HTML Emitter and CSS [message #48902] |
Tue, 21 June 2005 18:01  |
I have successfully embedded the ReportEngine in our web application
(running on Weblogic, had to turn on "prefer web-inf classes" because of
a conflict involving different versions of Rhino, I think). I want to
generate HTML reports inside our main application UI (currently a
servlet includes a header.jsp, then runs the report, then includes a
footer.jsp). I haven't had much time to look into making the report
style fit the main application style... but I already see one problem:
If invoke setEmbeddable(true) on
org.eclipse.birt.report.engine.api.HTMLRenderOption, it turns on a "No
CSS" mode, which is not exactly what I want. Our internal requirements
for web applications say that styles are to be defined by CSS only.
I would like the report to keep using CSS for styles, but skip the HTML
head, body and other tags so it could be included inside a larger HTML
page. I realize there could be conflicts with CSS names, but I'd like to
have that option available. Ideally, I would like to be able to specify
the CSS class names (and id attribute values) that our main application
uses in the Report Designer (maybe that's possible, I haven't really
explored all the styles options in the Report Designer)
Erkki Lindpere
Re: HTML Emitter and CSS [message #53184 is a reply to message #52462] |
Fri, 01 July 2005 15:29  |
Erkki Lindpere wrote:
> Thanx for the reply. I must admit my first message wasn't very thought
> through. We have a tight schedule at the moment, but when I have more
> time to work on improving the report embedding and have studied the
> style options in BIRT a bit more, I'll get back to you.
I thought about this a little, and I only came up with this:
1) Provide a completely "style-less" emitter option. An application can
then define the styles just for some tags or depending on which div they
are in. It would make the style designing in BIRT somewhat useless, but
I think it would be a good idea to have more run-time flexibility.
2) Allow the designer to define what id and/or class names will be used
(why couldn't the custom style names be used in the HTML output?), or
maybe even import a CSS file. But that would probably mean a lot of
changes to the current code?
Erkki
FUDForum. Page generated in 0.03655 seconds
