
> > 1.3.
> > Regards,
> > Joakim Andersson
Previous Topic:build/rebuild problems
Next Topic:Assigning an additionally none java file extension for build/compilation...?
Current Time: Tue Jul 22 13:58:15 EDT 2025
Powered by FUDForum. Page generated in 1.27189 seconds
